2018 VW Amarok V6 - Cent. Elect. gone "rogue"
DJMAXIZA
South Africa, Johannesburg
C?ID=200764
Good day all, first post for help, though been using VCDS with HEX+CAN USB for some time and as of recently, acquired HEX-NET. Please excuse the very long post - aiming to provide as much info as possible, to seek your expert advice. Also, I will post 2 scans at end of post, one being very first and second the current config.
Vehicle:
2018 VW Amarok DC Highline Extreme (2H), 3.0L V6 TDi 165kW, DDXC - (South Africa), VIN:WV1ZZZ2HZJA011164
Problem:
Front Doors Electric Windows - depending on 09 Cent. Elect. Subsystem coding, I get erratic results with front electric windows and the electric side mirrors. Herewith some behaviours:
  1. Front window button direction is inverted - button up, lets windows down. Also, left and right are not always same i.e. left will be operating correctly, while right is inverted, or both is inverted - all depends on coding. Can just not get both front doors to operate normally.
  2. Left and right windows are swapped. Left button operates right window and vice versa for right button.
  3. Compounded issue with both the above issues happening at same time.
Electric Side Mirrors - since this problem arose, no coding I tried, changes the situation:
  1. Mirror direction/position is inverted.
  2. Rotary button in Fold Up position, then mirrors are in normal driving position.
  3. Rotary button in any other position (Left Adjust, Right Adjust, Heating, 0-Position), then the mirrors fold up in park position.
  4. In the folded up position, when rotary button is in Left Adjust as an example, I can adjust mirror, though it is done while in the folded up position.
Some events leading up to current situation:
Prior to receiving my HEX-NET, I only made basic changes to coding, such as adding 69-Trailer control module to 19-CAN Gateway, enabling selective locking and audible confirmation of locking in 09-Cent. Elect. Everything was operating as per normal.
Upon receiving my HEX-NET in March and reading up on trailer hitch retrofitting from RT Wiki, I then proceeded to properly code for the 69-Trailer control module, by coding 10-Park/Steer Assist, 69-Trailer and some coding to 01-Engine control module on advise from Ross-Tech support - from 012A4132232608020001 to 012A4132233608020001.
In my curious nature, I gone through all control modules to see what else was up for "review"... Have not made any other changes, other than in 09-Cent. Elect. Regarding this, I saw that Subsystem 2 & 3, could use some tweaking...
  1. For Subsystem 2, Byte 0, I have changed from "00 Control Module not coded" to "03 Right-Hand-Drive (RHD)"
  2. For Subsystem 3, Byte 0, I have changed from "00 Control Module not coded" to "02 Standard"
I believe this is where things gone wrong.
Attempted corrective actions:
When the vehicle started to exhibit the strange behaviours, I started trying various coding selections in these two Subsystems, from the available coding selections in Long Coding Helper for these modules. No combination of changes would correct the situation.
I reached out to RT Support and sent them the Debug Logs. Guidance was to revert the coding back to original. I have done so, but still the issues persisted. I have even gone as far as reverting coding of every single control module and Subsystem, back to the original from my initial scan. Also after doing so with no success, removing negative terminal on battery for over 15 min, to hope for a miracle. No amount of coding, custom or original, resolved the issue.
Discovered some partial remedy:
While looking at the coding again and scratching my head, I tried something a bit unorthodox (in my mind at least). Without going into the Long Coding Helper, I manually tried other coding for these two Subsystems (2 and 3 under 09-Cent. Elect.) control modules.
As I noticed the available selections and their corresponding bits values in Subsystem 3 was either 000000 or 020000, I tried and entered 010000 and coding was accepted. The left window operated normally! Then I went to Subsystem 2 and when selecting RHD (030000), the direction of button operation was inverted (up moving window down and vice versa). Changing it to Not Coded (000000) or LHD (020000), both had the same effect of then swapping left and right functions but window direction still inverted.
I then tried also to manually code Subsystem 2 to 010000 also and coding was accepted, with result that electric window button operation for both front doors are now normal and as should be. I honestly do not know what else this "unlabelled" coding could affect, but all seems normal with one exception, mirrors. The mirrors are still misbehaving as per the problem statement above.
I decided not to try much more, as I am not sure what else I could affect and gave this information to RT support. Their guidance was to post all this in the forum to seek some experienced help in this regard.
Some questions:
  1. How can I restore proper function on the electric mirrors?
  2. Could the "unlabelled" coding I entered (that is not available for selection in the Long Coding Helper), affect anything else? I have not observed anything else abnormal, other than the mirrors still.
  3. Could the label files for 09-Cent. Elect. be incomplete or inaccurate, against the newer control modules and Subsystems?
  4. Is there a way to extract mapping files for the Subsystem controllers, or does the master controller (09-Cent. Elect.) contain info on all Subsystems?
Finally:
In an attempt to extract as much supporting information as possible, I manually ran Controller Channel Maps for all modules. Most are UDS, but for some I was still able to extract PLA and PLB map files, including the 09-Cent. Elect. module. Others for which I could extract mapping files is: 09, 19, 61, 69.
Also for all control modules, I extracted the CSV admap and blockmap files, as well as saved Advanced Identification files for all. I cannot attach all these to the post, but will gladly share them all with whomever needs it to help me out.
Herewith my scan outputs:
This is the very initial scan on the Amarok, selecting all addresses to be scanned. This scan was done with HEX+CAN USB interface, where all consequent work was done with HEX-NET when received earlier this year.
Scan done after Trailer Control Module (address 69) was fitted, but not yet coded, other than being added to the CAN Gateway.
Saturday,23,December,2017,14:49:22:08083
VCDS Version: 17.12.0.1 (x64)
Data version: 20171213 DS285.1
VIN: WV1ZZZ2HZJA011164   License Plate: TBD
Mileage: 120km-74mi   Repair Order: 2017-12-23
Chassis Type: 2H-VN81 (XX - All Addresses)
Scan: 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 14
          15 16 17 18 19 1A 1B 1C 1D 1E 1F 20 21 22 23 24 25 26 27 28
          29 2A 2B 2C 2D 2E 2F 30 31 32 33 34 35 36 37 38 39 3A 3B 3C
          3D 3E 3F 40 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50
          51 52 53 54 55 56 57 58 59 5A 5B 5C 5D 5E 5F 60 61 62 63 64
          65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78
          79 7A 7B 7C 7D 7E 7F 80 81 82 83 84 85 86 87 88 89 8A 8B 8C
          8D 8E 8F 90 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0
          A1 A2 A3 A4 A5 A6 A7 A8 A9 AA AB AC AD AE AF B0 B1 B2 B3
          B4 B5 B6 B7 B8 B9 BA BB BC BD BE BF C0 C1 C2 C3 C4 C5
          C6 C7 C8 C9 CA CB CC CD CE CF D0 D1 D2 D3 D4 D5 D6 D7
          D8 D9 DA DB DC DD DE DF E0 E1 E2 E3 E4 E5 E6 E7 E8 E9
          EA EB EC ED EE EF F0 F1 F2 F3 F4 F5 F6 F7 F8 F9 FA FB
          FC FD FE FF
VIN: WV1ZZZ2HZJA011164   Mileage: 120km-74miles
Address 01: Engine (J623-DDXC)       Labels: None
   Part No SW: 2H6 907 311 B    HW: 059 907 309 J
   Component: 3.0l V6 TDI   H21 0001
   Revision: 9AH21---
   Coding: 012A4132232608020001
   Shop #: WSC 00059 790 00056
   ASAM Dataset: EV_ECM30TDI0112H6907311B 001002
   ROD: EV_ECM30TDI0112H6907311B.rod
   VCID: 275D03D45EF28712AE8-8072
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 2H0 927 158 J    HW: 0DR 325 025 C
   Component: 2H0 30 TDIRdW H22 1003
   Revision: --H22---
   Coding: 000001
   ASAM Dataset: EV_TCMAL450211 002011
   ROD: EV_TCMAL450211.rod
   VCID: 3467E4989F24FC8A1BA-8060
   Part No SW: 2H6 907 379 A    HW: 2H6 907 379
   Component: ESC           H06 0310
   Revision: 00000000    Serial number: 61887000000232
   Coding: 207368B64995B69604A316A992546D85390000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN817GP 008001
   ROD: EV_Brake1ESCCONTIVN817GP_008.rod
   Component: LENKW.SENSOR  H07 0070
   Serial number: 24061713470647
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF306B0E1E8E6DABDE-802A
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 2H6 907 040 B    HW: 2H6 907 040 B
   Component: ClimatronicT5 H04 0613
   Revision: 00001K05
   Coding: 0000000402
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis_VN81.rod
   VCID: 26430ED059F89E1A95E-8072
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.CLB
   Part No SW: 7E0 937 089 B    HW: 7E0 937 089 B
   Component: BCM PQ25 MMI4 H82 0752
   Revision: BB082001    Serial number: 58217189170111
   Coding: 3C0002380CA1140013380E3164CB86D4B280654F60CE7160310000030803
   VCID: 326BE2806D30F2BA096-8066
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 030717 04  42  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 802 EJ    HW: 6R0 959 802 EJ  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  023 2322
   Serial number: 13102844170613031920
   Subsystem 3 - Part No SW: 6R0 959 801 EF    HW: 6R0 959 801 EF  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2322
   Serial number: 13202847170627193416
   Subsystem 4 - Part No: 5C0 951 171
   Component: Sensor, DWA 0  005 0502
   Subsystem 5 - Part No: 5C0 951 171
   Subsystem 6 - Part No SW: 2H0 959 442     HW: 2H0 959 442
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39170001675810047257
   Coding: A5FFFF
   Subsystem 7 - Part No SW: 6R0 959 811 P    HW: 6R0 959 811 P
   Component: J388__TSG_HL  022 1323
   Serial number: 13102709170713092001
   Subsystem 8 - Part No SW: 6R0 959 812 P    HW: 6R0 959 812 P
   Component: J389__TSG_HR  022 1323
   Serial number: 13102708170707001926
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231717203575
   Coding: 30810E
   Shop #: WSC 00059 790 00011
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71E92D8CA0B689A230C-8024
   Part No SW: 2K5 959 655 B    HW: 2K5 959 655 B
   Component: VW10Airbag01T H08 0018
   Revision: --------    Serial number: 003V1004LLSN
   Coding: 000000000000000000000000000000003154
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   VCID: 3B75CFA4B27A33F2DA0-806E
   Serial number: 3495RRB400M59NFOE9UQ
   Serial number: 3505RRB401E59L4II8EM
   Serial number: 3555YRB400I59JH2NA4T
   Serial number: 3565YRB400K59JH6F8T8
   Part No SW: 2H6 920 883     HW: 2H6 920 883
   Component: KOMBI         H09 1109
   Coding: 131E000300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   VCID: 6ED336F0B188965A2DE-803A
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.CLB
   Part No SW: 7E0 909 901     HW: 7E0 937 089 B
   Component: GW-K-CAN TP20 H82 0752
   Revision: BB082001
   Coding: 742303
   VCID: 68DF40E89B6C486A672-803C
   Component: IMMO          H09 1109
   VCID: 6ADB3AE08D607A7A716-803E
Address 32: Differential Locks (J647)       Labels:* 2H0-927-771.clb
   Part No SW: 2H0 927 771 B    HW: 2H0 927 771
   Component: Quersperre    H04 0018
   Revision: 11001001    Serial number: 4DG 11.07.17 00
   Coding: 000001
   ASAM Dataset: EV_QuersUDSAAMVN817 002001
   ROD: EV_QuersUDSAAMVN817.rod
   VCID: 2D51F1FC7C0EAD42544-8078
   Part No SW: 5C0 035 680 F    HW: 5C0 035 680 F
   Component: MU-S-N-ER     H41 0449
   Serial number: VWZAZ2T5276334
   Coding: 06180709BE00000011110001000918001F0100D60020010047
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 244714D82FC46C0A8BA-8070
   Subsystem 1 - Part No SW: 3G0 919 866 BF    HW: -----------
   Component: MRM2 2017/18  --- 0821
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.CLB
   Part No SW: 7E0 907 534     HW: 7E0 937 089 B
   Component: Batt.regelung H82 0752
   Coding: E10008AF
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.CLB
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000441972527
   Coding: 0100000100000000
   VCID: 306FE888633CC0AA7F2-8064
Address 76: Park Assist (J446)       Labels:| 7E0-919-475.clb
   Coding: 30810E
End---------------------(Elapsed Time: 43:04, Deb=2)-----------------------
This is my very latest scan, as the vehicle control modules are coded currently (I applied some convenience changes to 09 again, as well as 69 changes applied, as reverting to the original coding on all modules did not resolve the issue)
Saturday,21,April,2018,16:39:00:26037
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
Dealer/Shop Name: DJ
VIN: WV1ZZZ2HZJA011164   License Plate: HF82LZGP
Mileage: 8680km-5393mi   Repair Order: 2018-04-21
Chassis Type: 2H-VN81 (2H - VW Amarok V6 (2017 >))
Scan: 01 02 03 04 08 09 10 15 17 19 25 32 33 5F 61 69 76
VIN: WV1ZZZ2HZJA011164   Mileage: 8680km-5393miles
   Revision: 9AH21---
   VCID: 271E1F905E88A17C79-8072
   Revision: --H22---
   Coding: 000001
   VCID: 3424F8DC9F5EDAE4CC-8060
   Coding: 01
   VCID: 7EB01AF4E192C0B46A-802A
   Revision: 00001K05
   Coding: 0000000402
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 260012945982B87442-8072
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Coding: 3D0002B84CA3140013380EF17ECB96DCF28065FF60CE7160310000030803
   VCID: 3228FEC46D4AD4D4DE-8066
   Coding: 0228DD
   Coding: A5FFFF
   Coding: 318103
   VCID: 71AA31C8A0CCAFCCE7-8024
   VCID: 3B36D3E0B200159C0D-806E
   Coding: 131E020300
   VCID: 6E902AB4B1F2B034FA-803A
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Revision: BB082001
   Coding: 742303
   VCID: 689C5CAC9B166E04B0-803C
   VCID: 6A9826A48D1A5C14A6-803E
   Coding: 000001
   VCID: 2D12EDB87C748B2C83-8078
Address 33: OBD-II        Labels:
   ROD: N/A
   VCID: 3424F8DC075EDAE4CC-8060
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 2404089C2FBE4A645C-8070
   Coding: E10008AF
   Coding: 010D000000000000
   VCID: 302CF4CC6346E6C4A8-8064
   Coding: 318103
End----------(Elapsed Time: 01:51, VBatt start/end: 14.4V/14.4V)-----------
Any advice and help will be much appreciated!
Regards
Derick Joubert
iichel
Netherlands, eastern part
C?ID=284912
Original 09: 3C0002380CA1140013380E3164CB86D4B280654F60CE7160310000030803
Current 09: 3D0002B84CA3140013380EF17ECB96DCF28065FF60CE7160310000030803 <-- not even remotely the same
Original J386: 000000
Current J386: 010000 <-- different!
Original J387: 000000
Current J387: 010000 <-- different!
Don't get me wrong, but if you say 'reverted to original' and it's not the same, then it's not strange that the behaviour is different.
Do this, re-learn comfort function and report back.
The PQ25 window regulator modules have an unknown coding unfortunately.
Putting all the coding back to the last known working coding would be the first step.
DJMAXIZA
C?ID=200764
Hi Iichel, as per post, reverting to original config was the first step. I have even gone as far as reverting every control module's config to original, even removing the retrofit trailer control module too, so everything back to stock. This is why this is such a strange behaviour, as with all control modules back to original config, the problem still persisted and even RT Support mentioned it was odd and recommended I seek more support on the forum.
The current config is with the convenience changes in coding applied again, as reverting to the original coding had no effect in resolving the problem.
You pointed to the interesting thing also: J386 and J387: while the original 000000 coding for both did not fix the issue and the Long Coding Helper only offered a limited selection of options (010000 not available as a selection on either one), I somehow got the idea to try 010000 on J387 and then J386. In both instances the coding was accepted and that changed the electric windows to operate normally again for the first time since the problem started. Hence the question if the label files could possibly be outdated against the latest control module and subsystems.
The Electric mirrors are however still not corrected and decided to come to the forum to seek help, as I did not want to further risk entering "unproven/undocumented" coding.
Regarding PQ25, I did manage to extract PLA and PLB map files by using Controller Channel Maps function, if that will help?
Also, you mentioned re-learning comfort function - would you mind telling me what this is and how, as this is new to me? (this could be the missing link after I reverted back to original coding)
iichel
C?ID=284912
so what I would recommend
- revert to original coding (again, sorry) you can probably leave the trailer installation installed
- ignition off
- lock the car
- wait a few minutes
- unlock car
- ignition on
- see what happens
otherwise, disconnect the battery shortly.
the WRM coding usually only takes effect after an ignition cycle.
learning the comfort function is quite easy
for every window:
- close window
- pull up window switch to 2nd click
- hear click from window motor
- release
DJMAXIZA
C?ID=200764
Thank you for prompt reply. I now get what you were saying with the re-learning of comfort function - yes, I had to do that to get the one-touch rolling up and down operational again after some of the changes.
On the point of cycling the power (ignition on and off), I have also done that, as well as disconnected the battery for about 15 minutes (twice) after some of the changes and then back to original coding. I have tried several times with different codings, as well as with original.
The only thing I did not do, was the locking of the car with ignition off. I can give that a try tomorrow, after changing back to original coding again and give feedback.
Thank you
iichel
C?ID=284912
If disconnecting the battery doesn't make a difference, I doubt the locking will have a better chance of succes...
DJMAXIZA
C?ID=200764
I tend to agree, though desperation has seen people do stranger things :)! I do appreciate the time you have taken to look at this and responding, hopefully more geniuses will be drawn to this problem, as I am truly bowled over by this issue. Have a good eve, regards.
siLc
Tallinn, Estonia
C?ID=330192
If all else fails, you can have the dealer SVM the car back to factory settings.
Revert then verify with a manual terminal 15 sleep mode initiation or additionally if supported a withdrawn wake request on CAN LIN by deselect on gateway or isolated track.
DJMAXIZA
C?ID=200764
Hi siLc, I was also thinking something to the same effect, should I not get it resolved with advice from the forum. Do you have any details on this process? Is it a single guided function (one process that reverts all control modules), or does it need to be done for each control module individually?
Reason I am asking, is that I often find that dealers do not know these more "specialised" support functions and if I can give them a heads-up, it speeds the process along. Any detail in this regard will be appreciated. Thanks
DJMAXIZA
C?ID=200764
Hi Jack, from my reply you will surmise that I am not close to the expert you guys are! Would you mind giving me more detail on how to perform the above? Or a link that explains this, so I can go through it and attempt with confidence? Thanks
DJMAXIZA
C?ID=200764
Issue resolved
Good day all,
So, I had the vehicle to my dealer tech for this and some other preventative maintenance (outside service schedule).
The coding for Address 09: Cent. Elect. (J519) was coded back to factory. More specifically, the coding for both Subsystem 2 and 3 (J386 & J387 respectively), was changed to 850000. This is not coding available yet within the current version of VCDS label files for this control unit it seems.
It brings up two questions in my mind:
  1. Why did VCDS not read this coding on the first baseline scan I did, just after I took delivery and prior to any changes made? The reference scan read 000000 instead of 850000
  2. Why is this coding configuration not available for selection in the long coding helper? Is it because the label files for this control module could be incomplete, or outdated against the latest control modules/SW run on them
Besides the correction of this issue, I also had a SW upgrade done to Address 5F: Information Electr. (J794) (MIB II). You will notice the SW version change in the two scans.
For completeness, please find below the initial reference Auto Scan and then the latest, after issue resolved.
Reference Scan:
Saturday,23,December,2017,15:06:47:08083
Mileage: 120km-74mi   Repair Order: 2017-12-23a
Chassis Type: 2H-VN81 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 32 5F 61 69 0B
   Revision: 9AH21---
   Revision: --H22---
   Coding: 000001
   Coding: 01
   Revision: 00001K05
   Coding: 0000000402
   Coding: 3C0002384CA3140013380E3164CB86D4B280654F60CE7160310000030803
   Coding: 0228DD
   Coding: A5FFFF
   Coding: 30810E
   Coding: 131E000300
   Revision: BB082001
   Coding: 742303
   Coding: 000001
   Coding: E10008AF
End-------------------------(Elapsed Time: 03:38)--------------------------
Issues Corrected Auto Scan:
Friday,04,May,2018,12:05:23:26037
Mileage: 9130km-5673mi   Repair Order: 2018-05-04 - 5F DTC Cleared
VIN: WV1ZZZ2HZJA011164   Mileage: 9130km-5673miles
   Revision: 9AH21---
   Coding: 012A4132233608020001
   Shop #: WSC 29940 001 1048576
   Revision: --H22---
   Coding: 000001
   Coding: 01
   Revision: 00001K05
   Coding: 0000000402
   Coding: 0228DD
   Coding: 850000
   Coding: 850000
   Coding: A5FFFF
   Coding: 31810E
   Coding: 131E020300
   Revision: BB082001
   Coding: 742303
   Coding: 000001
   Component: MU-S-N-ER     H41 0468
   Coding: E10008AF
   Coding: 010D000100000000
End----------(Elapsed Time: 02:00, VBatt start/end: 12.3V/12.3V)-----------
I trust this will help someone with the same issue.
Regards
Derick
