Results 1 to 10 of 11
Thread: Recoding TCM T3 Touareg TDI
    Nov 2014
    I was advised to post my own thread about recoding the transmission control modules for the late model Touareg's. This is a big question amongst the enthusiasts out there to able to recode their module to a eurospec/cayenne tune or possibly swap modules from older years and then recode those to work. Im posting up my autoscan in hopes Ross-Tech can help the community out in figuring this out.
    Tuesday,03,April,2018,23:37:12:24016
    VCDS Version: 17.8.0.1 (x64)
    VIN: WVGEP9BP1GD001091   License Plate:
    Mileage: 6978km-4335mi   Repair Order:
    Chassis Type: BP-VW52 (7P6)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 52 53 55 56 5F
              62 65 69 6C 6D 72
    VIN: WVGEP9BP1GD001091   Mileage: 6978km-4335miles
    Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
       Part No SW: 7P1 907 401 C    HW: 7P0 907 401 K
       Component: 3.0TDI FSA    H21 0007
       Revision: 56H21---
       Coding: 292A4012233600050000
       Shop #: WSC 25156 444 00000
       ASAM Dataset: EV_ECM30TDI0117P1907401C 001008
       ROD: EV_ECM30TDI0117P1907401C.rod
       VCID: 306F3E5E6B7E83C63A-8064
    Readiness: 0 0 0 1 1
    Address 02: Auto Trans (J217)       Labels:. 0C8-927-755.clb
       Part No SW: 0C8 927 755 R    HW: 0C8 927 755
       Component: AL1000 AISIN  130 3374
       Coding: 010200000C008400000000000000000000000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_TCMAL991031 003118
       ROD: EV_TCMAL991031_003.rod
       VCID: 408F6E9EDBDE1346CA-8014
    Address 03: ABS Brakes (J104)       Labels:| 7P0-907-379.clb
       Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
       Component: MK25A         H37 0521
       Revision: --------    Serial number: 40445439037245
       Coding: 5B7613C349242554DAF4C89C92D3A4607301
       ASAM Dataset: EV_MK25AXT 010001
       ROD: EV_ESPMK25A01000.rod
       VCID: 4C974AAEE796C72626-8018
    340740 - Databus
              U1121 00 [072] - Missing Message
                        Reset counter: 91
                        Mileage: 4519 km
                        Date: 2018.03.26
                        Time: 10:51:24
                        Standard Freeze  Frame Dynamic: 00 48 00 00 00 00 00 00 01 00 01 20 5E
       Part No SW: 4H0 907 064 GK    HW: 4H0 907 064 GK
       Coding: 0D860016000000000000
       VCID: 78FFC67ECB8E9B86B2-802C
       Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Serial number: 3215000088285008
    00956 - Key 2
                        Reset counter: 91
                        Mileage: 4494 km
                        Date: 2017.12.21
                        Time: 10:31:46
                        Fault Status: 00101101
                        Reset counter: 97
                        Mileage: 4519 km
                        Date: 2018.03.26
                        Time: 10:51:24
       Part No SW: 7P6 907 040 CN    HW: 7P6 907 040 CN
       Component: Klima 2 Zonen H23 1507
       Coding: B606200A80
       VCID: 020BA4969552C1569C-8056
    0248 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 91
                        Mileage: 4519 km
                        Date: 2018.03.26
                        Time: 10:51:24
    0318 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 91
                        Mileage: 4519 km
                        Date: 2018.03.26
                        Time: 10:51:24
                        Voltage terminal 30-Data: 14.7 V
                        Outside air temperature-Data: 22.50 °C
                        Engine speed-Data: 760 /min
       Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
       Revision: 22020001    Serial number: 00001089081002
       Coding: 26000096963C5D010020480000005D4C431C6608A2010265000000008040110000000000000000
       VCID: 6ADBEC368522391634-803E
       Component: WWS    150516  033 0021
       Serial number: 90243400150521203007
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
       Component: RLFS  H10 0020
       Serial number: 20571917
       Coding: 025223
       Subsystem 3 - Part No SW: 7P6 941 431 AC    HW: 7P6 941 431 AC
       Component: E1 - LDS  H02 0040
       Serial number: 00000000002505150018
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z01EE1705
       Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0137714793
       Coding: 952F00
    Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
       Part No SW: 7P6 919 475 D    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0030
       Revision: --------    Serial number: 28231514202249
       Coding: 310504
       ASAM Dataset: EV_VW526ParkiAssis2 001013
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 4487628ECFC60F66EE-8010
       Part No SW: 7P0 959 655 E    HW: 7P0 959 655 E
       Component: VW10Airbag04Z H10 0043
       Revision: --------    Serial number: 003NK003U6HG
       Coding: 00000000000000000000000000000000345A
       ASAM Dataset: EV_AirbaVW10BPAVW526 002001
       ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
       VCID: 43856192CAC8085ED7-8016
       Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
       Component: BF-Gewichtss.  003 0005
       Serial number: 5850000R154280LSFT
       Serial number: 3575LRB404V37T8AF1J
       Serial number: 3585LRB40513ALK4390V
       Serial number: 3517ARB401654R14QIRF
       Serial number: 3527ARB401454R14TKC4
       Serial number: 3557BRB40513EENA89H5
       Serial number: 3567BRB404V3EENAKGA4
       Part No SW: 4H0 953 568 L    HW: 7P6 953 507 AF
       Component: Lenks.Modul   H06 0005
       Revision: --------    Serial number: 01374OEA000RM
       Coding: 0000D5
       VCID: 3C771A6EBF3677A696-8068
       Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
       Component: E221__MFL-TAS  H05 0028
       Serial number: 0029689 TRW 20150317
    Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb
       Part No SW: 7P6 920 983 A    HW: 7P6 920 983 A
       Component: Kombi         H13 0515
       Revision: 13240302    Serial number: 658310515592001
       Coding: 8B7733022B08CF05020004
       ASAM Dataset: EV_KombiUDSRBVW526 001022
       ROD: EV_KombiUDSRBVW526_VW52.rod
       VCID: 3D71176AAC2C7EAEA1-8068
    16776973 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 89
                        Mileage: 4494 km
                        Date: 2017.12.13
                        Time: 13:54:08
       Part No SW: 7P6 907 530 M    HW: 7P6 907 530 F
       Component: GW-CAN-L-MOST H13 6042
       Revision: --------    Serial number: 00000001868374
       Coding: 000103AD00
       ROD: EV_GatewUDS_VW52.rod
       VCID: 428B6496D5D20156DC-8016
       Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
       Component: Batt_Sensor  H07 0190
       Serial number: 32139D16385701048222
    5707 - Tire Pressure Monitoring Module
              U0127 00 [008] - No Communications
                        Reset counter: 89
                        Mileage: 4494 km
                        Date: 2017.12.13
                        Time: 13:54:06
                        Voltage terminal 30: 12.0 V
                        Voltage terminal 15: 12.1 V
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    5072 - Door Control Module - Driver's Door
              U0199 00 [008] - No Communications
                        Reset counter: 97
                        Mileage: 4519 km
                        Date: 2018.03.26
                        Time: 10:51:22
                        Voltage terminal 30: 14.5 V
                        Voltage terminal 15: 14.5 V
                        Control Module temperature: 31 °C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5074 - Door Control Module - Rear Left
              U0201 00 [008] - No Communications
                        Reset counter: 97
                        Mileage: 4519 km
                        Date: 2018.03.26
                        Time: 10:51:22
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Component: MEM-FS        H08 0156
       Revision: AA000000    Serial number: 00000150997016
       Coding: C0581B0015004001000001010101202020202121202020
       VCID: 35610F4A9C1CA6EE69-8060
                        Reset counter: 97
                        Mileage: 4519 km
                        Date: 2018.03.26
                        Time: 10:51:24
       Part No SW: 7P6 907 566 A    HW: 4H0 907 566 F
       Component: SWA Master    H06 0021
       Serial number: 0369585735
       Coding: 030221
       VCID: 3F8D6D62A6206CBEB3-806A
       Subsystem 1 - Part No SW: 7P6 907 568 A    HW: 4H0 907 568 F
       Component: SWA Slave  H06 0021
       Serial number: 0369126123
       Coding: 030221
       Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
       Component: TSG FA        H02 0306
       Revision: --------    Serial number: 0000152084897
       Coding: 011D17205E00453005080000
       VCID: 7AFBDC76F5828996C4-802E
       Revision: 00002001    Serial number: 0369635401
       Coding: 0187123A68B9509580A00620210A18000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P6 959 719 A    HW: 7P6 959 719 A
       Component: GTO BT  H20 0059
       Serial number: 112153805
       Subsystem 3 - Part No SW: 7P0 959 591 D    HW: 6R0 959 591 D
       Component: J245 PS30.408  H03 0004
       Serial number: 0000FST000APRQG00000
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 E    HW: 8V3 959 591 A
       Component: J394 PS30.408  H03 0004
       Serial number: 0000CGQ00048CW200000
       Coding: 191100
       Subsystem 5 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
       Component: GEB.F.Heckoef  H16 0813
       Serial number: 65021784
                        Reset counter: 97
                        Mileage: 4519 km
                        Date: 2018.03.26
                        Time: 10:51:24
                        Reset counter: 97
                        Mileage: 4519 km
                        Date: 2018.03.26
                        Time: 10:51:24
       Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
       Component: TSG BF        H02 0306
       Revision: --------    Serial number: 0000151552235
       VCID: 489F76BEFBEE2B0602-801C
       Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C1552400039
       Coding: 01040200
       ROD: EV_ParkbA7.rod
       VCID: 36630846891AADF660-8062
       Slave 3:
    12656659 - Databus
                        Reset counter: 91
                        Mileage: 4519 km
                        Date: 2018.03.26
                        Time: 10:51:24
                        Voltage: 14.6 V
       Coding: 012A02010B000400
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0005
       Coding: B00000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0005
       Coding: B00000
       Component: Radio U SIRIU H66 0133
       Revision: AB001007    Serial number: 156FY0F8271601
       Coding: 020007020100000001
       VCID: 2447C20E27862F66CE-8070
       Part No SW: 7P6 035 664 K    HW: 7P6 035 664 A
       Component: H-BN-NA       H41 0933
       Revision: --------    Serial number: 606E/0FB006177
       Coding: 010200050040E1EF51022B0E00000003F00001030000000000
       VCID: 408F6E9ED3DE1346CA-8014
       Subsystem 1 - Part No: 7P6 060 884 B
       Component: NAR 2015  1202
       Subsystem 2 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
       Component: DU8 SV Touch  H56 0046
       Serial number: VWZ8Z9RX8005FN
       Subsystem 3 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
       Component: CD-Database  6208
                000 -  -  - Intermittent
                        Reset counter: 89
                        Mileage: 4494 km
                        Date: 2017.12.13
                        Time: 13:54:13
                        Bin. Bits: 00000000 10000000
                        Bin. Bits: 00000000 00000000
       Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
       Component: TSG HL        H03 0306
       Revision: --------    Serial number: 0000152162340
       Coding: 011817200000253005080000
       Part No SW: 7P6 907 273 L    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0003
       Serial number: 30000000017137
       ASAM Dataset: EV_RDKBERU30 005005
       ROD: EV_RDKBERU30.rod
       VCID: 45817F8AC4FC366EF9-8010
    Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
       Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
       Component: Anhaenger     H20 0160
       Revision: 7C001003    Serial number: 0369528751
       Coding: 0200000200000000
       VCID: 377D05428E1054FE7B-8062
       Part No SW: 7P6 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0020
       Revision: 00H08000    Serial number: 525 PA8JA41831
       Coding: 0130001
       VCID: 377D0542461054FE7B-8062
       Part No SW: 7P6 959 107 C    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0043
       Revision: 22010001    Serial number: 137501115
       Coding: 0533314003
       ROD: EV_HeckkTouar.rod
       Component: TSG HR        H03 0306
       Revision: --------    Serial number: 0000152337396
    End-------------------------(Elapsed Time: 05:36)--------------------------
    What exactly is different about a "eurospec/cayenne tune"?
    As a general rule, components in modern cars that affect emissions, which the TCU most certainly does, will not accept codings for markets where the emissions specs are different.
    Nov 2014
    Uwe,
    The VW Tdi fix noticeably reduced the performance and capabilities of the transmission on the 7P Touaregs. Having the ability to recode the transmission to regain hill decent control, display which gear on HUD, modify shift points to higher in the rpm, engine braking, all which seems to be present of euro models / or possibly cayenne’s. It would be nice if someone had an auto scan from a European 15+ MY Touareg or Cayenne. As I said in the other thread, it seems the 14+ models have a different rev Module that requires long coding rather than short codes. I may opt to try and swap for a early 7P module and see if it’ll take the European soft coding. Thoughts on swapping modules? I can get one for $150 shipped
    Quote Originally Posted by 04_sti View Post
    So you're trying to un-do the TDI "fix", at least the portion that was applied to the TCU?
    FWIW, my wife and I have a 2015 T'reg TDI. It has not been "fixed", nor do I intended to I allow to to be "fixed". I checked the TCU's coding. It is identical to yours.
    There are folks out there who claim to be able to re-flash these TCUs to a pre-fix state, but Ross-Tech will not touch undoing any part of this fix due to potential legal ramifications.
  5. Likes Fredrick Awuor liked this post
    Nov 2014
    If thats the route you'd like to go, then you can take that same line of thought and apply it to about 99% of all the things that are possible within VCDS. Hell, having a "tweaks" forum section in of itself could have legal ramifications. I dont think thats the appropriate response to my question. However, after meeting you in person when i ATTEMPTED to buy my vagcom, it doesnt surprise me.
    Most "tweaks" that one can do with VCDS have absolutely nothing to do with emissions, and they certainly aren't undoing a parts of a "fix" for things where billions of dollars in fines are involved and for which several people are now rotting in a federal prison.
    Feb 2018
    I too am interested in possible TCU modifications since my '16 Q5 was "fixed." I accept that it will now gulp DEF and behave differently during warm-up. That, I can live with. However, the lurching transmission and delayed accelerator response are deal-breakers long-term. More than unpleasant, it renders the car dangerous in some situations. Truly, it feels like, put the pedal down and wait 2 seconds for the electrons to wake up.
    I've ordered a used Touareg TCM, so we'll see what that brings. There are other reports on the InterWeb of that being successful.
    Or maybe there's something else going on? Scan below:
       Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
       Component: 0BK 30 TDIUSA H19 1007
       Revision: --H19---
       VCID: 4BC39A519342E16FD7A-801E
    12514 - Internal Control Module - Processor Performance Monitoring
              P060A 00 [032] - -
                        Mileage: 51433 km
                        Date: 2018.03.16
                        Time: 12:04:09
                        Unlearning counter according OBD: 5
                        Voltage terminal 30: 11.829 V
                        Engine speed: 668 /min
                        Transmission fluid temperature: 43 ∞C
                        Status of brake signals-Brake Light Switch: operated
                        Status of brake signals-Brake pressure switch: not activated
                        Status of brake signals-Validity of brake pressure information: valid
                        Status of brake signals-Validity of brake pedal information: valid
                        Driving position: P
                        Transmission output speed: 0.00 /min
                        M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                        M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                        M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
                        Status electric parking lock holder solenoid-Desired State Solenoid Out 10: OFF
                        Status electric parking lock holder solenoid-Desired State Solenoid Out 11: OFF
                        Status electric parking lock holder solenoid-Desired State Solenoid Out 12: OFF
                        Status electric parking lock holder solenoid-Desired State Solenoid Out 13: OFF
                        Status electric parking lock holder solenoid-Desired State Solenoid Out 14: On
                        selected gear: without traction
                        Transmission input speed: 313.00 /min
                        Status of starter lock: OFF
                        Stop process prevented-Oil temperature too low: not active
                        Stop process prevented-Transmission fluid temperature too high: not active
                        Stop process prevented-Adaptation procedure active: not active
                        Stop process prevented-Pressure accumulator filling not completed: not active
                        Stop process prevented-Gear 1 or 2 not selected: not active
                        Start process requested-Driver intention: not active
                        Start-stop conditions: Stop prohibition: no start request
                        Start-stop enabling: No release by coordinator
                        M015_Time Normal Mode: 1123 s
                        M019_Time Since Reset: 7650 ms
                        M018_Time In Afterrun: 0 s
                        M014_Time Since Shift: 7650 ms
  9. Likes 04_sti liked this post
  10. #8
    Nov 2014
    Quote Originally Posted by timbo View Post
       Revision: --H19---
              P060A 00 [032] - -
                        Mileage: 51433 km
                        Date: 2018.03.16
                        Time: 12:04:09
                        Driving position: P
    What is the model number Touareg module did you order and from where? I found one for 150 shipped for a module ending in 750g
  11. #9
    Verified VCDS User carboncow's Avatar
    Central Ohio
    Dumb new guy here doing research...
    Are these TCM some what interchange from Audi to Vw to Porsche? Or is more just people talking bout pulling the mapping/program off of one and trying to lay it onto another? I figured the way Porsche does stuff is not the way VAG does even knowing the hardware is the same. Think VCDS vs Durametric...same stuff but different. Very curious.
    2008 V6 Lux+ Pkg with factory towing
    Alaska Grey in Delaware, Ohio
    VCDS-Mobile
  12. #10
    Quote Originally Posted by carboncow View Post
    Not sure. I would consider that "uncharted territory", at least for me. Also, you have a 7L-chassis Touareg, not the newer 7P that's previously been discussed in this thread. I'll tell you this much: Transmission programming is not just specific to the exact model and engine, but even to the sales market (NAR vs. ROW).
