- Joined
- Aug 10, 2016
- Messages
- 3,759
- Reaction score
- 4,174
- Location
- Netherlands, eastern part
- VCDS Serial number
- C?ID=284912
So, my cute little Polo Bluemotion is perfectly fine except for that it's broken in a very annoying way.
It has decided not to waste anymore energy on power steering. Not the best thing to happen with 215 wide tires. 01288 and 00566 DTCs.
It all started when the fire nation attacked of course. But yesterday, during a normal drive, I suddenly lost power steering on the highway.
No light, no notification, just failed. I pulled over and checked the fuse in the battery compartment for the thick wire and the fuse for Terminal 15. Both were OK.
Switched off the engine and restarted, but no effect. Tested steering angle sensor; static cornering lights were OK. So, the problem was hereby isolated to the power steering pump system.
Today I took some more time to pull off the connectors and inspect them for water ingress. Nothing special to see, no copper green discolouration and verified resistance and voltage with multimeter.
CAN, power, GND, all good. Battery voltage is well above 12V, and engine starts and runs without any hassle. Generator produces a healthy 14.4V as well.
I was able to enter the pump with VCDS and interrogate the advanced measurement values.
+15 was OK but +30 was 1.86V, rather less than the 14.x V measured at the connector.
So I gave both ends of the connector a quick squirt of WD40 and a good wash with a cotton swab.
Did some googling for 01288 and this is mostly pointing to fuses and battery. I connected the wire to a different fuse of 200A and still no regain of function.
--> http://wiki.ross-tech.com/wiki/index.php/01288
So I'm now with my - very muscular- hands in the proverbial hairs (this joke works better in my Dutch mother tongue, forgive me).
scan, the errors in 09 and 55 are due to the headlight being removed for acces to the SA pump.
Saturday,19,May,2018,19:24:43:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
VCDS Version 18.2.0.3 HEX-V2 CB: 0.4411.4
VIN: WVWZZZ6RZBYxxxxx License Plate:
Mileage: Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 44 47 55 56 57
61 69 6C 77
VIN: WVWZZZ6RZBYxxxxx Mileage:
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 907 425
Component: R3 1.2l TDI H06 9980
Revision: 12005001 Serial number:
Coding: 00114036033401080000
ASAM Dataset: EV_ECM12TDI03103P906021B 001043
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 270B06DDAF6FF1FF132-8073
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD4885432500C5841A126EC25500521505
Shop #: WSC 00049 770 00138
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
VCID: 0F7B4E7D27DF89BFFB2-805B
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6RA 959 654 HW: 6RA 959 654
Component: LENKW.SENSOR H02 0020
Serial number: 090465LBH0000C
Coding: 01
ASAM Dataset: EV_LWSKLOVW25X 005002
ROD: EV_LWSKLOVW25X.rod
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Revision: 00092000 Serial number: 0346244897
Coding: 030C0C
ROD: EV_KESSY_PQ35GP.rod
VCID: 372BD69D7FCF617F832-8063
Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3829D5A172516E078A8-806D
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0733
Revision: B9080001 Serial number: 0771 092150183
Coding: 3CB02FF828CB2400933906E2FFEB9FD0808260EF608D78D0B0A050030820
VCID: 688945E162713E87DA8-803D
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 140415 03 37 0059
Coding: 0380DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8611
Serial number: KU0KU011111300010103
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU007111300016463
Coding: 1000AB
Subsystem 4 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K0 951 605 C
Subsystem 6 - Part No: 1K8 951 171 A
Subsystem 7 - Part No SW: 6C0 959 442 C HW: 6C0 959 442 C
Component: E221__MFL-DC1 H04 0103
Serial number: 29160000978830096203
Coding: A80000
Subsystem 8 - Part No SW: 6R0 959 811 B HW: 6R0 959 811 B
Component: J388__TSG_HL 002 0803
Serial number: KU0-KU008.06.0910897
Coding: 08BC32
Subsystem 9 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Serial number: KU0-KU004.06.0913330
Coding: 08BC32
Fault Status: 00101010
Reset counter: 252
Mileage: 69806 km
Date: 2018.05.19
Time: 18:19:22
03645 - Output Module for LED Headlamps; Left
Fault Status: 00101100
Reset counter: 252
Mileage: 69806 km
Date: 2018.05.19
Time: 18:19:46
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231422402620
Coding: 318001
ASAM Dataset: EV_VW75XParkAssis8K 001003
ROD: EV_EPHVA18VW250GPCS_VW25.rod
VCID: 3B23CAAD43E7451F67A-806F
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX0142TCE
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F691C3DEC97ECC-801F
Serial number: 3575HRB40650BI7U48C8
Serial number: 3585HRB405J09RECEOUJ
Serial number: 3515RRB405T0BTBEF9G7
Serial number: 3525RRB405R0BTBEKPFQ
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H04 0709
Coding: 140E01
VCID: 3333E28D6BB78D5FBFA-8067
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuerger‰t f¸r Lenkhilfe: keine Kommunikation]
Reset counter: 252
Mileage: 69806 km
Date: 2018.05.19
Time: 17:58:10
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0733
Revision: B9080001
Coding: 042200
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 040400E200000100000000
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316.rod
VCID: 2E05F3F98095A0B7D04-807B
Component: IMMO H04 0709
Coding: 000007
VCID: 6A8D3FE97CFD0C97CCC-803F
Address 2B: Steer. Col. Lock (J764) Labels:| 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 11000256123005
Coding: 4100000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F3BEEFD879FA9BFDB2-807B
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7666620365
Coding: 010100
VCID: 2B03FAEDB307D59FF7A-807F
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 686 E HW: 1T0 035 686 H
Component: RNS-MID H26 6276
Revision: AB001001 Serial number: VWZ6Z7P1950254
Coding: 00070002010000A10001
VCID: 3635DB9978459877984-8063
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V15 8515
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11221
Shop #: WSC 12345
VCID: 2F3BEEFD8E5FA9BFDB2-807B
00566 - Steering Assistance Operation
27-00 - Implausible Signal
01288 - Terminal 30; Steering Assist
07-00 - Signal too Low
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0000052
ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
ROD: EV_AudioVerst10KanalSTT4.rod
VCID: 280905E1A271FE871A8-807D
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Coding: 0192000001000000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
ROD: EV_HeadlRegulVWLWRPt_VW25.rod
VCID: 77AB169D3F4FA17F432-8023
5276949 - Positioning Motor for Headlight Range Left
C1085 15 [008] - Open or Short to Plus
Reset counter: 252
Mileage: 69806 km
Date: 2018.05.19
Time: 18:19:20
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 57: TV Tuner Labels: None
Part No SW: 3C0 919 148 B HW: 3C0 919 148
Component: R78 DTV-JP 0250
Revision: R0H14000 Serial number: 80100800042102
Coding: 0000816
Shop #: WSC 01324 020 00200
VCID: 280905E1AEF1FE871A8-807D
Subsystem 1 - Part No: 4F0 919 805
Component: R204 TVKLeser 0010
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0733
Coding: 030F1A5A
Subsystem 1 - Part No SW: 6C0 915 181 HW: 6C0 915 181
Component: J367-BDM H08 0223
Serial number: 61083A44504351928092
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0080
Revision: 3A002002 Serial number: 00000116932377
Coding: 0100000100000000
VCID: 2F3BEEFD871FA9BFDB2-807B
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7E0 907 441 HW: 7E0 907 441
Component: J772__Rearview 0040
Revision: 00H08000 Serial number: 525PA8-J060533
Coding: 0030115
VCID: 65974CD5996323EFE1E-8031
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 E HW: 3C8 035 730 E
Component: Telefon 025 0983
Revision: -------- Serial number: 35502105254406
Coding: 020100000100010000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi.rod
VCID: 25170CD5D563E3EF21E-8071
End----------(Elapsed Time: 02:27, VBatt start/end: 14.5V/14.3V)-----------
