Mac version for VCDS
Shibin Kumar
India
C?ID=161647
Guys,
Is there a Mac version for VCDS. Windows is for ever so slow. If there is one please do let me know. I tried to find this but no luck.
Thanks!!
PetrolDave
Westbury, UK
C?ID=1423
No there is not, but several people successfully run VCDS under Boot Camp.
VCDS is a Windows program. It would have to be re-written from scratch to run on Mac. It's not worth it for the 10-15% market share that Mac computers have, especially when you can buy a Windows machine that will run VCDS just fine these days for $200 or less.
But If you really insist on running VCDS on a Mac, Boot Camp works great.
iichel
Netherlands, eastern part
C?ID=284912
I've been using it for a while now in a virtualised Windows 7 x32 environment, with Oracle Virtualbox. Works like a charm.
golfi_vend
Tartu, Estonia
C?ID=195131
Second gen. HEX devices work better also. I think because being HID devices, rather then FTDI ones.
Old Hex-Can was very upset running through Virtual Box.
iichel
C?ID=284912
I did have some issues with VMWare Fusion, mostly timeouts or late responses.
I haven't had such a problem on Virtual Box, neither with the HEX+CAN or with the HEX V2
Santos
Until you have to update the interface. The Virtual environments let go the HID device, OSX grabs it, and causes all sorts of problems.
If it works for someone like that, great, but please understand it's "not supported". That means if doesn't work begin with, mysteriously stops working, or you have troubles with it, such as not being able to update interface firmware or whatever, we're not really in a position to help trouble-shoot it. There are just too many combinations of Mac OS version, different VM hypervisors (and versions thereof), and Windows versions for us to be able reproduce such problems.
DJAlix
London, United Kingdom
C?ID=238277
Although I have dedicated windows machines I have also been using VCDS on Mac's via "Parallels" for nearly going on 9 years with zero issues.
Shibin Kumar
India
C?ID=161647
All of you Thanks very much for your inputs and support.
Regards,
Shibin
Filou96
France
C?ID=258992
I use VCDS on differents Mac laptops with VMWare Fusion running Win XP pro and Windows 7 since several years without any problems.
