Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Change behavior of ASC/ESP button?
    Tartu, Estonia
    This is my custom label file created with info from internet. Value 29 would be correct.
    The world is my oyster...
  2. Likes Uwe, localstring liked this post
  3. #12
    Feb 2019
    Thanks for your quick reply! I think I'll try that within the next few days, hoping not to break anything
  4. #13
    Quote Originally Posted by localstring View Post
    Take a full Auto-Scan first, VCDS will save it as a baseline if you need it.
    VCDS also saves a log of every change you make, so you can see what the old and new values were if needed.
  5. Likes Uwe, localstring liked this post
  6. #14
    Feb 2019
    Thank you for your advice. I take a full Auto-Scan every time I change something. So I think it would be possible for me to change things back.
    What I'm really worried about is the fact that a change could potentially cause irreperable damage if I'm not 100% sure that I'm in the right place with Byte 29, Bit 0-3.
    And even if it is the right Byte (it worked on MasterTommy's car with the same ABS module like mine) I believe there are different circumstances on each car and there may be situations where things don't behave as expected.
    For example, isn't it fundamentally different when ESP settings are set via the menu than via a button?
    Sorry guys, maybe I'm just way too scared
  7. #15
    I've changed the setting on my Octavia exactly as you are asking and all is working perfectly. No damage
    AFAIK the button is just a shortcut to avoid the hassle of having to use the menus - I don't have a button (but intend to retrofit one) so I have to use the menus.
  8. Likes Uwe, localstring liked this post
  9. #16
    Feb 2019
    Hi! I have 3.0tdi allroad A6 2010 model. ESP button is single step. I would like to change it to two step.
    Current coding is 0033164
    edit. 4f facelift also has the inner long light disabled with xenon light unless you hold the long light switch. Is it possbile to code these to work as normal long lights? it is possible with relay.
    Monday,11,February,2019,18:15:08:35041
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
    VIN: WAUZZZ4F8AN075336   License Plate:
    Chassis Type: 4F-AU56 (4F0)
    Scan: 01 02 03 05 08 09 15 16 17 18 19 34 3C 42 46 47 4C 4F 52 53
              55 56 5F 62 69 72 76
    VIN: WAUZZZ4F8AN075336   Mileage: 230390km-143157miles
    Address 01: Engine (CDY)       Labels: Redir Fail!
       Part No SW: 4F9 910 402 A    HW: 4F0 907 401 E
       Component: 3.0TDI EDC17G000AG  0080
       Revision: 16H03---    Serial number:
       Coding: 0125002C191F0128
       Shop #: WSC 83968 425 739974
       VCID: 24040495E7531E6A99-8070
    001682 - Fan 1 Control Circuit
                   P0692 - 000 - Short to Plus
                        Fault Frequency: 16
                        Mileage: 229893 km
                        Date: 2019.02.09
                        Time: 15:36:49
                        Temperature: 18.9°C
                        Mass Air / Rev.: 1192.6 mg/str
                        Duty Cycle: 95.5 %
                        Temperature: 112.1°C
    001650 - Cylinder 2 Glow Plug Circuit (Q11)
                   P0672 - 000 - Electrical Fault
                        Mileage: 230197 km
                        Date: 2019.02.11
                        Time: 04:36:24
                        RPM: 819 /min
                        Voltage: 12.16 V
                        Temperature: 22.5°C
                        Lambda: 21.1 %
                        Temperature: 8.1°C
    001651 - Cylinder 3 Glow Plug Circuit (Q12)
                   P0673 - 000 - Electrical Fault
                        Mileage: 230197 km
                        Date: 2019.02.11
                        Time: 04:36:24
                        RPM: 819 /min
                        Voltage: 12.16 V
                        Temperature: 22.5°C
                        Lambda: 21.1 %
                        Temperature: 8.1°C
       Part No SW: 4F2 910 156 R    HW: 09L 927 156 C
       Component: AG6 09L 3,0 TDI RdW 0040
       Revision: --H05---    Serial number:        4562627
       Coding: 0000001
       Shop #: WSC 02325 785 00200
       VCID: 3424F4D557B38EEA09-8060
    Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
       Part No SW: 4F0 910 517 AM    HW: 4F0 614 517 BD
       Component: ESP8 quattro    H03 0100
       Coding: 0033164
       VCID: 6FAE3BB97E15ED3234-803A
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
       Component: FBSAUDIC6 ELV   H05 0100
       Revision: 00H05000    Serial number: 10602601551044
       Coding: 0000131
       Shop #: WSC 24569 001 1048576
       VCID: 25021991EC69E7628E-8070
       Subsystem 1 - Part No: 4F0 910 132 E
       Component: FBSAUDIC6 EZS   H03 0020
       Subsystem 2 - Part No: 4F0 910 220 K
       Component: FBSAUDIC6 IDG   H01 0053
    Address 08: Auto HVAC        Labels: 4F0-910-043.clb
       Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
       Component: KLIMABETAETIGUNGH30 0080
       Revision: 00000076    Serial number: 00000000695480
       Coding: 0006422
       VCID: 1D723171C4392FA2D6-8048
    00003 - Control Module
                        Fault Status: 00100011
                        Mileage: 202987 km
                        Date: 2018.02.13
                        Time: 06:47:45
                        Temperature: 8.0°C
                        Fault Status: 00101010
                        Reset counter: 99
                        Mileage: 229717 km
                        Date: 2019.01.22
                        Time: 11:41:58
                        Temperature: 22.0°C
       Part No SW: 4F0 910 279 N    HW: 4F0 907 279
       Component: ILM Fahrer      H22 0320
       Coding: 0013121
       Shop #: WSC 02335 785 00200
       Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H10 0040
       Coding: 00056595
       Shop #: WSC 02335
       Coding: 00146221
       Shop #: WSC 02335
    Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
       Part No SW: 4F0 910 655 Q    HW: 4F0 959 655 G
       Component: Airbag AU1042 H07 0200
       Revision: --------    Serial number: 003F9002NJE%
       Coding: 30314236303630303032554A304C34463053
       Shop #: WSC 02323 785 00200
       ROD: EV_Airba10AURB4.rod
       VCID: 3522C9D194C997E23E-8060
       Serial number: 3574SRB40000B04C9A7D
       Serial number: 3584SRB40000B0413A2Z
       Serial number: 3516HRB401RCB77N3SO2
       Serial number: 3526HRB402TD0ORB041E
       Serial number: 3554NRB40000573032CS
       Serial number: 3564NRB400005734A51W
       Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
       Component: J0527               0530
       Revision: 00H05000    Serial number: 90026100790036
       Coding: 0002042
       VCID: 271E13999665F572BC-8072
       Component: E0221           H02 0100
    Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
       Part No SW: 4F0 920 933 Q    HW: 4F0 920 933 Q
       Component: KOMBIINSTR.   H08 0147
       Revision: 00300000    Serial number: DHK00DK3A
       Coding: 03566A0303010008000000
       Shop #: WSC 02391 823 56573
       VCID: 3522C9D19CC997E23E-8060
       Part No SW: 4F0 910 105 A    HW: 4F0 265 081 AA
       Component: Heizgeraet      H08 0100
       Revision:        B    Serial number: 09018641
       Coding: 0000111
       Shop #: WSC 02145 785 00200
       VCID: 1B763F69DA2D219228-804E
    01406 - No Flame
                000 -  -  - Intermittent
                        Reset counter: 99
                        Mileage: 229715 km
                        Date: 2019.01.21
                        Time: 11:57:29
                            Start
                        Temperature: 24.0°C
                        Temperature: -48.0°C
       Part No SW: 4F0 907 468 N    HW: 4F0 907 468 G
       Component: GW-BEM 5CAN-M H06 0035
       Revision: MB200030    Serial number: 3000M10311808C
       Coding: 000303
       VCID: 3A38DAEDB5D7789AD3-806E
       Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790146483
                        Fault Frequency: 22
                        Reset counter: 99
                        Mileage: 228102 km
                        Date: 2018.12.13
                        Time: 08:27:32
                        Bin. Bits:    00000
                        Voltage: 11.60 V
                        Count: 11
    Address 34: Level Control        Labels: 4F0-910-553.clb
       Part No SW: 4F0 910 553 D    HW: 4F0 907 553 A
       Component: J197 LUFTFEDER  H17 0030
       Serial number: 00872000835600
       Coding: 0000220
    Address 3C: Lane Change        Labels: None
       Part No SW: 4L0 910 566 D    HW: 4L0 907 566 B
       Component: J0769_SWA_MasterH01 0020
       Revision: 00H01000    Serial number: 6PZ 009 014-15
       Coding: 0000104
       VCID: 2F2EFBB9BE95AD3274-807A
       Subsystem 1 - Part No: 4L0 910 568 D
       Component: J0770_SWA_Slave_H01 0020
       Subsystem 2 - Serial number: 6PZ 009 014-35
       Subsystem 3 - Serial number: 5F22.03.1000H010003CN12489’
       Subsystem 4 - Serial number: N12489’
       Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
       Revision:             Serial number: 0000103332440
       Coding: 011F02205040410003
       VCID: 46C0BE1DF12F0C7AA7-8012
                        Fault Status: 00101100
                        Reset counter: 74
                        Mileage: 228757 km
                        Date: 2018.12.29
                        Time: 14:43:38
    Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
       Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
       Component: Komfortgeraet   H29 0250
       Revision: 02500029    Serial number: 01283640830000
       Coding: 0402053
       VCID: 3522C9D15CC997E23E-8060
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
       Component: BOSE G3 C6    H01 0100
       Revision: AG001300    Serial number: 00000000075526
       Coding: 0D010000
       VCID: 291A15A14071C302AA-807C
    Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
       Part No SW: 4F0 910 274 B    HW: 4F0 907 274
       Component: J793  RKA+      H02 0110
       Revision: 00000815    Serial number: 00008150116855
       Coding: 0623569
       VCID: 23060789E25D1952E0-8076
       Part No SW: 4F0 910 280     HW: 4F0 907 280 C
       Component: ILM Beifahrer   H13 0100
       Revision:             Serial number: 00000000634875
       Coding: 0001013
       VCID: 5EF0767D89BF74BA8F-800A
       Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
       Revision:             Serial number: 0000103277188
       VCID: 45C2B911CC290762AE-8010
                        Fault Status: 01101100
                        Reset counter: 72
                        Mileage: 206635 km
                        Date: 2018.04.08
                        Time: 21:43:42
       Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
       Component: EPB  CEFC0090   H05 0090
       Revision: --H05---
       Coding: 0000321
       VCID: 210A0D81F8410B42F2-8074
       Part No: 8P0 907 357 H
       Component: Dynamische LWR  H02 0010
       Coding: 0000004
       VCID: 3FCEABF96EF55DB2E4-806A
       Part No SW: 4F0 035 053 B    HW: 4F0 035 053
       Component: Radio U Basic H45 0020
       Revision: AB001007    Serial number: 341CQ0A7721265
       Coding: 010003010000000000
       VCID: 1C743C751F2326AA21-8048
       Part No SW: 4E0 035 652 A    HW: 4E0 035 652
       Component: B-BN-EU       H56 0048
       Revision: --------    Serial number: 349C60A7537959
       Coding: 010100050002F3ED11000305EF6300030001
       VCID: 1F0E0B790E353DB2C4-804A
       Subsystem 1 - Part No: 4G0 919 884 F
       Component: EUR 2010  1005
       Subsystem 2 - Part No SW: 4L0 919 604     HW: 4L0 919 604
       Component: DU6 Basic  H43 0306
       Serial number: 9355CK0A1100935
       Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 M
       Component: Bedienteil MM  H01 0060
       Serial number: 00000001546455
                        Fault Frequency: 28
                        Reset counter: 99
                        Mileage: 228203 km
                        Date: 2018.12.13
                        Time: 18:08:45
                        Voltage: 14.40 V
    03606 - Antenna for Telphone Base-Plate
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Fault Frequency: 6
                        Reset counter: 72
                        Mileage: 230227 km
                        Date: 2019.02.11
                        Time: 05:15:44
                        Voltage: 14.00 V
       Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
       Revision:             Serial number: 0000010273387
       Coding: 010E00204040220003
       VCID: 43C6A709C21D395280-8016
    Address 69: Trailer        Labels:. 4F0-907-383.clb
       Part No SW: 4F0 907 383 D    HW: 4F0 907 383 D
       Component: ECS - TOWBAR MODULE 0404
       Coding: 0000001
       VCID: 2C14ECB58F83D62A51-8078
       Revision:             Serial number: 0000010275467
       Part No SW: 4L0 910 283 C    HW: 4L0 919 283 C
       Component: Parkhilfe 8-Kan H02 0500
       Revision: 00H02000    Serial number: 12621008800451
       Coding: 0201416
       VCID: 2A18EAAD8577C81AA3-807E
    01548 - Sensor for Parking Aid; Rear Right (G206)
                        Fault Status: 00101001
                        Reset counter: 99
                        Mileage: 229247 km
                        Date: 2019.01.11
                        Time: 17:16:04
    End----------(Elapsed Time: 02:00, VBatt start/end: 12.2V/12.2V)-----------
  10. #17
    Feb 2019
    Ok, first of all I wanna say thank you so much to you guys helping me out
    I just tried it a minute ago and it works like a charm! I'm so happy now
    I just saw that the Front Assist has also been disabled when setting ASR off. I assumed this was only the case with ESP Sport or ESP Off. But it looks like the ASR is behaving the same way.
    However, do you think there is a way to have ASR and Front Assist on at the same time? I can't imagine exactly for what the Front Assist needs the ASR.
  11. #18
    I noticed the same - on asking other owners the conclusion was that with ASR off the calculations used by Front Assist might be invalid so to avoid possible legal issues VAG disable Front Assist when ASR is off.
    Personally I've always found Front Assist far to willing to "cry wolf" so having it disabled doesn't bother me - every time it's alarmed I've said "WTF there's no need for that"!!!
  12. Likes Uwe liked this post
  13. #19
    Dec 2016
    Amsterdam
    Thats the pre-warning, you can turn that off in the car settings in the infotainment (stays off after a key-cycle). Front assist will still be on but at least you wont get that annoying warning that feels like you just avoided certain death when you just passed too close to a bush.
    Current:
  14. Likes Uwe, PetrolDave liked this post
