1 month post-dieselgate fix. Not happy with the transmission remap BTW.
Tuesday,24,April,2018,17:27:31:32531
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
VIN: WA1CVAFPXGA033966 License Plate:
Mileage: 54120km-33628mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
62 69 6C 6D 72 AC
VIN: WA1CVAFPXGA033966 Mileage: 54120km-33628miles
Address 01: Engine (J623-CPNB) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 401 AC HW: 4G0 907 401 E
Component: 3.0TDI FSA H14 0008
Revision: 58H14---
Coding: 2A2A4032053603050000
Shop #: WSC 58767 001 1048576
ASAM Dataset: EV_ECM30TDI0118K5907401AC 002008
ROD: EV_ECM30TDI0118K5907401AC_002.rod
VCID: 71BF28B9D12EEBBF8D6-8024
9954 - NOx Reductant Consumption too Low
P20F4 00 [032] - -
Readiness: 0 0 0 1 0
Part No SW: 8R0 927 158 Q HW: 0BK 927 156 AM
Component: 0BK 30 TDIUSA H19 1007
Revision: --H19---
VCID: 4BC39A519342E16FD7A-801E
12514 - Internal Control Module - Processor Performance Monitoring
P060A 00 [032] - -
Mileage: 51433 km
Date: 2018.03.16
Time: 12:04:09
Unlearning counter according OBD: 5
Voltage terminal 30: 11.829 V
Engine speed: 668 /min
Transmission fluid temperature: 43 ∞C
Status of brake signals-Brake Light Switch: operated
Status of brake signals-Brake pressure switch: not activated
Status of brake signals-Validity of brake pressure information: valid
Status of brake signals-Validity of brake pedal information: valid
Driving position: P
Transmission output speed: 0.00 /min
M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
Status electric parking lock holder solenoid-Desired State Solenoid Out 10: OFF
Status electric parking lock holder solenoid-Desired State Solenoid Out 11: OFF
Status electric parking lock holder solenoid-Desired State Solenoid Out 12: OFF
Status electric parking lock holder solenoid-Desired State Solenoid Out 13: OFF
Status electric parking lock holder solenoid-Desired State Solenoid Out 14: On
selected gear: without traction
Transmission input speed: 313.00 /min
Status of starter lock: OFF
Stop process prevented-Oil temperature too low: not active
Stop process prevented-Transmission fluid temperature too high: not active
Stop process prevented-Adaptation procedure active: not active
Stop process prevented-Pressure accumulator filling not completed: not active
Stop process prevented-Gear 1 or 2 not selected: not active
Start process requested-Driver intention: not active
Start-stop conditions: Stop prohibition: no start request
Start-stop enabling: No release by coordinator
M015_Time Normal Mode: 1123 s
M019_Time Since Reset: 7650 ms
M018_Time In Afterrun: 0 s
M014_Time Since Shift: 7650 ms
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS
Component: ESP8 quattro H09 0020
Coding: 23DD1C03
Shop #: WSC 06335 123 12345
VCID: 117F4839B16E8BBFED6-8044
Part No SW: 8K0 907 064 KP HW: 8K0 907 064 KP
Component: BCM2 2.0 H15 0711
Coding: 0D854040000000000000
VCID: 0849655DC234CA773A8-805C
Subsystem 1 - Part No SW: 8K0 959 754 B HW: 8K0 959 754 B
Serial number: 0815000088064019
Serial number: 3215000122947016
Part No SW: 8K1 820 043 AR HW: 8K1 820 043 AR
Revision: C3000000 Serial number: 01160720152334
Coding: 3621228280
Shop #: WSC 06335 000 00000
VCID: 78A9159DB2D4BAF74A8-802C
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001123248101
Coding: 26000091863CAFE00100488000003D0D0F9CE608A6090225000008004000030100000034000000
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 150702 H12 0050
Serial number: 90243014150624140620
Coding: 01DD13
Component: G397_RLFS H06 0004
Serial number: 20442295
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000000207151649
Component: USHL4.2 H30 0030
Serial number: 00000000095Z0015F6FD
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0155891111
Coding: 0F0000
Serial number: 74984BB7000000000001
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H53 0812
Serial number: 003NED153ZV%
Coding: 303635313832383132304A55304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4CC1994D964CE657DE0-8018
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R150000MV9R
Serial number: 6334MSME532D41034
Serial number: 6344MSME532D2C03E
Serial number: 6352QSME49594C7A.
Serial number: 6362QSME49592678S
Serial number: 63732SME52592748+
Serial number: 63832SME5C5921483
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862OGL000C0
Coding: 000037
VCID: 48C9A55D82B40A77FA8-801C
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 982 A HW: 8R0 920 982 A
Component: KOMBIINSTR. H35 0567
Revision: 00200000 Serial number: 03K47XE7G
Coding: 83B622000301D705020000
VCID: 392FD099C95E63FF756-806C
Part No SW: 8R0 907 468 AA HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0070
Revision: 1Z130032 Serial number: 3241Z15616087B
Coding: 80CF07FF00
VCID: 7EA5038590F084C7004-802A
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 9700287303
Serial number: 15195001100011200410
Part No SW: 8R0 959 760 E HW: 8R0 959 760 C
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000153085367
Coding: C1581B000F0000000000
VCID: 43D3B271BB92292F2FA-8016
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0374769434
Coding: 010211
Shop #: WSC 06334 000 00000
VCID: 3FDBBE81D7FA4DCF4B2-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0374837545
Coding: 010211
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0511
Revision: Serial number: 0000158699036
Coding: 011D13215E00440004
VCID: 4FFB8E4167DADD4FBB2-801A
Part No SW: 8R0 909 144 P HW: 8R0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0010016624
Coding: 100000010001
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 45D7AC69B526171F01E-8010
Revision: 00002001 Serial number: 0374391760
Coding: 0126023A20FA709784A0053A20040047
Shop #: WSC 06334 123 12345
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000001027333
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H04 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H04 0090
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813047092507
VCID: 2D07F4C90D16CF5FE9E-8078
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0511
Revision: Serial number: 0000158966212
VCID: 4EC5934560D0D447B04-801A
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 00000001692332
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2DCF95CCD868E77CC-806E
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156G20F8295245
Coding: 020007010000000001
VCID: 241111ED5EDC0E17360-8070
Part No SW: 8R1 035 746 H HW: 8R1 035 746 G
Component: H-BNT-NA H43 0937
Revision: -------- Serial number: 523G 0F7577400
Coding: 160200060005A1EF55028B5E00000403140000000000000000
VCID: 3C21C98DC66C56D76E0-8068
Subsystem 1 - Part No: 8R0 060 884 CS
Component: NAR 2015 1201
Component: DU7 High H42 0104
Serial number: A130GR0F3415309
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000002310507
Component: CD-Database 6208
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000158943507
Coding: 010C13204000240004
VCID: 46D5AB6588A01C07084-8012
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H12 0100
Revision: 1A001001 Serial number: 00000410004278
Coding: 0200000000000000
Shop #: WSC 12345 123 12345
VCID: 3635DBA5F8408C87984-8062
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-JA5A179
Coding: 1010010
VCID: 3431E1ADE23C9E97A60-8060
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D27C489DD765FDF59E-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Component: TSG HR H01 0510
Revision: Serial number: 0000158775725
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 151841820
ROD: EV_RDCMA00100_008.rod
VCID: 2F3BEEC1079ABD4FDB2-807A
End----(Elapsed Time: 02:16, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
