Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Leon Cupra MK2 ESP deactivation.
    May 2017
    Israel
    i have tried it before, and i know for a fact that my Module is not able to do what i need it to do.
    Please, if you do not know the answer do not post one...
  2. #12
    Quote Originally Posted by zoriq747 View Post
    Please do not be so rude, you had not said whether you had tried the suggested coding all I asked was whether you had tried it.
    Rudeness doesn't make people want to help you, good manners do - worth remembering.
  3. #13
    May 2017
    Israel
    I don't think I am rude and it is not my intention.
    I have asked 2 specific questions, there were no need to take the thread to a different direction, talking about latest versions ECT.
    I ask only people that know the answers to the questions I have asked to answer please!
  4. #14
    IMHO clarifying what the latest version is of VCDS was necessary and of interest to ALL VCDS owners/users, the thread did then return to your specific questions but you chose not to initially answer whether you have tried the suggested coding change.
    You say you KNOW that your ABS is not capable of supporting ESP off yet in your first post you say:
    i understood from some one that i need to swap it out for a different one
    which implies that you do NOT KNOW that your ABS is not capable but merely that someone had told you it isn't. So it is necessary to clarify this point, as you may not need to go through the cost and work of replacing your ABS if a simple coding change will achieve your desired aim.
    That's not how internet forums work - statements must be clarified and sometimes that shows that the original question and/or assumptions were not correct.
  5. Likes Uwe liked this post
  6. #15
    Aug 2016
    The Hague, NL
    Just to clarify, I suggested the coding for you to try first for two reasons:
    - I didn't know what you tried before and I made the same interpretation as Dave did.
    - If you can make your current ABS pump work by coding, there would be no need to purchase another one.
    Either way, you're welcome.
  7. Likes downtime liked this post
  8. #16
    May 2017
    Israel
    Thank you for.you help.
    Does any one know the answers to the following?
    i need to swap it out for a different one, the 1K0-907-379-BJ and i have a few questions.
    1. Does it matter what P/N the ABS pump is?
    2. What long code do i need for my vehicle after the swap?
  9. #17
    New User
    Lithuania
    1. 379 BJ should be a direct swap in. Other possible variants are BH, BL, BK and BS modules.
    2. For BJ, you should be able to use the ESP deactivation coding posted in the #4 post.
    I think your current 379 AT can have possibility of ESP function deactivation but you will need to try a coding. There is not a chance I am going to discuss this publically so if you are interested, feel free to drop me a Private Message.
  10. #18
    May 2017
    Israel
    Ok, some updates
    I now have an option of "ESP OFF" with a long press on the esp button but in some scenarios, when applying the brakes, the esp is starting to correct the car.
    Can i do something to be able to disable the ESP altogether by using the ESP button or is there some other way?
