Having the same issue with a 2017 r8v10 (non-plus). Am trying to disable the the automatic rear spoiler.
Found "rear spoiler" in "46 central conv" and unchecked it. This resulted in the manual spoiler button becoming non-functional (anticipated), the spoiler changing to deployed and remaining that way (unanticipated), and 2 warning lights in the instrument cluster. Went back in and re-enabled "rear spoiler" (in 46 central conv) and all functions (and warning lights) returned to normal. HOWEVER, I do see some "malfunction" indications in the autoscan which were likely just created.
here is a copy of the auto-scan .... any help in disabling the rear spoiler would be appreciated
Friday,31,January,2020,16:59:04:21655
VIN: WUAEAAFX3H7904380 License Plate:
Mileage: 14353km-8918mi Repair Order:
Chassis Type: FX-AU72 (4S0)
Scan: 01 02 03 05 06 08 09 11 31 14 15 16 17 19 1B 20 22 36 3B 42
44 46 52 53 55 5F 65 6C 81 A6 C2
VIN: WUAEAAFX3H7904380 Mileage: 14353km-8918miles
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
A6-Microphone -- Status: Malfunction 0010
C2-Auto Trans 2 -- Status: OK 0000
Address 01: Engine (------CSPB) Labels: None
Part No SW: 4S0 907 552 H HW: 4T0 907 552 A
Component: 5.2l V10HDZ / H56 0003
Revision: NHH56---
Coding: 1A2500320526000D3000
Shop #: WSC 03993 003 1048576
ASAM Dataset: EV_ECM52FSI1114S0907552H 001003
ROD: EV_ECM52FSI1114S0907552G.rod
VCID: 3B23305523E0E9AFDC5-806E
Address 02: Auto Trans (J217) Labels: None
Part No SW: 4S0 927 155 G HW: 0BH 927 711 F
Component: AU 6E SB NAR H10 3914
Revision: 00H10V01
ASAM Dataset: EV_TCMDL800041 001013
ROD: EV_TCMDL800041_AU72.rod
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4S0 907 379 D HW: 4S0 907 379 D
Component: ESP PREMIUM H09 0300
Coding: 01A9C10B809583D04B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004048
ROD: EV_ESPPremiAU57X_AU72.rod
VCID: 3E25394130F2FC87FBB-806A
0668 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[ComScl_PDU_HSP_01_Timeout]
Reset counter: 50
Mileage: 14346 km
Date: 2020.01.31
Time: 16:09:52
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: E4
Uz: 99
Part No SW: 4H0 907 064 JD HW: 4H0 907 064 JD
Component: BCM2 2.0 H44 0582
Coding: 0D806506000000000000
VCID: 74B1DB694EBE66D7DDF-8020
Serial number: 3216000310185011
00956 - Key 2
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 8
Mileage: 14340 km
Date: 2020.01.31
Time: 15:13:51
Part No SW: 4S0 959 760 HW: 4S0 959 760
Component: MEM-BFS 001 0020
Revision: AA001003 Serial number: 00000184364315
Coding: 00001000000420F1000001210101210000000000000000
VCID: 7BA3F05563E029AF9C5-802E
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4S0 820 043 K HW: 4S0 820 043 K
Component: AC Automat H08 0040
Revision: 20012000 Serial number: 96800000005805
Coding: 4000A01000000410
ASAM Dataset: EV_AirCondiVAPrehAU72x 003005
ROD: EV_AirCondiVAPrehAU72x.rod
VCID: 333318750BB021EF045-8066
Operating and display unit 2 for air conditioning:
Subsystem 1 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Serial number: 00000000000000007211
Operating and display unit 3 for air conditioning:
Subsystem 2 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Operating and display unit 4 for air conditioning:
Subsystem 3 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 HK HW: 4H0 907 063 EK
Component: BCM1 2.0 H21 0725
Revision: 2502102S Serial number: 00001565960402
Coding: 010D0011143C9FF07D0048C380001800C59CD2882A08322100040894F1001100006000340B0000
VCID: 78A9EF5952D602B7F17-802C
Subsystem 1 - Part No SW: 4S1 955 119 B HW: 8V2 955 119 A
Component: WWS624 170122 043 0081
Serial number: 90248162170206144405
Coding: 3247FD
Component: G397_RLFS H06 0004
Serial number: 62551774
Coding: 02005D
Subsystem 3 - Part No SW: 4S0 941 531 HW: 4S0 941 531
Component: E1 - LDS H01 0044
Serial number: 30 01 2017 00000668
Component: USHL4.2 H30 0030
Serial number: 00000000095Z02AF2C24
Subsystem 5 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 76E80C8800PAG0MUFU03
Address 11: Engine II (-----) Labels: None
Revision: NHH56---
ASAM Dataset: EV_ECM52FSI2114S0907552H 001003
ROD: EV_ECM52FSI2114S0907552G.rod
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 4S0 907 376 D HW: 4S0 907 376 C
Component: DAEMPFUNGS-SG H06 0064
Serial number: 061216073
ASAM Dataset: EV_AudiMagneRide 002008
ROD: EV_AudiMagneRide.rod
Address 15: Airbags (J234) Labels:* None
Part No SW: 4S0 959 655 HW: 4S0 959 655
Component: Airbag10.43 H62 0204
Revision: -------- Serial number: 003NJ0015NTH
Coding: 303338453036303038324A55304C34533053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001036
VCID: 7EA5F94170723C87BBB-802A
Serial number: 6940000Y160001K3RX0F
Serial number: 3575HRB405J49IMAE14D
Serial number: 3585HRB4063480GQCP8G
Serial number: 3515JRB400A598PGA1I5
Serial number: 3525JRB4016599BCII81
Serial number: 3554VRB40165971EA9UA
Serial number: 3564VRB40185971ES10-
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4S0 907 129 K HW: 4S0 907 129 K
Component: Lenks.Modul H06 0007
Revision: C0071527 Serial number: 91335QAO00414-
Coding: 000034
VCID: 3E2539413072FC87FBB-806A
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4S0 920 890 A HW: 4S0 920 890 A
Component: FBenUSA H14 0251
Coding: 086F30C1BA81CF050230ECC41800801000000000
ASAM Dataset: EV_DashBoardBOSCHAU724 001022
ROD: EV_DashBoardBOSCHAU724.rod
VCID: 34311B690EBE26D71DF-8060
16777088 - Databus
[HSP_01 communication error can_error_timeout]
Reset counter: 50
Mileage: 14346 km
Date: 2020.01.31
Time: 16:09:53
Part No SW: 4S0 907 468 B HW: 4S0 907 468 A
Component: J533--Gateway H15 0074
Revision: -------- Serial number: 00000002514206
Coding: 802103161C
ASAM Dataset: EV_GatewPkoUDS 002000
Subsystem 1 - Part No SW: 4S0 915 181 HW: 4S0 915 181
Component: J367-BDM H08 0270
Serial number: 54026A19542871129320
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 0D0000
VCID: 3A2D35512C5AD0A7C73-806E
Address 20: High Beam Assist. (J844) Labels:* None
Part No SW: 81A 857 511 H HW: 81A 857 511 H
Component: FLA H10 0003
Revision: AB001001
Coding: 0404001D00010001000001
ASAM Dataset: EV_HighBeamAssisAU724 001007
ROD: EV_HighBeamAssisAU724.rod
VCID: 2D070E0DED94771F521-8078
Address 22: AWD (J492) Labels: None
Part No SW: 4S0 907 160 HW: 4S0 907 160
Component: 4 Wheel Drive H07 0207
Revision: 00001002 Serial number: BBPX5BD
ASAM Dataset: EV_AllWheelContrBORGLB724 006012
ROD: EV_AllWheelContrBORGLB724.rod
VCID: 6E85C90120124C072BB-803A
Component: MEM-FS 001 0020
Revision: AA001003 Serial number: 00000184364314
Coding: 00181900000420F1C00001210101210000000000000000
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E02LNV6
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372B2C651FC8CDCF38D-8062
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011C53425000000300000402
VCID: 47CB5CA56FA8BD4F48D-8012
Part No SW: 4S0 909 144 H HW: 4S0 909 144 B
Component: EPS H13 0905
Revision: 00000000 Serial number: L00189128
Coding: 0903
ASAM Dataset: EV_EPSZFAU72X 003010
ROD: EV_EPSZFAU72X_003.rod
VCID: 3A2D35512CDAD0A7C73-806E
Revision: 00002001 Serial number: 0431027138
Coding: 0106069A00F2D081E0B0CA00008500000001000000000000000000000000
Subsystem 1 - Part No SW: 4S0 959 719 A HW: 4S0 959 719 A
Component: GTO BF H01 0010
Serial number: 20170116081838 00131
Subsystem 3 - Part No SW: 4G8 959 252 A HW: 4G8 959 252
Component: HSP-SG H11 0031
Serial number: WA125170000025282231
00317 - Rear Lid Control Module (J605)
Reset counter: 10
Mileage: 14353 km
Date: 2020.01.31
Time: 16:30:46
Component: TSG BF H03 0511
Coding: 011C53425E00000300000400
VCID: 46D551A168A2A447B3B-8012
Part No SW: 4S0 907 801 HW: 8K0 907 801 J
Component: EPB-4 H03 0001
Revision: -------- Serial number: 20000000003169
ROD: EV_ParkiBrake_AU72.rod
VCID: 70B9D7793A265AF7397-8024
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Coding: 077A081122600400
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005011
VCID: 3635216118C234C723B-8062
Subsystem 1 - Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0008
Coding: E02200
Subsystem 2 - Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0008
Coding: E02200
Part No SW: 4S0 035 025 B HW: 4S0 035 025
Component: MU-H-LNS-US 053 0907
Serial number: A353B0H7515387
Coding: 012704020000000013220002041A00102F0000E1007000047E
ASAM Dataset: EV_MUHig6C8Gen2HBAS 001182
ROD: EV_MUHig6C8Gen2HBAS.rod
VCID: 2809FF19C2765237A17-807C
Subsystem 1 - Part No SW: V03 959 801 GG HW: -----------
Component: NAR 2017 --- 0057
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 4S1 919 614 D HW: 4S1 919 614 D
Component: ControlUnit_H H30 0206
Serial number: APVAK123121600010145
Component: Gracenote2--- --- 3011
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Reset counter: 2
Mileage: 14228 km
Date: 2020.01.22
Time: 14:06:05
Voltage terminal 30: 14.2 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 D HW: 4H0 907 273 B
Component: RDKBERU25 H10 0900
Serial number: 10000000037129
ROD: EV_RDKBERU25_AU57.rod
VCID: 2C010309D68E7E1745F-8078
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 A HW: 95B 980 551 L
Component: RVC Compact H12 0201
Coding: 027504010A000001000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
ROD: EV_CamSysRVRVCPANAAU57X_002_AU72.rod
VCID: 392F2A5D29DCDBBFCE9-806C
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4S1 713 041 E HW: 4M1 713 041 F
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20161110001621
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736.rod
Address A6: Microphone (J886) Labels:. 420-907-394.clb
Part No SW: 420 907 394 B HW: 420 907 394
Component: BELTMICBOX H10 0820
Coding: 0101030202
ASAM Dataset: EV_BeltMicPARAGAU335 003011
ROD: EV_BeltMicPARAGAU335.rod
VCID: 1869CFD97216E2B7117-804C
0112 - Microphone 3 for Drivers Side
B1205 13 [009] - Open Circuit
Reset counter: 2
Mileage: 14228 km
Date: 2020.01.22
Time: 14:05:41
Address C2: Auto Trans 2 (J217) Labels: None
Part No SW: 4S0 927 109 HW: 4S0 927 109
Component: DL800 ZSG H12 0002
Revision: --H12--- Serial number: 0000000025
ASAM Dataset: EV_TCMDL800421 001024
ROD: EV_TCMDL800.rod
VCID: 73B3D8754B3061EFC45-8026
