Results 1 to 10 of 20
Thread: Issues with White Cluster Swap into 2006 B6 Passat
    Aug 2017
    I'm having an issue with my white cluster swap. I used a 36/32 pin adapter so i'm having an error code for the 2nd fuel pressure sensor causing my fuel gauge to be off. i'm planning on fixing this today. The issue i can't figure out is that the vehicle status lists two items that i can't "ok" out of. the airbag error, due to the airbag igniter 2 not being resisted out (Planning on doing this weekend), and a service interval reminder. i tried clicking ok on the steering wheel, the back button, i just can't seem to get past the vehicle status menu. I'm guessing this is the reason i'm not able to see any of the audio track names, etc. I can see all other menus such as bluetooth (when my phone is connected), MFA for mpgs, speed, etc, and settings menu (minus convenience). When i had the red cluster, i had to ok past the airbag issue before i could see track names from the radio but i can't seem to do that anymore since the cluster upgrade. Any help would be appreciated. Below is a list of the hardware i'm using:
    MK6 GLI Steering Wheel
    RCD510 from 2014 Passat (1K0 035 188 F)
    Bluetooth Module (7P6035730N)
    White Cluster from 2013 Passat (3C8920 971B)
    CAN Gateway (3C0907530Q)
    Tuesday,08,May,2018,11:35:16:45999
    Workshop Code: 028 00028 000001
    VIN: WVWFU93C96P141044   License Plate: XXXXXX
    Mileage: 93810km-58290mi   Repair Order:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 42 44 46 52 53 56
              62 65 72 77
    VIN: WVWFU93C96P141044   Mileage: 93810km-58290miles
    Address 01: Engine        Labels: 03H-906-032-BLV.clb
       Part No SW: 03H 997 033 M    HW: Hardware No
       Component: P3.6-FSI-LEV2   G00 2370
       Revision: --H08---    Serial number: VWZCZ000000000
       Coding: 0000175
       Shop #: WSC 00028 028 00001
       VCID: 372823B8C346BE4F832-8062
    000406 - Engine Oil Temp. Sensor (G8)
                   P0196 - 004 - Implausible Signal
                        Mileage: 93497 km
                        Date: 2018.05.05
                        Time: 00:04:46
                        RPM: 646 /min
                        Load: 31.0 %
                        Temperature: 65.0C
                        Temperature: 45.0C
                        Absolute Pres.: 830.0 mbar
                        Voltage: 13.716 V
       Part No SW: 09G 927 750 HK    HW: 09G 927 750 AJ
       Component: AQ 250 6F           1271
       Revision: 00H38000    Serial number:
       Coding: 0000072
       Shop #: WSC 20129 444 64522
       VCID: 015C8D60DD0230FF7D6-8054
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
       Component: ESP 440 C2     H015 0003
       Revision:  H015       Serial number: 0658525310
       Coding: 0046544
       Shop #: WSC 20129 444 84803
       VCID: 303A18A426286977C28-8064
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 AC    HW: 3C0 907 044 AC
       Component: ClimatronicPQ46 050 0404
       Revision: 00050005    Serial number: 00000000000000
       VCID: 629EA2EC38448BE704C-8036
    00710 - Defroster Flap Positioning Motor (V107)
                        Reset counter: 159
                        Mileage: 93815 km
                        Date: 2018.05.08
                        Time: 11:29:23
                        Reset counter: 159
                        Mileage: 93815 km
                        Date: 2018.05.08
                        Time: 11:29:23
       Revision: 00H46000    Serial number: 00000002275893
       Coding: E5848B1340041000400A00000F00000000680040640000
       Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer VW461  012  0503
       Coding: 00063445
       Shop #: WSC 00028
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
       Shop #: WSC 00028
    Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
       Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
       Component: SDAR XM         H03 0080
       Revision: 00000000    Serial number: AUZ4Z7E2039462
       VCID: 2B000FC80F0E0AAFF7A-807E
                        Reset counter: 159
                        Mileage: 93815 km
                        Date: 2018.05.08
                        Time: 11:28:44
       Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
       Component: 0M AIRBAG VW8R  029 2521
       Revision: 10029000    Serial number: 003A3PQVZGM%
       Coding: 0012365
       VCID: 2E0606DC3C1C7F87D04-807A
       Subsystem 1 - Part No: 3C0 959 339 A
       Component: BF-Gewichtsens. 006 0002
       Subsystem 2 - Serial number: 00000000032UUM
       Subsystem 3 - Serial number: 0001.01.00000060000000000063
       Subsystem 4 - Serial number: 0000006332MSME0D32666CJ63
       Subsystem 5 - Serial number: 2666CJ6342MSME0D451A70C63
       Subsystem 6 - Serial number: 51A70C6351HTS69SDQUAL2J63
       Subsystem 7 - Serial number: QUAL2J6361HTS69SDMAN72 63
       Subsystem 8 - Serial number: MAN72 63727TS6I2IIPQI2063
       Subsystem 9 - Serial number: IPQI2063827TS6I2I6QN23F
       Subsystem 10 - Serial number: 6QN23F
    01587 - Igniter 2 for Airbag; Drivers Side (N250)
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
       Component: J0527               0025
       Revision: 00030000    Serial number: 3C5953507CN
       Coding: 0002811
       VCID: 74B2D4B492B01557660-8020
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H08 0010
       Coding: 00000131
       Part No SW: 3C8 920 971 B    HW: 3C8 920 971 B
       Coding: 261F00
       VCID: 2C020CD406800D97FE0-8078
    9459739 - Fuel Level Sensor 2
              B1058 1B [009] - Resistance Too High
                        Reset counter: 158
                        Mileage: 93815 km
                        Date: 2018.05.08
                        Time: 11:19:24
       Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
       Component: J533  Gateway   H13 0172
       Revision:   H13       Serial number: 3640P1612801E9
       Coding: FD82FF0700170200F102
       VCID: 2F381BD83B16768FDB2-807A
       Part No SW: 3C0 919 965     HW: 3C0 919 965
       Component: Kompass         005 0002
       Revision: 00005000    Serial number: 1166279TPYVX04
       VCID: 6D84C1D0F19AC49FA9E-8038
       VCID: 55F489307D0A6C5F71E-8000
    No Faults Found
       Part No SW: 3C0 959 433 Q    HW: 3C0 959 433 Q
       Component:    IMMO         051 0383
       Revision: 00051000    Serial number: VWZCZ000000000
       Shop #: WSC 20129 444 54527
       VCID: 382A2084CE58B1378A8-806C
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C0 959 760 B    HW: 3C0 959 760 B
       Component: Sitzverstellung     0701
       Revision: 00003000    Serial number: 00000000000000
       VCID: 2C020CD40A000D97FE0-8078
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1K0 959 701 L
       Component: Tuer-SG         024 2461
       Coding: 0001463
       Part No: 1K1 909 144 K
       VCID: 333017A8D73E526FBFA-8066
       Component:    KSG PQ46 RDK 051 0218
       Coding: 1B910F8801860E761804141FF00A8F0E081800
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
       Part No: 1K0 959 702 L
       Coding: 0001462
       Revision:   013
       Coding: 0000013
       VCID: 211CEDE07DC2D0FF5D6-8074
       Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
       Component: Radio Prem-8  H05 0008
       Revision: -----09S    Serial number: VWZ4Z7N3483641
       Coding: 0501000001000B
       VCID: 2B000FC8030E0AAFF7A-807E
    02633 - Antenna for Satellite Tuner
                        Reset counter: 159
                        Mileage: 93815 km
                        Date: 2018.05.08
                        Time: 11:28:42
                        Reset counter: 159
                        Mileage: 93815 km
                        Date: 2018.05.08
                        Time: 11:28:42
       Part No: 1K0 959 703 D
       Component: Tuer-SG         021 2432
       Coding: 0000144
       VCID: 313C1DA02D22607FCD6-8064
       Component:    RDK              0420
       Coding: 0100100
       Part No: 1K0 959 704 D
       Coding: 0000144
       VCID: 323E12AC28245B67B4C-8066
       Part No SW: 7P6 035 730 N    HW: 7P6 035 730 N
       Component: TELEFON       H16 4217
       Revision: 1B001001    Serial number: 00007666860899
       Coding: 0A10040000010110
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3D243190EDFA941F59E-8068
    End----------(Elapsed Time: 02:11, VBatt start/end: 13.7V/13.7V)-----------
    Please post a full Auto-Scan so we can see all fault codes and module hardware & software versions.
  3. Likes Uwe liked this post
    Aug 2017
    The coding for my red gauge cluster was 0007205. I can't copy over the code without having major issues correct?
    Quote Originally Posted by pskop9 View Post
    Definitely not. "0007205" is an older, 'short' coding whereas "261F00" is a newer-style 'long' coding. Yes, that's counter-intuitive since the newer one actually has one digit less.
    As for your Service Interval reminder.. What do you have in the SRI-related Adaptation channels?
    Aug 2017
    I was able to get rid of the SRI item by resetting the oil quality. Now the only issue I have is with the airbag error. Is there a reason why I can't ok past the error message or is there a way to bypass it on the MFA screen? I know I can't get rid of the airbag light on the dash but I have no idea why I can't ok out of the airbag error message
    Aug 2017
    So i'm super confused now. I resisted out the error for the airbag so i'm all good to go as far as errors on the dash go. No here is where i'm scratching my head. there is no audio track info whatsoever. i scroll through all the options and nothing. See below:
    I looked through my radio coding and there are no BAP or DDP options. I'm assuming this is because the radio came out of a 2014 vehicle. what's weird is that when i had my red dash, it would display all audio information from all sources except Bluetooth. Does anyone have any idea on where i could look next? i highly doubt the fuel gauge error is causing my audio info to be missing. I have also removed the navigation from my can list. I had this check by mistake.
    On another note, I previously had a compass, can that be coded to the new cluster or would i need to swap CCM's? Auto-scan is below:
    Thursday,17,May,2018,19:59:05:45999
    Mileage: 94870km-58949mi   Repair Order:
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 37 42 44 46 52 53
              56 62 65 72 77
    VIN: WVWFU93C96P141044   Mileage: 94870km-58949miles
       Coding: 0000175
                   P0196 - 004 - Implausible Signal - Intermittent
                        Mileage: 93497 km
                        Date: 2018.05.05
                        Time: 00:04:46
                        RPM: 646 /min
                        Load: 31.0 %
                        Temperature: 65.0C
                        Temperature: 45.0C
                        Voltage: 13.716 V
       Coding: 0000072
       Coding: 0046544
                        Reset counter: 177
                        Mileage: 94871 km
                        Date: 2018.05.17
                        Time: 19:55:20
       Coding: 00063445
       Shop #: WSC 00028
       Coding: 00208933
       Shop #: WSC 00028
                        Reset counter: 177
                        Mileage: 94871 km
                        Date: 2018.05.17
                        Time: 19:55:19
       Coding: 0012365
       Subsystem 3 - Serial number: 0001.01.000000600000000000 63
       Subsystem 4 - Serial number: 000000 6332MSME0D32666CJ 63
       Subsystem 5 - Serial number: 2666CJ 6342MSME0D451A70C 63
       Subsystem 6 - Serial number: 51A70C 6351HTS69SDQUAL2J 63
       Subsystem 7 - Serial number: QUAL2J 6361HTS69SDMAN72  63
       Subsystem 8 - Serial number: MAN72  63727TS6I2IIPQI20 63
       Subsystem 9 - Serial number: IPQI20 63827TS6I2I6QN23F
       Coding: 0002811
       Coding: 00000131
       Coding: 240D00
                        Reset counter: 177
                        Mileage: 94871 km
                        Date: 2018.05.17
                        Time: 19:48:10
       Coding: FD82FF0740170200F102
                        Reset counter: 177
                        Mileage: 94871 km
    No Faults Found
    Address 37: Navigation
       Coding: 0001463
       Coding: 0001462
       Revision:   013
       Coding: 0000013
       Coding: 00000001010010
                        Reset counter: 177
                        Mileage: 94871 km
                        Date: 2018.05.17
                        Time: 19:55:18
                        Reset counter: 177
                        Mileage: 94871 km
                        Date: 2018.05.17
                        Time: 19:55:18
       Coding: 0000144
       Component:    RDK              0420
       Coding: 0100100
       Coding: 0000144
    End----------(Elapsed Time: 02:13, VBatt start/end: 13.4V/13.5V)-----------
    Jun 2014
    Poland
    radio is too old ,
  9. #8
    Aug 2017
    Quote Originally Posted by Spacewalker View Post
    radio is too old ,
    The radio is from a model year newer than the car i pulled the cluster out of. That doesn't make any sense.
  10. #9
    Dallas (McKinney) ,TX ,USA
    For radio, go to Gan gateway and uncheck 37 -Navi, then save new list. I do not think RCD-510 have Navi .
    For Compass , you have to add GPS antenna to RCD-510 to have compass.
    But your main problem will be fuel gauge , it will not read correct, because cluster not see Fuel level sensor 2.
    For this email me direct.
    Coding: 240D00
    Reset counter: 177
    Mileage: 94871 km
    Date: 2018.05.17
    Time: 19:48:10
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    email: marinmm2001@gmail.com , info@advancedcarelectronics.com
    https://www.advancedcarelectronics.com/
  11. Likes Uwe liked this post
  12. #10
    Aug 2017
    i'm gonna try to disconnect the battery and see if maybe that fixes the missing compass and audio menu. i can fix the fuel gauge once i get the pins for the harness in the mail
