Results 1 to 5 of 5
Thread: Audi A6 2018 - modify output audio channel gains - enable development mode
    May 2018
    Slovenia
    I would like to decrease the level of the front center audio channel as it is too loud comparing to front left/right channels.
    Any information in this regard is welcome.
    I also tried to enable development mode on MMI unit but got error "out of range".
    Any hint?
    This is auto scan (MMI):
    VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 15 16 17 19 20 36 3B 42 44 46 52 53 55 5F
              62 6D 72 8F 90 AC
       Part No SW: 4G1 035 043 J    HW: 4G1 035 043 D
       Component: MU-H-N-EU     054 0910
       Serial number: A736C0JS031856
       Coding: 01750101FF0A000013110001000A00002F0006E5F1700100DF
       Shop #: WSC 02391 785 00200
       ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
       VCID: 2516067E456C899F21E-8070
       Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
       Component: ECE 2017/2018  --- 0161
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Serial number: AUZ8Z9JY80AADB
       Multimedia Operating Unit:
       Serial number: 90349RD500081
       Component: Gracenote2  --- 1016
    1637 - Interface for External Media
              U11B8 00 [008] - No Communications
              [USB - communication error]
                        Reset counter: 50
                        Mileage: 41 km
                        Date: 2018.05.08
                        Time: 16:02:34
                        Voltage terminal 30: 13.0 V
                        Interface for external media: status-Status: Measured value not available
    Thank you.
    Dec 2016
    Amsterdam
    Please post a complete auto-scan.
    Enabling developement mode usually requires a different diagnostic mode which VCDS only supports on a few modules. Someone from RT can probably verify this.
    Current:
    May 2018
    Slovenia
    This is complete scan
    Wednesday,16,May,2018,20:39:28:55547
    VIN: WAUZZZ4G5JN109158
              62 6D 72 8F 90 AC
    Address 01: Engine (J623-DDDA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 HA    HW: 04L 907 309 AA
       Component: R4 2.0l TDI   H20 4166
       Revision: 8DH20---
       Coding: 0A254012232401080000
       ASAM Dataset: EV_ECM20TDI01104L906021HA 004005
       ROD: EV_ECM20TDI01104L906021HA_004.rod
       VCID: 6B823046E3087FEFB7A-803E
    Address 02: Auto Trans (J217)       Labels:* None
       Part No SW: 4G1 927 153 G    HW: 0CJ 927 156
       Component: 0CK 20TDI RdW H05 0001
       Revision: --H05---    Serial number: 0000001026
       Coding: 100001
       ASAM Dataset: EV_TCMDL382021 002028
       ROD: EV_TCMDL382021_AU48.rod
       VCID: 2E04F952109ACAC7D04-807A
       Manual Transmission Fluid Pump:
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
       Component: V553 MTFP  003 0576
       Serial number: 75145041180085000604
       Coding: 06A29E41604579829B00
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 41DEB2EEB10445BF3D6-8014
       Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
       Component: BCM2 2.0      H61 0825
       Coding: 01A8700E000000000000
       VCID: 7CA0031A96E6E8572E0-8028
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
       Component: KLIMA 2 ZONEN H14 0113
       Serial number: 11041800110852
       Coding: 34010908210000
       ASAM Dataset: EV_AirCondiBasisUDS 003009
       ROD: EV_AirCondiBasisUDS_003.rod
       VCID: 619E526E11C425BF1D6-8034
       Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
       Component: BCM1 2.0      H20 0368
       Revision: 1502003S    Serial number: 00001960321702
       Coding: 0105C01440349FE0C1014083A0001800CF9CC3082E08020100000494E101140200400024030000
       VCID: 74B02B3ABEB6A017660-8020
       Component: WWS57X 180226  H38 0080
       Serial number:         180305063526
       Coding: 0045F7
       Serial number: 21305132X81A955547A0
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
       Component: E1 - LDS  H07 0044
       Serial number: 12 03 2018  00001374
       Subsystem 4 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
       Component: Humidity_Sens  H02 0007
       Serial number: 8F419B1900PAG0FSA002
       Component: Airbag10.43   H83 0098
       Revision: --------    Serial number: 003P100G64W1
       Coding: 30333130313630323637554A304C34473053
       VCID: 3B22C006D3E82F6F67A-806E
       Serial number: 3575HRB400A5DKL2A8MI
       Serial number: 3585HRB40165DNAKA9OT
       Serial number: 3515JRB40025DPR4EGV/
       Serial number: 3525JRB405D5EP2CDPN+
       Serial number: 3554VRB405V5G08E41GI
       Serial number: 3564VRB40635FQRSNGI0
       Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
       Component: Lenks.Modul   H06 0005
       Revision: C0068538    Serial number: 91560RCJ0001U
       Coding: 000014
       VCID: 3B22C006D3682F6F67A-806E
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Serial number: 03 03 2018  C0005465
       Part No SW: 4G8 920 934 R    HW: 4G8 920 934 R
       Component: TDieRdw       H17 0225
       Revision: 18001312    Serial number: 658050418592003
       Coding: 13A60D000B410008010000
       ASAM Dataset: EV_RBD4K 004060
       ROD: EV_RBD4K.rod
       VCID: 40D8B7EABA0E4CB7328-8014
       Part No SW: 4G8 907 468 K    HW: 4G8 907 468
       Component: J533--Gateway H15 0110
       Revision: --------    Serial number: 00000002932798
       Coding: C0CD074418
       ASAM Dataset: EV_GatewPkoUDS 002011
       ROD: EV_GatewPkoUDS_002.rod
       Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
       Serial number: 1877437304
       Voltage stabilizer:
       Serial number: 18012400000000000061
    Address 20: High Beam Assist. (J844)       Labels: None
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       Coding: 04018264747464545425363E00
       VCID: 678A4C76FF605B8FD32-8032
       Revision: AA000000    Serial number: 00000311376229
       Coding: 0058130000006001000001010101102030303232203232
       VCID: 77AA1C36AFC0CB0F432-8022
       Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA820FGF3A
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3634D132E8CAF207984-8062
       Component: TSG FA        H03 0511
       Coding: 011F16015E00628002080002
       VCID: 47CAACF69FA07B8FF32-8012
       Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
       Component: RCevo         H55 0202
       Revision: 00000001    Serial number: 0000583390
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A2CC502DCD216677CC-806E
       Revision: 00002001    Serial number: 0476962835
       Coding: 011A062080B93080C320088408010E470000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177 B
       Component: Sensor, DWA  005 0002
       Subsystem 2 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
       Serial number: 0000000AP00046752767
       VCID: 46D4A1F298AA6287084-8012
       Part No SW: 4H0 907 801 N    HW: 4H0 907 801 M
       Component: EPB-4         H01 0020
       Revision: --------    Serial number: 00000002482501
       ASAM Dataset: EV_ParkiBrake 001033
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 3332E826FBB8E72FBFA-8066
       Coding: 04FA02102A630200
       VCID: 3430EB3AFEB6E017A60-8060
       Coding: E01E00
       Coding: E01E00
                        Reset counter: 50
                        Mileage: 41 km
                        Date: 2018.05.08
                        Time: 16:02:34
       Component: TSG HL        H03 0511
       Coding: 010F14004000628002080002
       VCID: 49CEAACE89B48DFFE56-801C
       Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
       Component: HDSG-Modul    H02 0049
       Revision: 13002003    Serial number: 080802130
       Coding: 111104C000
       ASAM Dataset: EV_HDSGAu571 001022
       ROD: EV_HDSGAu571.rod
       VCID: 323CED2204A2EE27B4C-8066
       Component: TSG HR        H03 0511
    Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
       Component: RGS-VL        H16 0080
       Coding: 00060000031F030000030801424CDA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313EE22E01A4D53FCD6-8064
    Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
       Component: RGS-VR        H16 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 180800336
       ROD: EV_RDCMA00100_008.rod
       VCID: 2F3AE4561790C3CFDB2-807A
    End----------(Elapsed Time: 01:54, VBatt start/end: 12.1V/12.1V)-----------
    May 2018
    Slovenia
    Anybody knows how to change the level of the audio channels?
    I need to decrease the level of front center audio channel.
    May 2018
    Slovenia
    I simply disconnected the center loudspeaker and now the sound is much better.
