Auto close on rain detect.
Demo3
C?ID=335057
I have been through my coding several times and still it seems that I am missing something, because it still does not work. I do see it in the setup menu and I enabled it but...
Would someone take a look?
I also have an issue were my cruse control will disengage for no apparent reason, it does not cut off it just disengages... I press resume immediately and it goes back to the set speed. I am getting "02-Auto Trans -- Status: Malfunction 0010" errors.
Wednesday,30,May,2018,14:36:42:21870
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: 3VWCA7AU2FM500815   License Plate:
Mileage: 28069km-17441mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75
VIN: 3VWCA7AU2FM500815   Mileage: 28069km-17441miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 D    HW: 04L 907 309
   Component: R4 2.0l TDI   H23 9283
   Revision: 85H23---
   Coding: 011D0012032410081000
   Shop #: WSC 04908 444 00000
   ASAM Dataset: EV_ECM20TDI01104L906021D 004017
   ROD: EV_ECM20TDI01104L906021D_004.rod
   VCID: 26150AB668625BD72BB-8072
   Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 03253104    Serial number: TFK01412062102
   Shop #: WSC 00066 790 00201
   ROD: EV_TCMDQ250021.rod
   VCID: 231313A21B50AEFF4C5-8076
21182 - Clutch
          P2789 00 [072] - Adaptive Learning at Limit
                    Mileage: 27813 km
                    Date: 2018.05.26
                    Time: 15:32:34
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revision: 00000000    Serial number: 53404000000896
   Coding: 04FA6AA12420096C007F020181C82520562490004081A4B200630050C002
   Shop #: WSC 01383 790 50316
   VCID: 47CBA732CF28A2DFF0D-8012
   Revision: 00021000    Serial number: 0351474282
   Coding: 030C0C
   VCID: 3A2DCEC68CDACF377F3-806E
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 02020124200100010005004012111400
   VCID: 42DDB626E40A87F7273-8016
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Component: BCM PQ37BOSCH 028 0145
   Revision: --------    Serial number: 86582711140229
   Coding: 00511A464041A2E969E44000001407001800000000000000000000000000
   Shop #: WSC 00066 790 07031
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4ACD9E06DC3A5FB7EF3-801E
   Component: WWS    141018  043 0581
   Serial number:         150114084629
   Component: RLHS  037 0059
   Serial number: S4Y14M12D03H18M25S29
   Coding: 06A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H02 0003
   Serial number: 0000FST0001HMTX00000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H02 0003
   Serial number: 0000FST0001HLMP00000
   Coding: 191800
                    Fault Frequency: 22
                    Reset counter: 248
                    Mileage: 27665 km
                    Date: 2018.05.23
                    Time: 20:12:00
   Serial number: 003GCR00THW7
   Occupant Detection:
   Component: BF-Gewichtss.  H10 0021
   Serial number: IBH0000J140001UQ5E0H
   Coding: 303137
   Subsystem 2 - Part No SW: -----------    HW: 480 001 411 14
   Serial number: 3570000000015AD8E11P
   Subsystem 3 - Part No SW: -----------    HW: 480 001 411 14
   Serial number: 35800000000C9209E11L
   Subsystem 4 - Part No SW: -----------    HW: 480 400 412 14
   Serial number: 3510002BB18B3AB3B106
   Subsystem 5 - Part No SW: -----------    HW: 480 400 212 14
   Serial number: 35200029B18B3AB551EF
   Subsystem 6 - Part No SW: -----------    HW: 480 401 411 14
   Serial number: 3550002C5188FC11A057
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 411 14
   Serial number: 3560002C7188FC102231
   Revision: FF032032    Serial number: 20141203500626
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 0451703EBE9E49C755F-8050
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA5121A2980CF05020878001000000000000000
   Shop #: WSC 00066 790 00195
   VCID: 65974DBA55E490CFE21-8030
   Revision: --------    Serial number: 21121410000112
   Coding: 0901000800087300EF00020A1C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07029
   ROD: EV_GatewConti_011_VW37.rod
   VCID: 72BD26E6942A7777773-8026
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29140002590240094482
   Coding: 29FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0017742
   Revision: 00000000    Serial number: 14000337476004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431E0FEAEBE3947A5F-8060
   Serial number: 031214060502IW
   Coding: 003A13200000040000000000
   VCID: 40D9BC2EEA0695E7317-8014
   Serial number: 00000000000000509039
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43D3B322FB108EFF2C5-8016
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0060
   Serial number: VWZ8Z1EC4022EEW
   Coding: 22000000AAAAAA0000
   ASAM Dataset: EV_AMPMst12C1ALPI 001007
   ROD: EV_AMPMst12C1ALPI.rod
   VCID: 639353A25BD0EEFF0C5-8036
   Serial number: 27121406050622
   Coding: 003A13200C00040000000000
   VCID: 3FDBBFD297F8EA1F48D-806A
   Serial number: 00000000000000431379
   Coding: 091000
   Coding: 060A00010B000400
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 5G0 035 876     HW: 5G0 035 876
   Component: MU-S-NS-US    014 0645
   Serial number: V7B01412140069
   Coding: 027302020000000021220002001800001F0100340100010546
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 698F418AB9FCB4AFC69-803C
   Subsystem 1 - Part No SW: 5G0 919 605 K    HW: 5G0 919 605 K
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS600CNM
   Subsystem 2 - Part No SW: 5G0 919 866 S    HW: -----------
   Component:  NAR 2015  --- 0022
   Component: OCULowMQBUS   007 0564
   Coding: 02730002C2823A017F1E06000000
   Shop #: WSC 00066 790 07177
   ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:45, VBatt start/end: 12.2V/12.1V)-----------
DV52
C?ID=194404
   Revision: 85H23---
21182 - Clutch
                    Mileage: 27813 km
                    Date: 2018.05.26
                    Time: 15:32:34
   Coding: 030C0C
   Revision: 00001K01
   Coding: 06A8DD
   Sun Roof:
   Coding: 191800
   Roof Blind:
   Coding: 191800
                    Fault Frequency: 22
                    Reset counter: 248
                    Mileage: 27665 km
                    Date: 2018.05.23
                    Time: 20:12:00
   Occupant Detection:
   Coding: 303137
   Coding: 0410
   Coding: 29FFFF
   Coding: 011000
   Coding: 0102
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
Demo3: Hi. I'm not sure if you are aware, but engaging Auto Rain Close tweak on a mk7 Golf (in any part of the world) is one of the more problematic tweaks. Some have gotten it to work, but there are lots of attempts that have been unsuccessful. I have no idea why. It doesn't appear to be a VCDS specific issue - I've seen the same dynamic with other diagnostic cables . There have been lots of hypotheses as to why this occurs - some say that it has to do with the type of Rain-Light-Sensor installed (I'm not sure if this is true). Some say that it's important to make the coding changes before the adaptation channel changes - again, I'm not sure if this is true.
As to whether you have correctly made the changes, I note that your RLHS code-string is 06A8DD. This looks correct for the tweak. I can't confirm the adaptation channel changes from your auto-scan, but I assume that you have correctly changed these settings. I also assume that you have undertaken the obligatory "in-car" procedure as described HERE (see also the previous post)
As for your cruise control problem - I agree the trouble code in the module @hex 02 does look suspicious. I note that Byte 5, Bit 5 on your Engine module (@ hex01) is set - meaning that your car has the standard CCS (PR-8T2/8T6). So, I assume that reference to "adaptive learning" refers to the gear change dynamic (not to ACC) . Just as a suggestion - how about trying to reset the gearbox via basic settings? Dana did some good work developing the procedure for MQB vehicles HERE
hadez16
C?ID=289891
RLHS = rain closing not possible
RLFS = rain closing possible
Period.
Demo3
C?ID=335057
Thanks guys!
MasterTommy
Amsterdam
C?ID=295586
Period.
Are these sensors easy to swap, or are they glued to the windshield?
Demo3
C?ID=335057
So... If I could get a hold of one of those sensors (FLFS) I could swap them?
hadez16
C?ID=289891
I can't tell exactly sorry...but the search function should reveal this.
DJAlix
London, United Kingdom
C?ID=238277
Incorrect. The sensor is held in place via a metal clip which puts pressure on the sensor in order to push it towards the glass. In order to create and even seal and aid in the transfer of light etc a "gel pad" should / needs to be installed between said sensor and the glass. The pad is sticky by nature but its not there to secure the sensor. The pad does not actually need to be there for the sensor to work but if you want it to work correctly then you should fit one which is 32mm across and 1mm high.
MasterTommy
Amsterdam
C?ID=295586
Interesting. So to swap the sensor you only need a new sensor and nothing else?
DV52
C?ID=194404
^^^ interesting question - galvanized into action by its asking (because I wanted to know the answer) - I managed to put together the following:
Now, I'm by no means an expert in this stuff, so I would value any correction in my understanding -please. However, if I'm reading the WD correctly, the combined Humidity-RLS is connected purely to the BCM (the data pin is #28 on the C socket).
But clearly the humidity information must be wheeled to the air-con module somehow (via the convenience CAN bus maybe?). Hence both the BCM and HVAC modules have software switches in their code-strings to confirm (or not) the presence of the humidity component of the sensor - this makes sense.
Of course it's easy to change the code string to register that the humidity component of the sensor is absent (if the sensor is changed) - but does this simple alteration permit the air con to operate successfully? I don't know, it probably will operate OK -but can anyone here confirm this?
The other "confounder" (in my mind) is the physical install. As DJAlix correctly advises, the actual sensor is separated from the windshield by a "silicon layer coupling pad" and both the sensor and the coupling pad fit into the housing which is attached to the windshield. The VW material makes the following comment about the removal/installation procedure:
There are different housings depending on the make of rain and light sensor.​
This being so- it might be prudent to first confirm that the size and shape of the new RLS sensor and coupling pad, is compatible with the dimensions of the housing that's currently attached to the windshield (ETKA - I assume)
But - if anyone proceeds with this retrofit - please provide your observations
golfman
C?ID=103115
Period.
Hi hadez16 what about if you have this???? RLS
This is from my 2015 polo.
Subsystem 1 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S2Y15M04D27H13M00S51
Coding: 1238DD
Scott
hadez16
C?ID=289891
To my knowledge, rain closing is and was never possible with PQ25 platform.
boots
France
C?ID=125580
I am sorry to re-open this topic but I am exactly in the same situation: trying to activate the rain closing onto MQB, but on a 2017 Tiguan.
I do see it in the setup menu and I enabled it and I have the following coding for RLHS 06A8DD (Component: RLHS 047 0105)
To me it looks like the windows/sunroof are not powered anymore after door locking, instead of staying powered for 24 hours to allow the rain closing function
Do you think I could give a try to modify something into the following module:
05-Acc/Start Auth: Byte 4/ bit 1 "automatic terminal 15 S-contact shut down by vehicle locked externally, Yes" is ticked -> can I try to deactivate it ? Or am I gonna have issues of low battery or some bad experience ?
It reminds me an option I had to activate onto my previous vehicle from year 2013 (not MQB) in module 09 : "Power windows/sunroof enabled after Terminal 15/ Ignition off"
Have a good day
DV52
C?ID=194404
boots: Hi. As is clearly evident - the central message in ALL responses above is that the auto rain close tweak is at best problematic on MQB platform vehicles and according to @hadez16 it's "not possible on RLHS" units.
Of course, it IS entirely possible that there is a hitherto unknown fix to this problem that has alluded previous attempts to implement this tweak. So, yes please experiment and please report your findings (either way) so as to add to the sum knowledge of the forum community.
boots
France
C?ID=125580
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 22 2B 36 42 44 52 55
          5F 65 6D A5 BB BC CA
VIN: WVGZZZ5NZJW355437   Mileage: 101027km-62775miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 EJ    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 3661
   Revision: B4H25---
   Coding: 0125001203661D083000
   ASAM Dataset: EV_ECM20TDI01104L906026EJ 004003
   ROD: EV_ECM20TDI01104L906026EJ_004.rod
   VCID: 76B5E2A5F842AEFB78F-8022
   Part No SW: 0DL 300 011 N    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2014
   Revision: 00H06V07
   VCID: 33331BB1ABB0FBD39F1-8066
   Revision: 00000000    Serial number: 62817000001624
   Coding: 0AEE6B9A54250B71477B070362CA4950D62AD0E2E046927D38625008422A4200002F641A1B13111435351919323200
   VCID: 77ABEFA1FF48D7F3639-8022
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0458647485
   Coding: 132C2C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E253A8590F226BB60F-806A
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98292332
   Component: Sitzmemory    H08 0022
   Serial number: Y0006QJ715920
   Coding: 0010000000000500818281808181000000008181000000F400
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide.rod
   VCID: 3C21308D86EE34AB4EB-8068
   Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
   Component: AC Automat    H35 4301
   Revision: 20K09000    Serial number: 00000B00697613
   Coding: 0002012420211001110510400010102A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 4ACD6655DC3A9A1BCC7-801E
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001729902702
   ROD: EV_BCMBOSCH_018.rod
   VCID: 094F995999BCD10305D-805C
   Subsystem 1 - Part No SW: 5NB 955 119     HW: 5NB 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 171005  033 0372
   Serial number: 00000001710030302312
   Serial number: S9Y17M10D25H19M48S57
   Coding: 06A8DD
   Serial number: 000000000ZY172523HR6
   Serial number: 00000000000039351445
   Part No SW: 3Q0 919 294 B    HW: 3Q0 919 294
   Component: PDC 8 Kanal   H08 0029
   Serial number: 000109177478030
   Coding: 0071451811
   ASAM Dataset: EV_EPHBO18VW3260000 007018
   ROD: EV_EPHBO18VW3260000_SK37.rod
   VCID: 38292C9DB2D6188BAA3-806C
   Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H02 0233
   Coding: 320067C158FF8728749C8145804087
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Serial number: 003VWR3JGSE1
   Coding: 98CCC0C00C0000005C5400CF000800000065
   Belt Pretensioner left:
   Component: BeltPretRevFL  106 1032
   Serial number: 5NB857705C0283R01496
   Coding: 80000D
   Belt Pretensioner right:
   Component: BeltPretRevFR  106 1032
   Serial number: 5NB857706C0291R00360
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 002 310 17
   Serial number: 357000000001FC44092J
   Subsystem 4 - Part No SW: -----------    HW: 480 002 310 17
   Serial number: 358000000006FC44092P
   Subsystem 5 - Part No SW: -----------    HW: 480 402 310 17
   Serial number: 3510001AB275C8A54233
   Subsystem 6 - Part No SW: -----------    HW: 480 402 010 17
   Serial number: 3520001C3275C8A2F1EG
   Subsystem 7 - Part No SW: -----------    HW: 480 402 410 17
   Serial number: 3550001A1275C8A3172$
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 610 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001A52742B04B29.
   Subsystem 9 - Part No SW: -----------    HW: 480 402 610 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001A52742B05B2F2
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 402 610 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001A52742B05E6D%
   Subsystem 11 - Part No SW: -----------    HW: 480 001 710 17
   Serial number: I0M0000000046A11A82$
   Subsystem 12 - Part No SW: -----------    HW: 480 001 710 17
   Serial number: I0N0000000056A11A82+
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20171023301073
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   VCID: 73B3DBB1EB30BBD35F1-8026
   Part No SW: 5NA 920 791 B    HW: 5NA 920 791 B
   Component: KOMBI         407 3193
   Coding: 07AD00986E84000801887B071401000080000000
   VCID: 42DD4E75E40A425B047-8016
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 16101710803386
   Coding: 030500045F087300FB07225C1E0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 2771723192031378AS3B
   Coding: 2D0000
   Serial number: 1329825604
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00022.08.17
   Coding: 0101
   VCID: 4CC1604DD64E842BFEB-8018
   Serial number: 17000287127015
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD1B9912C89C3ADD-8024
   Serial number: Y0006QJ715934
   Coding: 0010000000000500018281808181000000008181000000F400
   Serial number: 130917EID14183
   Coding: 001F1A20D200048000001000
   VCID: 43D34B71FB104B530F1-8016
   Revision: 00000000    Serial number: 0002113139
   Coding: 01000011004001
   ROD: EV_SteerAssisVWBSMQBA_009.rod
   VCID: 40D9447DEA06504B123-8014
   Serial number: 080917EI809678
   Coding: 001F1020DE00048000001000
   Coding: 08EA000009000000
   VCID: 75B7E5A9E544A5E3715-8020
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 5NA 035 042 A    HW: 5NA 035 042
   Component: MU-H-LN-EU    H54 1161
   Serial number: A847J0HS011712
   Coding: 02730601FF0000005111000100080A101F0100E4012004009F
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H61 9214
   Serial number: VWZ6ZJX0311141
   Subsystem 2 - Part No SW: V03 959 800 QT    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Component: Gracenote2  --- 1016
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 40000000118414
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 343118ADAEBEFCEB86B-8060
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 31592336200000
   Coding: 0A28
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 19101712K22552
   Coding: 0003070600000401002223448150A90094000E200020
   Serial number: 310717EGV0933A
   Coding: 002A10200101048000001000
   VCID: 45D75569F5247563215-8010
   Serial number: 310717EGV13623
   Coding: 208040732602
   VCID: 3D273D899DF43DA3795-8068
End----------(Elapsed Time: 02:10, VBatt start/end: 12.4V/12.4V)-----------
Then I have tryied to deactivate this one : (05-Acc/Start Auth: Byte 4/ bit 1) but it didn't change anything for the rain closing.
By the way, I have seen a lot of adaptations. Could you tell me what is referring to: "Terminal 15" and "S-Contact" or how would be named the power for windows/sunroof please ?
DV52
C?ID=194404
@boots : "Terminal 15 " refers to a nomenclature that is defined in DIN 72552 (it's a standard for automotive electric terminals). Specifically, T15 refers to a voltage supply that is provided by the battery - but that is controlled via the ignition switch. So for T15, ignition switch-off = 0 Volts, ignition switch-on = battery volts.
T15 is in contrast to another terminal definition "T30" which is always @ battery voltage regardless of the ignition switch status (notice that T15 is half T30- interesting, I think).
The S-Contact is a separate switch inside the ignition switch mechanism that is activated by the insertion of the key. So, the S-Contact senses the presence of the ignition key before the contacts on the ignition switch change status.
boots
France
C?ID=125580
Thank you for these interesting definitions !
khaledabdulaziz
Israel
C?ID=394371
Period.
can I try and replace the RLHS with RLS ?
if I can, what is the HW no. of the RLS I should put?
