Results 1 to 4 of 4
Thread: Audi A3 2016 US to EU
    Feb 2018
    Czech Republic
    maybe this topict belongs more to "How to ..." section, but here also ...
    After visiting a dealer, the car cames to me with problem not functioning remote, so I coded BCM back to US and "relearn" the remote ... The ligts,etc.stays ok, but I am not sure what other things are related to apart of the 315MHz (300-400MHz) is in our country "restricted for public use" ... eventhough when you order a new key at a dealer by the VIN (so "preprogrammed"), you still get 315MHz ... So what´s the "right" way to "converse" it? Do it needs to replace the BCM or if it is just recoded, you can use the 434MHz (or 868 even w/o kessy?) As I understood in accordance of this table: http://wiki.ross-tech.com/wiki/index.php/Immobilizer I assume, that even a new key is N/A (even when I found some basic settings, but won´t take it ... ) , but what about the rest? Probably new fw for 5F even w/o navi? Other problem is that when I select cz language in coding of instrument cluster, it still displays in en (probably due to fw - is it very different from 3G/3GP? I.e. green menu, etc.?) ...
    Here are the scans:
    Monday,23,April,2018,20:11:12:12188
    VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
    VIN: WAUA7GFF7G1061464   License Plate:
    Chassis Type: FF-AU37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F 6C BB BC
    VIN: WAUA7GFF7G1061464   Mileage: 41294km-25658miles
    Address 01: Engine (J623-CNSB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0003
       Revision: --H13---
       Coding: 0A1D00122424000F2000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
       ROD: EV_ECM18TFS0208V0906264F.rod
       VCID: 3FCEAFF3A65220BC21-806A
    Readiness: 0000 1100
       Part No SW: 0D9 300 042 C    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4907
       Revision: 06253104    Serial number: TFK01510140227
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 197A216B18B62E8CFF-804C
       Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
       Component: ESC           H42 0623
       Revision: 00000000    Serial number: 63015000003124
       Coding: 13FF6A9234260A6D017B020681C729C8562C5080408194B4024100548208
       ROD: EV_Brake1UDSContiMK100IPB_034.rod
       VCID: 79BA01EBF8F6CE8C5F-802C
       Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
       Component: AC Automat    H14 0060
       Revision: 20028000    Serial number: 00000000783810
       Coding: 03000014010000000000000000001400
       VCID: 3228F6C76500FDD4DE-8066
       Serial number: B29847D7000000000001
       Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
       Component: BCM MQBAB MNA H24 0175
       Serial number: 01061531200076
       Coding: 04141A42C04122F541804004511007000000000000000000000000000000
       Shop #: WSC 12345 444 00001
       ROD: EV_BCMBOSCH_015.rod
       VCID: 7F4EEFF3E6D2E0BC61-802A
       Component: WWS371 150808  042 0585
       Serial number:         151029123312
       Coding: 0A47F7
       Serial number: 60886543
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
       Serial number: 07 09 2015  00001065
       Component: Sirene, DWA  005 0312
       Serial number: 00000000000033981301
       Sun Roof:
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST000MVS4D00000
       Coding: 101F00
       Revision: --------    Serial number: 39391530801758
       Coding: 0010150011
       ROD: EV_EPHVA18AU3700000_002_AU37.rod
       VCID: 43C6A303CABA445C45-8016
       Serial number: 003GCR03WAK.
       Coding: 9DCCFCC0000000005000001AC24800000065
       VCID: 47DEB713FE82687C99-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34230167A12111540025
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34230168A12111550405
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 694000000000001E9VSG
       Coding: 303332
       Subsystem 4 - Part No SW: -----------    HW: 480 002 910 15
       Serial number: 35700000000FF3C8371-
       Subsystem 5 - Part No SW: -----------    HW: 480 002 910 15
       Serial number: 35800000000C04C8371K
       Subsystem 6 - Part No SW: -----------    HW: 480 400 311 15
       Serial number: 3510002B71D25F00F11$
       Subsystem 7 - Part No SW: -----------    HW: 480 400 311 15
       Serial number: 3520002B31D25F03027V
       Subsystem 8 - Part No SW: -----------    HW: 480 401 808 15
       Serial number: 3550002A31CB0C04303V
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 401 808 15
       Serial number: 3560002A51CB0C0483A6
       Part No SW: 8V0 953 521 EP    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0120
       Revision: --------    Serial number: 10111508490973
       Coding: A018
       ASAM Dataset: EV_SMLSKLOMQB 020001
       VCID: 0C54483FA764CB2474-8058
       Part No SW: 8V0 920 960 M    HW: 8V0 920 960 M
       Component: KOMBI         H03 6423
       Coding: 07F519092B8000080800A8001800000000000000
       Shop #: WSC 20745 401 00001
       VCID: 45C2BD1BC48E7A6C6B-8010
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 01111510800611
       Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
       ROD: EV_GatewConti_013_VW37.rod
       Serial number: 27 10 2015  B0070220
       Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
       Serial number: 120815BHB12065
       Coding: 00100B204000048000000002
       VCID: 41CAA90BD0A6564C57-8014
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 0102
       VCID: 44C4A01FCFB443647C-8010
       Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
       Serial number: 130815DHC14678
       Coding: 001003204000048000000002
       VCID: 40CCAC0FDBAC5F4458-8014
       Coding: 011A000101000000
       VCID: 75A20DDBD4EEAAEC3B-8020
       Part No SW: 8V0 035 844 C    HW: 8V0 035 844
       Component: MU-S-S-US     014 0660
       Serial number: A7A01111150128
       Coding: 01730100FF0A000011110001001A00002F0002440100010002
       ASAM Dataset: EV_MUStd6C3PASE 002020
       ROD: EV_MUStd6C3PASE.rod
       VCID: 393AC1EBB8760E8C1F-806C
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0014
       Serial number: AUZ8Z9FY30EDEE
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
       Serial number: C1000018091500040112
              B11CF 53 [009] - Deactivated
                        Reset counter: 125
                        Mileage: 41294 km
                        Date: 2018.04.23
                        Time: 19:31:19
                        Voltage terminal 30: 12.1 V
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
       Component: MQB RVC Mid   H07 0140
       Coding: 027300010201000300
       ASAM Dataset: EV_2CamSysRearPASE 006016
       ROD: EV_2CamSysRearPASE.rod
       VCID: 302CFCCF6B0CCFC4A8-8064
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 101015BJ814474
       Coding: 000003204000048000000002
       Serial number: 101015BJ814473
    End----------(Elapsed Time: 01:29, VBatt start/end: 12.1V/12.1V)-----------
    With a new VIN "preprogrammed" key from dealer (I´ve tried also the procedure via ignition and door locks simmilar to "relearn" learned remote and even with the learned key more than 10meters it starts and run on the new key - with fault just in instrument cluster - but remote not works ... ) :
    Saturday,28,April,2018,11:38:07:12188
    VIN: WAUA7GFF7G1061464   Mileage: 41464km-25764miles
       Revision: --H13---
    15072 - Engine Start Blocked by Immobilizer
              P1570 00 [032] - -
                        Mileage: 41464 km
                        Date: 2018.04.28
                        Time: 10:46:19
                        Engine speed: 1142.75 /min
                        Normed load value: 17.3 %
                        Coolant temperature: 73 °C
                        Intake air temperature: 47 °C
                        Voltage terminal 30: 11.972 V
                        FRF_IMMO_SNAPSHOT_BYTE1: 50
                        FRF_IMMO_SNAPSHOT_BYTE2: 50
                        FRF_IMMO_SNAPSHOT_BYTE3: 153
                        FRF_IMMO_SNAPSHOT_BYTE4: 11
                        FRF_IMMO_SNAPSHOT_BYTE5: 16
                        FRF_IMMO_SNAPSHOT_BYTE6: 0
                        Engine: operating status: IS
    Readiness: 0000 0100
    21197 - Transmission Control Unit
              P1701 00 [008] - Locked
                        Mileage: 41464 km
                        Date: 2018.04.28
                        Time: 10:46:19
       Coding: 0A47F7
       Coding: 00006C
       Light switch:
       Sun Roof:
       Coding: 101F00
       Coding: 0010150011
       Coding: 333135
       Coding: 333135
       Occupant Detection:
       Coding: 303332
       Coding: A018
    9456681 - Key
              B104C 29 [008] - Implausible Signal
                        Mileage: 41464 km
                        Date: 2018.04.28
                        Time: 10:46:19
       Coding: 0102
                        Reset counter: 125
                        Mileage: 41294 km
                        Date: 2018.04.23
                        Time: 19:31:19
    End----------(Elapsed Time: 01:29, VBatt start/end: 12.3V/12.3V)-----------
    Any ideas? And what is the right fw for EU and this 5F? (still the same/similar in green menu?) Thanks
    This car does not seem to be broken. Moving to Tweaks.
    Feb 2018
    Czech Republic
    Ok, thanks. The car was a little bit broken, but that is not the issue now (interesting is e.g. after repair and refilling th A/C it was necessary to run basic settings for first run of a compressor to make the compressor work ... It was obvious, that it some time not works because it was a little "stale"/smelly ... just for info that in case of newer cars you need a diag for almost everything ;-) ...)
    Feb 2018
    Czech Republic
    Hi again, little "update" ... The car is in use, still not fully "EUropied" , still little smelly (also after ozone,etc. and mainly with A/C off) and still with US Instr.cluster, but with "plate" under speed needle swaped from 860E cluster (will add some photos) and now the main problem is different numbers spacing(even when showing km/h l/100km values...), so "meantime" is in progress solution for fully "EU conversion", but the question is, if it can be changed in the cluster in the car. Reflash to diff. sw or...? Thanks
