this car read fault 4746 magnetic clutch
i have changed the magentic clutch , and test the circuit diagram , and nothing change , when i checked the coding of the engine control unit , i fount in byte 4 , that the car with not a electric pump and this pump of this car should be electrical ,
Could you tell me if this code of ECU is right or not ?
note : i have cleared the fault at the moment of taking the auto-scan
Tuesday,05,June,2018,11:54:40:22511
VCDS Version: 18.2.0.3 HEX-NET CB: 0.4411.4
VIN: WVGZZZ5NZCW516545 License Plate: DESKTOP
Mileage: 74020km-45993mi Repair Order:
Chassis Type: 5N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 4C 52 53 56 62 72
VIN: WVGZZZ5NZCW516545 Mileage: 74020km-45993miles
01-Engine -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAVD) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 DC HW: 03C 907 309 J
Component: 1.4l R4/4V TS H04 1686
Revision: LGH04--- Serial number: 00000000000000
Coding: 00190012002600000000
Shop #: WSC 44131 002 1048576
ASAM Dataset: EV_ECM14TSI01103C906027DC 001005
ROD: EV_ECM14TSI01103C906027DC.rod
VCID: E582F5B0E436A96C0B-80B0
Readiness: 1110 0101
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 AH HW: 5N0 614 109 AH
Component: J104 C6 450M VDE4 0003
Revision: --H07--- Serial number: 00000004603480
Coding: 0005390
VCID: F1AA91E0E8FE75CC67-80A4
Reset counter: 2
Mileage: 73871 km
Date: 2012.10.21
Time: 22:08:36
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.25 V
Bin. Bits: 00011111
Count: 220
Hex Value: 0x0000
02214 - Tire Pressure Warning
Reset counter: 10
Mileage: 74000 km
Date: 2012.10.25
Time: 13:31:30
Speed: 38.0 km/h
Hex Value: 0x0000
Voltage: 14.00 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
Part No SW: 5K0 907 044 ES HW: 5K0 907 044 ES
Component: Climatronic H18 1112
Revision: 00001003
Coding: 0000001002
VCID: 804CC4241B546C4498-80D4
Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
Component: BCM PQ35 M 011 0048
Revision: BC011001
Coding: 40180A3B80251AC0400800C0100081E44B010088524D8D60648040000040
VCID: BB3673C83A32CF9C8D-80EE
Subsystem 1 - Part No: 5N1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS 280711 03 32 0010
Coding: 009795
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 226
Mileage: 74023 km
Date: 2012.10.26
Time: 00:00:05
Term 15 Off
Voltage: 12.60 V
Address 10: Park/Steer Assist (J791) Labels:| 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261123501472
Coding: 148003
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000.rod
VCID: C4C408344FCCB064FC-8090
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__206 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PGS6HH3
Coding: 0012342
VCID: CCD42014AF9C782434-8098
Subsystem 1 - Serial number: 6332MTS613682151
Subsystem 2 - Serial number: 6342MTS604352151
Subsystem 3 - Serial number: 6351HTS6S0SDAAKJ
Subsystem 4 - Serial number: 6361HTS6QV9EAAKJ
Part No SW: 5K0 953 501 BH HW: 5K0 953 569 L
Revision: FF010040 Serial number: 20110818300752
Coding: 1182140000
VCID: F1AA91E020FE75CC67-80A4
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Coding: 820000
Part No SW: 5N0 920 872 B HW: 5N0 920 872 B
Component: KOMBI H03 0607
Coding: 111F01
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: B12A51E0E07E35CC27-80E4
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 250711F2000130
Coding: 356002
VCID: B52265F01C1619EC7B-80E0
Fault Status: 00110100
Reset counter: 1
Mileage: 73871 km
Date: 2012.10.21
Time: 22:08:37
Part No SW: 0AY 907 554 E HW: 0AY 907 554 E
Component: Haldex 4Motion 0043
Coding: 0000005
VCID: CDD22D105486712C23-8098
Component: IMMO H03 0607
VCID: EA98868C0D28861426-80BE
Part No SW: 5N0 959 701 D HW: 5N0 959 701 D
Component: Tuer-SG 009 2111
Coding: 0000188
VCID: B62062FCC11012F472-80E2
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.285 1002
Revision: 1AH03835 Serial number: 00112250258801
Coding: 0000258
VCID: BC3470D4FF3CC8A484-80E8
01288 - Terminal 30; Steering Assist
Fault Status: 00101011
Fault Priority: 9
Reset counter: 12
(no units): 2.0
Voltage: 12.50 V
Part No SW: 5N0 959 702 D HW: 5N0 959 702 D
Coding: 0000188
VCID: B73E6FF8C61AEBFC69-80E2
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000160728
Coding: 0026157
Shop #: WSC 54569 001 1048576
VCID: B52265F0DC1619EC7B-80E0
Reset counter: 1
Mileage: 73871 km
Date: 2012.10.21
Time: 22:08:36
Voltage: 12.40 V
Count: 71
Hex Value: 0x1273
Hex Value: 0x0001
Hex Value: 0x1010
Reset counter: 1
Mileage: 73871 km
Date: 2012.10.21
Time: 22:08:37
Voltage: 12.20 V
Count: 61
Hex Value: 0x1273
Hex Value: 0x0001
Hex Value: 0x1010
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
Component: Radio RCD510 052 0208
Revision: 00000001 Serial number: VWZ1Z3L1614145
Coding: 0500040004000C
VCID: A306ABA8A282975CA5-80F6
Part No SW: 5N0 959 703 D HW: 5N0 959 703 D
Component: Tuer-SG 007 2102
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: B83C6CC4CB04E48460-80EC
Part No SW: 5N0 959 704 D HW: 5N0 959 704 D
Coding: 0000144
VCID: B93A69C0F00EFD8C9F-80EC
End----------(Elapsed Time: 01:18, VBatt start/end: 12.5V/12.5V)-----------
