Vehicle Identification No. 3VWE57BU6KM013560
Model Jetta 1.4
JEM
Date of production 28.03.2018
Year 2018
Sales type BU33MS
Engine Code DGXA
Transmission Code RZE
engine at idle, coolant +80c
Model Jetta 1.4
JEM
Year 2018
Sales type BU33MS
Engine Code DGXA
Tuesday,29,May,2018,11:40:29:29015
VCDS Version: 18.5.0.0 (x64) HEX-NET CB: 0.4422.4
Data version: 20180518 DS291.0
VIN: 3VWE57BU6KM013560 License Plate:
Chassis Type: BU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 2B 3C 42 44 47 52 5F 75 A5 CA
VIN: 3VWE57BU6KM013560 Mileage: 119km-73miles
CA-Sunroof -- Status: Malfunction 0010
Address 01: Engine (J623-DGXA) Labels: None
Part No SW: 04E 906 024 L HW: 04E 907 309 BT
Component: R4 1.4l TSI H20 5595
Revision: D4H20000
Coding: 012A0012236411087000
Shop #: WSC 00066 790 00312
ASAM Dataset: EV_ECM14TFS01104E906024L 001003
ROD: EV_ECM14TFS01104E906024B.rod
VCID: AA1701FECD8EFE1BB9-80FE
Address 02: Auto Trans (J217) Labels: Redir Fail!
Part No SW: 09S 927 158 R HW: 09S 927 158
Component: AISIN 8G30/18 301 3552
Coding: 0100000100000000000000000000000000000000
Shop #: WSC 25454 002 1048576
ASAM Dataset: EV_TCMAQ300031 001008
ROD: EV_TCMAQ300031.rod
VCID: CEDF6D6E91A6F23B05-809A
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DA HW: 5Q0 614 517 AH
Component: ESC H62 0753
Revision: 00000000 Serial number: 50198000000593
Coding: 70FB6AA12421216FC57C0206A0C3250E562484A34005A4701841F058C2A2430B00000012121212B835351919323200
Shop #: WSC 01383 790 50316
VCID: F3A9DC9A5AC4FFD3CA-80A6
Part No SW: 3Q0 959 435 J HW: 3Q0 959 435 J
Component: VWKESSYMQB 037 1104
Revision: 00037000 Serial number: 0467941210
Coding: 132C0C0723
ASAM Dataset: EV_KessyHellaMQBAB 004043
VCID: C1C5465250F81D4388-8094
Part No SW: 5GM 907 044 M HW: 5GM 907 044 M
Component: Climatronic H04 2007
Revision: 00001K04
Coding: 0102001420011800110400001211100C
ASAM Dataset: EV_ACClimaBHBVW37X 006148
Part No SW: 5Q0 937 087 AS HW: 5Q0 937 087 AP
Component: BCM PQ37BOSCH 034 0246
Revision: -------- Serial number: C86427021803IC
ROD: EV_BCMBOSCH_018.rod
VCID: 8C5BA766273A802BAB-80D8
Subsystem 1 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 047 0105
Serial number: SBY18M03D06H15M42S12
Coding: 0038DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 521 AS HW: 5Q1 953 569
Component: Lenks.Modul H03 0120
Serial number: 0100010320180C300483
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5Q0 907 572 N HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0681
Coding: 320000C119FFC428949C810580301600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
VCID: C2C7495E55FE065B91-8096
Part No SW: 5Q0 959 655 AG HW: 5Q0 959 655 AG
Component: AirbagVW21 004 0336
Serial number: 003NUM080RC$
Coding: 8CCCFC00000000005000001AC20800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 854D92420450F163F4-80D0
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000008HYPUV
Coding: 303441
Subsystem 2 - Part No SW: ----------- HW: 480 001 301 18
Serial number: 35700000000CA045EA2T
Subsystem 3 - Part No SW: ----------- HW: 480 002 801 18
Serial number: 35800000000CF5EC8A28
Subsystem 4 - Part No SW: ----------- HW: 480 401 501 18
Serial number: 3510001BF285E664279D
Subsystem 5 - Part No SW: ----------- HW: 480 401 501 18
Serial number: 3520001BB2888600D473
Subsystem 6 - Part No SW: ----------- HW: 480 402 802 18
Component: FrontSensor_D 000 6149
Serial number: 3550001A928F9E51647I
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 702 18
Component: FrontSensor_P 000 6149
Serial number: 3560001C5291EE721501
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 17A 920 890 HW: 17A 920 890
Component: KOMBI 514 0610
Coding: 09A4091A6788CF050288230B50000000A0000000
Shop #: WSC 00066 790 00278
ASAM Dataset: EV_DashBoardVDDMQBA0 001024
ROD: EV_DashBoardVDDMQBA0_VW27.rod
VCID: E58DB2C2E410116354-80B0
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 15011800840365
Coding: 030100047F085708FB0002D81C0F00010001070000000000000000000000
Shop #: WSC 00066 790 00013
ROD: EV_GatewNF.rod
VCID: B8332BB603225C8B3F-80EC
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0052
Serial number: 39170002879030048025
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 1774015600
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H07 0021
Serial number: 18000029238012
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0.rod
VCID: B1251692E0588DC378-80E4
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 A HW: 2Q0 907 686 A
Component: HRE3_Kl15_Mst H03 0052
Serial number: 00000468361060
Coding: 5000C500
ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
ROD: EV_HREntryHellaGen3Kl15.rod
Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B
Component: TSG FS 011 0032
Serial number: 7038802100967
Coding: 00281B200000028000000000
VCID: C5CD524244D03163B4-8090
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000000234762
Coding: 011000
Part No SW: 5QM 909 144 B HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 172 1081
Coding: 911F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: D0E373168B92E4CB17-8084
Address 47: Sound System (J525) Labels:* None
Part No SW: 5F0 035 456 HW: 5F0 035 456
Component: KonzernAmp12K H03 2109
Revision: -------- Serial number: A1126A00003400
Coding: 0203000000AAAAAA000000000000
ASAM Dataset: EV_AMPCAN12C4PASE 001002
ROD: EV_AMPCAN12C4PASE.rod
VCID: E287A9DEF53E665BB1-80B6
Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B
Component: TSG BFS 011 0032
Serial number: 8038806200958
Coding: 002813200000028000000000
VCID: C4CB4F464FEA086BA3-8090
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000000234160
Coding: 091000
Part No SW: 3Q0 035 844 B HW: 3Q0 035 844 B
Component: MU-S-S-US 722 0867
Coding: 02730100AA00000041220003001808009F0510F40120040002
ROD: EV_MUStd4CDELP_VW26.rod
VCID: AE1F0DEEF166923B65-80FA
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 H50 8130
Serial number: VWZ6ZJV0561965
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02730102C2823A017F1E06000000
ROD: EV_OCULowMQB.rod
VCID: C3C94C5A4AE40F539A-8096
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 1272
Serial number: 27101741K11226
Coding: 0003070100020201002200548150490084000E200120
ROD: EV_MFKBoschMQBB_VW27.rod
VCID: 88539B763342EC0B8F-80DC
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 K HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 00800073710B
VCID: BE3F3DAE210662BBF5-80EA
0279 - Switch for Sunroof
B13C4 29 [008] - Signal Implausible
Reset counter: 50
Mileage: 117 km
Date: 2018.05.25
Time: 15:42:26
Controls-Sunroof button: not activated
Controls-Sunroof shade button: not activated
Controls-Button for sliding roof: not activated
Controls-Search lights: Current cannot be measured
End----------(Elapsed Time: 01:35, VBatt start/end: 13.1V/13.0V)-----------
;SW:04E-906-024-L HW:04E-907-309-BT --- Engine
;Component:R4 1.4l TSI H20 5595, Coding:012A0012236411087000
;EV_ECM14TFS01104E906024L,001003,EV_ECM14TFS01104E906024B.rod
;Tuesday,29,May,2018,11:48:28:29015
;VCDS Version: Beta 18.5.0 (x64) Data version: 20180518 DS291.0
;VCID: AA1701FECD8EFE1BB9-80FE
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),3VWE57BU6KM013560,
IDE00019,Voltage terminal 30,12.940, V
IDE00020-ENG57549,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,750, /min
IDE00025,Coolant temperature,81, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,637, s
IDE00083,Throttle valve position (absolute),12.5, %
IDE00084,Absolute load value,20, %
IDE00085,Normed load value,14.9, %
IDE00086,Accelerator position,15, %
IDE00090-ENG57549,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,23.6, Nm
IDE00148,Median injection timing,0.767, ms
IDE00150,Pressure in brake booster,282.54, hPa
IDE00151,Oil fill level,65.864, mm
IDE00152,Oil warning threshold,43.080, mm
IDE00155,Timing angle retardation cylinder 1,0.0, °
IDE00156,Timing angle retardation cylinder 2,0.0, °
IDE00157,Timing angle retardation cylinder 3,0.0, °
IDE00158,Timing angle retardation cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,527.0, °C
IDE00172,A/C compressor torque,20.0, Nm
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-23.906, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-23.750, °
IDE00178,Camshaft adjustment intake bank 1: specified value,21.648, °
IDE00179,Camshaft adjustment intake bank 1: actual value,21.492, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.29, °
IDE00187,Coolant temperature at engine start,22.5, °C
IDE00188,Fuel high pressure: actual value,9.992, MPa
IDE00190,Charge air pressure specified value,333.28, hPa
IDE00191,Charge air pressure: actual value,975.16, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,25.5, °C
IDE00194,Coolant temperature at radiator output: specified value,95.3, °C
IDE00196,Engine oil temperature,73.9, °C
IDE00201,High fuel pressure: specified value,10.000, MPa
IDE00202,Low fuel pressure: specified value,415.0, kPa
IDE00304,Fuel level,48.00, l
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00348,Intake air temperature,36, °C
IDE00349,Throttle valve position: normed,2, %
IDE00350,Air mass: specified value,7.7, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG57549,Cruise Control System (CCS): status-Bits 0-7,2,
IDE00357,Fuel temperature,45.0, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,978.44, hPa
IDE00371,Fuel consumption,0.65, l/h
IDE00375,Generator: load signal,32.23, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,735.0, mV
IDE00393,Accelerator pedal: sensor voltage 2,374.6, mV
IDE00394,Camshaft position: start of phase window,113.64, °
IDE00406,Camshaft speed (RPM),377.5, /min
IDE00407-ENG57549,Rail pressure regulation: status-Bits 0-7,1,
IDE00412-ENG57549,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG57549,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG57549,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG57549,Starter control: terminal 50 acknowledgment-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00417-ENG57549,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00432,Particle filter: time since last regeneration,0.000, H
IDE00434,Particle filter: soot mass calculated,6, mg
IDE00436,Particle filter: kilometers since last regeneration,0.000, km
IDE00443-ENG57549,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,ERROR,
IDE00451,Currently running routine,Unknown,
IDE00474,Ambient air pressure,97, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,3.4, Nm
IDE00496-ENG57549,Activation of oil pressure switch valve-Bits 0-7,0,
IDE00497-ENG57549,Status of oil pressure switches-Bits 0-7,133,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside air temperature,25, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.003 Lambda / -0.020 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.825, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,1.000, Lambda
IDE00583,Throttle valve specified value,3, %
IDE00584,Distance driven since erasing DTC memory,99, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00588,Fuel tank fill level,99.6, %
IDE00592,Oxygen sensor control status,Closed loop, / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,0.5, Degrees
IDE00594,Absolute intake pressure,30, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,0.0, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,8,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00699,ESI: minimum oil level in service interval,32.000, mm
IDE00700,ESI: maximum oil level in service interval,-32.000, mm
IDE00727,Test steps still to be performed,4,
IDE00738,Test of oxygen sensors bank 1: Delta-Lambda,0.00000,
IDE00752,Test of oxygen sensor control.,Test off,
IDE00752-ENG127302,Test of oxygen sensor control.-Test_Program_Channel 213,235,
IDE00773,Terminal 15 status via CAN,1,
IDE00787,Cause for cancellation,0,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00973,Outside air temperature,25.5, °C
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,0.0000,
IDE01260,Generator power,348.717, W
IDE01267,Height correction,0.96588,
IDE01378,High fuel pressure: control deviation,0.0020, MPa
IDE01385-ENG57549,Wear index-Bits 0-7,0,
IDE01386-ENG57549,Soot index-Bits 0-7,0,
IDE01407,Particle filter: fuel consumption since last regeneration,0.000, l
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.825, V
IDE01650,Throttle valve position 2,12, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Syst. OK,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,228,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,TVV is OK,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,223,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,activated,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01834,Battery voltage,12940, mV
IDE01869,Long-term fuel trim bank 1 at idle,0.23, %
IDE01870,Oxygen sensor after catalytic converter: operating status,B1-S2 OK,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,209,
IDE01872,Result of oxygen sensor aging test after catalytic converter,B1-S2 OK,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,209,
IDE01873,Test of catalytic converter: measured value,9.9612,
IDE01874,Test of catalytic converter: result,CatB1 Ok,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,219,
IDE01876,Adaptation of loss torque,0.6, Nm
IDE01877-ENG57549,Operating condition of idle speed control-Bits 0-7,0,
IDE01878-ENG28465,Adaptation of throttle valve-Byte,00000100 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,31.841, %
IDE01885,Shut off of oxygen sensor control,l-Reg.ON,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,4,
IDE01888,Cold start enrichment: adaptation area 1,0.953,
IDE01889,Cold start enrichment: adaptation area 2,0.922,
IDE01890,Cold start enrichment: adaptation area 3,0.875,
IDE01891,Cold start enrichment: adaptation area 4,0.852,
IDE01892,Cold start enrichment: adaptation area 5,0.852,
IDE01893,Fuel pump: specified value,46.892, %
IDE01898,Load value: specified value,119.02, %
IDE01900,Charge press. ctrl.: spec. value,99.6, %
IDE01901,Lost torque adaptation: idle,0.6, Nm
IDE01902,Lost torque adaptation A/C compressor,2.5, Nm
IDE01903,Lost torque adaptation driving mode,2.3, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,2.6, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,0.98810,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.03168,
IDE01911,Leakage air,3.2, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1.0000,
IDE01914-ENG57549,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,170,
IDE01922,Vehicle distance driven,119, km
IDE01923,Control module distance driven,119455, m
IDE01928,Close cam shaft angle at quantity control valve,26.1, °
IDE01929,Open cam shaft angle at quantity control valve,-6.1, °
IDE01930,High pressure regulation: adaptation value,0.066, MPa
IDE01932,High pressure pump injection volume,3.37, mm³
IDE01975,Numb.of misfir.: cylinder 1,40,
IDE01976,Numb.of misfir.: cylinder 2,33,
IDE01977,Numb.of misfir.: cylinder 3,17,
IDE01978,Numb.of misfir.: cylinder 4,31,
IDE02115-ENG57549,Adjustment requirements for basic setting-Bits 0-7,191,
IDE02116,Exhaust gas temperature before catalytic converter,408.86, °C
IDE02117,Relative load value,18.33, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,2.91, MPa
IDE02540-ENG57549,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02756,Number of manual engine starts,145,
IDE02757,Number of automatic engine starts,10,
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,26,
IDE03010-MAS01627,Number of prevented stop processes-Steering,29,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,0,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,34,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,60,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,30,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,12,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,2,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,17,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,4,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,B1-S1 OK,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,237,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,0.00, °
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.494, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.502, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.854, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.146, V
IDE03328,Transmission neutral position sensor voltage,0, mV
IDE03362,Requested transmission torque,1000.0, Nm
IDE03375-ENG57549,Adaptation status for transmission neutral position sensor-Bits 0-7,0,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3313.6, mV
IDE03393-ENG57549,Selector lever position-Bits 0-7,8,
IDE03584-ENG57549,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG57549,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,not active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,not active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,not active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03692-ENG57549,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,128,
IDE03693-ENG57549,Monitoring status of additional Onboard Diagnosis-Bits 0-7,161,
IDE03709,Angle difference actual-specified camshaft adjuster,0.094, °
IDE03711,Mass flow through throttle valve,7.3, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,28.467, %
IDE03805,Test of brake booster pump: result,Test off,
IDE03805-ENG127323,Test of brake booster pump: result-Test_Program_Channel 603,235,
IDE03806-ENG57549,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,3,
IDE03807-ENG57549,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,2,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,216.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,147.70, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,30.966, %
IDE03932,Charge pressure actuator: specified position,140.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3240.0, mV
IDE03935,Charge pressure actuator: adaptation for upper stop,140.0, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.99313,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE04002,Charge press. ctrl.,BP_A act:98, kPa
IDE04003,Charge air temperature sensor,B1S1:36 °C / °C,
IDE04010,Engine torque: normalized,8, %
IDE04011,Nominal torque,280, Nm
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:9920/--- kPa,
IDE04083,Coolant temperatures,ECT 1:81 °C / ECT 2:25 °C,
IDE04088,Turbocharger 1: temperature,Compr. in/out---/38 °C / Compr. in/out---/--- °C,
IDE04110,Additional inputs and outputs,,
IDE04278,Bypass valve f high press turboch turbine inlet: target value,100.00, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,98.78, %
IDE04280,Bypass valve f high press turboch turbine inlet: offset closed,1.61, %
IDE04281,Bypass valve f high press turboch turbine inlet: offset open,-1.61, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,10.81, %
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,64,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,0,
IDE04302-ENG57549,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,18,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,3203.8, mV
IDE04410,Intake manifold pressure: target value,313.20, hPa
IDE04420,Activation of secondary air system,Atmosphere/off,
IDE04604,Accelerator pedal travel,0.00, %
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04654-ENG57549,CAN status - engine control module-Bits 0-7,0,
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,7,
IDE04677,O2 sensor 1 bank 1: O2 sensor actual value,0.9961,
IDE04685,Setpoint generation interior torque,22.4, Nm
IDE04693,Increasing desired torque intervention of ESP,-55705.6, Nm
IDE04695-ENG99946,Immobilizer snapshot A-Sia Error Snap A,00 00 00,
IDE04696-ENG102592,Immobilizer snapshot B-Sia Error Snap B,00 00 00,
IDE04858,Brake booster low pressure actual value,695.98, hPa
IDE04887,Powertrain target torque,74.5, Nm
IDE04889,Target torque for combustion engine crankshaft level,8.7, Nm
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05140,Intake manifold pressure raw value,306.80, hPa
IDE05221,E-machine torque actual value,0.0, Nm
IDE05240-ENG57549,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG57549,A/C compressor release status-Bits 0-7,1,
IDE05261-ENG57549,Gear position sensor: last valid value-Bits 0-7,14,
IDE05332-ENG57549,Heat request from heater to thermal management-Bits 0-7,3,
IDE05436,Engine operating condition,Idling,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,24.0, °C
IDE05438,Rear cat conv temp main cat conv model value,340.26, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.00000000,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0000, rad
IDE05444,Air filling: specified value,18.70, %
IDE05449,Oxygen sensor 2 bank 1 internal resistance limit value,6320, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00183,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,719.85, °C
IDE05470,Cat converter oxygen storage capacity,751.2, mg
IDE05472,Cat converter oxygen storage capacity ref standardized,10.5801,
IDE05474,Main cat converter OSC age correction factor,1.031,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,7.7, kg/h
IDE05479,Misfire recognition reference moment,5.621, %
IDE05482,Tank venting adaptation factor,2.434,
IDE05485-ENG57549,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05508,Adaptation val cyl 1 with slow diagnosis,1.00000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,1.00000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,1.00000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,1.00000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,1.00000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,1.00000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,1.00000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,1.00000,
IDE05593,Secondary air injection sensor 1,976.80, hPa
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,30,
IDE05797,Throttle valve adapter: specified value,3.172, %
IDE06015,Time since term 15 OFF StartStop,65535, s
IDE06017,Camshaft position deviation from reference position,-0.04, °
IDE06020,Intake air temperature in intake manifold bank raw value,35.3, °C
IDE06021,Intake air temperature before throttle valve: raw value,38.3, °C
IDE06023-ENG57549,BDE operating mode flag register-Bits 0-7,1,
IDE06039,Required RPM at idle speed,750.0, /min
IDE06040,High fuel pressure: regulator output value,0.0520, MPa
IDE06045-ENG57549,Output DTM status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06049,Pressure in brake booster: raw value,282.58, hPa
IDE06059,Particulate filter: oil ash mass,0.00, g
IDE06098,Sensor control factor: output value,1.00116,
IDE06307-MAS00106,Stop prevention history data-Year,2018,
IDE06307-MAS00107,Stop prevention history data-Month,5,
IDE06307-MAS00108,Stop prevention history data-Day,25,
IDE06307-MAS00109,Stop prevention history data-Hours,16,
IDE06307-MAS00110,Stop prevention history data-Minutes,40,
IDE06307-MAS00111,Stop prevention history data-Seconds,26,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Driving situation,
IDE06307,Stop prevention history data,Steering,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Auxiliary consumers power too high,
IDE06308,Start request history data,Motor protection active,
IDE06308,Start request history data,Cat. heater,
IDE06308,Start request history data,Rolling vehicle,
IDE06308,Start request history data,Hybrid battery power insufficient,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Engine hood open,
IDE06308,Start request history data,Sporadic function restriction,
IDE06308,Start request history data,Restriction in the start system,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,Brake under pressure too low,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,Fuel salinization protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,Engine temperature too low,
IDE06386,Oil level: static measurement,64.692, mm
IDE06387,Oil level: last valid dynamic value,0.000, mm
IDE06388,Oil level: condition for static measurement fulfilled,0,
IDE06393,Oil level: dynamic average value,19.584, mm
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06446-ENG57549,Status: incline angle-Bits 0-7,1,
IDE06567,Start-stop function deactivation frequency counter,17,
IDE06568,Stop prevention by driver frequency counter,116,
IDE06569,Vehicle stopped frequency counter,234,
IDE06610,Vehicle standstill with stop frequency counter,18,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,2,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,8,
IDE06702-ENG57549,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06703-ENG57549,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG57549,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06706-ENG57549,ACC variants-Bits 0-7,2,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,32,
IDE06708-ENG57549,Cruise control switch actuation-Bits 0-7,1,
IDE06709-ENG57549,ACC variants (coding)-Bits 0-7,3,
IDE06711-ENG57549,Cruise control system: temporary deactivation-Bits 0-7,255,
IDE06758,Air mass since engine start,3.19, kg
IDE06759,Cam shaft adaptation inlet: counter,0,
IDE06760,Camshaft adaptation: exhaust: counter,0,
IDE06946-ENG57549,Brake actuated status-Bits 0-7,3,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,12,
IDE07050-ENG57549,Starter control: release conditions-Bits 0-7,98,
IDE07051-ENG57549,Engaged gear: raw signal-Bits 0-7,0,
IDE07094,Correction factor injector cylinder 1,1.0355,
IDE07095,Correction factor injector cylinder 2,0.9808,
IDE07096,Correction factor injector cylinder 3,0.9868,
IDE07097,Correction factor injector cylinder 4,0.9988,
IDE07164,Number injections,33250,
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG57549,Overrun cut-off-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,0,
IDE07233-ENG57549,Bit string for status of oil level-Bits 0-7,66,
IDE07234,Status bid for valid static oil level,1,
IDE07235,Status bid for dynamic oil level,0,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07573,Throttle valve adapter: actual value,3.08, %
IDE07693,Max. supply pressure of low pressure fuel pump,0.0, kPa
IDE07697,System test status of fuel supply,32,
IDE07796-ENG57549,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07904-ENG57549,Brake test switch status-Bits 0-7,1,
IDE07905-ENG57549,Brake light switch status-Bits 0-7,1,
IDE07906-ENG57549,Upper clutch switch: status-Bits 0-7,0,
IDE08562,Basic correction factor: Injector cyl. 1: filtered,1.0165,
IDE08563,Basic correction factor: Injector cyl. 2: filtered,0.9913,
IDE08564,Basic correction factor: Injector cyl. 3: filtered,0.9905,
IDE08565,Basic correction factor: Injector cyl. 4: filtered,1.0018,
IDE09307-ENG57549,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG57549,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09309-ENG57549,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG57549,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09313-ENG57549,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG57549,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG57549,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG57549,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.08, s
IDE09925-ENG57549,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,-0.352, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,1.117, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,-1.60, °
IDE09932,Intake camshaft bank1: adaption value sensor tolerance,-0.26, °
IDE10040,Outlet camshaft bank 1 active operating mode,1,
IDE10041-ENG57549,Intake camshaft bank1 active operating mode-Bits 0-7,1,
IDE10041-ENG57549,Intake camshaft bank1 active operating mode-Bits 0-7,0,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10302,Time since engine start,674.0, s
IDE10303,Integrated air masse at first engine start,3.2302, kg
IDE10641,Low fuel pressure adaptation value for EFP: modeled,60.0, kPa
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,2,
IDE11116,Start/stop driver request: counter internal-motor restart,3,
IDE11293,Fuel consumption difference: injectors/sensors,4.660, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,4.953, l
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,19.82, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,-12.58, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,-9.58, %
IDE12201,High-pressure fuel injection valve adapted value: cylinder 4,-2.48, %
IDE12210,Particle filter: water mass,0.0, g
IDE12355,ESI: consumption equivalent of the engine control module,0.00000014,
IDE12460,Low pressure procedure: pressure regulation valve open,0.00, kPa
IDE12461,Pressure regulator valve pulse duty factor,0.00, %
IDE12462,Pressure regulator valve opening pressure,0.0, kPa
IDE12463,Pressure regulator valve minimum pulse duty factor,False result,
IDE12463-ENG127289,Pressure regulator valve minimum pulse duty factor-Test_Program_B TRUE UBYTE,0,
IDE12464,Rail pressure at end of test,0.000, MPa
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,5600, mg
IDE13086,Particle filter: maximum soot build-up reached,8000, mg
IDE13087,Particle filter: maximum ash build-up reached,30, g
MAS15845,Fuel: tank fill level,48.5, l
MAS15866,High pressure buildup gradient during pressure limitation valve opening test,0.000, MPa/revolution
MAS15883,Maximum fuel high-pressure with extended value range,0.000, MPa
MAS16287,High pressure buildup process with engine of: extended range,0.000, MPa/s
MAS16534-ENG57549,A/C compressor info: switch-off status-Bits 0-7,0,
ENG119898,Actual_section_of_standard_test,1,
ENG112928-ENG57549,Air_conditioning_compressor_actual_status-Bits 0-7,0,
ENG101413,Calibration Identification,04E024L 5595DXAA,
ENG99697,Calibration Verification Number,76 07 50 BA,
ENG126402-ENG57549,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG20102,Engine Friction - Percent Torque,5.0, %
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Con Enc Cou B 1,00 04 00 8F 00 06 00 04 00 00 00 00 00 05 00 04 00 00 00 00 00 16 00 04 00 0B 00 03 00 04 00 03 00 02 00 04 00 00 00 00 00 02 00 04 00 00 00 00 00 00 00 00 00 00 00 00,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2018,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,5,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,16,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,14,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,0,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,59,
ENG127734,Life_cycle_data_start_requirement_development,not active,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2018,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,5,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,25,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,15,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,46,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,43,
ENG127735,Life_cycle_data_stop_prohibition_development,not active,
ENG127735,Life_cycle_data_stop_prohibition_development,A/C,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2011,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,2,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,19,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,2,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,30,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,47,
ENG127733,Life_cycle_data_system_failure,not active,
ENG127733,Life_cycle_data_system_failure,Engine,
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
Elapsed Time: 00:41
