Here is reference scan of new Seat Leon facelift.
I saw on other scans that some members have subsystem sunroof and blind, and I dont get those subsystems even tho I have sunroof and blind installed in car.
Additional equipment from factory: ACC, Line Assist, High Beam Assist, Panorama roof, Park Pilot
Friday,25,May,2018,22:04:42:22554
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
VIN: VSSZZZ5FZHR08xxxx License Plate:
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 4B 52 5F A5 D6 D7
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BN HW: 04L 907 309 R
Component: R4 2,0L EDC H24 1197
Revision: B5H24---
Coding: 01190012034401082000
Shop #: WSC 00049 770 00128
ASAM Dataset: EV_ECM20TDI01104L906026BN 002002
ROD: EV_ECM20TDI01104L906026BN_002.rod
VCID: 77AA1CB02F48C51F40D-8022
17156 - Databus
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CE HW: 5Q0 614 517 AC
Component: ESC H25 0413
Revision: 00000000 Serial number: 50877000000847
Coding: 19EE62922428096C077D060940C32498462490E0600224731460F078C022430000000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
VCID: 76B411B42842BC175BB-8022
Part No SW: 5F0 907 044 AL HW: 5F0 907 044 AL
Component: Climatronic H05 1801
Revision: 00001K09
Coding: 02000124200110011105004000101020
Shop #: WSC 00049 770 00101
VCID: 70B827AC4A269227817-8024
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001711803289
ROD: EV_BCMBOSCH_017.rod
VCID: 7F5AF4900778FD5F08D-802A
Subsystem 1 - Part No SW: 5F1 955 119 A HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 170406 041 0574
Serial number: 170427134430
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S4Y17M04D26H00M26S06
Coding: 06885D
Sun Roof:
Roof Blind:
Part No SW: 5QA 919 294 A HW: 5QA 919 294
Component: PDC 8 KanalH07 0038
Serial number: 000308418617132
Coding: 0471051001
ASAM Dataset: EV_EPHVA18AU3700000 009031
ROD: EV_EPHVA18AU3700000_009_AU37.rod
VCID: 4ACC95440C3A88F7EF3-801E
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 H HW: 5Q0 907 572 H
Component: ACC BOSCH MQB H10 0620
Coding: 2D0060C251FFC728949C814560400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002005
VCID: 3C20C39C56EE26476DF-8068
0836 - Databus
[FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
Fault Frequency: 76
Reset counter: 225
Mileage: 9164 km
Date: 2018.02.17
Time: 13:43:32
Control Module temperature: 8 °C
Voltage terminal 15: 11.9 V
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQP89NPEW
Coding: 98CCC000000000005C0000CC000800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0F7A445037D8EDDFF8D-805A
Subsystem 1 - Part No SW: ----------- HW: 454 002 504 17
Serial number: 3576U00000099294B32E
Subsystem 2 - Part No SW: ----------- HW: 454 002 704 17
Serial number: 3586U00000047585D32D
Subsystem 3 - Part No SW: ----------- HW: 454 802 104 17
Component: SideSensor_Dr 301 0148
Serial number: 3516R17607C10000000X
Subsystem 4 - Part No SW: ----------- HW: 454 802 004 17
Component: SideSensor_Pr 301 0148
Serial number: 3526R56697C100000003
Subsystem 5 - Part No SW: ----------- HW: 454 801 404 17
Component: FrontSensor_D 304 0149
Serial number: 3556V8FDA870E000000$
Part No SW: 5Q0 953 507 HA HW: 5Q0 953 549 E
Revision: -------- Serial number: 02051708490456
Coding: 6C00
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 7CA0039C166EE6472DF-8028
Address 17: Instruments
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0006368973
Coding: 030100F40F087300FB000258080F00010001050000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 2F3AE4D09798CDDFD8D-807A
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000G0398070517
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75886000001705041803
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0032
Serial number: 0000254479606
Coding: 00300320DC00040000001000
VCID: 47CAAC701F28759FF0D-8012
Serial number: 00000000000014412369
Coding: 310000
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 129 1072
Coding: 9107
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D6A6782524678F021-8010
21760 - Databus
[HCA_01 Botschaft - CAN-Timeout]
Reset counter: 150
Mileage: 6703 km
Date: 2017.11.28
Time: 17:29:51
Motor status: 02
System status: Driving mode
Supply voltage: 13.25 V
Temperature: 31.0 °C
KFC: 55
KFA: 00 00
Environmental conditions: 20
uioUdNotFilt_xdu16: 13.31 V
uAdSensI_SwitchedKl30_xdu16: 13.31 V
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 001 0285
Serial number: 30041710801959
Coding: 000000070100094200000940000000000000000000000000000000000000
VCID: 72BC2DA4442AA037773-8026
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0032
Serial number: 0000254048401
Coding: 00100320DE00040000001000
VCID: 46D4A17418226C970BB-8012
Serial number: 00000000000014433559
Coding: 290000
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5QA 035 846 A HW: 5QA 035 846 A
Component: MU-S-N-ER H31 0363
Serial number: SEZAZ2T1106214
Coding: 04738201FF0A00001111000100080A002F0101C401200100C6
ASAM Dataset: EV_MUStd6C3TSAT 001015
ROD: EV_MUStd6C3TSAT_SK25.rod
VCID: 42DCBD64340A50B7273-8016
Subsystem 1 - Part No SW: 5F0 919 606 HW: 5F0 919 606
Component: ABTm-2_8-CR H41 1041
Serial number: SEZ8Z9TJH01SFD
Subsystem 2 - Part No SW: 6P0 919 866 M HW: -----------
Component: ECE1 2017 --- 0730
7226 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Pedestrian assist (0x3A) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 106
Mileage: 10785 km
Date: 2018.04.15
Time: 14:37:42
Voltage terminal 30: 12.1 V
BAP-BAP_Function_ID: 02
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 28041711P11150
Coding: 0303070300000400002213448050A90094000E200020
ROD: EV_MFKBoschMQBB_VW27.rod
VCID: 3B22C08053E0217F645-806E
1275 - Unknown Error Code
B182E F0 [024] - Unknown Error Elaboration
Intermittent - Confirmed - Not Tested Since Memory Clear
Reset counter: 64
Mileage: 6510 km
Date: 2017.11.24
Time: 17:08:22
Control Module temperature: 27 °C
Outside air temperature: 15.0 °C
Vehicle speed: 53.35 km/h
System run time: 872.1 s
Voltage terminal 15: 13.3 V
mid: 01 62
Status of camera: operational
Engine_Running_Info: 1
Software_Info_4: 1
Software_Info_3: 3
Software_Info_2: 2
Software_Info_1: 0
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 7EA409940072F45703B-802A
0774 - Light Bulb for Low Beam
C1198 29 [040] - Signal Implausible
Reset counter: 0
Mileage: 10852 km
Date: 2018.04.17
Time: 17:15:46
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
ROD: EV_LED_PLUS_R_KEBODAVW416.rod
Reset counter: 0
Mileage: 10852 km
Date: 2018.04.17
Time: 17:15:46
End----------(Elapsed Time: 01:34, VBatt start/end: 12.5V/12.4V)-----------
