Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Issues with White Cluster Swap into 2006 B6 Passat
    Jun 2014
    But your main problem will be fuel gauge , it will not read correct, because cluster not see Fuel level sensor 2.
    For this email me direct.
    Part No SW: 3C8 920 971 B HW: 3C8 920 971 B
    Component: KOMBI H05 0705
    Coding: 240D00
    Shop #: WSC 00028 028 00001
    VCID: 2C020CD406800D97FE0-8078
    9459739 - Fuel Level Sensor 2
    B1058 1B [009] - Resistance Too High
    he have 4WD, he just need missing PIN into adaptor ,. he knew that already
  2. Likes Jetta ,97, Uwe liked this post
  3. #12
    Aug 2017
    After disconnecting the battery for an hour, the audio menu appeared on the cluster. All is good now. Regarding the compass, what will I need to enable this?
  4. #13
    Feb 2020
    I have the same issue with fuel gauge. Can you provide what pins have to be changed or added. Thank you.
  5. #14
    Feb 2020
    Do you have the details?
  6. #15
    Jun 2014
    Quote Originally Posted by mreuro View Post
    but what happen ?
    you did retrofits , or what ...
    more details always need ...not just simple "help"
  7. #16
    Mar 2015
    Australia
    For Passat you need to modify the 32-36 pin adapter harness as they do not include all the needed wires (add these wires)
    Black 36 pin -> Blue 32 pin
    16 -> 3
    23 -> 4
    Suitable for Passat 4mo.
    For Golf 4mo you also need to add a wire to fuel sender 2 under the back seat as it is missing a wire from the fuel sender to the cluster at pin 4 of the new 32pin connector.
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  8. #17
    Feb 2020
    but what happen ?
    Yes I did retrofit Cluster from 2012 CC and I did get the adapter and I do have the same codes and the fuel gauge is only showing 1/2 tank.
  9. #18
    Feb 2020
    Quote Originally Posted by kamold View Post
    16 -> 3
    23 -> 4
    Thank you!
  10. #19
    Feb 2020
    I know I still have to code the cluster to read from two fuel senders not one. I found where I have to do it but i need the security code to do it. I have looked and I found one security code but it still wont let me change it from 1 to 2.
    The code I found is 25327 was accepted but not to change what i need to change.
  11. #20
    Jun 2014
    no ...you dont now
    this always show 1 , even if car is factory 2 fuel sensor
  12. Likes NEtech, Uwe liked this post
