- Joined
- Apr 21, 2018
- Messages
- 3
- Reaction score
- 4
- Location
- Chattanooga TN USA
- VCDS Serial number
- C?ID=297278 (NRRT)
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 13 15 16 17 19 22 2B 3C 42 44 52 5F 75 CA
VIN: 3VWM17AU9JM762540 Mileage: 1171km-727miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13---
Coding: 311900122426002F1000
Shop #: WSC 00066 790 00424
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: EV_ECM18TFS0208V0906264M.rod
VCID: 46D65C9488228E87084-8012
Address 03: ABS Brakes (J104) Labels:| 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AM HW: 5Q0 614 517 AB
Component: ESC H25 0312
Revision: 00000000 Serial number: 62107000000692
Coding: 43FA6AA13426096E407C0304A0C329C2562C9002C005943C10435050E089430000010312121212B435351919323200
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: EV_Brake1UDSContiMK100ESP_036_VW37.rod
VCID: 7CA2FE7C866E04572E0-8028
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0466138733
Coding: 032C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
VCID: 3C223E7CC6EEC4576E0-8068
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 G HW: 5GM 907 426 G
Component: AC Manuell H03 2001
Revision: 00001K05
Coding: 02020004200110000000000000000002
ASAM Dataset: EV_ACManueBHBVW37X 004134
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 4CC26EBC964E74D7DE0-8018
Part No SW: 5Q0 937 087 AR HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 034 0245
Revision: -------- Serial number: C86402011800GH
Shop #: WSC 00066 790 00395
ROD: EV_BCMCONTI.rod
VCID: 0B40ADA0D3C033EF17A-805E
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 171119 043 0551
Serial number: 97022066171125084348
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 047 0105
Serial number: S4Y17M10D11H12M37S47
Coding: 00A8DD
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 2D00008101FFC728949C810500401600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: 3E263474D0F2D647404-806A
Component: AirbagVW20 010 0830
Serial number: 003GCR08V5T2
VCID: 47C851908F28978FF32-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH0000000000083QNO1
Coding: 303135
Subsystem 2 - Part No SW: ----------- HW: 480 002 511 17
Serial number: 357000000005FB7D292-
Subsystem 3 - Part No SW: ----------- HW: 480 002 511 17
Serial number: 35800000000CB338182L
Subsystem 4 - Part No SW: ----------- HW: 480 401 211 17
Serial number: 3510001B52653ED5A446
Subsystem 5 - Part No SW: ----------- HW: 480 401 211 17
Serial number: 3520001C127E0422655S
Subsystem 6 - Part No SW: ----------- HW: 480 402 509 17
Serial number: 3550002A325629A2116T
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 509 17
Serial number: 3560002A125629A3C08+
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Revision: -------- Serial number: 05121720240069
Coding: 0400
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 07489190CFA8578F332-8052
Part No SW: 5G1 920 840 C HW: 5G1 920 840 C
Component: KOMBI 242 0310
Coding: 0BA41015A188CF0502886B095000000080000000
VCID: 2708F1102F68778F132-8072
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 30111700841500
Coding: 0901000830085900FB0020080A0F00000001070000000000000000000000
Shop #: WSC 00066 790 07026
ROD: EV_GatewNF_VW27.rod
VCID: 382A226CF2D6E8778A8-806C
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 28170002952100041439
Coding: 30FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H55 0041
Serial number: 0336145
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7084
Serial number: HA1-00025.09.17
Coding: 0001
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000269635002
Coding: 5500000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3432165CEEBE0C17A60-8060
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Serial number: 0460727250
Coding: 01011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3D243378DDF4CD5F59E-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0080
Serial number: 0460785113
Coding: 010111
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 5038734501824
Coding: 003A13200000020000000000
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000000088501
Coding: 011000
B122D 29 [008] - Signal Implausible
Reset counter: 112
Mileage: 1048574 km
Time: 00:00:00
Part No SW: 5QM 909 144 B HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 172 1081
Coding: 810A0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 50FA7ACC7A665037A28-8004
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 6038735700494
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000000033122
Coding: 091000
Part No SW: 3Q0 035 844 B HW: 3Q0 035 844 B
Component: MU-S-S-US 722 0867
Coding: 02731200FF00000051220001001808009F0508D40120050002
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 2E060434009226C7D04-807A
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 H50 8130
Serial number: VWZ6ZJT3190241
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02730202C2823A017F1E06020000
ROD: EV_OCULowMQB.rod
VCID: 43D04580BB10BBAF2FA-8016
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 00804073720C
ROD: EV_SunRoofCONTIAU736.rod
End----------(Elapsed Time: 01:52, VBatt start/end: 12.1V/12.1V)-----------
