I have an Audi A3 MY2006 and the remote keys not working. I tried to learn them and when I learn 46-10-00 save after 46-10-01 then save 1 and I push the open button the signs flashing but the keys are not working I saw in the MB 011 when I push the open or close button the MB 011- 1 and 3 says "not OK".
S contact is right, door contacts are ok, the keys are for the car (I checked by VIN)
So I do not have more idea.
Thanx for any idea
Thanx for any idea
Wednesday,16,May,2018,20:13:54:34036
VCDS Version: 18.2.0.3
VIN: WAUZZZ8P87A083410 License Plate:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 62 72 76
77 7D
VIN: WAUZZZ8P87A083410 Mileage: 179040km-111250miles
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DH HW: 03G 906 018 DH
Component: R4 2.0l PPD1.2 G 1185
Revision: --H32--- Serial number: AUX7Z0F8FNR0C7
Coding: 0000078
Shop #: WSC 00867 233 67275
VCID: 6E86C625DC9F4A37904-803A
001649 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 006 - Electrical Fault - MIL ON
Fault Status: 11100001
Fault Frequency: 10
Reset counter: 40
Mileage: 177989 km
Date: 2018.05.01
Time: 13:15:18
Torque: 0.0 Nm
0.00 %
Voltage: 11.75 V
Bin. Bits: 00110000
Temperature: 24.0°C
012600 - Intake Manifold Runner Control
P3138 - 006 - Regulation Deviation - Intermittent
Reset counter: 38
Mileage: 179019 km
Date: 2018.05.15
Time: 13:52:55
RPM: 832 /min
Torque: 72.0 Nm
Mass Air / Rev.: 414.2 mg/str
Lambda: -4.7 %
Text: Kein Messwert verfuegbar
Readiness: N/A
Part No SW: 02E 300 043 E HW: 02E 927 770 AE
Component: GSG DSG 070 1153
Revision: 04507000 Serial number: 00000608230651
Shop #: WSC 06314 000 00000
VCID: 1676CEC5848FD2F7B84-8042
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0006786
VCID: 73B0D751B7BD67DF7FA-8026
Part No SW: 8P0 820 043 N HW: 8P0 820 043 N
Component: KlimavollautomatH18 0300
Revision: 122290 Serial number: 8P0820043N
VCID: 37282341E345CBFF832-8062
00483 - Control Module for Auxiliary Air Heater
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 245
Mileage: 177205 km
Date: 2018.04.25
Time: 16:04:53
Reset counter: 24
Mileage: 179044 km
Date: 2018.05.16
Time: 02:29:33
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006221458
Coding: F58A5F019214100000160000160000000008EE175A0500
Shop #: WSC 04653 141 00011
VCID: 40DA489DB68B8C47328-8014
Subsystem 1 - Part No: 8P1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 04653
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Coding: 00150573
Shop #: WSC 04653
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H12 3760
Revision: 91H12376 Serial number: 003620G278NO
Coding: 0071612
VCID: 42DE4295B8879E5724C-8016
Subsystem 1 - Serial number: 6332DRB403E24CAF0
Subsystem 2 - Serial number: 6342DRB403E28E8D3
Subsystem 3 - Serial number: 63528RB401AFEB47%
Subsystem 4 - Serial number: 63628RB401994539L
Subsystem 5 - Serial number: 63729RB401AF440DU
Subsystem 6 - Serial number: 63829RB401AF4436R
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0014142
VCID: 41DC4D99BD81854F3D6-8014
Component: E0221 H07 0090
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 931 HW: 8P0 920 931
Component: KOMBIINSTR. VDO H19 0570
Revision: D0H19003 Serial number: 2248F003040354
Coding: 0000118
Shop #: WSC 80093 222 69422
VCID: 70BAD85DC6AB5CC7828-8024
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 J HW: 1K0 907 951
Component: J533__Gateway H12 0160
Revision: H12 Serial number: 3200106906812E
Coding: 7F3F0FC207002102
VCID: 2E0606251C1F0A37D04-807A
Revision: D0H19003 Serial number: AUX7Z0F8FNR0C7
Shop #: WSC 00137 211 56823
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000248
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.079 H07 1806
VCID: 3432144DF23320E7A60-8060
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 188000186D088505400FC67300
Shop #: WSC 04653 141 00121
VCID: 3C223C6DDA63E8A76E0-8068
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30674696638406
VCID: 71BCDD59CDA155CF8D6-8024
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000248
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Coding: 0000012
VCID: 3D243169C179E1AF59E-8068
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H52 0100
Revision: 02S Serial number: AUZ2Z3F4518337
Coding: 0001065
Shop #: WSC 06435 000 00000
VCID: 323E125508272ED7B4C-8066
Reset counter: 51
Mileage: 178879 km
Date: 2018.05.08
Time: 17:04:54
Bin. Bits: 01
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0070
Coding: 0000216
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0000216
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
Revision: 00H09000 Serial number: 00067824820627
Coding: 0001013
Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
Component: FSE_255x BT H26 0290
Revision: 00000000 Serial number: 00000005026392
Coding: 0001291
VCID: 3B203F71DF6DEF9F67A-806E
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D0401291119712FE9E-8078
014 - Defective
End----(Elapsed Time: 01:30, VBatt start/end: 11.7V/11.9V. VIgn 12.0V)-----
