2003 8E B6 Airbag Adaption VIN error codes
You could always send me the components to be properly married along with old and new parts with DEF to be possibly repaired/stripped.
Clusters, all keys, engine ecu or ecu's...........most importantly...........documentation to prove ownership.
I like the idea of the backup attempt and then trying a genuine swap of 050 after time extensions are clocked out.
I have seen ecu's and clusters get locked for days when working outside the factory 050 security breaches............which are normally 10 minutes to an hour.
Your car supports anti............. gone in 60 seconds with RB4.
Not down with OPP......BDP but CP.................:p
   #42
stolenheartdealer
C?ID=107120
Great SUCCESS!
So I flashed my 'original' BIN, followed the 'USED' procedure and all turned out well. The cluster thought the car was an automatic so I fixed that in adaption and I had to do a couple scans since modules will intermittently check VIN and complain (throw a code) at different times. However... it appears... to be solved, finally :cool:
I may have missed something and I may have more after my drive to work tomorrow BUT I don't think it's ever too early to say a HUGE thank you to all who've added a little input and sounded off on my issue as I have been helped GREATLY
LESSON LEARNED: Don't manually edit an ECU to match a cluster because it isn't as simple as matching the IMMO IDs, #s, VIN and SKCs. I have no idea how I would have edited my VIN without destroying my cluster to begin with but I definitely won't have to do it again :D
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
Tuesday,14,October,2014,20:04:46:06829
Chassis Type: 8E (00 - Audi A4 2003)
Scan: 01 03 08 09 15 16 17 46
VIN: WAULC68E33A372452   Mileage: 212830km/132246miles
Address 01: Engine        Labels: 06B-909-518-AMB.lbl
   Part No SW: 8E0 909 518 AF    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0003
   Coding: 0016701
   Shop #: WSC 87119 806 641192
   VCID: 74ED2C9814A182BE8FF-513C
Readiness: 0110 1101
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      3429
   Coding: 04275
   Shop #: WSC 06435
   VCID: 264906D0C2FDA02EC1B-5120
   Part No: 8E0 820 043 AC
   Component:   A4 Klimaautomat   1119
   Coding: 00000
   Shop #: WSC 63351
   VCID: 62C15AC0EE551C0EED3-513C
   Part No: 8E0 907 279 E
   Component: int. Lastmodul  USA 0305
   Coding: 00003
   VCID: 346DEC980421C2BE4FF-4B00
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 C
   Component: Airbag 8.4EP        2000
   Coding: 0010607
   Shop #: WSC 63351 000 00000
   VCID: 3777DB94455729A66AD-513C
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0308
   Coding: 00041
   VCID: 3E79CEB03A6D18EEA9B-4B00
   Part No: 8E0 920 950 L
   Component: KOMBI+WEGFAHRS. RB4 D37
   Coding: 01231
   Shop #: WSC 01116
   VCID: 3261EA80FE35CC8E5D3-513C
   WAULC68E33A372452     AUZ6Z0C0439357
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 BB
   Component: Komfortgerát T7B    1311
   Coding: 15978
   Shop #: WSC 06435
   VCID: 72E12A803EB58C8E9D3-4B18
   Component: Tõrsteuer.FS BRM 0003
   Component: Tõrsteuer.BF BRM 0003
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0003
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0003
