Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 2003 Audi RS6 ECU checksum error / inability to activate ABS bleed procedure
    I program my ecu's for identity transfer "free"..............
    I bet I can make you a backup of that shitty chip to CD file.
    Then you can get that POS soldered tower out of that ECU & load the file to an off road unit with no VIN number for race track.
  2. #12
    Apr 2018
    you're right, i mis-read your point to mean aftermarket chips being plug/play.
    so you're contending the only solution with an ECU check sum error is replacement (used or new)?
    In other words your programming and/or dealer flashing won't solve the problem because the unit itself is faulty?
  3. #13
    Apr 2018
    thanks for all the feedback. long story short - i mailed the ECU to MTM in germany. they sent back a generic ECU with a soldered MTM chip on it. that eliminated the ECU check sum error code. 2 ECU repair shops previously passed on fixing this unit.
    i'm still not able to cycle the abs pump, but i think now it's more of a function of the ABS hardware that came with the car. The check sum error had permanently turned off the MIL light and failed to notify of secondary air injection issues. and that's just what i was able to catch.
    so thanks again. this ticks off a box that really bothered me. with all the work i've done (turbos, fuel tank, oil cooler, valve, suspension, etc.), i'm down to replacing a few squeaky poly bushings with stock ones - which is a nice problem to have vis-a-vis past issues.
  4. #14
    Post a new auto-scan and right after clearing the codes let me show you something.........
  5. Likes Fredrick Awuor liked this post
  6. #15
    Apr 2018
    (headlight error was just due to disconnected range finder)
    Friday,14,December,2018,14:48:01:35104
    VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WUAPV64B63N904881   License Plate:
    Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
              75 76 77
    Address 01: Engine        Labels: 077-907-558-BCY.lbl
       Part No: 4D1 907 558 D
       Component: 4.2l V8/5VT     G   0003
       Coding: 0006752
       Shop #: WSC 00000 785 00200
       VCID: 2F381A73AB05DE7FDB2-5160
    Readiness: 0000 1101
    Address 02: Auto Trans        Labels: 01L-927-156.lbl
       Part No: 4B0 927 156 FL
       Component: AG5 01L 4.2l5VT USA 0305
       VCID: 76B6EF1714DFAFB7584-5160
       Part No: 4B0 614 517 AD
       Component: ESP 5.7 RS 6        2310
       Coding: 06697
       Shop #: WSC 12345
       VCID: 6390A643B24D2A1F0FA-51F2
    Address 06: Seat Mem. Pass        Labels: None
       Part No: 4B0 959 760 C
       Component: Sitzmemory R1 BF    0205
       Coding: 00003
       VCID: 2D04007BA439AC6FE9E-4AE0
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AR
       Component: A6-Klimavollautomat 0208
       Coding: 00010
       VCID: 6A8ECB6755577B57CCC-2580
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4B0 959 655 Q
       Component: Airbag 8.4EP        3001
       Coding: 0000607
       VCID: 3E2637377C6F27F7404-5184
       Part No: 4B0 920 983 D
       Component: KOMBI+WEGFAHRS. VDO D13
       Coding: 03284
       Shop #: WSC 02301
       VCID: 290CF46B90E1B04F056-5160
       WUAPV64B63N904881     AUZ7Z0C2409246
    Address 35: Centr. Locks        Labels:. 4B0-962-258.lbl
       Part No: 4B0 962 258 M
       Component: Central Lock/Alarm  D38
       Coding: 15885
       VCID: 33301603421DFA9FBFA-4EEA
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0204
       Coding: 00001
       VCID: 2C020D7F9F23A567FE0-4AE0
       Part No: 4Z7 907 357
       Coding: 00050
       VCID: 045285DF57338D27560-4B00
    00776 - Level Control System Sensor; Left Front (G78)
                28-10 - Short to Plus - Intermittent
    Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
       Part No: 4B0 035 195 N
       Component: symphony II NP2    0260
       Coding: 00221
       Shop #: WSC 67840
       VCID: 2B000E639A2DA25FF7A-4FFC
                49-00 - No Communications
                36-00 - Open Circuit
    Address 76: Park Assist        Labels: 8Z0-919-283.lbl
       Part No: 8Z0 919 283
       Component: Parkingsyst. A6 RDW D08
       Coding: 01116
       VCID: 025E83C74D27831764C-513C
    End----(Elapsed Time: 04:47, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
