Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 69
Thread: Newb to R-T Forums, Help re; MULTI MODULE “No Signal/Communication
  1. #21
    Oct 2017
    The Bay, CALI
    Will do in a bit as I’m st work currently.
    So should I NOT select my model car before Autoscan and just run it per default settings?
  2. #22
    Quote Originally Posted by Poodini View Post
    Correct, especially as you appear to have been selecting the wrong chassis type (B6/B7 instead of B8).
    VCDS will interrogate the CAN gateway to determine what modules that THINKS are installed in your car.
    See Uwe's post where he asks whether your car has the modules that cannot be communicated with - one example being is your car a quattro or front wheel drive?
  3. #23
    Correct, just leave it on Auto-Detect.
  4. #24
    Oct 2017
    The Bay, CALI
    That’s weird because based on my VIN I’ve been selecting 8K but it shows as B7 and not as B8!
    Was going off what was explained in the YouTube vid.
    I’ll rescan tonight minus selecting chassis type and will upload early tonight.
    Thanks for the replies btw
  5. #25
    Oct 2017
    The Bay, CALI
    Full disclosure: I have a 2009 Audi A4 B8 2.0l TFSi Quattro S Line with Bang n Olufsen speaker system + Symphony.
  6. #26
    Color me confused. This is what shows up when I select 8K in VCDS:
  7. #27
    Oct 2017
    The Bay, CALI
    So does it not show which chassis I selected? I’ve chosen 8K each time so I’m not sure as to why it then selects B7 as the chassis type
  8. #28
    What happens if you leave the chassis type as Auto-Detect?
  9. #29
    Oct 2017
    The Bay, CALI
    Mornng,
    Here is this morning's scan using just the CAN only/default Autoscan settings:
    Wednesday,02,May,2018,06:00:21:20172
    VIN: WAUMF78K09N032328   License Plate:
    Mileage: 218350km-135676mi   Repair Order:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 1B 20 22 2E 36 3C 42 46 47
              52 53 55 56 62 65 72 77
    VIN: WAUMF78K09N032328   Mileage: 218350km-135676miles
    1B-Active Steering -- Status: Cannot be reached 1100
    20-High Beam Assist. -- Status: Cannot be reached 1100
    22-AWD -- Status: Cannot be reached 1100
    Address 01: Engine (-----CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 D    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H14 0002
       Revision: E1H14---
       Coding: 0104010A190F0160
       Shop #: WSC 80178 667 427686
       ASAM Dataset: EV_ECM20TFS8K2907115D A01002
       ROD: EV_ECM20TFS8K2907115D.rod
       VCID: 303A1938CAA7BF47C28-8064
    Readiness: 0010 0001
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 C    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H04 0050
       Revision: --H04---
       Coding: 001002
       Shop #: WSC 02145 785 00200
       ASAM Dataset: EV_TCMAL651 A01004
       ROD: EV_TCMAL651.rod
       VCID: 36362F2028C39177984-8062
       Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
       Component: ESP8 quattro  H04 0060
       Coding: 150500
       Shop #: WSC 02399 823 56573
       VCID: 79ACE41C59DDBE0F356-802C
       Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
       Component: BCM2 1.1      H80 0143
       Coding: 0D0100
       VCID: 75B4E82C75C5DA6F51E-8020
       Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Component: ELVAUDIB8  H36 0041
       Serial number: 0208000064623015
       Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
       Component: KLIMA 3 ZONEN H06 0140
       Revision: C1000000    Serial number: 0120.09.080964
       Coding: 64002000
       VCID: 72BED33004ABCD5774C-8026
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H22 0253
       Revision: 05022001    Serial number: 00000000233517
       Coding: 2A0050108034AF216781810300003D0D4F1C520800010141000000
       Shop #: WSC 00070 123 12345
       VCID: 303A1938CA27BF47C28-8064
       Component: WWS 250908  H06 0070
       Serial number: SWF08090257114
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10262520
       Coding: 035028
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000002409080001
    03207 - Charisma Switch Module
                        Reset counter: 64
                        Mileage: 218290 km
                        Date: 2018.04.30
                        Time: 21:01:00
       Part No SW: 8K0 919 475 D    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0020
       Revision: 11001001    Serial number: 52930827200238
       Coding: 000103
       VCID: 3A2E3B101C5B75177CC-806E
       Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
       Component: AirbagVW-AU10 H27 0410
       Serial number: 0039KD14AK5%
       Coding: 303836354230303030304A55304C384B3053
       Shop #: WSC 02135 785 00200
       VCID: 40DA49F87A072FC7328-8014
       Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
       Component: BF-Gewichtss.  H01 0030
       Serial number: 5810000R08000023WX
       Serial number: 6334MSME41624D55D
       Serial number: 6344MSME402177634
       Serial number: 6352QSME390D1F20K
       Serial number: 6362QSME040A0D3CK
       Serial number: 63732SME27071A26Y
       Serial number: 63832SME2709290E0
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90319HIM00043
       Coding: 000036
       VCID: 3D24300C0D75422F59E-8068
       Component: E221 - MFL  H02 0010
       Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
       Component: KOMBIINSTR.   H17 0224
       Revision: 00000000    Serial number: 9DR21FU98
       Coding: 831F08004700D705020001
       VCID: 2D04004CDD15D2AFE9E-8078
    02797 - Control Module for Directional Stabilization Assistance (J759)
                        Reset counter: 57
                        Mileage: 217967 km
                        Date: 2018.04.27
                        Time: 00:58:11
       Part No SW: 8T0 907 468 J    HW: 8T0 907 468 J
       Component: GW-BEM 6CAN   H06 0094
       Revision: 4HB20042    Serial number: 4200H088278039
       Coding: 000303
       VCID: 48CA51D852B71787FA8-801C
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H04 0150
       Serial number: 18044A69090908
    03110 - Active Steering Control Module (J792)
                        Reset counter: 64
                        Mileage: 218290 km
                        Date: 2018.04.30
                        Time: 21:01:40
                        Reset counter: 64
                        Mileage: 218290 km
                        Date: 2018.04.30
                        Time: 21:01:41
    03395 - Control Module for High Beam Assistant
                        Reset counter: 64
                        Mileage: 218290 km
                        Date: 2018.04.30
                        Time: 21:01:45
    Address 1B: Active Steering
    Address 20: High Beam Assist.
    Address 22: AWD
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785     HW: 8T0 035 785
       Component: SG ext.Player H06 0210
       Revision: 00000000
       Coding: 020302
       VCID: 78AAE11862D7A7074A8-802C
       Part No SW: 8K0 959 760     HW: 8K0 959 760
       Component: MEM-FS        H05 0043
       Revision: AA000000    Serial number: 00001001150922
       Coding: 00581B00000000000000
       VCID: 77A8E2246FC9A87F432-8022
       Part No SW: 8K0 907 566 B    HW: 4L0 907 566 B
       Component: J0769_SWA_MasterH01 0050
       Revision: 00H01000    Serial number: 6PZ 009 014-13
       VCID: 36362F2024439177984-8062
       Subsystem 1 - Part No: 8K0 907 568 B
       Component: J0770_SWA_Slave_H01 0050
       Subsystem 2 - Serial number: 6PZ 009 014-33
       Subsystem 3 - Serial number: 5F02.10.0800H010003CD10008˙
       Subsystem 4 - Serial number: D10008˙
       Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
       Revision:             Serial number: 0000007788525
       Coding: 011C13204E00410001
       VCID: 41DC4CFC718D26CF3D6-8014
       Revision: 00002001    Serial number: 0114774675
       Coding: 0106263A007A4405833001
       Shop #: WSC 00070 000 00000
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0040
       Serial number: 00000000000000037477
       Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS034  H06 0037
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
       Part No SW: 8T0 035 223 S    HW: 8T0 035 223 B
       Component: DSP Prem      H13 0210
       Revision: 00013001    Serial number: 34833002084005
       Coding: 0203010302
       VCID: 3E26370000735937404-806A
    02247 - Subwoofer (R148/R157)
                        Reset counter: 64
                        Mileage: 218290 km
                        Date: 2018.04.30
                        Time: 21:06:07
                        Voltage: 12.00 V
                        Temperature: 41.0°C
                        Temperature: 48.0°C
                        Bin. Bits: 00000100
       Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
       Revision:             Serial number: 0000007729191
       Coding: 011C13201400410001
       VCID: 40DA49F87A872FC7328-8014
                        Reset counter: 66
                        Mileage: 218290 km
                        Date: 2018.05.01
                        Time: 09:03:26
       Revision: 00000003    Serial number: 10000000639010
       VCID: 343215283E3F8367A60-8060
       Part No: 8K0 907 357 B
       Component: Dynamische LWR  H01 0030
       Coding: 0000004
       VCID: 34321528323F8367A60-8060
       Part No SW: 8T1 035 195 L    HW: 8T1 035 195 L
       Component: Symph3 Sirius H02 0211
       Revision: 00000004    Serial number: AUZ5Z4H1050539
       Coding: 0403000201018500C3DB270800
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
       Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
       Revision:             Serial number: 0000100319838
       Coding: 010C13204000210001
       VCID: 44D245E86E9F33E7160-8010
    Address 65: Tire Pressure (J502)       Labels:. 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0250
       Revision: 00001001    Serial number: 13140781838920
       Coding: 0CD154
       Revision:             Serial number: 0000100319852
       Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
       Component: FSE_256x BT     H33 0550
       Revision: 00000000    Serial number: 00000005021273
       Coding: 0010370
       VCID: 3B203E141F614C1F67A-806E
    End----------(Elapsed Time: 01:56, VBatt start/end: 12.3V/12.3V)-----------
  10. Likes PetrolDave liked this post
  11. #30
    Oct 2017
    The Bay, CALI
    So if I’ve read this right, the main culprit looks to be CAN Gateway J533 with the 3 faults (high beam, awd, & active steering) showing the same error ie not communicating/ no signal
