Results 1 to 4 of 4
Thread: 2011 Audi A7 3.0 TDI quattro
    Nov 2016
    Was helping a friend today with his 2011 A8 3.0 TDI quattro, so here's a scan;
    Wednesday,09,May,2018,17:35:47:24986
    VCDS Version: 18.2.0.3
    VIN: WAUZZZ4G1BN0XXXXX   License Plate:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 30 36 3B 42 44 46 52 53 55
              56 5F 62 6D 72 82
    VIN: WAUZZZ4G1BN0XXXXX   Mileage: 281090km-174661miles
    Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 401 F    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0002
       Revision: 53H37---
       Coding: 1A254012042601020800
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TDI0114G0907401F 001002
       ROD: EV_ECM30TDI0114G0907401F.rod
       VCID: 26427DEF5986977442-8072
       Part No SW: 4G0 927 156 K    HW: 0B5 927 156 F
       Component: 0B5 30 TDIRdW H05 0009
       Revision: --H05---    Serial number: 0000001242
       Coding: 000001
       ROD: EV_TCMDL501.rod
       VCID: 346697A79F5AF5E4CC-8060
       Part No SW: 4G0 907 379     HW: 4G0 907 379
       Component: ESP PREMIUM   H09 0190
       Coding: 27A68702E465E140DB00
       ASAM Dataset: EV_ESPPremiAU57X 003013
       ROD: EV_ESPPremiAU57X_003.rod
       VCID: 6ED245CFB1F69F34FA-803A
       Part No SW: 4H0 907 064 BP    HW: 4H0 907 064 AP
       Component: BCM2 2.0      H23 0333
       Coding: 01BA3000000000000000
       Shop #: WSC 00196 210 90007
       VCID: 78FE6397CBB2D18420-802C
       Serial number: 2310000091630016
       Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
       Component: KLIMA 2 ZONEN H10 0055
       Serial number: 18011100040217
       Coding: 3623000810
       ASAM Dataset: EV_AirCondiBasisUDS 002031
       VCID: 244667E72FBA65645C-8070
       Part No SW: 4H0 907 063 N    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0092
       Revision: 20012002    Serial number: 00000000887535
       Coding: 2600201040349FE00181008380001D0CCF9DC30A27090101000004602100
       VCID: 336494BB9254F2DCD5-8066
       Component: WWS57X 101216  H32 0051
       Serial number:         101223053733
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11235357
       Coding: 02562B
       Subsystem 3 - Part No SW: 4G0 941 531 G    HW: 4G0 941 531 G
       Component: E1 - LDS  H07 0044
       Serial number: 21 01 2011  00000300
       Component: Humidity_Sens  H02 0002
       Serial number: 22184985000000000001
       Part No SW: 4H0 919 475 G    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0021
       Revision: 11001001    Serial number: 55931101201700
       Coding: 100304
       ASAM Dataset: EV_EPHVA18AU57X0000 001001
       ROD: EV_EPHVA18AU57X0000_001.rod
       VCID: 3662ADAF8926E7F4F2-8062
    Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG001G5P%
       Coding: 30314530323130303133554A305234473853
       Serial number: 3575HRB405L0BI7U6GQ4
       Serial number: 3585HRB404T0C15I58F5
       Serial number: 3515JRB405J07S8SMH2$
       Serial number: 3525JRB405L07S8S3P3W
       Serial number: 3554VRB405D09GGSI0H/
       Serial number: 3564VRB405T09GGSD9EF
       Revision: 00000000    Serial number: 20110125000795
       Coding: 000034
       VCID: 306E9BB76342C9C4A8-8064
       Component: E221 - MFL  H07 0009
       Part No SW: 4G8 920 981 C    HW: 4G8 920 981 C
       Component: TDieGb        H34 0303
       Revision: 18100069    Serial number: 658220111593062
       Coding: 33A600020B032600010100
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K.rod
       VCID: 336494BB9A54F2DCD5-8066
       Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000085162
       Coding: 00CD077D00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 326A91BF654EFBD4DE-8066
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650459546
       Voltage stabilizer:
       Serial number: 11012001158011200181
       Part No SW: 4H0 907 440     HW: 4H0 907 440
       Component: STS           H06 0030
       Revision: S0H06000    Serial number: 00000000010370
       Coding: 01010101000000000000000202
       VCID: 64C627E7673A25649C-8030
       Component: MEM-FS        H03 0153
       Revision: AA000000    Serial number: 00001002275338
       VCID: 77FC60ABC6ACDEFC29-8022
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0004
       Revision: --------    Serial number: EJ1BPA32001B3E0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6BD44CDB82E46A1CDD-803E
       Part No SW: 4G8 959 793 C    HW: 4G8 959 793 A
       Component: TSG FA        H04 0210
       Coding: 011F46224E21620002080002
       Shop #: WSC 02312 785 00200
       VCID: 408ECB77D3E2594458-8014
       Part No SW: 4G0 909 144 L    HW: 4G0 909 144 F
       Component: RCEPS         H32 0010
       Revision: 00001000    Serial number: 0010029116
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0141565241
       Coding: 013B062220B9BC0083200A04000100000000000000000000000000000000
       Subsystem 3 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H09 0027
       Serial number: WA100975000000157344
       Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
       Component: TSG BF        H04 0210
       VCID: 3F8CC88BAE1C26BC21-806A
       Part No SW: 4H0 907 801 D    HW: 4H0 907 801 A
       Component: EPB-4         H03 0010
       Revision: --------    Serial number: 00000000035144
       ASAM Dataset: EV_ParkiBrake 001021
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 295876D34898B80C6F-807C
       Component: ....LWR12.... H02 0012
       Serial number: 110115-0004-017
       Coding: 1123A6101000A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C568FC7476AAD2494-8078
       Part No SW: 4G0 035 061 G    HW: 4G0 035 061
       Component: Radio U DAB   H52 0097
       Revision: AB001007    Serial number: 109AV0B7509309
       Coding: 010103020100000001
       VCID: 21486EF338A8704C37-8074
       Part No SW: 4G0 035 670 B    HW: 4G0 035 670
       Component: H-BNT-EU      H46 0239
       Revision: --------    Serial number: 428LW0A7508001
       Coding: 090101040003E5ED45008B3E000000030000010000000000
       VCID: 224A61FF3DAE6B542E-8076
       Subsystem 1 - Part No: 8R0 060 884 N
       Component: EUR 2011  1205
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Serial number: AUZ8ZDA1300AS4F
       Subsystem 3 - Part No SW: 4G2 919 612 L    HW: 4G2 919 612 L
       Component: E380 BDT C7  H08 0120
       Serial number: 90349KAQ0004J
       Component: CD-Database  2712
       Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
       Component: TSG HL        H03 0209
       Coding: 010F04224021620002080002
       VCID: 428AC17FDDEE4B544E-8016
       Part No SW: 4G8 959 107 D    HW: 4G8 959 107
       Component: HDSG-Modul    H12 0036
       Revision: 11012001    Serial number: 014100170
       Coding: 0A3205C000
       ASAM Dataset: EV_HDSGAu573 001014
       ROD: EV_HDSGAu571.rod
       Component: TSG HR        H03 0209
       Part No SW: 4G8 919 604 A    HW: 4G8 919 604 A
       Component: HeadUpDisplay 012 0042
       Coding: AA0000
       ASAM Dataset: EV_HUDContiC7 001020
       ROD: EV_HUDContiC7.rod
       VCID: 31689EB36048C0CCA7-8064
    End-------------------------(Elapsed Time: 05:40)--------------------------
    2014 Audi S4 Avant, 'black edition'.
    2019 Audi Q2 Sport 30 tdi.
  2. Likes Uwe liked this post
  3. #2
    Jul 2015
    Kent, UK
    That's not an A8; that's a MY2011 A6
    Julian
  4. Likes Uwe, Dukedesmo liked this post
  5. #3
    Nov 2016
    Quote Originally Posted by JulianHicks View Post
    Julian
    Late to reply and you are (partly) right, it's not an A8.
    The car is actually an A7, I should have realised at the time as did the scan for a friend to help with a deployment fault with the rear spoiler - apparently a common occurrence on A7s? Scan was after having reset the error.
    My mistake when posting, can anyone change the thread title accordingly?
  6. #4
    Quote Originally Posted by Dukedesmo View Post
    Yes.
  7. Likes Dukedesmo liked this post
