Recoding TCM T3 Touareg TDI
04_sti
C?ID=230582
I was advised to post my own thread about recoding the transmission control modules for the late model Touareg's. This is a big question amongst the enthusiasts out there to able to recode their module to a eurospec/cayenne tune or possibly swap modules from older years and then recode those to work. Im posting up my autoscan in hopes Ross-Tech can help the community out in figuring this out.
Tuesday,03,April,2018,23:37:12:24016
VCDS Version: 17.8.0.1 (x64)
VIN: WVGEP9BP1GD001091   License Plate:
Mileage: 6978km-4335mi   Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 52 53 55 56 5F
          62 65 69 6C 6D 72
VIN: WVGEP9BP1GD001091   Mileage: 6978km-4335miles
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P1 907 401 C    HW: 7P0 907 401 K
   Component: 3.0TDI FSA    H21 0007
   Revision: 56H21---
   Coding: 292A4012233600050000
   Shop #: WSC 25156 444 00000
   ASAM Dataset: EV_ECM30TDI0117P1907401C 001008
   ROD: EV_ECM30TDI0117P1907401C.rod
   VCID: 306F3E5E6B7E83C63A-8064
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217)       Labels:. 0C8-927-755.clb
   Part No SW: 0C8 927 755 R    HW: 0C8 927 755
   Component: AL1000 AISIN  130 3374
   Coding: 010200000C008400000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMAL991031 003118
   ROD: EV_TCMAL991031_003.rod
   VCID: 408F6E9EDBDE1346CA-8014
Address 03: ABS Brakes (J104)       Labels:| 7P0-907-379.clb
   Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
   Component: MK25A         H37 0521
   Revision: --------    Serial number: 40445439037245
   Coding: 5B7613C349242554DAF4C89C92D3A4607301
   ASAM Dataset: EV_MK25AXT 010001
   ROD: EV_ESPMK25A01000.rod
   VCID: 4C974AAEE796C72626-8018
340740 - Databus
          U1121 00 [072] - Missing Message
                    Reset counter: 91
                    Mileage: 4519 km
                    Date: 2018.03.26
                    Time: 10:51:24
                    Standard Freeze  Frame Dynamic: 00 48 00 00 00 00 00 00 01 00 01 20 5E
   Part No SW: 4H0 907 064 GK    HW: 4H0 907 064 GK
   Component: BCM2 2.0      H37 0572
   Coding: 0D860016000000000000
   VCID: 78FFC67ECB8E9B86B2-802C
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 3215000088285008
00956 - Key 2
                    Reset counter: 91
                    Mileage: 4494 km
                    Date: 2017.12.21
                    Time: 10:31:46
                    Fault Status: 00101101
                    Reset counter: 97
                    Mileage: 4519 km
                    Date: 2018.03.26
                    Time: 10:51:24
   Part No SW: 7P6 907 040 CN    HW: 7P6 907 040 CN
   Component: Klima 2 Zonen H23 1507
   Coding: B606200A80
   VCID: 020BA4969552C1569C-8056
0248 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 91
                    Mileage: 4519 km
                    Date: 2018.03.26
                    Time: 10:51:24
0318 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 91
                    Mileage: 4519 km
                    Date: 2018.03.26
                    Time: 10:51:24
                    Voltage terminal 30-Data: 14.7 V
                    Outside air temperature-Data: 22.50 °C
                    Engine speed-Data: 760 /min
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Revision: 22020001    Serial number: 00001089081002
   Coding: 26000096963C5D010020480000005D4C431C6608A2010265000000008040110000000000000000
   VCID: 6ADBEC368522391634-803E
   Component: WWS    150516  033 0021
   Serial number: 90243400150521203007
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20571917
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 AC    HW: 7P6 941 431 AC
   Component: E1 - LDS  H02 0040
   Serial number: 00000000002505150018
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01EE1705
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0137714793
   Coding: 952F00
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28231514202249
   Coding: 310504
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 4487628ECFC60F66EE-8010
   Part No SW: 7P0 959 655 E    HW: 7P0 959 655 E
   Component: VW10Airbag04Z H10 0043
   Revision: --------    Serial number: 003NK003U6HG
   Coding: 00000000000000000000000000000000345A
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   VCID: 43856192CAC8085ED7-8016
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R154280LSFT
   Serial number: 3575LRB404V37T8AF1J
   Serial number: 3585LRB40513ALK4390V
   Serial number: 3517ARB401654R14QIRF
   Serial number: 3527ARB401454R14TKC4
   Serial number: 3557BRB40513EENA89H5
   Serial number: 3567BRB404V3EENAKGA4
   Part No SW: 4H0 953 568 L    HW: 7P6 953 507 AF
   Revision: --------    Serial number: 01374OEA000RM
   Coding: 0000D5
   VCID: 3C771A6EBF3677A696-8068
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H05 0028
   Serial number: 0029689 TRW 20150317
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb
   Part No SW: 7P6 920 983 A    HW: 7P6 920 983 A
   Component: Kombi         H13 0515
   Revision: 13240302    Serial number: 658310515592001
   Coding: 8B7733022B08CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001022
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 3D71176AAC2C7EAEA1-8068
16776973 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 89
                    Mileage: 4494 km
                    Date: 2017.12.13
                    Time: 13:54:08
   Part No SW: 7P6 907 530 M    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6042
   Revision: --------    Serial number: 00000001868374
   Coding: 000103AD00
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 428B6496D5D20156DC-8016
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 32139D16385701048222
5707 - Tire Pressure Monitoring Module
          U0127 00 [008] - No Communications
                    Reset counter: 89
                    Mileage: 4494 km
                    Date: 2017.12.13
                    Time: 13:54:06
                    Voltage terminal 30: 12.0 V
                    Voltage terminal 15: 12.1 V
                    Control Module temperature: 29 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
5072 - Door Control Module - Driver's Door
          U0199 00 [008] - No Communications
                    Reset counter: 97
                    Mileage: 4519 km
                    Date: 2018.03.26
                    Time: 10:51:22
                    Voltage terminal 30: 14.5 V
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 31 °C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
5074 - Door Control Module - Rear Left
          U0201 00 [008] - No Communications
                    Reset counter: 97
                    Mileage: 4519 km
                    Date: 2018.03.26
                    Time: 10:51:22
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000150997016
   Coding: C0581B0015004001000001010101202020202121202020
   VCID: 35610F4A9C1CA6EE69-8060
                    Reset counter: 97
                    Mileage: 4519 km
                    Date: 2018.03.26
                    Time: 10:51:24
   Part No SW: 7P6 907 566 A    HW: 4H0 907 566 F
   Component: SWA Master    H06 0021
   Serial number: 0369585735
   Coding: 030221
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 3F8D6D62A6206CBEB3-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 7P6 907 568 A    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0021
   Serial number: 0369126123
   Coding: 030221
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000152084897
   Coding: 011D17205E00453005080000
   VCID: 7AFBDC76F5828996C4-802E
   Revision: 00002001    Serial number: 0369635401
   Coding: 0187123A68B9509580A00620210A18000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719 A    HW: 7P6 959 719 A
   Component: GTO BT  H20 0059
   Serial number: 112153805
   Subsystem 3 - Part No SW: 7P0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS30.408  H03 0004
   Serial number: 0000FST000APRQG00000
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 E    HW: 8V3 959 591 A
   Component: J394 PS30.408  H03 0004
   Serial number: 0000CGQ00048CW200000
   Coding: 191100
   Subsystem 5 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
   Component: GEB.F.Heckoef  H16 0813
   Serial number: 65021784
                    Reset counter: 97
                    Mileage: 4519 km
                    Date: 2018.03.26
                    Time: 10:51:24
                    Reset counter: 97
                    Mileage: 4519 km
                    Date: 2018.03.26
                    Time: 10:51:24
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000151552235
   VCID: 489F76BEFBEE2B0602-801C
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1552400039
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: 36630846891AADF660-8062
   Slave 3:
12656659 - Databus
                    Reset counter: 91
                    Mileage: 4519 km
                    Date: 2018.03.26
                    Time: 10:51:24
                    Voltage: 14.6 V
   Coding: 012A02010B000400
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0005
   Coding: B00000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0005
   Coding: B00000
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156FY0F8271601
   Coding: 020007020100000001
   VCID: 2447C20E27862F66CE-8070
   Part No SW: 7P6 035 664 K    HW: 7P6 035 664 A
   Component: H-BN-NA       H41 0933
   Revision: --------    Serial number: 606E/0FB006177
   Coding: 010200050040E1EF51022B0E00000003F00001030000000000
   VCID: 408F6E9ED3DE1346CA-8014
   Subsystem 1 - Part No: 7P6 060 884 B
   Component: NAR 2015  1202
   Subsystem 2 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
   Component: DU8 SV Touch  H56 0046
   Serial number: VWZ8Z9RX8005FN
   Subsystem 3 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
   Component: CD-Database  6208
            000 -  -  - Intermittent
                    Reset counter: 89
                    Mileage: 4494 km
                    Date: 2017.12.13
                    Time: 13:54:13
                    Bin. Bits: 00000000 10000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000152162340
   Coding: 011817200000253005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 L    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0003
   Serial number: 30000000017137
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30.rod
   VCID: 45817F8AC4FC366EF9-8010
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
   Component: Anhaenger     H20 0160
   Revision: 7C001003    Serial number: 0369528751
   Coding: 0200000200000000
   VCID: 377D05428E1054FE7B-8062
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H08000    Serial number: 525 PA8JA41831
   Coding: 0130001
   VCID: 377D0542461054FE7B-8062
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 137501115
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000152337396
End-------------------------(Elapsed Time: 05:36)--------------------------
What exactly is different about a "eurospec/cayenne tune"?
As a general rule, components in modern cars that affect emissions, which the TCU most certainly does, will not accept codings for markets where the emissions specs are different.
04_sti
C?ID=230582
Uwe,
The VW Tdi fix noticeably reduced the performance and capabilities of the transmission on the 7P Touaregs. Having the ability to recode the transmission to regain hill decent control, display which gear on HUD, modify shift points to higher in the rpm, engine braking, all which seems to be present of euro models / or possibly cayenne’s. It would be nice if someone had an auto scan from a European 15+ MY Touareg or Cayenne. As I said in the other thread, it seems the 14+ models have a different rev Module that requires long coding rather than short codes. I may opt to try and swap for a early 7P module and see if it’ll take the European soft coding. Thoughts on swapping modules? I can get one for $150 shipped
So you're trying to un-do the TDI "fix", at least the portion that was applied to the TCU?
FWIW, my wife and I have a 2015 T'reg TDI. It has not been "fixed", nor do I intended to I allow to to be "fixed". I checked the TCU's coding. It is identical to yours.
There are folks out there who claim to be able to re-flash these TCUs to a pre-fix state, but Ross-Tech will not touch undoing any part of this fix due to potential legal ramifications.
04_sti
C?ID=230582
If thats the route you'd like to go, then you can take that same line of thought and apply it to about 99% of all the things that are possible within VCDS. Hell, having a "tweaks" forum section in of itself could have legal ramifications. I dont think thats the appropriate response to my question. However, after meeting you in person when i ATTEMPTED to buy my vagcom, it doesnt surprise me.
Most "tweaks" that one can do with VCDS have absolutely nothing to do with emissions, and they certainly aren't undoing a parts of a "fix" for things where billions of dollars in fines are involved and for which several people are now rotting in a federal prison.
timbo
C?ID=327905
I too am interested in possible TCU modifications since my '16 Q5 was "fixed." I accept that it will now gulp DEF and behave differently during warm-up. That, I can live with. However, the lurching transmission and delayed accelerator response are deal-breakers long-term. More than unpleasant, it renders the car dangerous in some situations. Truly, it feels like, put the pedal down and wait 2 seconds for the electrons to wake up.
I've ordered a used Touareg TCM, so we'll see what that brings. There are other reports on the InterWeb of that being successful.
Or maybe there's something else going on? Scan below:
   Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H19 1007
   Revision: --H19---
   Coding: 000001
   VCID: 4BC39A519342E16FD7A-801E
12514 - Internal Control Module - Processor Performance Monitoring
          P060A 00 [032] - -
                    Mileage: 51433 km
                    Date: 2018.03.16
                    Time: 12:04:09
                    Unlearning counter according OBD: 5
                    Voltage terminal 30: 11.829 V
                    Engine speed: 668 /min
                    Transmission fluid temperature: 43 ∞C
                    Status of brake signals-Brake Light Switch: operated
                    Status of brake signals-Brake pressure switch: not activated
                    Status of brake signals-Validity of brake pressure information: valid
                    Status of brake signals-Validity of brake pedal information: valid
                    Driving position: P
                    Transmission output speed: 0.00 /min
                    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
                    Status electric parking lock holder solenoid-Desired State Solenoid Out 10: OFF
                    Status electric parking lock holder solenoid-Desired State Solenoid Out 11: OFF
                    Status electric parking lock holder solenoid-Desired State Solenoid Out 12: OFF
                    Status electric parking lock holder solenoid-Desired State Solenoid Out 13: OFF
                    Status electric parking lock holder solenoid-Desired State Solenoid Out 14: On
                    selected gear: without traction
                    Transmission input speed: 313.00 /min
                    Status of starter lock: OFF
                    Stop process prevented-Oil temperature too low: not active
                    Stop process prevented-Transmission fluid temperature too high: not active
                    Stop process prevented-Adaptation procedure active: not active
                    Stop process prevented-Pressure accumulator filling not completed: not active
                    Stop process prevented-Gear 1 or 2 not selected: not active
                    Start process requested-Driver intention: not active
                    Start-stop conditions: Stop prohibition: no start request
                    Start-stop enabling: No release by coordinator
                    M015_Time Normal Mode: 1123 s
                    M019_Time Since Reset: 7650 ms
                    M018_Time In Afterrun: 0 s
                    M014_Time Since Shift: 7650 ms
04_sti
C?ID=230582
   Revision: --H19---
   Coding: 000001
          P060A 00 [032] - -
                    Mileage: 51433 km
                    Date: 2018.03.16
                    Time: 12:04:09
                    Driving position: P
What is the model number Touareg module did you order and from where? I found one for 150 shipped for a module ending in 750g
carboncow
Central Ohio
C?ID=266014
Dumb new guy here doing research...
Are these TCM some what interchange from Audi to Vw to Porsche? Or is more just people talking bout pulling the mapping/program off of one and trying to lay it onto another? I figured the way Porsche does stuff is not the way VAG does even knowing the hardware is the same. Think VCDS vs Durametric...same stuff but different. Very curious.
Not sure. I would consider that "uncharted territory", at least for me. Also, you have a 7L-chassis Touareg, not the newer 7P that's previously been discussed in this thread. I'll tell you this much: Transmission programming is not just specific to the exact model and engine, but even to the sales market (NAR vs. ROW).
carboncow
Central Ohio
C?ID=266014
thx. We are shopping for a T3 so trying to sort the post fix solutions. It’s amazing the amount of info out there but it all doesn’t connect and as you state we know VAG can have 10 sub versions in the same run. So not sure what all this talk about Audi and P-Car info is...I would suspect nothing is interchangeable as two mismatched modules from the same year VAG might now work.
