Results 1 to 5 of 5
Thread: MKIV 2003 Jetta 1.8t AWP - N249 Code Question - P1287
    Dec 2017
    Hi All,
    So over the weekend, I pulled off one heck of a procedure on my 2003 jetta with 207,xxx miles! It consisted of replacing a cracked exhaust manifold, leaking flex joint on downpipe, and the original K03s turbo with a K04-001 with only 30,xxx miles on it.
    After about ~12 hours, I had pulled off success! Bled my coolant system, and everything looked good, i was so happy!
    Car ran well, no CEL came up, no boost issues, or anything of the sort. Sadly, I did not perform an auto-scan immediately prior to starting the procedure =( Last time I did an autoscan was on 4/2/18 and I did not have this code.
    Anyway, after completing and driving for a day or 2, I ran an autoscan and I get P1287 - Boost Pressure Control Valve (N249) Open Circuit.
    Entire autoscan is here:
    Tuesday,05,June,2018,13:05:47:53404
    VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
    VIN: 3VWSE69M03M161580   License Plate: BR49BL
    Mileage: 332620km-206680mi   Repair Order:
    Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
              75 76
    VIN: 3VWSE69M03M161580   Mileage: 332620km-206680miles
    Address 01: Engine        Labels: 06A-906-032-AWP.lbl
       Part No: 06A 906 032 LP
       Component: 1.8L R4/5VT     G   0007
       Coding: 07500
       Shop #: WSC 12857
       VCID: 77AB16EA06D04D7F40D-5160
       3VWSE69M03M161580     VWZ7Z0C6698338
    17695 - Boost Pressure Control Valve (N249)
                P1287 - 35-00 - Open Circuit
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
       Part No: 1C0 907 379 M
       Coding: 0019970
       VCID: 3431E1E652266667A5F-5184
       Part No: 1C0 909 605 F
       Component: 04 AIRBAG VW61 0202 0001
       Coding: 12340
       Shop #: WSC 00066
       VCID: 270B06AA96F01DFF10D-513C
    Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
       Part No: 1J0 907 487 A
       Component: Lenkradelektronik   0005
       Coding: 00118
       Shop #: WSC 00066
       VCID: 2F3BEE8ABE0045BFD8D-5184
       Part No: 1J0 920 906 J
       Component: KOMBI+WEGFAHRSP VDO V65
       Coding: 07232
       Shop #: WSC 08080
       VCID: 2F3BEE8ABE0045BFD8D-513C
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70B92DF663BE1A47817-513C
                49-00 - No Communications
       Part No: 1C0 959 799 C
       Component: 1H Komfortgerát HLO 0003
       Coding: 00259
       Shop #: WSC 00066
       VCID: 372BD6EA46508D7F80D-4B1E
       Component: 1H Tõrsteuer.FS KLO 0009
       Component: 1H Tõrsteuer.BF KLO 0009
       Component: 1H Tõrsteuer.HL KLO 0009
       Subsystem 4 - Part No: Steuerger
       Component: t HR    antwortet nicht
    Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
       Part No: 3B7 035 180 E
       Component: RADIO 3CP          0004
       Coding: 04031
       Shop #: WSC 00066
       VCID: 221D17BEFDD2F8D7473-513C
    End----------(Elapsed Time: 05:00, VBatt start/end: 12.1V/12.1V)-----------
    I first thought I had forgotten to put back the N249 electrical plug i removed on back of intake manifold plate, but checked that and it is indeed plugged in. Also, checked function of my DV (forge 007) and it holds vacuum OK. So my question is, how can I test using Vag-com the functionality of the N249 valve, prior to shelling out $ for a new one?? Or is there something else I should be looking at?
    Thank you all!
    HQ
    Thanks for posting an Auto-Scan!
    Vehicle Identification No. 3VWSE69M03M161580
    Model Jetta GLS
    JEM
    Date of production 28.03.2003
    Year 2003
    Sales type 9M25N4
    Engine Code AWP
    Transmission Code EHA
    An "open circuit" is some sort of electrical path issue.
    • Unplug the N249 and ohm test it, it should be 20 to 35 Ω (at approx. 20 C).
    • With the engine at idle, do you have battery power to /1 (yellow/black) at the N249?
    • /2 (grey/green) goes to ECM T121/105, is that wire to factory design?
    You can also play around with Output Testing for fun and games:
    http://www.ross-tech.com/vcds/tour/out_test.php
    Jef
  3. Likes Uwe liked this post
    JPPSG!
    http://forums.ross-tech.com/forumdis...Repair-Support
    You were in here recently, please verify the N249 is plugged into the correct harness connector and not the SAI noid or that left undone.
    Please clear codes re-post the scan right after doing so, then do output tests with VCDS to see what is clicking and is for correct component to be initiated.
    In addition to Jef's advice, a noid light can also be used to verify if the tracks to the two control solenoids are functional for wiring.
  5. Likes Fredrick Awuor liked this post
  6. #4
    Dec 2017
    JPPSG!
    I will confirm N249 is plugged in correctly tonight, and then perform Jef's ohm test as well, and report back !
    Thanks All
    Dec 2017
    Just to update everyone, I found the /2 (grey/green) wire broken at the connector, was able to remove the terminal from connector, re-solder, and cleared the code, has not come back yet! Thanks for your help
