Results 1 to 10 of 13
Thread: Eco Mode Seat Ateca 2018
    Apr 2018
    The eco mode on my Ateca is not saved which means that I have to turn it back on every time I restart the engine. On my previous Seats eco mode remained operational until I decided to change it. The indicator light says it's in eco mode but in fact it is in drive. Is there anyway via my VCDS cable to save eco mode rather than having to reset it all the time. Any advice would be appreciated.
    Please post an Auto-Scan so people can see how this vehicle is equipped and configured.
    We don't all have a 2018 Ateca handy to check out, and even if we had one, there's a good chance that it would be equipped differently than yours.
    Tartu, Estonia
    Quote Originally Posted by aggie View Post
    Altough i agree with Uwe to post autoscan, as a general rule of this forum on every topic asking about help for a car, the same happens on my MY2018 Leon.
    It also applies to ewery other mode also(Individual and Sport), Gearbox goes back to Drive mode.
    The world is my oyster...
    The same reverting to Drive mode has been commented on by owners of 2018 Skoda Octavia cars - seems VAG have changed the behaviour on most (all?) 2018 models.
    My guess is that this is to improve the real world fuel consumption and emissions figures that will be published soon in the EU.
    Apr 2018
    The diagnostic print out for my Seat Ateca with the eco mode problem which I hope can be altered with my VCDS cable.
    Friday,02,March,2018,15:34:21:64486
    VCDS Version: 18.2.0.3 (x64)
    VIN: VSSZZZ5FZJ6537554   License Plate: W6AGY
    Mileage: 4796km-2980mi   Repair Order:
    Chassis Type  5F-SE37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 4B 52 5F 6D
    VIN: VSSZZZ5FZJ6537554   Mileage: 4796km-2980miles
    4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 JT    HW: 04E 907 309 BJ
       Component: R4 1.4l TFS   H24 3750
       Revision: R6H24---
       Coding: 01250072232405083000
       Shop #: WSC 33361 790 00134
       ASAM Dataset: EV_ECM14TFS01104E906027JT 001005
       ROD: EV_ECM14TFS01104E906027JT_AU37.rod
       VCID: 7F0DDD53E6069ABC61-802A
       CAN Converter 01:
    4178 - Fuel Injection Malfunction
              P0148 00 [101] - -
                        Mileage: 4718 km
                        Date: 2018.02.28
                        Time: 16:01:14
                        Engine speed: 880.50 /min
                        Normed load value: 25.5 %
                        Coolant temperature: 34 �C
                        Intake air temperature: 22 �C
                        Voltage terminal 30: 12.604 V
                        High fuel pressure: specified value: 14.3565 MPa
                        Fuel high pressure: actual value: 0.2555 MPa
                        High fuel pressure: regulator output value: 8.2780 MPa
                        Low fuel pressure: specified value: 497.9 kPa
                        Fuel pump: specified value: 55.391 %
                        Low fuel pressure adaptation value for EFP: modeled: 120.0 kPa
                        Fuel level: 50.00 l
       Part No SW: 0CW 300 042 H    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1603
       Revision: 00005008    Serial number: CU501710237712
       ROD: EV_TCMDQ200021_AU27.rod
       VCID: 3B75E943B29E469C0D-806E
       Part No SW: 5Q0 614 517 CQ    HW: 5Q0 614 517 AC
       Component: ESC           H25 0423
       Revision: 00000000    Serial number: 63067000001148
       Coding: 21EE8A9234232473877C060562C72484512C24E1604624733022F074C202430B002D641212131A1E35351919323200
       ROD: EV_Brake1UDSContiMK100IPB_037_VW27.rod
       VCID: 020B54A795F4F7540E-8056
       Component: VWKESSYMQB    037 0907
       Revision: 00037000    Serial number: 0460094714
       Coding: 132C0C0707
       VCID: 3E73E057A18C53B42A-806A
       Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
       Component: GEB.F.Heckoef  H17 0903
       Serial number: 98297778
       Part No SW: 5F0 907 044 AL    HW: 5F0 907 044 AL
       Component: Climatronic   H05 1801
       Revision: 00001K09
       Coding: 06100004200114011005000100101020
       Shop #: WSC 33361 790 00116
       VCID: 70EF0E6FAB58F5C4E8-8024
       Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
       Component: BCM MQBAB H   H36 0253
       Serial number: 01001731201065
       ROD: EV_BCMCONTI.rod
       VCID: 0919438BA8C2A40C4F-805C
       Subsystem 1 - Part No SW: 81A 955 555 A    HW: 81A 955 555
       Serial number: 20849467X81A955555A0
       Coding: 80007E
       Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
       Serial number: 000000000ZY1719016KA
       Subsystem 3 - Part No SW: 5QD 951 605     HW: 5QD 951 605
       Serial number: 00002856223972824118
       Part No SW: 5QA 919 283 B    HW: 5QA 919 283
       Component: PDC 4 KanalH07 0044
       Serial number: 000308419617305
       Coding: 0601150011
       ASAM Dataset: EV_EPHVA14AU3700000 009033
       ROD: EV_EPHVA14AU3700000_009_AU37.rod
       VCID: 4999838BE842E40C8F-801C
       Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H02 0233
       Coding: 3200608150FF8728749C8165004087
       Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
       Component: Airbag VW21   006 0703
       Revision: --------    Serial number: 003W4PNELF7F
       Coding: 98CCC0C0000000005C5400CC008800000065
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 05014FBB84DAC06C2B-8050
       Subsystem 1 - Part No SW: -----------    HW: 454 001 710 17
       Serial number: 3570000000035DE4992V
       Subsystem 2 - Part No SW: -----------    HW: 454 001 810 17
       Serial number: 358000000005C51C4A2O
       Subsystem 3 - Part No SW: -----------    HW: 454 802 610 17
       Serial number: 35100E67044120000004
       Subsystem 4 - Part No SW: -----------    HW: 454 802 610 17
       Serial number: 35200A98F3912000000O
       Subsystem 5 - Part No SW: -----------    HW: 454 801 610 17
       Serial number: 355006D912812000000C
       Part No SW: 5Q0 953 507 HR    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 07111704400667
       Coding: 1414
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 0D11779BDCAAB82C63-8058
       Part No SW: 5F0 920 950 E    HW: 5F0 920 950 E
       Component: KOMBI         303 0310
       Coding: 27A4221A2B80060001886A011000000080000000
       Shop #: WSC 73430 031 00134
       VCID: 2959230B4802C40C6F-807C
       Component: GW MQB High   518 5323
       Serial number: 04111710801808
       Coding: 030500F42F085700EB0002481C0F00010001070000000000000000000000
       Shop #: WSC 33361 790 00114
       ROD: EV_GatewNF_SE27.rod
       VCID: 387FF64F83A86D84E0-806C
       Subsystem 2 - Part No SW: 5F0 959 537 D    HW: 5F0 959 537 D
       Serial number: 000000000H0345220917
       Coding: 012000
       Serial number: 75886000001710300D15
       Serial number: 17000306853017
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71E90B6BA052FCCCE7-8024
       Serial number: 0000287753546
       Coding: 00311220D001040000001000
       VCID: 479D85B3FE56127C99-8012
       Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000017332272
       Coding: 3D0000
       Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
       Component: EPS_MQB_ZFLS  507 5081
       Coding: 811F0000
       Shop #: WSC 33361 790 00163
       ROD: EV_SteerAssisMQB_015.rod
    Address 4B: Multifunc. Module
    Interface not compatible.
       Serial number: 0000287339938
       VCID: 468388B7F95C0B7462-8012
       Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000017231050
       Coding: 250000
    Address 5F: Information Electr. (J794)       Labels:* 5F0-035-MIB-STD2.clb
       Part No SW: 5QA 035 858 B    HW: 5QA 035 858 B
       Component: MU-S-ND-ER    H41 0468
       Serial number: SEZAZ2T1248258
       Coding: 04238601D70A000011110101008808232F0100D601200500C6
       ASAM Dataset: EV_MUStd6C1TSAT 001015
       ROD: EV_MUStd6C1TSAT_SK25.rod
       Subsystem 1 - Part No SW: 575 919 606     HW: 575 919 606
       Component: ABT_High-2_N  H41 1041
       Serial number: SEZ8Z9T1S00WZR
       Subsystem 2 - Part No SW: 6P0 919 866 M    HW: -----------
       Component: ECE1 2017  --- 0730
       Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0261
       Revision: --------    Serial number: 31623791000000
       Coding: 1908
       ROD: EV_DeckLidCONTIAU736_SE37.rod
       VCID: 41899BABD0722C4C57-8014
    End-------------------------(Elapsed Time: 05:08)--------------------------
    Jun 2017
    This behaviour has to do with emission standards and the car has to be in exactly this mode where it was registered/approved into its emission class.
  7. #7
    If it's embedded in the firmware by VAG with no coding or adaptation channel option to change (which is what we suspect) then it's unlikely that the behaviour can be changed.
  8. #8
    Apr 2018
    Thanks PetrolDave , at least I know, now that it cannot be changed which is a pity really as i would like to have remained in Eco Mode without resetting it every time.
  9. #9
    I wouldn't say this is certain.
    Then again, I don't know if it is possible either.
  10. Likes PetrolDave liked this post
  11. #10
    That's not what we've been saying
  12. Likes Uwe liked this post
