Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 2010 A4 quattro 2.0T differences
    May 2018
    Transmission and engine are now friends, and both in the car. Will have an update shortly, just getting things hooked up and the laptop charged
  2. #12
    May 2018
    Here she is. Apparently the unit does not like what is going on very much. Many things are equated to not being hooked up or having lost power previously. The car also has had the trip status as SAFE this whole time, which means it also doesn't like my key I guess. I am not sure if I can adapt this myself, but I haven't checked, I just recall some forum posts now and again about it. It'll all be taken care of in due time of course. Anyway, I'm approaching the road to getting it to fire up, which of course means I need that sorted out and a few other things. Unfortunately, random things I do not know about will restrict starting, sometimes crazy stuff. Like on the BMW m5, if your hood latch sensor goes awry it just wont start. Anywho, here she is, all 1500 lines :I
    If you have an suggestions, please tell me, trying to figure it all out alone is a bit of a grind and the number of tabs I have open on google is astounding. And for those of you interested, here is a thread I started on Audizine showing what I'm doing with a bit more color: https://www.audizine.com/forum/showt...-s-B8-A4-Build
    Friday,01,June,2018,17:01:51:09178
    VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4411.4
    Mileage: 220310km-136894mi   Repair Order: 03 w/ trans
    Chassis Type: 8T0
    Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72
       Mileage: 220310km-136894miles
    08-Auto HVAC -- Status: Malfunction 1010
    Address 01: Engine (J623-CAUB)       Labels:. 079-907-560-CAU.clb
       Part No SW: 8T0 907 560 G    HW: 8T0 907 560
       Component: 4.2l V8/4V    H10 0008
       Revision: 76H10---
       Coding: 01140009180F0120
       Shop #: WSC 93204 999 83903
       VCID: 3E25C295B0758857404-806A
    10 Faults Found:
                        Load: 0.0 %
                        Temperature: -40.0°C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    006418 - Pressure Sensor for Brake Boost (G294)
                   P1912 - 001 - Short to Plus
                        Fault Status: 01100001
                        Load: 0.0 %
                        Temperature: 21.0°C
                        Temperature: 26.0°C
                        Absolute Pres.: 940.0 mbar
                        Voltage: 12.954 V
    000400 - Fuel Pressure Sensor (G247)
                   P0190 - 001 - Circuit Malfunction
                        Load: 0.0 %
                        Temperature: 21.0°C
                        Temperature: 26.0°C
                        Voltage: 12.827 V
    001796 - Clutch Switch (F36)
                   P0704 - 004 - Implausible Signal
                        Load: 0.0 %
                        Temperature: 21.0°C
                        Temperature: 26.0°C
                        Voltage: 12.954 V
    000112 - Sensor for Ambient Air Temperature (G17)
                   P0070 - 001 - Malfunction
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 16:56:09
                        Load: 0.0 %
                        Temperature: 21.0°C
                        Temperature: 27.0°C
                        Voltage: 13.081 V
    004200 - Intake Air Switch-Over Valve (N335)
                   P1068 - 004 - Open Circuit
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 17:15:50
                        RPM: 119 /min
                        Load: 100.0 %
                        Temperature: 21.0°C
                        Temperature: 27.0°C
                        Voltage: 12.192 V
    005495 - Right Engine Mount Solenoid Valve (N145)
                   P1577 - 004 - Open Circuit
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 17:15:50
                        RPM: 119 /min
                        Load: 100.0 %
                        Temperature: 21.0°C
                        Temperature: 27.0°C
                        Voltage: 12.192 V
    005491 - Left Engine Mount Solenoid Valve (N144)
                   P1573 - 004 - Open Circuit
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 17:15:50
                        RPM: 119 /min
                        Load: 100.0 %
                        Temperature: 21.0°C
                        Temperature: 27.0°C
                        Voltage: 12.192 V
    001152 - Coolant Fan Control Circuit 1
                   P0480 - 004 - Electrical Malfunction
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 17:15:50
                        RPM: 119 /min
                        Load: 100.0 %
                        Temperature: 21.0°C
                        Temperature: 27.0°C
                        Voltage: 12.192 V
    001153 - Coolant Fan Control Circuit 2
                   P0481 - 004 - Electrical Malfunction
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 17:15:50
                        RPM: 119 /min
                        Load: 100.0 %
                        Temperature: 21.0°C
                        Temperature: 27.0°C
                        Voltage: 12.192 V
       Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 AN
       Component: ESP8 quattro  H04 0010
       Coding: 150D10
       Shop #: WSC 02391 823 56573
       VCID: 7AAD0E85ECDD64773CC-802E
    12 Faults Found:
    02214 - Tire Pressure Warning
                000 -  -  - Intermittent
                        Reset counter: 99
                        Mileage: 219357 km
                        Date: 2017.08.20
                        Time: 11:43:35
                        Hex Value: 0x4400
                        Hex Value: 0x4006
                        Hex Value: 0x1237
                        Hex Value: 0x1CA8
                        Hex Value: 0x00FF
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2017.09.05
                        Time: 12:11:53
                        Hex Value: 0x00C0
                        Hex Value: 0x0806
                        Hex Value: 0x1203
                        Hex Value: 0x0373
                        Hex Value: 0x00FF
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.30
                        Time: 20:32:02
                        Hex Value: 0x0000
                        Hex Value: 0x0082
                        Hex Value: 0x0032
                        Hex Value: 0x0296
                        Hex Value: 0x00FF
                        Fault Frequency: 7
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:21
                        Hex Value: 0x0000
                        Hex Value: 0x0782
                        Hex Value: 0x002B
                        Hex Value: 0xB99D
                        Hex Value: 0x00FF
                        Fault Frequency: 29
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:21
                        Hex Value: 0x0000
                        Hex Value: 0x0782
                        Hex Value: 0x0027
                        Hex Value: 0x859D
                        Hex Value: 0x00FF
                        Fault Frequency: 31
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:23
                        Hex Value: 0x0000
                        Hex Value: 0x2282
                        Hex Value: 0x0038
                        Hex Value: 0x339C
                        Hex Value: 0x00FF
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.30
                        Time: 20:32:02
                        Hex Value: 0x0000
                        Hex Value: 0x0082
                        Hex Value: 0x0032
                        Hex Value: 0x0296
                        Hex Value: 0x00FF
                        Reset counter: 131
                        Hex Value: 0x0000
                        Hex Value: 0x2280
                        Hex Value: 0x0038
                        Hex Value: 0x66A4
                        Hex Value: 0x00FF
                        Fault Status: 00101101
                        Reset counter: 131
                        Hex Value: 0x0000
                        Hex Value: 0x2280
                        Hex Value: 0x001C
                        Hex Value: 0x23A3
                        Hex Value: 0x00FF
                        Fault Status: 00100101
                        Reset counter: 131
                        Hex Value: 0x0000
                        Hex Value: 0x2280
                        Hex Value: 0x001C
                        Hex Value: 0x2AA4
                        Hex Value: 0x00FF
                        Reset counter: 131
                        Hex Value: 0x0000
                        Hex Value: 0x2280
                        Hex Value: 0x0038
                        Hex Value: 0x1BA3
                        Hex Value: 0x00FF
    01794 - Control Module - Incorrect Chassis (VIN) Number
                000 -  -  - Intermittent - MIL ON
                        Fault Status: 10100000
                        Reset counter: 131
                        Hex Value: 0x0000
                        Hex Value: 0x2280
                        Hex Value: 0x0014
                        Hex Value: 0x13A3
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 DF    HW: 8K0 907 064 DF
       Component: BCM2 1.1      H02 0321
       Coding: 090100
       Shop #: WSC 02399 823 56573
       VCID: 77AB17B1DFCF791F432-8022
       Serial number: 0509000034446013
       Component: J764 ELV MLB  H36 0042
       Serial number: 0209000046095011
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:21
    02241 - Engine Control Module; Immobilizer Data not Adapted
                000 -  -
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.05.01
                        Time: 23:19:45
    02811 - Control Module for Electronic Steering Column Lock (J764)
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.05.05
                        Time: 19:34:14
    02823 - Requirements for Locking the Steering Column Lock not met
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.05.05
                        Time: 22:20:11
       Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
       Component: KLIMA 1 ZONE  H08 0160
       Revision: A1000000    Serial number: 01010720090991
       Coding: 64002000
       VCID: 7DA70599FDF3534F19E-8028
    8 Faults Found:
                        Fault Status: 01101000
                        Reset counter: 91
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.30
                        Time: 20:31:59
    00256 - A/C Pressure/Temperature Sensor (G395)
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.30
                        Time: 20:31:59
                        Temperature: 15.0°C
    03220 - Stop Valve for Coolant for Climatronic (N422)
                        Fault Status: 00101001
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:19
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:19
                006 - Short to Plus
                        Fault Status: 01100110
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.05.01
                        Time: 23:19:45
                        Voltage: 12.70 V
                        Voltage: 12.90 V
                        Voltage: 13.00 V
                        Voltage: 13.00 V
                        Bin. Bits: 00000000
                        Time: 0.00 s
                        Count: 1
                        Reset counter: 131
                        Reset counter: 131
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000297025
       Coding: 690000B1063C00010000080300007F5F0F14520802000001000000
       Shop #: WSC 08180 444 68462
       VCID: 3C21C89DA6699A476E0-8068
       Component: WWS 260609  H06 0070
       Serial number: SWF09060260410
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
       Component: E1 - LDS  H08 0090
       Serial number: 00000000002506090800
    9 Faults Found:
    03351 - Bulb for DRL and Marker Light; Left
                        Fault Status: 01101100
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.30
                        Time: 20:31:00
    03354 - Bulb for DRL and Marker Light; Right
                        Reset counter: 91
                        Mileage: 219028 km
                        Date: 2017.08.15
                        Time: 21:15:00
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2017.10.07
                        Time: 15:19:00
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:11:00
                        Reset counter: 87
                        Mileage: 220204 km
                        Date: 2017.09.01
                        Time: 20:39:00
                        Reset counter: 87
                        Mileage: 220204 km
                        Date: 2017.09.01
                        Time: 20:39:00
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.30
                        Time: 20:31:00
                        Reset counter: 91
                        Mileage: 219028 km
                        Date: 2017.08.15
                        Time: 21:15:00
    00910 - Indicator Lamp for Emergency Flashers (K6)
                        Reset counter: 91
                        Mileage: 1048574 km
       Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
       Component: AirbagVW-AU10 H37 0520
       Serial number: 003EGD0264ET
       Shop #: WSC 02145 785 00200
       VCID: 42DDB665C40DECB724C-8016
       Serial number: 5810000R0900004FL4
       Serial number: 6334MSME4903092CC
       Serial number: 6344MSME49636B47O
       Serial number: 6352QSME20313434/
       Serial number: 6362QSME7E311C20I
    9443859 - Driver's Front Airbag Crash Sensor
              B101A 15 [137] - Open or Short to Plus
                        Mileage: 220314 km
                        Date: 2009.04.30
                        Time: 20:31:56
    9444115 - Front Passenger's Front Airbag Crash Sensor
              B101B 15 [137] - Open or Short to Plus
                        Mileage: 220314 km
                        Date: 2009.04.30
                        Time: 20:31:56
    9442836 - Front Passenger's Airbag Disabled Indicator Lamp
              B1016 14 [137] - Open or Short to Ground
                        Mileage: 220314 km
                        Date: 2009.05.05
                        Time: 22:26:32
    12583424 - Powertrain Databus
              U0002 00 [008] - No Communications
              [High Speed CAN Communication Bus no signal/communication]
                        Reset counter: 131
    9482752 - Seat Occupied Recognition
              B10B2 00 [008] - Function Restriction due to Missing Message(s)
              [Bladder Mat: functional restriction because of missing message]
                        Reset counter: 131
       Component: Lenks.Modul   H16 0014
       Revision: --------    Serial number: 90315IFT0004U
       Coding: 000014
       VCID: 3D27C599BD73934F59E-8068
                        Reset counter: 131
                        Reset counter: 40
                        Reset counter: 131
                        (no units): 44.0
                        Text: 2C8BFFFFFFFF00C0FF
                        RPM: 0
                        Raw, Index/Key Err.: 255 255 000
       Part No SW: 8K0 920 950 E    HW: 8K0 920 950 E
       Component: KOMBIINSTR.   H19 0253
       Revision: 00100000    Serial number: BWX33GR69
       Coding: 8B1209000300D705020000
       VCID: 313FE9A9712B672FCD6-8064
                        Fault Frequency: 82
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:13
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:21
    00771 - Fuel Level Sensor (G)
                        Fault Status: 00101010
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:13:51
    00438 - Fuel Supply Sensor 2 (G169)
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:13:51
       Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0101
       Revision: GB500049    Serial number: 4900G096208416
       Coding: 00C303
       VCID: 50F98C2D1AE10E27A28-8004
       Component: J367-BDM  H06 0160
       Serial number: 19082A05110609
                        Fault Frequency: 37
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2017.09.29
                        Time: 16:20:18
                        Bin. Bits:    10011
                        Voltage: 11.60 V
                        Count: 6
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:00:00
                        Bin. Bits:    00000
                        Voltage: 13.00 V
                        Count: 7
                        Bin. Bits:    10000
                        Time: 0.40 s
                        Fault Frequency: 25
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:00:00
                        Bin. Bits:    00000
                        Voltage: 13.00 V
                        Count: 7
                        Bin. Bits:    10000
                        Time: 0.40 s
    01312 - Powertrain Data Bus
                        Fault Frequency: 61
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:00:00
                        Bin. Bits:    00000
                        Voltage: 13.00 V
                        Count: 7
                        Bin. Bits:    10000
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.05.02
                        Time: 00:08:26
                        Bin. Bits:    00000
                        Voltage: 13.30 V
                        Count: 7
                        Bin. Bits:    10000
                        Time: 0.90 s
    01304 - Radio
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.05.05
                        Time: 22:12:08
                        Bin. Bits:    10000
                        Voltage: 13.10 V
                        Count: 12
                        Bin. Bits:    10000
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000008999560
       Coding: 011C03204000410001
       VCID: 45D7AD79D5A3DB8F01E-8010
                        Reset counter: 131
                        Reset counter: 131
                        Reset counter: 131
                        Reset counter: 131
                        Reset counter: 131
       Revision: 00002001    Serial number: 0119131169
       Coding: 0106023A007A000400B0010000000000
       Subsystem 2 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS039  H06 0041
    10 Faults Found:
    02616 - Fuel Tank Cap; Unlock
                        Fault Status: 01101001
                        Reset counter: 22
                        Mileage: 218339 km
                        Date: 2017.08.07
                        Time: 12:37:14
    02615 - Fuel Tank Cap; Lock
                        Reset counter: 23
                        Mileage: 218369 km
                        Date: 2017.08.07
                        Time: 13:04:11
    03305 - Wire for Engine Start Request
                        Fault Status: 00100110
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:00:00
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:21
                        Fault Frequency: 147
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:39
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.05.02
                        Time: 00:08:30
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.05.05
                        Time: 22:27:22
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:14:14
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:14:14
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:14:14
       Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
       Component: DSP STD       H07 0230
       Revision: S2200000
       Coding: 0203010101
       VCID: 74B120BDCEB91207660-8020
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000009013006
       VCID: 44D1B07DDE99E287160-8010
                        Reset counter: 131
                        Reset counter: 131
                        Reset counter: 131
                        Reset counter: 131
                        Reset counter: 131
       Component: EPB Audi B8   H09 0090
       Revision: 00000003    Serial number: 00000000402919
       VCID: 3431E0BD8E395207A60-8060
    7 Faults Found:
                        Reset counter: 131
                        Voltage: 13.10 V
                        Count: 68
                        Hex Value: 0x0273
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                        Reset counter: 131
                        Voltage: 13.10 V
                        Count: 67
                        Hex Value: 0x0273
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    03200 - Switch for Electric Parking Brake (E538)
                        Fault Status: 00101011
                        Fault Frequency: 23
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.05.01
                        Time: 23:50:33
                        Voltage: 14.20 V
                        Count: 38
                        Hex Value: 0x0173
                        Hex Value: 0x0008
                        Hex Value: 0x1010
    03182 - Clutch Position Sensor (G476)
                        Fault Status: 01101010
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.05.01
                        Time: 23:19:46
                        Voltage: 13.00 V
                        Count: 51
                        Hex Value: 0x02F3
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:21
                        Voltage: 12.60 V
                        Count: 66
                        Hex Value: 0x0270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:21
                        Voltage: 12.60 V
                        Count: 64
                        Hex Value: 0x0270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
                        Fault Status: 11101101
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.30
                        Time: 20:32:02
                        Voltage: 12.00 V
                        Count: 80
                        Hex Value: 0x0260
                        Hex Value: 0x0001
                        Hex Value: 0x0101
       Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
       Component: Con3 Sirius   H03 0351
       Revision: 00000005    Serial number: AUZ5Z6I1240320
       Coding: 05020000010105004119070000
       VCID: 46D5AA75E8A5D097084-8012
       Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Component: Display
                000 -  -
                        Reset counter: 22
                        Mileage: 218339 km
                        Date: 2017.08.07
                        Time: 11:58:26
    03138 - Input AUX IN
                        Fault Status: 01101011
                        Reset counter: 22
                        Mileage: 218339 km
                        Date: 2017.08.07
                        Time: 11:58:35
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:24
    02259 - Information Display and Control Head (Front) (J685)
                        Reset counter: 40
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000101439676
       Coding: 010C03204000210001
       VCID: 42DDB665C48DECB724C-8016
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000101439673
    End----------(Elapsed Time: 01:28, VBatt start/end: 13.2V/12.8V)-----------
  3. #13
    You've got an awful lot of DTCs that are flagged "Intermittent". I would go through each and every control module and clear faults in 'em, one at a time. Then cycle ignition and scan again to see what comes back.
    No, you're not going to be able to do the immobilizer adaptation with VCDS. The path of least resistance on that might be to send the ECU out for to have the Immo disabled in it. That won't fix the error message in the dash, but it will at least allow the engine to run.
  4. Likes Zingrox liked this post
  5. #14
    May 2018
    I completely forgot about clearing the faults. Ill make sure to get on that, thank you! As for the immobilizer, it is apparently rather hard to deal with. Several people and businesses just don't deal with it because of that. I found a guy who has his own tuning business who says he can do it, hopefully. The last guy said he could do it, I sent him the eeprom files, and he responded that he wont now because it is the 9.1.1 and he hasnt before
  6. #15
    May 2018
    Woo momma she narrowed down a tad. As for the immobilizer, I dont expect you guys to worry about that, I'll find that on my own time. Ive moved coding files on it twice now to see if they work, the people I discussed it with seemed to have complete confidence in them. One was even password protected and demanded not to be shared, which I will comply with. Regardless, we'll see. The SAFE message apparently relates to the key fobs adaption, rather than the immobilizer, but I'm still new to this chassis and cant be too sure I guess. I was originally talking about the key fob rather than the immobilizer
    Also, I would not doubt having a sensor or positive/ground wire in the wrong place. While I don't actively see things in the wrong place, you never know. I have a second harness I use to reference and debate what should be what if I'm not entirely sure, in addition to the old engine and harness.
    Friday,01,June,2018,18:17:32:09178
    Mileage: 220310km-136894mi   Repair Order: 04 w/ trans
    Chassis Type: 8T0
       Revision: 76H10---
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 18:57:08
                        Load: 0.0 %
                        Temperature: 22.0°C
                        Temperature: 27.0°C
                        Voltage: 13.335 V
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 18:57:08
                        Load: 0.0 %
                        Temperature: 22.0°C
                        Temperature: 27.0°C
                        Voltage: 13.335 V
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 18:57:08
                        Load: 0.0 %
                        Temperature: 22.0°C
                        Temperature: 27.0°C
                        Voltage: 13.335 V
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 18:57:08
                        Load: 0.0 %
                        Temperature: 22.0°C
                        Temperature: 27.0°C
                        Voltage: 13.335 V
    Readiness: 0110 1101
       Coding: 150D10
       Coding: 090100
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:37
       Coding: 64002000
                006 - Short to Plus
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:37
                        Voltage: 12.70 V
                        Voltage: 12.70 V
                        Voltage: 11.70 V
                        Voltage: 12.70 V
                        Bin. Bits: 00000000
                        Time: 240.00 s
                        Count: 1691
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:37
                        Temperature: 1.0°C
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:37
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:38
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:38
       Coding: 00FD11
    8 Faults Found:
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:00
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:00
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:00
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:00
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:00
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:00
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:00
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:00
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:39
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:40
       Coding: 000014
                        Fault Frequency: 85
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:13
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:06:21
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:13:51
                        Reset counter: 131
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 00:13:51
       Coding: 00C303
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:37
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:42
       Revision: S2200000
       Coding: 0203010101
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:37
                        Voltage: 12.80 V
                        Count: 80
                        Hex Value: 0x0273
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:38
                        Voltage: 12.90 V
                        Count: 51
                        Hex Value: 0x0273
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Component: Display
                000 -  -
                        Reset counter: 91
                        Mileage: 220314 km
                        Date: 2009.04.28
                        Time: 19:08:47
    End----------(Elapsed Time: 01:20, VBatt start/end: 12.8V/12.8V)-----------
  7. Likes Uwe liked this post
  8. #16
    May 2018
    New information has surfaced. The car, upon seeing an error with a transmission or difference in hardware, will throw an unclearable error and refuse to communicate with the unit. Because I did not adapt my ecu to the modules of the car via the long coding before I put it together, it will now forever refuse to communicate until it is virginized/entirely wiped. Now for anyone else doing so, this is still possible if you decode ALL your modules and match the cars before putting it together. This is awfully verbose to do, so the best way would be to clear the ecu so it will think its new and adapt to the car as is. Doing so is not possible for us, and requires dealer intervention if they are able to be swoon to do so. The information for the ecu and immobilizer must be imported from Germany, from Audi themselves, over a secure connection and ethernet only. This is a problem for us, because getting that to happen is very unlikely. This information was from someone who has done manual conversions more than once, he very much knows whats going on here. Your best bet is to make good friends with a dealer or someone working there.
    Thats what I can tell you guys so far. As I progress with this I will continue to update
  9. #17
    May 2018
    So I took the car to a shop that said they where capable of recoding the ECU to virginize it or at least remove the immobilizer past the key so the car would start. It has been about a year now, and they got nowhere big. The ECU was recoded, did not work, immo off also did not work. I'm suspicious of bcm 2 currently, amongst other wiring messes. I'm currently using the a4's when the s5's could very well have a different pinout, as it controls parts of the start authentication. I thought it'd be ok since the key and modules used where native to the original car. They have given up, I'm taking the car back, I'll investigate myself.
