Results 1 to 10 of 16
Thread: -07 Jetta and egr change
    Apr 2018
    Hi, new here and from Finland so try to understand my poor english
    So. i changed egr valve and it runs very unstable after that, of course.
    Then i did tba adaptation and tried to do also egr adaptation but it shows error in last box where the values are.
    Valve itself is new and for sure right one, and don´t know what to do next.
    Maybe have to put some basic settings to both first, but how is the question?
    edit: i would put codes here but i forget to send it from my laptop to home.........
    Please post an Auto-Scan so people can see exactly what engine/ECU this car has.
    Apr 2018
    I will do that tomorrow.
  4. Likes Uwe liked this post
    Apr 2018
    So, yesterday i changed the egr valve, drive home couple of miles and while driving the engine light show up.
    When i get home engine wobbles and run badly at idle speed.
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
    VIN: WVWZZZ1KZ7M001334   Mileage: 356800km-221705miles
    Address 01: Engine        Labels: 03C-906-056-BAG.lbl
       Part No SW: 03C 906 056 DP    HW: Hardware No
       Component: MED9.5.10       G00 9029
       Revision: 66H08---    Serial number: VWZ7Z0F4116953
       Coding: 0000072
       Shop #: WSC 00066 000 00000
       VCID: 74B121BE82B01517660-8020
    001031 - EGR Sensor 2
                   P0407 - 004 - Signal too Low
                        Mileage: 356806 km
                        Time: 19:33:53
                        Load: 0.0 %
                        Temperature: 35.0°C
    Readiness: 1110 0101
       Revision: 00H11001
       Coding: 0002689
       VCID: 73B322A287BE122F7FA-8026
       Part No: 1K0 820 047 DQ
       Component: Climatic PQ35   090 0505
       VCID: 76B51BB694CC0707584-8022
       Part No SW: 3C0 937 049 P    HW: 3C0 937 049 P
       Revision: 00H46000    Serial number: 00000000352858
       Coding: 08078E2700041500470A00000F000000000959035C0000
       VCID: 3635DBB6D44C4707984-8062
       Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  013  0402
       Coding: 00063445
       Shop #: WSC 00066
       Component: 2J AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD0JBEU.
       Coding: 0012874
       VCID: 3D27C49AF17A945F59E-8068
       Subsystem 1 - Serial number: 6332MSME0E661B009
       Subsystem 2 - Serial number: 6342MSME0E0B33126
       Subsystem 3 - Serial number: 6351HSME096C6137B
       Subsystem 4 - Serial number: 6361HSME0960221B%
       Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
       Component: Lenksäulenmodul 636 0070
       Coding: 0000041
       VCID: 00597D6EC60839B7728-8054
       Part No SW: 1K0 920 863 A    HW: 1K0 920 863 A
       Revision: V0003000    Serial number: VWZ7Z0F4116953
       Coding: 0023103
       Shop #: WSC 00011 888 06946
       VCID: 290F00CA15F218FF056-807C
       Revision:   H12       Serial number: 31001064140558
       Coding: 3D3F074007001002
       VCID: 2C01F9DE1A000DD7FE0-8078
       Component: IMMO            3HL 1610
       Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
       Component: J386  TUER-SG FT    1125
       Revision: 11006001    Serial number: 00000006168601
       Coding: 0000180
       VCID: 3C21C99EEA609D576E0-8068
       Part No: 1K1 909 144 K
       Component: EPS_ZFLS Kl.5   D06 1701
       VCID: 3333E2A2C73E522FBFA-8066
       Component:    KSG PQ35 G2  020 0202
       Coding: 00900A000106087F2D0484056008CF01E0FCA0
       Shop #: WSC 00020 210 01865
       VCID: 03537262D71E22AF6FA-8056
       Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
       Component: J387  TUER-SG BT    1125
       Revision: 11006001    Serial number: 00000523268606
       Coding: 0000436
       Part No: 1K0 035 186 R
       Component: Radio GR0       019 0023
       Revision: 0001905S    Serial number: VWZ2Z2F1346091
       Coding: 0040400
       VCID: 3537DCBAC94A4C1F91E-8060
       Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
       Component: J388   TUER-SG HL   1115
       Revision: 11005001    Serial number: 00000000064349
       Coding: 0000144
       Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
       Component: J389   TUER-SG HR   1115
       Revision: 11005001    Serial number: 00000000062352
       Coding: 0000144
       VCID: 3E25C396FC7C8F47404-806A
    Address 76: Park Assist        Labels: 1K0-919-283.lbl
       Part No: 1K0 919 283 A
       Component: 12 Einparkhilfe     0101
       VCID: 2D07F4DA211A04DFE9E-8078
    End----(Elapsed Time: 01:13, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
    So what to do next, thanks advance for any help
    Is there any other chances than bad wiring or faulty valve, and how to measure the wirings?
    Apr 2018
    Any ideas??? Thinking of checking that egr cable if looks ok, and then read codes again. And try to reset them, also from engine side if visible there.
    Apr 2018
    I tried to clear fault code from engine module, but it always keep coming back.
    Then i tried again egr adaptation and now it went through, weird.
    After that i read codes and little different came from egr.....
       Coding: 0000072
                   P0407 - 004 - Signal too Low - Intermittent
                        Mileage: 356806 km
                        Time: 15:58:27
                        Load: 0.0 %
                        Temperature: 6.0°C
       Revision: 00H11001
       Coding: 0002689
       Coding: 00063445
       Shop #: WSC 00066
       Coding: 0012874
       Coding: 0000041
       Coding: 0023103
       Coding: 0000180
       Coding: 0000436
       Coding: 0040400
       Coding: 0000144
       Coding: 0000144
    End----(Elapsed Time: 01:11, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
    I managed to clear all codes after that, and values from tba and egr was like this :
    Address 01: Engine (03C 906 056 DP)
    16:33:20 Group 074: Exhaust Gas Recirculation (EGR) Valve Alignment
    0.780 V Potentiometer (G212) Zero Position
    0.800 V Potentiometer (G212) Actual Position
    ADP. O.K. Potentiometer (G212) Status
    16:32:15 Group 060: Throttle Body Alignment
    15.6 % Throttle Valve Sensor 1 (G187)
    84.0 % Throttle Valve Sensor 2 (G188)
    0 Throttle Adaptation Steps Counter
    ADP. O.K. Throttle Body Alignment Status
    After that i started car and let it run til normal temp. It run wobbling, and rpm was not steady.
    Then i read the codes and this it :
       Coding: 0000072
    Readiness: 1010 0101
       Revision: 00H11001
       Coding: 0002689
       Coding: 00063445
       Shop #: WSC 00066
       Coding: 0012874
       Coding: 0000041
       Coding: 0023103
       Coding: 0000180
       Coding: 0000436
       Coding: 0040400
       Coding: 0000144
       Coding: 0000144
    End----------(Elapsed Time: 01:11, VBatt start/end: 12.6V/12.6V)-----------
    So what next???
    Apr 2018
    Any ideas what to do next? Is there still some wrong values or something in those two components?
  9. #8
    Jul 2014
    Hi Zak 69,
    "So, yesterday i changed the egr valve,". Genuine VAG EGR?
    Regards HMC
  10. #9
    Apr 2018
    Quote Originally Posted by HMC View Post
    Hi Zak 69,
    Regards HMC
    No, it was some stock?? part (sorry, don't know the right word) but looked serial number from real.oem and it's a right one for sure.
    I've been also tryin to find values for those wirings so i can measure if they are ok.
  11. #10
    Jul 2014
    Get a genuine one, aftermarket parts especially electronics, cannot be trusted now.
    Regards HMC
  12. Likes Uwe liked this post
