Results 1 to 6 of 6
Thread: Audi R8 rear spoiler coding errors
    New User
    Apr 2018
    Hi
    I’m really hoping someone can help me with the coding for my rear spoiler. I have a 2018 R8 RWS which had the pop up spoiler fitted at the factory. I’ve had the genuine Audi carbon fixed spoiler from a V10 plus fitted by my local dealer in its place. Unfortunately they don’t seem to be able to remove the errors I am getting as the car still thinks it has a pop up spoiler which isn’t working. I can get access to a VCDS cable but I’m not sure exactly what needs to be done to code it properly. I can only find one thread online where another person had a similar problem but the solution he has posted is in German and I’m not 100% certain I understand what needs done. If anyone could help it would be really appreciated as the warnings going off everytime I drive my car is driving me mad. Thanks very much.
    Cheers Scott
    We'll need you to post a full Auto-Scan here so we can see what modules are fitted to your R8.
  3. Likes Uwe liked this post
    New User
    Apr 2018
    I'll try and get that done ASAP then. Cheers
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by 115sf View Post
    I was asked to do this for another R8 owner who also went dynamic to fixed. It was a pretty simple coding tweak.
    Once we have your Auto-Scan, we can tell you if the same tweak applies to your model year.
    Silence gives consent.
  6. Likes DrMike liked this post
    New User
    Jan 2020
    Having the same issue with a 2017 r8v10 (non-plus). Am trying to disable the the automatic rear spoiler.
    Found "rear spoiler" in "46 central conv" and unchecked it. This resulted in the manual spoiler button becoming non-functional (anticipated), the spoiler changing to deployed and remaining that way (unanticipated), and 2 warning lights in the instrument cluster. Went back in and re-enabled "rear spoiler" (in 46 central conv) and all functions (and warning lights) returned to normal. HOWEVER, I do see some "malfunction" indications in the autoscan which were likely just created.
    here is a copy of the auto-scan .... any help in disabling the rear spoiler would be appreciated
    Friday,31,January,2020,16:59:04:21655
    VIN: WUAEAAFX3H7904380   License Plate:
    Mileage: 14353km-8918mi   Repair Order:
    Chassis Type: FX-AU72 (4S0)
    Scan: 01 02 03 05 06 08 09 11 31 14 15 16 17 19 1B 20 22 36 3B 42
              44 46 52 53 55 5F 65 6C 81 A6 C2
    VIN: WUAEAAFX3H7904380   Mileage: 14353km-8918miles
    A6-Microphone -- Status: Malfunction 0010
    C2-Auto Trans 2 -- Status: OK 0000
    Address 01: Engine (------CSPB)       Labels: None
       Part No SW: 4S0 907 552 H    HW: 4T0 907 552 A
       Component: 5.2l V10HDZ / H56 0003
       Revision: NHH56---
       Coding: 1A2500320526000D3000
       Shop #: WSC 03993 003 1048576
       ASAM Dataset: EV_ECM52FSI1114S0907552H 001003
       ROD: EV_ECM52FSI1114S0907552G.rod
       VCID: 3B23305523E0E9AFDC5-806E
    Address 02: Auto Trans (J217)       Labels: None
       Part No SW: 4S0 927 155 G    HW: 0BH 927 711 F
       Component: AU 6E SB  NAR H10 3914
       Revision: 00H10V01
       ASAM Dataset: EV_TCMDL800041 001013
       ROD: EV_TCMDL800041_AU72.rod
       Part No SW: 4S0 907 379 D    HW: 4S0 907 379 D
       Component: ESP PREMIUM   H09 0300
       Coding: 01A9C10B809583D04B00
       ASAM Dataset: EV_ESPPremiAU57X 004048
       ROD: EV_ESPPremiAU57X_AU72.rod
       VCID: 3E25394130F2FC87FBB-806A
    0668 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [ComScl_PDU_HSP_01_Timeout]
                        Reset counter: 50
                        Mileage: 14346 km
                        Date: 2020.01.31
                        Time: 16:09:52
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: E4
                        Uz: 99
       Part No SW: 4H0 907 064 JD    HW: 4H0 907 064 JD
       Component: BCM2 2.0      H44 0582
       Coding: 0D806506000000000000
       VCID: 74B1DB694EBE66D7DDF-8020
       Serial number: 3216000310185011
    00956 - Key 2
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 8
                        Mileage: 14340 km
                        Date: 2020.01.31
                        Time: 15:13:51
       Part No SW: 4S0 959 760     HW: 4S0 959 760
       Component: MEM-BFS       001 0020
       Revision: AA001003    Serial number: 00000184364315
       Coding: 00001000000420F1000001210101210000000000000000
       VCID: 7BA3F05563E029AF9C5-802E
       Part No SW: 4S0 820 043 K    HW: 4S0 820 043 K
       Component: AC Automat    H08 0040
       Revision: 20012000    Serial number: 96800000005805
       Coding: 4000A01000000410
       ASAM Dataset: EV_AirCondiVAPrehAU72x 003005
       ROD: EV_AirCondiVAPrehAU72x.rod
       VCID: 333318750BB021EF045-8066
       Operating and display unit 2 for air conditioning:
       Subsystem 1 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
       Component: E775 BuA_2  H07 0020
       Serial number: 00000000000000007211
       Operating and display unit 3 for air conditioning:
       Subsystem 2 - Part No SW: 8S0 820 359     HW: 8S0 820 359
       Component: E776 BuA_3  H07 0020
       Operating and display unit 4 for air conditioning:
       Subsystem 3 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
       Component: E777 BuA_4  H07 0020
       Part No SW: 4H0 907 063 HK    HW: 4H0 907 063 EK
       Component: BCM1 2.0      H21 0725
       Revision: 2502102S    Serial number: 00001565960402
       Coding: 010D0011143C9FF07D0048C380001800C59CD2882A08322100040894F1001100006000340B0000
       VCID: 78A9EF5952D602B7F17-802C
       Subsystem 1 - Part No SW: 4S1 955 119 B    HW: 8V2 955 119 A
       Component: WWS624 170122  043 0081
       Serial number: 90248162170206144405
       Coding: 3247FD
       Serial number: 62551774
       Coding: 02005D
       Subsystem 3 - Part No SW: 4S0 941 531     HW: 4S0 941 531
       Component: E1 - LDS  H01 0044
       Serial number: 30 01 2017  00000668
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z02AF2C24
       Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Serial number: 76E80C8800PAG0MUFU03
    Address 11: Engine II (-----)       Labels: None
       Revision: NHH56---
       ASAM Dataset: EV_ECM52FSI2114S0907552H 001003
       ROD: EV_ECM52FSI2114S0907552G.rod
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 4S0 907 376 D    HW: 4S0 907 376 C
       Component: DAEMPFUNGS-SG H06 0064
       Serial number:       061216073
       ASAM Dataset: EV_AudiMagneRide 002008
       ROD: EV_AudiMagneRide.rod
       Part No SW: 4S0 959 655     HW: 4S0 959 655
       Component: Airbag10.43   H62 0204
       Revision: --------    Serial number: 003NJ0015NTH
       Coding: 303338453036303038324A55304C34533053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001036
       VCID: 7EA5F94170723C87BBB-802A
       Serial number: 6940000Y160001K3RX0F
       Serial number: 3575HRB405J49IMAE14D
       Serial number: 3585HRB4063480GQCP8G
       Serial number: 3515JRB400A598PGA1I5
       Serial number: 3525JRB4016599BCII81
       Serial number: 3554VRB40165971EA9UA
       Serial number: 3564VRB40185971ES10-
       Part No SW: 4S0 907 129 K    HW: 4S0 907 129 K
       Component: Lenks.Modul   H06 0007
       Revision: C0071527    Serial number: 91335QAO00414-
       Coding: 000034
       VCID: 3E2539413072FC87FBB-806A
       Part No SW: 4S0 920 890 A    HW: 4S0 920 890 A
       Component: FBenUSA       H14 0251
       Coding: 086F30C1BA81CF050230ECC41800801000000000
       ASAM Dataset: EV_DashBoardBOSCHAU724 001022
       ROD: EV_DashBoardBOSCHAU724.rod
       VCID: 34311B690EBE26D71DF-8060
    16777088 - Databus
              [HSP_01 communication error can_error_timeout]
                        Reset counter: 50
                        Mileage: 14346 km
                        Date: 2020.01.31
                        Time: 16:09:53
       Part No SW: 4S0 907 468 B    HW: 4S0 907 468 A
       Component: J533--Gateway H15 0074
       Revision: --------    Serial number: 00000002514206
       Coding: 802103161C
       Subsystem 1 - Part No SW: 4S0 915 181     HW: 4S0 915 181
       Component: J367-BDM  H08 0270
       Serial number: 54026A19542871129320
       Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
       Component: DYNAMIKLENK.  H06 0740
       Coding: 0D0000
       VCID: 3A2D35512C5AD0A7C73-806E
    Address 20: High Beam Assist. (J844)       Labels:* None
       Part No SW: 81A 857 511 H    HW: 81A 857 511 H
       Component: FLA           H10 0003
       Revision: AB001001
       Coding: 0404001D00010001000001
       ASAM Dataset: EV_HighBeamAssisAU724 001007
       ROD: EV_HighBeamAssisAU724.rod
       VCID: 2D070E0DED94771F521-8078
    Address 22: AWD (J492)       Labels: None
       Part No SW: 4S0 907 160     HW: 4S0 907 160
       Component: 4 Wheel Drive H07 0207
       Revision: 00001002    Serial number: BBPX5BD
       ASAM Dataset: EV_AllWheelContrBORGLB724 006012
       ROD: EV_AllWheelContrBORGLB724.rod
       VCID: 6E85C90120124C072BB-803A
       Component: MEM-FS        001 0020
       Revision: AA001003    Serial number: 00000184364314
       Coding: 00181900000420F1C00001210101210000000000000000
       Component: SARA 6D red   H04 0056
       Revision: --------    Serial number: EJ1BPA7E02LNV6
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 372B2C651FC8CDCF38D-8062
       Coding: 011C53425000000300000402
       VCID: 47CB5CA56FA8BD4F48D-8012
       Part No SW: 4S0 909 144 H    HW: 4S0 909 144 B
       Component: EPS           H13 0905
       Revision: 00000000    Serial number:      L00189128
       Coding: 0903
       ASAM Dataset: EV_EPSZFAU72X 003010
       ROD: EV_EPSZFAU72X_003.rod
       VCID: 3A2D35512CDAD0A7C73-806E
       Revision: 00002001    Serial number: 0431027138
       Coding: 0106069A00F2D081E0B0CA00008500000001000000000000000000000000
       Subsystem 1 - Part No SW: 4S0 959 719 A    HW: 4S0 959 719 A
       Component: GTO BF  H01 0010
       Serial number: 20170116081838 00131
       Subsystem 3 - Part No SW: 4G8 959 252 A    HW: 4G8 959 252
       Component: HSP-SG  H11 0031
       Serial number: WA125170000025282231
    00317 - Rear Lid Control Module (J605)
                        Reset counter: 10
                        Mileage: 14353 km
                        Date: 2020.01.31
                        Time: 16:30:46
       Coding: 011C53425E00000300000400
       VCID: 46D551A168A2A447B3B-8012
       Part No SW: 4S0 907 801     HW: 8K0 907 801 J
       Component: EPB-4         H03 0001
       Revision: --------    Serial number: 20000000003169
       ROD: EV_ParkiBrake_AU72.rod
       VCID: 70B9D7793A265AF7397-8024
       Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0115
       Coding: 077A081122600400
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005011
       VCID: 3635216118C234C723B-8062
       Subsystem 1 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H09 0008
       Coding: E02200
       Subsystem 2 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H09 0008
       Coding: E02200
       Part No SW: 4S0 035 025 B    HW: 4S0 035 025
       Component: MU-H-LNS-US   053 0907
       Serial number: A353B0H7515387
       Coding: 012704020000000013220002041A00102F0000E1007000047E
       ASAM Dataset: EV_MUHig6C8Gen2HBAS 001182
       ROD: EV_MUHig6C8Gen2HBAS.rod
       VCID: 2809FF19C2765237A17-807C
       Subsystem 1 - Part No SW: V03 959 801 GG    HW: -----------
       Component: NAR 2017  --- 0057
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 4S1 919 614 D    HW: 4S1 919 614 D
       Serial number: APVAK123121600010145
       Component: Gracenote2---  --- 3011
              B11CF 53 [009] - Deactivated
                        Reset counter: 2
                        Mileage: 14228 km
                        Date: 2020.01.22
                        Time: 14:06:05
                        Voltage terminal 30: 14.2 V
                        Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                        Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
    Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
       Part No SW: 4H0 907 273 D    HW: 4H0 907 273 B
       Component: RDKBERU25     H10 0900
       Serial number: 10000000037129
       ROD: EV_RDKBERU25_AU57.rod
       VCID: 2C010309D68E7E1745F-8078
    Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
       Part No SW: 4S0 980 556 A    HW: 95B 980 551 L
       Component: RVC Compact   H12 0201
       Coding: 027504010A000001000040
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
       ROD: EV_CamSysRVRVCPANAAU57X_002_AU72.rod
       VCID: 392F2A5D29DCDBBFCE9-806C
       Part No SW: 4S1 713 041 E    HW: 4M1 713 041 F
       Component: GSM-LL        H09 0073
       Revision: 0L0D5012    Serial number: 20161110001621
       ROD: EV_GSMWaehlZFAU736.rod
    Address A6: Microphone (J886)       Labels:. 420-907-394.clb
       Part No SW: 420 907 394 B    HW: 420 907 394
       Component: BELTMICBOX    H10 0820
       Coding: 0101030202
       ASAM Dataset: EV_BeltMicPARAGAU335 003011
       ROD: EV_BeltMicPARAGAU335.rod
       VCID: 1869CFD97216E2B7117-804C
    0112 - Microphone 3 for Drivers Side
              B1205 13 [009] - Open Circuit
                        Reset counter: 2
                        Mileage: 14228 km
                        Date: 2020.01.22
                        Time: 14:05:41
    Address C2: Auto Trans 2 (J217)       Labels: None
       Part No SW: 4S0 927 109     HW: 4S0 927 109
       Component: DL800 ZSG     H12 0002
       Revision: --H12---    Serial number: 0000000025
       Coding: 000001
       ASAM Dataset: EV_TCMDL800421 001024
       ROD: EV_TCMDL800.rod
       VCID: 73B3D8754B3061EFC45-8026
    New User
    Mar 2020
    Mexico
    Quote Originally Posted by DrMike View Post
       Revision: NHH56---
       Revision: 00H10V01
              U1111 00 [008] - -
                        Reset counter: 50
                        Mileage: 14346 km
                        Date: 2020.01.31
                        Time: 16:09:52
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: E4
                        Uz: 99
    00956 - Key 2
                        Reset counter: 8
                        Mileage: 14340 km
                        Date: 2020.01.31
                        Time: 15:13:51
       Coding: 3247FD
       Coding: 02005D
       Revision: NHH56---
       Coding: 000034
    16777088 - Databus
                        Reset counter: 50
                        Mileage: 14346 km
                        Date: 2020.01.31
                        Time: 16:09:53
       Coding: 802103161C
       Coding: 0D0000
       Revision: AB001001
       ROD: EV_SARA2.rod
       Coding: 0903
                        Reset counter: 10
                        Mileage: 14353 km
                        Date: 2020.01.31
                        Time: 16:30:46
       Coding: E02200
       Coding: E02200
                        Reset counter: 2
                        Mileage: 14228 km
                        Date: 2020.01.22
                        Time: 14:06:05
       Coding: 0101030202
                        Reset counter: 2
                        Mileage: 14228 km
                        Date: 2020.01.22
                        Time: 14:05:41
       Coding: 000001
    Hi, anyone found the solution for this?
