Results 1 to 10 of 15
Thread: 2003 Audi RS6 ECU checksum error / inability to activate ABS bleed procedure
    Apr 2018
    When i use the VCDS to scan the car engine module i inevitably get the following error which returns immediately upon clearing:
    16985 - Internal Control Module
    P0601 - 001 - Memory Check Sum Error - MIL ON
    first of all - my MIL won't ever illuminate. i suspect this is due to the MTM chip installed as i do recall seeing it when the stock chip is returned and key in ignition. However, the error remains even when stock chip is re-installed.
    my question is twofold - is there a way to fix this error short of a new/refurb. ECU (i.e. can it be repaired by myself?), and also, would this error prevent me from cycling the ABS bleed procedure?
    when i try to start the ABS procedure with the 'start' button in output tests, it just does nothing and forces me to hit 'done'. the ABS system has no errors, it's 5.7 and the system operates fine. i've tried the generic login and also the soft codes version. Neither avenue helps in activating the ABS pump. Nor did trying to activate it w/ brake pedal depressed or car running.
    I can run the test just fine on my audi a6 2000 with the same cable and laptop, so i don't think they're the problem.
    Any/all insight greatly appreciated. i think i have a pretty good grasp of the car as i've removed the engine (twice...), replaced fuel tank, rebuilt the turbos, alternator, replaced an intake valve and master cylinder amongst other frustrating procedures. So don't hesitate to suggest solutions that seems too deep in the weeds, although simple solutions are obviously preferred. ;-)
    I would imagine there are people who could probably fix that, but I don't visualize it as a DIY project.
    Where are you seeing a bleed procedure for this ABS that calls for the use of a scan-tool?
    We generally appreciate users posting a complete Auto-Scan, which often contains valuable context.
  3. Likes cullenvb liked this post
    Dallas (McKinney) ,TX ,USA
    Quote Originally Posted by cullenvb View Post
    Most likely your problem with ECU internal fault is you MTM chip.Second hand ECU can be install , but If you put used ECU , it has to be programed , it is not plug and play.
    Is the chip mounted in ECU our like plug to ECU harness?
    For ABS like UWE said post autoscan .
    Out of curiosity , why you want to bled your brakes if your working good like you mention?
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  5. Likes Uwe, cullenvb liked this post
  6. #4
    Apr 2018
    Friday,04,May,2018,12:25:37:35104
    VIN: WUAPV64B63N904881   License Plate:
              75 76 77
    Address 01: Engine        Labels: 077-907-558-BCY.lbl
       Part No: 4D1 907 558 D
       Component: 4.2l V8/5VT     G   0003
       Coding: 0006752
       Shop #: WSC 00000 785 00200
       VCID: 2F381A73AB05DE7FDB2-5160
    Address 02: Auto Trans        Labels: 01L-927-156.lbl
       Part No: 4B0 927 156 FL
       Component: AG5 01L 4.2l5VT USA 0305
       VCID: 76B6EF1714DFAFB7584-5160
    Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
       Part No: 4B0 614 517 AD
       Component: ESP 5.7 RS 6        2310
       Coding: 06697
       Shop #: WSC 12345
       VCID: 6390A643B24D2A1F0FA-51F2
       Part No: 4B0 959 760 C
       Component: Sitzmemory R1 BF    0205
       Coding: 00003
       VCID: 2D04007BA439AC6FE9E-4AE0
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AR
       Component: A6-Klimavollautomat 0208
       Coding: 00010
       VCID: 6A8ECB6755577B57CCC-2580
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4B0 959 655 Q
       Component: Airbag 8.4EP        3001
       Coding: 0000607
       VCID: 3E2637377C6F27F7404-5184
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4B0 920 983 D
       Component: KOMBI+WEGFAHRS. VDO D13
       Coding: 03284
       Shop #: WSC 02301
       VCID: 290CF46B90E1B04F056-5160
       WUAPV64B63N904881     AUZ7Z0C2409246
    Address 35: Centr. Locks        Labels:. 4B0-962-258.lbl
       Part No: 4B0 962 258 M
       Component: Central Lock/Alarm  D38
       Coding: 15885
       VCID: 33301603421DFA9FBFA-4EEA
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0204
       Coding: 00001
       VCID: 2C020D7F9F23A567FE0-4AE0
       Part No: 4Z7 907 357
       Coding: 00050
       VCID: 045285DF57338D27560-4B00
       Part No: 4B0 035 195 N
       Component: symphony II NP2    0260
       Coding: 00221
       Shop #: WSC 67840
       VCID: 2B000E639A2DA25FF7A-4FFC
                49-00 - No Communications
                36-00 - Open Circuit
    Address 76: Park Assist        Labels: 8Z0-919-283.lbl
       Part No: 8Z0 919 283
       Component: Parkingsyst. A6 RDW D08
       Coding: 01116
       VCID: 025E83C74D27831764C-513C
    End----------(Elapsed Time: 04:33, VBatt start/end: 12.3V/12.2V)-----------
    Apr 2018
    I had a brake pedal that would fall to the floor if pushed with enough effort. I solved the problem - which i'll discuss in another post as it may help others in my situation - but until then I had assumed there was air in the ABS pump/module.
    so, for the bleeding procedure that calls for a scan tool I went to ABS brakes (3), output tests (3), and start/next. as soon as I hit that button I get output test sequence complete. there is no activation of the ABS pump whatsoever. thanks!
    Apr 2018
    You may be right w/ the internal fault source, but i did ship the ECU to the original installer who bench-tested it. he found the chip slightly dislodged, but otherwise it passed his tests - for whatever that's worth. he then returned the ECU to me along w/ the OE chip. that's why i said when i swapped chips and continued to see the check sum error i felt it was the ECU at fault. the chip is mounted onto the ECU board's pins, not plugged into the harness, if that helps.
    brakes are working well now solely b/c of the recent bleedings. over the course of 2-3 years the brakes got new pads/rotors, new brake lines and i put in a new master cylinder. so obviously i introduced air into the system. long story short, the solution i found was to retract the pistons fully then power bleed. i had bubbles hanging out within the calipers' piston bores. This was hugely magnified due to fact the front calipers have 8 pistons each. So now with the vacuum assist purged post-shut off, the pedal play is limited to the movement within the brake booster itself and not much more.
    until i discovered this trick myself, i had been resigned to thinking air must be within the ABS pump and because i couldn't activate it i was going to have to live with it. thanks.
  9. Likes Uwe liked this post
  10. #7
    Apr 2018
    Europe
    Hello , if I am right this car has ME 7.1.1. ecu. This dtc I saw several times on remapped me 7.1.1 cars. But mostly a tuner can fix it. But it's really strange that the problem remains when ecu is put back to stock.
    As far as I know the mil lamp on does not affect driveability of the car, but when light is always on, you won't notice other issues.
    Best regards
    John
  11. Likes cullenvb liked this post
  12. #8
    I can tell you what........... I have brand new RS6 ECU's...in the factory box & reman ..........
    https://www.ebay.com/itm/AUDI-03-04-...MAAOSw0JpV5J5f
    I highly recommend getting one of these though if playing real RS6.....
    http://www.bosch-motorsport.de/media...2775343627.pdf
  13. Likes cullenvb, Fredrick Awuor liked this post
  14. #9
    Apr 2018
    thank you John. i believe you are correct ME 7.1.1. i mailed the tuner my ecu with the MTM chip (after i noticed the Check sum error) and he was unable to see the error, which confounds me.
    As for the MIL lamp, it's not so much drivability, it's the fact it NEVER comes on - even when a scan shows a code indicating "MIL on". Nor does it appear when i initially inset the key before start-up. Yet i know the MIL lamp itself works as it does briefly show up on start-up w/ the stock chip reinstalled. So is this a known manifestation of the MTM chip mod? In hindsight i'm led to believe MTM was not the best choice for chipping the RS6, but i'm not about to cry about spilt milk.
    Is there a definitive answer in terms of the repairability of the ecu (via flashing?)? And if the answer is that i'll need another ECU, is that a simple plug and play or is there a dealer intervention necessary?
  15. #10
    I gave you answer in Post #3,
    no it is not plug and play. But do not need to go to dealer . I can do programing if you need it.
    Also it does not have to be new ECU, you can get used ECU as well and it can be programed.
    Immobilizer/ECU
