Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 2018 VW Amarok V6 - Cent. Elect. gone "rogue"
    Mar 2014
    South Africa, Johannesburg
    Quote Originally Posted by siLc View Post
    If all else fails, you can have the dealer SVM the car back to factory settings.
    Hi siLc, I was also thinking something to the same effect, should I not get it resolved with advice from the forum. Do you have any details on this process? Is it a single guided function (one process that reverts all control modules), or does it need to be done for each control module individually?
    Reason I am asking, is that I often find that dealers do not know these more "specialised" support functions and if I can give them a heads-up, it speeds the process along. Any detail in this regard will be appreciated. Thanks
  2. #12
    Mar 2014
    Revert then verify with a manual terminal 15 sleep mode initiation or additionally if supported a withdrawn wake request on CAN LIN by deselect on gateway or isolated track.
    Hi Jack, from my reply you will surmise that I am not close to the expert you guys are! Would you mind giving me more detail on how to perform the above? Or a link that explains this, so I can go through it and attempt with confidence? Thanks
  3. #13
    Mar 2014
    Issue resolved
    Good day all,
    So, I had the vehicle to my dealer tech for this and some other preventative maintenance (outside service schedule).
    The coding for Address 09: Cent. Elect. (J519) was coded back to factory. More specifically, the coding for both Subsystem 2 and 3 (J386 & J387 respectively), was changed to 850000. This is not coding available yet within the current version of VCDS label files for this control unit it seems.
    It brings up two questions in my mind:
    1. Why did VCDS not read this coding on the first baseline scan I did, just after I took delivery and prior to any changes made? The reference scan read 000000 instead of 850000
    2. Why is this coding configuration not available for selection in the long coding helper? Is it because the label files for this control module could be incomplete, or outdated against the latest control modules/SW run on them
    Besides the correction of this issue, I also had a SW upgrade done to Address 5F: Information Electr. (J794) (MIB II). You will notice the SW version change in the two scans.
    For completeness, please find below the initial reference Auto Scan and then the latest, after issue resolved.
    Reference Scan:
    Saturday,23,December,2017,15:06:47:08083
    VCDS Version: 17.12.0.1 (x64)
    Data version: 20171213 DS285.1
    VIN: WV1ZZZ2HZJA011164   License Plate: TBD
    Mileage: 120km-74mi   Repair Order: 2017-12-23a
    Chassis Type: 2H-VN81 (7E0)
    Scan: 01 02 03 04 08 09 10 15 17 19 25 32 5F 61 69 0B
    VIN: WV1ZZZ2HZJA011164   Mileage: 120km-74miles
    Address 01: Engine (J623-DDXC)       Labels: None
       Part No SW: 2H6 907 311 B    HW: 059 907 309 J
       Component: 3.0l V6 TDI   H21 0001
       Revision: 9AH21---
       Coding: 012A4132232608020001
       Shop #: WSC 00059 790 00056
       ASAM Dataset: EV_ECM30TDI0112H6907311B 001002
       ROD: EV_ECM30TDI0112H6907311B.rod
       VCID: 275D03D45EF28712AE8-8072
    Address 02: Auto Trans (J217)       Labels:* None
       Part No SW: 2H0 927 158 J    HW: 0DR 325 025 C
       Component: 2H0 30 TDIRdW H22 1003
       Revision: --H22---
       Coding: 000001
       ASAM Dataset: EV_TCMAL450211 002011
       ROD: EV_TCMAL450211.rod
       VCID: 3467E4989F24FC8A1BA-8060
       Part No SW: 2H6 907 379 A    HW: 2H6 907 379
       Component: ESC           H06 0310
       Revision: 00000000    Serial number: 61887000000232
       Coding: 207368B64995B69604A316A992546D85390000
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_Brake1ESCCONTIVN817GP 008001
       ROD: EV_Brake1ESCCONTIVN817GP_008.rod
       Component: LENKW.SENSOR  H07 0070
       Serial number: 24061713470647
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EF306B0E1E8E6DABDE-802A
    Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
       Part No SW: 2H6 907 040 B    HW: 2H6 907 040 B
       Component: ClimatronicT5 H04 0613
       Revision: 00001K05
       Coding: 0000000402
       ASAM Dataset: EV_ClimatronicT5 A01003
       ROD: EV_ClimaAutoT5Basis_VN81.rod
       VCID: 26430ED059F89E1A95E-8072
    Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 089 B    HW: 7E0 937 089 B
       Component: BCM PQ25 MMI4 H82 0752
       Revision: BB082001    Serial number: 58217189170111
       Coding: 3C0002384CA3140013380E3164CB86D4B280654F60CE7160310000030803
       VCID: 326BE2806D30F2BA096-8066
       Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
       Component: RLS 030717 04  42  0106
       Coding: 0228DD
       Subsystem 2 - Part No SW: 6R0 959 802 EJ    HW: 6R0 959 802 EJ  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  023 2322
       Serial number: 13102844170613031920
       Subsystem 3 - Part No SW: 6R0 959 801 EF    HW: 6R0 959 801 EF  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  023 2322
       Serial number: 13202847170627193416
       Subsystem 4 - Part No: 5C0 951 171
       Component: Sensor, DWA 0  005 0502
       Subsystem 5 - Part No: 5C0 951 171
       Subsystem 6 - Part No SW: 2H0 959 442     HW: 2H0 959 442
       Component: E221__MFL-DC1  H02 0103
       Serial number: 39170001675810047257
       Coding: A5FFFF
       Subsystem 7 - Part No SW: 6R0 959 811 P    HW: 6R0 959 811 P
       Component: J388__TSG_HL  022 1323
       Serial number: 13102709170713092001
       Subsystem 8 - Part No SW: 6R0 959 812 P    HW: 6R0 959 812 P
       Component: J389__TSG_HR  022 1323
       Serial number: 13102708170707001926
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0212
       Revision: --------    Serial number: 28231717203575
       Coding: 30810E
       Shop #: WSC 00059 790 00011
       ASAM Dataset: EV_VW75XParkAssis8K 001012
       ROD: EV_VW75XParkAssis8K_001_VN75.rod
       VCID: 71E92D8CA0B689A230C-8024
       Part No SW: 2K5 959 655 B    HW: 2K5 959 655 B
       Component: VW10Airbag01T H08 0018
       Revision: --------    Serial number: 003V1004LLSN
       Coding: 000000000000000000000000000000003154
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       VCID: 3B75CFA4B27A33F2DA0-806E
       Serial number: 3495RRB400M59NFOE9UQ
       Serial number: 3505RRB401E59L4II8EM
       Serial number: 3555YRB400I59JH2NA4T
       Serial number: 3565YRB400K59JH6F8T8
       Part No SW: 2H6 920 883     HW: 2H6 920 883
       Component: KOMBI         H09 1109
       Coding: 131E000300
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
       VCID: 6ED336F0B188965A2DE-803A
    Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
       Part No SW: 7E0 909 901     HW: 7E0 937 089 B
       Component: GW-K-CAN TP20 H82 0752
       Revision: BB082001
       Coding: 742303
       VCID: 68DF40E89B6C486A672-803C
       Component: IMMO          H09 1109
       VCID: 6ADB3AE08D607A7A716-803E
    Address 32: Differential Locks (J647)       Labels:* 2H0-927-771.clb
       Part No SW: 2H0 927 771 B    HW: 2H0 927 771
       Component: Quersperre    H04 0018
       Revision: 11001001    Serial number: 4DG 11.07.17 00
       Coding: 000001
       ASAM Dataset: EV_QuersUDSAAMVN817 002001
       ROD: EV_QuersUDSAAMVN817.rod
       VCID: 2D51F1FC7C0EAD42544-8078
       Part No SW: 5C0 035 680 F    HW: 5C0 035 680 F
       Component: MU-S-N-ER     H41 0449
       Serial number: VWZAZ2T5276334
       Coding: 06180709BE00000011110001000918001F0100D60020010047
       ROD: EV_MUStd4CTSAT_VW27.rod
       VCID: 244714D82FC46C0A8BA-8070
       Subsystem 1 - Part No SW: 3G0 919 866 BF    HW: -----------
       Component: MRM2 2017/18  --- 0821
       Part No SW: 7E0 907 534     HW: 7E0 937 089 B
       Component: Batt.regelung H82 0752
       Coding: E10008AF
       Component: Anhaenger     H12 0100
       Revision: 3A001001    Serial number: 00000441972527
       Coding: 0100000100000000
       VCID: 306FE888633CC0AA7F2-8064
    End-------------------------(Elapsed Time: 03:38)--------------------------
    Issues Corrected Auto Scan:
    Friday,04,May,2018,12:05:23:26037
    VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
    Dealer/Shop Name: DJ
    VIN: WV1ZZZ2HZJA011164   License Plate: HF82LZGP
    Mileage: 9130km-5673mi   Repair Order: 2018-05-04 - 5F DTC Cleared
    VIN: WV1ZZZ2HZJA011164   Mileage: 9130km-5673miles
       Revision: 9AH21---
       Coding: 012A4132233608020001
       Shop #: WSC 29940 001 1048576
       VCID: 271E1F905E88A17C79-8072
       Revision: --H22---
       Coding: 000001
       VCID: 3424F8DC9F5EDAE4CC-8060
       Coding: 01
       VCID: 7EB01AF4E192C0B46A-802A
       Revision: 00001K05
       Coding: 0000000402
       ROD: EV_ClimaAutoT5Basis.rod
       VCID: 260012945982B87442-8072
       Coding: 3C0002380CA1140013380E3164CB86D4B280654F60CE7160310000030803
       VCID: 3228FEC46D4AD4D4DE-8066
       Coding: 0228DD
       Coding: 850000
       Coding: 850000
       Coding: A5FFFF
       Coding: 31810E
       VCID: 71AA31C8A0CCAFCCE7-8024
       VCID: 3B36D3E0B200159C0D-806E
       Coding: 131E020300
       VCID: 6E902AB4B1F2B034FA-803A
       Revision: BB082001
       Coding: 742303
       VCID: 689C5CAC9B166E04B0-803C
       VCID: 6A9826A48D1A5C14A6-803E
       Coding: 000001
       VCID: 2D12EDB87C748B2C83-8078
       Component: MU-S-N-ER     H41 0468
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 2404089C2FBE4A645C-8070
       Coding: E10008AF
       Coding: 010D000100000000
       VCID: 302CF4CC6346E6C4A8-8064
    End----------(Elapsed Time: 02:00, VBatt start/end: 12.3V/12.3V)-----------
    I trust this will help someone with the same issue.
    Regards
    Derick
  4. Likes iichel, Uwe, Jack@European_Parts, Dana liked this post
  5. #14
    Aug 2016
    The Hague, NL
    thank you very much for posting the solution!
