Results 1 to 4 of 4
Thread: Q7 4M - Reverse Camera 'Low Line' Retrofit Doesnt show image when selecting reverse
    Mar 2016
    Hi Guys
    I've just retrofitted a rear camara "low line" (so no Extended CAN) into a 2016 Q7 4M. This is just power/ground/12v trigger then 2 wires from the camera into the back of the MIB2 5F module.
    While everything is working, the camera doesn't automatically appear when put in reverse gear. I have to switch the parking sensor button off and on and then the image appears. No errors / DTCS in VCDS. I enabled Low Line camera in 5F Byte 35 / Bit 4 and I've wired in the 12v trigger on the reverse gear
    Funny thing is, once you press the parking sensor button on the dash off and on and the video signal displays on the MMI, if you take the car out of reverse and drive forward then put it back into reverse the image then automatically appears as expected. Only the first time after the engine/electrics are off it doesnt.
    Any help would be appreciated. I scoured Modules 09/46/5F but to no avail.
    Andy
    Link to video showing issue: LINK
    Thursday,10,May,2018,14:41:50:50897
    VCDS Version: 18.2.0.3  HEX-NET CB: 0.4422.4
    VIN:    License Plate:
    Mileage: 18163km-11285mi   Repair Order:
    Chassis Type: 4M-AU73 (8W7)
    Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 2B 36 39 42 44 46 50
              52 5F 69 6D 74 81 82 8B A5 AC BB BC CA D6 D7
    VIN:    Mileage: 18163km-11285miles
    50-Seat Adj. 3rd row -- Status: OK 0000
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
       Part No SW: 4M0 907 401     HW: 059 907 309 B
       Component: 3,0TDI EDC17  H46 0005
       Revision: 91H46---
       Coding: 2A2A4032037E050335080000000000000000000000000000
       Shop #: WSC 41360 002 1048576
       ASAM Dataset: EV_ECM30TDI0114M0907401 001009
       ROD: EV_ECM30TDI0114M0907401.rod
       VCID: 66807A9599A11C7482-8032
    Address 02: Auto Trans        Labels:| 0BK-927-156.clb
       Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
       Component: 0D5  30TDIRdW H05 1013
       Revision: --H05---
       Coding: 100000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011.rod
       VCID: 3B36FBE1B2A3719C0D-806E
    Address 03: ABS Brakes (J104)       Labels:. 4M0-907-379-PRE-V1.clb
       Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
       Component: ESP9 Premium  H09 0657
       Coding: 249830B230A50A9DD1A05898187F52AAE6A6D2240C0C508B1A184A5567654B
       ASAM Dataset: EV_ESP9BOSCHAU536K 012013
       ROD: EV_ESP9BOSCHAU536K.rod
       VCID: 45C29D19C467376C6B-8010
       Part No SW: 4M1 959 760 E    HW: 4M1 959 760 E
       Component: MEM-BFS       008 0031
       Serial number: 00000231708975
       Coding: 003030000000B2410000010101010000110000313100000000000000000000
       ROD: EV_SCMPasseSideCONTIAU736.rod
       Part No SW: 4M0 820 043 AD    HW: 4M0 820 043 AD
       Component: Klima Zone 4  H52 0093
       Coding: 6618083D5544451102220280800000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
       ROD: EV_AirCondiFrontBHTCAU736.rod
       VCID: 679E77919EAB057CB9-8032
       Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
       Component: J216 FLuftV  H05 0003
       Serial number: 00000000000001206388
       Serial number: 9D09C06880PAG0MUFU02
       Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0266
       Coding: 07501943E17900CD050D57185BBF80F9130331009000000000000000A00016810A45013B125601
       VCID: 0248460595C9C0540E-8056
       Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C  Labels: 1KX-955-119.CLB
       Component: WWS536 160926  043 0893
       Serial number: 89565300401627000410
       Coding: 1BC7F7
       Serial number: 20051979X81A955547A0
       Coding: 02006E
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
       Component: E1 - LDS  H06 0008
       Serial number: 04 07 2016  00563031
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE113091611521371
       Coding: 230000
       Interior Light Module:
       Subsystem 5 - Part No SW: 4M0 947 135 CK    HW: 4M0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: Q00234916
       Subsystem 6 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
       Component: SL-Q7NF/AU736  H10 0013
       Serial number: 00000000000000043281
       Part No SW: 4M0 907 561 E    HW: 4M0 907 561
       Component: LRR4          H10 0220
       Coding: 3473FFEA58FFEC0A949880A0
       ASAM Dataset: EV_ACCBOSCHAU736 002018
       ROD: EV_ACCBOSCHAU49X_002.rod
       VCID: 3228D6C565E9B0D4DE-8066
       Part No SW: 4M0 959 655 E    HW: 4M0 959 655 E
       Component: Airbag10.44   H01 0103
       Serial number: 003UL0007F2Z
       Coding: AACCF0D80C80000098F650F3D0CC00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 005013
       ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
       VCID: 3D32F5F9ACB77FAC33-8068
       Subsystem 1 - Part No SW: -----------    HW: 442 062 311 16
       Serial number: 3577Y00C7209FF91D3CP
       Subsystem 2 - Part No SW: -----------    HW: 442 062 311 16
       Serial number: 3587Y00AD2093B71F278
       Subsystem 3 - Part No SW: -----------    HW: 442 0B2 611 16
       Serial number: 35177000429E291536B3
       Subsystem 4 - Part No SW: -----------    HW: 442 0B2 611 16
       Serial number: 35277001029E0847583%
       Subsystem 5 - Part No SW: -----------    HW: 442 0C2 811 16
       Serial number: 3557500AB21CC873E30M
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 442 0C2 811 16
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500AB21CC872F1DY
       Pedestrian Protection Center:
       Subsystem 7 - Part No SW: -----------    HW: 442 0C2 811 16
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500A522355F3D14%
       Subsystem 8 - Part No SW: -----------    HW: 442 421 711 16
       Component: PedPSensor_D2  21E 0887
       Serial number: I0M8U00C52093B72738I
       Subsystem 9 - Part No SW: -----------    HW: 442 421 711 16
       Component: PedPSensor_P2  21E 0887
       Serial number: I0N8U00C52093B73B52K
       Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 014A490990CFDB4C17-8054
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 4M0 920 790 B    HW: 4M0 920 790 B
       Component: FBenRDW       H16 0306
       Coding: 248400D07C80060001A3E9603000600000000000
       ASAM Dataset: EV_DashBoardAU736 001022
       VCID: 2E10C2B571D19434BA-807A
       Part No SW: 8W7 907 468 D    HW: 8W7 907 468 C
       Component: Gateway       H30 0309
       Revision: 5C010004    Serial number: 0485C280616C15
       Coding: 03010001000086407F07000000590032D8120007080000000175078E10000000
       ASAM Dataset: EV_CGateCONTIAU491 002040
       ROD: EV_CGateCONTIAU491_002_AU49.rod
       VCID: 4CD4A83DE70DC624B4-8018
       Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
       Component: J453 MFL  H06 0002
       Serial number: 20161206021922 00210
       Serial number: 0984792304
    Address 28: HVAC, Rear (E265)       Labels:* None
       Part No SW: 4M0 919 158 C    HW: 4M0 919 158 C
       Component: Klima Zone 2  H52 0092
       Coding: 000000000000040100820080000000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
       ROD: EV_AirCondiFondBHTCAU736.rod
       VCID: 3522EDD99487A7ECFB-8060
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
       Component: LCM_MLBevoH05 0024
       VCID: 77BE27D1CE0B95FC29-8022
       Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
       Component: ELV-MLBevo    H05 0032
       Serial number: 16000327363002
       Coding: 8800000000000000
       ROD: EV_ELVMarquMQBB.rod
       Component: MEM-FS        008 0031
       Serial number: 00000231697872
       Coding: 002832000000B2410000010101010000110000313100000000000000000000
       Shop #: WSC 48154 001 104857
       ROD: EV_SCMDriveSideCONTIAU736.rod
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 959 593 E    HW: 4M0 959 593 C
       Component: TSG FS        005 0057
       Serial number: 0000231660075
       Coding: 001D9A005E01000000003082
       ROD: EV_DCU2DriveSideMAXHCONT.rod
       VCID: 3E30F2F5A1B164B42A-806A
       Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
       Component: EPS_MLBEVO1BS H20 0005
       Serial number: 0000487018
       Coding: B0040101000101
       ASAM Dataset: EV_EPSVWBSAU736 009023
       ROD: EV_EPSVWBSAU736_009.rod
       VCID: 3424D0DD9FFDBEE4CC-8060
       Part No SW: 8W0 907 064 CD    HW: 8W0 907 064 D
       Component: BCM2 MLBevo   018 0344
       Coding: 01351E002F9100406309A0006600580203000000004706502F04000000040030001F0001000000
       ASAM Dataset: EV_BCM2HellaAU736 012013
       ROD: EV_BCM2HellaAU736_012_AU49.rod
       VCID: 004C4C0D9BC5D24418-8054
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY163140KQU
       Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000067942770
    Address 50: Seat Adj. 3rd row (J857)       Labels:* None
       Part No SW: 4M1 959 760 G    HW: 4M1 959 760 G
       Component: MEM-SR3       008 0016
       Serial number: 00000232754210
       Coding: FF201020F1000000000F000000000900000021210900000000000000440000
       ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
       ROD: EV_SCM3rdRowCONTIAU736.rod
       Part No SW: 4M0 959 592 E    HW: 4M0 959 592 C
       Component: TSG BFS       005 0057
       Serial number: 0000233427196
       Coding: 001D9A005C01000000003080
       ROD: EV_DCU2PasseSideMAXHCONT.rod
    Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
       Part No SW: 4M1 035 035     HW: 4M1 035 035
       Component: MU-P-LND-EU   033 0917
       Serial number: A641L0GB007363
       Coding: 01370601FF0A000053111101000A00332F001BF7017001009E
       ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
       VCID: 62886685758960546E-8036
       Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
       Component: ECE 2017/2018  --- 0161
       Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
       Component: AU536_DU_HIGH  H43 0008
       Serial number: AUZ8Z9GJ403D5G
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
       Component: ControlUnit_P  H15 0209
       Serial number: 11011700000000000315
       Component: Gracenote2  --- 1015
       Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
       Component: Anhaenger     H20 0214
       Revision: 9A001003    Serial number: 0389212548
       Coding: 0110000202010000
       VCID: 3326D3C19AF3B9DCD5-8066
       Trailer Articulation Angle Sensor:
       Subsystem 1 - Part No SW: 4M0 907 811     HW: 4M0 907 811
       Component: G820 KNWINSEN  H18 0019
       Serial number: 26377
    136203 - Supply Voltage
              P1757 00 [009] - Open Circuit
                        Reset counter: 29
                        Mileage: 18163 km
                        Date: 2018.05.10
                        Time: 14:38:54
       Part No SW: 8W8 959 107 B    HW: 8W8 959 107
       Component: HDSG-Modul    H13 0161
       Revision: --------    Serial number: 31105654300000
       Coding: 0090
       ROD: EV_DeckLidCONTIAU736_VW27.rod
       VCID: 48DC942DF3752A0490-801C
    Address 74: Chassis Control (J775)       Labels:* None
       Part No SW: 4M0 907 777 G    HW: 4M0 907 777 B
       Component: Fahrwerk-SG   H34 1213
       Serial number: 1712160205
       Coding: 98505848F8
       ASAM Dataset: EV_ChassContrContiAU426 001003
       ROD: EV_ChassContrContiAU426.rod
       Air Suspension Compressor:
       Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
       Component: V66LFKompOLV  H06 0013
       Serial number: 00000000004130099908
       Coding: 303030
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 4M2 713 041 F    HW: 4M2 713 041 F
       Component: GSM-LL        H09 0073
       Revision: 0L0D5012    Serial number: 20161123000279
       ROD: EV_GSMWaehlZFAU736_AU49.rod
       VCID: 291A31A9483FF30C6F-807C
       Part No SW: 4M0 919 617 C    HW: 4M0 919 617 C
       Component: HeadUpDisplay H28 1603
       Coding: 4F01C0
       ASAM Dataset: EV_HudNSEIKAU736 001015
       ROD: EV_HudNSEIKAU736_AU49.rod
    Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
       Part No SW: 4M0 907 541 E    HW: 4M0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU736 002018
       ROD: EV_ACC2BOSCHAU736_002_AU73.rod
       VCID: 302CDCCD6BE582C4A8-8064
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
       Component: BVS           H14 0042
       Coding: 0407030600000402024023A5AD0000B4B0F0C020C020
       ROD: EV_BVSMLBevKOSTAAU736.rod
       VCID: 2F2EDFB176DB9D3CB1-807A
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355 B    HW: 4M0 907 355 B
       Component: SCR-Stg-G3H04 0005
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736.rod
       Part No SW: 4M0 959 595 E    HW: 4M0 959 595 C
       Component: TSG HFS       005 0057
       Serial number: 0000232236371
       Coding: 000D98000001000000003080
       ROD: EV_DCU2RearDriveMAXHCONT.rod
       VCID: 40CC8C0DDB45124458-8014
       Component: TSG HBFS      005 0057
       Serial number: 0000232236617
       ROD: EV_DCU2RearPasseMAXHCONT.rod
       Part No SW: 4M0 907 594 G    HW: 4M0 907 594
       Component: SAD_STG_1     013 0005
       Coding: 5A8000053602
       ROD: EV_SunRoofCONTIAU736.rod
       VCID: 3A38FEE5BD99489416-806E
       VCID: 16600A55E9414CF4D2-8042
    End----------(Elapsed Time: 02:17, VBatt start/end: 12.1V/12.1V)-----------
    Oct 2017
    Northwest UK
    Hi Andy
    From what you describe it sounds like the camera is either wired incorrectly or it needs a software update. Was the camera a genuine part? Did you follow the wiring diagram as per ELSA?
    Jan 2015
    Bosnia and Herzegovina
    from your explanation it seems that parking sensors doesn't know that it has camera connected. I believe that your sensors are connected to 09 central electronic (correct me if I'm wrong) so probably some coding or adaptation channel that needs to be changed to display camera instead of sensors.
    Mar 2016
    Hi Myonus.
    Yep, all genuine parts used and wired in as per Erwin/Elsa. I never figured if it could be changed and after speaking to a few others around the world it seems like it was "just the way"
    @m87a - It could well be, but as I have no access to the vehicle now I can't really check but I can look at another Q7 in 09 and see what is what. Thanks
    Andy
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dynamic Pack | Matrix Lights | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | N-Vision | BOSE | DVD Changer | Homelink | Soft Door Close | Heat+Sound Ins Glass | Priv Glass | Heated Windscreen | Heated Steer Wheel | Adv Key | Elec Boot Cover | Side Assist | Air Suspension | Ambient Lighting | Heated+Fold Mirrors | Park Assist Pack | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap
