Results 1 to 10 of 19
Thread: Change behavior of ASC/ESP button?
    Dec 2016
    Amsterdam
    I'm usually in the habit of asking stuff that results in a 'not possible' answer, but here it goes;
    On certain golf 7's (pre-facelift), it seems to be possible to change the ASR/ESP button behavior through changing a bit in the ABS module. Stock seems to be ASR off (short press) and ESP sport (long press). It can be recoded to ASR off/ESP off (which seems to be stock on a Golf R?), ESP sport/ESP off and probably a dozen other styles.
    Anyway, this involves changing Byte 29 in de ABS controller (last byte). I was having a look at my ABS controller as I'm getting pretty fed up with the overactive ESP (as inn: I'd like to turn it off and have some fun every now and then. I've got the power to match anyway). Unfortunately, the ABS controller in my car seems to have 46 bytes, and byte 29 has hex value 'AA' (where golf 7’s have 09). Not something I'm going to touch.
    Does anyone have an idea if this is possible, more in-depth knowledge of the coding of these modules and/or a Golf 7 R facelift autoscan?
    ABS module:
    Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
    Component: ESC H25 0513
    Revision: 00000000 Serial number: 62057000001070
    Coding: 0AEE6B9A54220B744779070762C66950D62AD0E2E046967DB8 625088C2AA4200002F641A1B13111435351919323200
    ROD: EV_Brake1UDSContiMK100IPB_036.rod
    VCID: 77BE26B1CE6DD1FD84-8022
    Autoscan:
    Sunday,04,February,2018,03:55:42:41109
    VCDS Version: 18.1.0.2 (x64)  HEX-NET CB: 0.4411.4
    VIN: WVGZZZ5NZJW123456   License Plate:
    Mileage: 17976km-11169mi   Repair Order:
    Chassis Type: 5N-VW37 (3Q0)
    Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 3C
              42 44 47 4B 52 5F 65 69 6C 6D 75 82 A5 BB BC CA CF D6 D7
    VIN: WVGZZZ5NZJW123456   Mileage: 17976km-11169miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CUAA)       Labels:. 03N-906-026-CUA.clb
       Part No SW: 03N 906 026 D    HW: 03N 907 309
       Component: R4 2.0l BTD   X24 3680
       Revision: A1X24---
       Coding: 01250032047605083000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM20BTD01103N906026D 004005
       ROD: EV_ECM20BTD011.rod
       VCID: 2C14C9DD47ABA22539-8078
    Readiness: 1110 1011
       Part No SW: 0DL 300 011 M    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 2001
       Revision: 00H06V07
       VCID: 3228D7A5658FF4D573-8066
       Coding: 0AEE6B9A54220B744779070762C66950D62AD0E2E046967DB8625088C2AA4200002F641A1B13111435351919323200
       Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
       Component: VWKESSYMQB    037 0906
       Revision: 00037000    Serial number: 0451329535
       Coding: 132C2C0723
       ROD: EV_KessyHellaMQBAB.rod
       VCID: 3E30F395A1D720B587-806A
       Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
       Component: GEB.F.Heckoef  H17 0903
       Serial number: 98226912
    Address 06: Seat Mem. Pass (J521)       Labels:* None
       Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
       Component: Sitzmemory    H08 0022
       Serial number: Y0006QGM20164
       Coding: 001000020000050081C281808181000000008181000000F400
       ASAM Dataset: EV_SeatMemorPasseSide 002022
       ROD: EV_SeatMemorPasseSide_VW37.rod
       VCID: 3C34F99DB7CB32A5A9-8068
       Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
       Component: AC Automat    H35 4301
       Revision: 20K08000    Serial number: 00000B00605887
       Coding: 0002012420241001110510420010112A
       ASAM Dataset: EV_ACClimaPrehVW37X 002023
       ROD: EV_ACClimaPrehVW37X_002_VW37.rod
       VCID: 4AD8AF45ED1F9C152B-801E
       Subsystem 2 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
       Component: E265KlimaHeck  H02 0201
       Serial number:       04031501850571
    1048835 - Functionality limited due to Engine Control Module
              P1719 00 [008] - -
              [PTC-Reduzierung durch MSG]
                        Reset counter: 200
                        Mileage: 17976 km
                        Date: 2018.02.04
                        Time: 03:53:28
                        Voltage terminal 30: 14.2 V
                        Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                        Auxiliary heater: in stages-Act.val.: 2
                        Auxiliary heater: in stages-Specified value for control: 3
       Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
       Component: BCM MQBAB H   H36 0253
       Serial number: 01001721700533
       ROD: EV_BCMBOSCH_018.rod
       VCID: 095A5049A899D70DE2-805C
       Subsystem 1 - Part No SW: 5NB 955 119     HW: 5NB 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 170630  033 0372
       Serial number: 00000001706280300593
       Component: RLHS  042 0105
       Serial number: S8Y17M08D14H01M31S46
       Coding: 00A8EE
       Serial number: 000000000ZY1718333XN
       Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
       Serial number: 00002856223971734394
       Part No SW: 3Q0 919 298 B    HW: 3Q0 919 298
       Component: PLA 3.0 12K   H09 0029
       Serial number: 001607177478001
       Coding: 0A31667A51
       ASAM Dataset: EV_EPHBO2CVW3260000 010016
       ROD: EV_EPHBO2CVW3260000.rod
       Coding: 320167CB5CFF8728749C8145804087
       Serial number: 12071741350391
       ROD: EV_DRCONTITEMIC_VW27.rod
       VCID: 383CE58D83F31E854D-806C
       Part No SW: 5Q0 959 655 BK    HW: 5Q0 959 655 BK
       Component: AirbagVW21    005 0336
       Serial number: 003VXR33ZYC9
       Coding: 98FCC0C00C8000005C5400CF004800000065
       VCID: 0A586F45AD9FDC15EB-805E
       Belt Pretensioner left:
       Serial number: 5NB857705C0216R00777
       Coding: 80000D
       Belt Pretensioner right:
       Serial number: 5NB857706C0217R00515
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 000 808 17
       Serial number: 35700000000B2B19A62O
       Subsystem 4 - Part No SW: -----------    HW: 480 000 808 17
       Serial number: 35800000000156842728
       Subsystem 5 - Part No SW: -----------    HW: 480 400 208 17
       Serial number: 3510001BB260B4F1B4BB
       Subsystem 6 - Part No SW: -----------    HW: 480 402 807 17
       Serial number: 3520001A524CDB11F48B
       Subsystem 7 - Part No SW: -----------    HW: 480 402 907 17
       Serial number: 3550001C322EA2B5730%
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 480 402 907 17
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001B526D7C0386BB
       Subsystem 9 - Part No SW: -----------    HW: 480 402 907 17
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001B526D7C0475EE
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 480 402 907 17
       Component: PedP_Sensor_C  000 6149
       Serial number: 2300001B526D7C04615Z
       Subsystem 11 - Part No SW: -----------    HW: 480 002 707 17
       Serial number: I0M00000000D91C0252+
       Subsystem 12 - Part No SW: -----------    HW: 480 002 707 17
       Serial number: I0N000000002A1C0252W
       Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
       Revision: FF034034    Serial number: 20170802501343
       Coding: 0C10
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 73A612A1DA15BDDDB8-8026
       Part No SW: 5NA 920 791 B    HW: 5NA 920 791 B
       Component: KOMBI         407 3193
       Coding: 07A400987E8C000801887B0F3401000880000000
       VCID: 42C88765D52F4455E3-8016
       Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5304
       Serial number: 23071710800155
       Coding: 0B0500344F017300FB07225E9E0F00010001070000000000000000000000
       ROD: EV_GatewNF_VW27.rod
       VCID: 3326D2A19A95FDDD78-8066
       Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0040
       Serial number: 29170001574160027313
       Coding: 2DFFFF
       Subsystem 3 - Part No SW: 5QA 915 181 E    HW: 5QA 915 181 E
       Serial number: 4480423804
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 5Q0 907 155 F    HW: 5Q0 907 155 F
       Component: U13DCAC  H25 0780
       Serial number: 0024537
       Serial number: HA1-00020.06.17
       Coding: 0101
    Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH08 0014
       VCID: 45C29C79C401736DC6-8010
       Serial number: 17000199457001
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71AA18A9A0098FCD4A-8024
    Address 36: Seat Mem. Drvr (J810)       Labels:* None
       Serial number: Y0006QGM20144
       Coding: 001000020000150001C281808181000000008181000000F400
       ASAM Dataset: EV_SeatMemorDriveSide 002021
       ROD: EV_SeatMemorDriveSide_002_VW48.rod
    Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
       Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
       Component: MRR1Rear      H20 0510
       Revision: --------
       Coding: 14C002
       VCID: 3A38FF85BDFF0C95BB-806E
       Serial number: 080717EG809145
       Coding: 003F1B20D200048000001000
       VCID: 43C68261CA354D5DE8-8016
       Part No SW: 5QF 909 144     HW: 5QF 909 144 _
       Component: EPS_MQB_ZFLS  506 5572
       Coding: 9307
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 075E5671BE8DA17DF4-8052
    Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
       Part No SW: 3Q0 035 465     HW: 3Q0 035 465
       Component: MIB2_amp_P_VW H60 0440
       Revision: 00000001    Serial number: VWZ8Z1HJD00TYB7
       Coding: 1223060001A00A2AAA0000000000
       ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
       ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
       VCID: 6B960AC18225651D70-803E
    Address 4B: Multifunc. Module (J745)       Labels:* None
       Part No SW: 3Q0 907 338     HW: 3Q0 907 338
       Component: FCM MQB Low   002 0286
       Serial number: 21071710803739
       Coding: 000000050100085207104F010A0000000000000000000000000000000000
       ROD: EV_MultiModulContiVW48X.rod
       VCID: 72A817A5A50FB4D5B3-8026
       Serial number: 070717EG609369
       Coding: 003F1120DE00048000001000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 5NA 035 022 A    HW: 5NA 035 022
       Component: MU-H-LND-EU   H54 1121
       Serial number: A846G0HS006021
       Coding: 02730601000000005111010200880A331F0106E401200400DE
       VCID: 312AD8A96089CFCD0A-8064
       Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
       Component: ABT_High-2  H50 9130
       Serial number: VWZ6ZJT2116065
       Subsystem 2 - Part No SW: V03 959 800 QR    HW: -----------
       Component: ECE 2017/2018  --- 0161
       Component: Gracenote2  --- 1016
       Serial number: 30000000098730
       ROD: EV_RDKBERU30_006_VW37.rod
       VCID: 3424D1BD9F9BFAE561-8060
       Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
       Component: Anhaenger     H27 0264
       Revision: 8A001003    Serial number: 0449274529
       Coding: 0100000202000000
       Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
       Component: Areaview 2    H13 0608
       Serial number: C854707JG016316
       Coding: 01230600A30F200000204814
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
       ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
       VCID: 393AE089B8F9078DB2-806C
       Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0261
       Revision: --------    Serial number: 31450492700000
       Coding: 0AA8
       Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
       Component: OCULowMQBLGE  H17 0717
       Revision: --------
       Coding: 02230601EA42380D3F1CBE020045400382E608
       ASAM Dataset: EV_OCULowMQBLGE 004044
       ROD: EV_OCULowMQBLGE_004_VW27.rod
    Address 82: Heads Up Display (J898)       Labels:* None
       Part No SW: 5NA 919 608 B    HW: 5NA 919 608 B
       Component: HeadupDisplay 023 0302
       Coding: 574060
       ASAM Dataset: EV_HeadUpDisplContiVW481 001015
       ROD: EV_HeadUpDisplContiVW481.rod
       VCID: 47DE9671FE0D617D34-8012
       Component: MQB_B_MFK     H08 0272
       Serial number: 29071712K20584
       Coding: 000307060000040100262347C150A90098000E200040
       ROD: EV_MFKBoschMQBB_VW27.rod
       Serial number: 120717EG908013
       Coding: 002A11200101048000001000
       Serial number: 190617EFJ09168
       Coding: 208040732602
       ROD: EV_SunRoofCONTIAU736.rod
       VCID: 3D32F499ACD13BAD9E-8068
       Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
       Revision: --------
       Coding: 14C002
       ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
       VCID: 373EE6B18EED11FD44-8062
       Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
       Component: LED1L         H09 0003
       VCID: 16600B35E92708F57F-8042
       Component: LED1R         H09 0003
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
    End----------(Elapsed Time: 02:37, VBatt start/end: 14.4V/14.4V)-----------
    Current:
    Moving to Tweaks.
    Tartu, Estonia
    It would become A8 or A6 to have ESP Off in Your options.
    PS! Know Your legal requirements before this MOD.
    The world is my oyster...
  4. Likes MasterTommy, NEtech liked this post
    Dec 2016
    Amsterdam
    Thanks! Mind if I ask how you got detailed coding info? It looks to me like you're manually using Lcode with a different label file?
    For the record, current coding value results in ESC On/ASR Off/ESC Sport. Same as 09 in your drop-down menu.
    They're pretty easy as an end-user here since you have a light-version of rules to conform to as opposed to typerating the manufacturers go through.
    Current:
    Dec 2016
    Amsterdam
    Changed byte 29 to A8, and that worked! Going to try A6 too tomorrow just for posterity.
    Current:
  7. Likes Uwe liked this post
    Dec 2016
    Amsterdam
    So, 'tomorrow' turned into somewhere yesterday. Did want to give this a follow-up though.
    #8 and #6 have the same coding description and give the same button set-up. However, #8 seems to be a solution for that one guy who wants his screen to say 'ESP Off' but we all know you don't want to send that guy out with the ESP actually being off. Ergo, yet again ESP gets a little less strict when you supposedly turned it off, but it's not really.
    #6, well let's say I havent seen a Tiguan smoke all 4 wheels in the first three gears until yesterday.
    I'm going to do some more driving around to verify the differences, since time-for-some-fun-with-nobody-else-around situations don't present themselves every drive, but there definitely is a difference between these two settings.
    Current:
  9. Likes PetrolDave liked this post
  10. #7
    Dec 2016
    DE
    Golf 6 and Golf 7 are nothing alike so please don’t use a modified coding from this site on a Golf 7.
  11. Likes Uwe liked this post
  12. #8
    Dec 2016
    Amsterdam
    I get that, which is why first thing I tested if those bits affect the button behaviour in my car. They do, and they do exactly like the bit description in the screenshot. Which for me is enough to (very carefully) push the throttle with one eye closed sitting halfway on the seat and halfway out the car in case it explodes changing this completely untested coding change.
    Current:
  13. #9
    Dec 2016
    DE
    I don‘t understand your sarcasm, sorry.
  14. #10
    Feb 2019
    since I didn't want to start a new topic for this, I will ask my question here really hoping to get an answer from someone familiar with it.
    I own a Seat Leon FR 1.8 5F Facelift and I have the same ABS Module (47 Bytes) as MasterTommy:
    Adresse 03: Bremsenelektronik (J104)       Labeldatei: 5Q0-907-379-IPB-V1.clb
       Teilenummer SW: 5Q0 614 517 CF    HW: 5Q0 614 517 AD
       Bauteil: ESC           H25 0513
       Revision: 00000000    Seriennummer: 60657000002378
       Codierung: 20EE6A92342521708780060140CC2804562C84E16002147518425074C223430000000012121212B835351919323200
       Betriebsnr.: WSC 00049 770 00102
       ASAM Datensatz: EV_Brake1UDSContiMK100IPB 036010
       VCID: 77AA1D386F4116CFAFF-8022
    Even in combination with the corresponding .clb file my Coding looks like this, so I have no clue if I'm in the right place.
    I would like to have "ESC Activated / ASR off / ESC Sport" in my options in ESP Multimedia Menu.
    I assume that I have to change the value to "29". But I'm not sure, and I really don't want to break anything.
    Since it worked on MasterTommy's Golf 7 R with the exact same ABS module, can I assume it's gonna work on my Leon, too? The only difference is that the Golf has a button for the ESP, while on my car the setting is changed on the Multimedia Menu.
    I would really really appreciate if someone could help me on this.
    Btw: May I ask, golfi_vend where did you get the Label file from?
