Results 1 to 10 of 13
Thread: MY VOLKSWAGEN PASSAT WONT GO INTO GEAR
    Mar 2018
    Nigeria
    PLS SEE MY SCAN RESULT BELOW. I CHECKED MEASURING BLOCKS 30 31 AND 32
    Friday,30,March,2018,10:30:02:37132
    VIN: WVWZZZ3CZCP015734   License Plate:
    Mileage: 74700km-46416mi   Repair Order:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4F 52 53 56 61 62 72
    VIN: WVWZZZ3CZCP015734   Mileage: 74700km-46416miles
    01-Engine -- Status: Not registered 0011
    02-Auto Trans -- Status: Not registered 0011
    Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
       Part No SW: 06J 906 027 B    HW: 06J 907 309 B
       Component: MED17.5.2        04 8317
       Revision: PAH04---    Serial number: VWZCZ000000000
       Coding: 0404001024070060
       VCID: 2A0DFF1AE0F639970CC-807E
    005668 - MIL Request Signal Active (Check TCM for errors too!)
                   P1624 - 000 -  - Intermittent
                        Temperature: 62.0C
                        Temperature: 33.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 11.049 V
    001674 - ECM Power Relay Load Circuit
                   P068A - 000 - Opens Too Early
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 62.0C
                        Temperature: 33.0C
                        Voltage: 11.049 V
                   U1017 - 015 -
                        Fault Status: 01101111
                        Mileage: 74701 km
                        Date: 2012.08.20
                        Time: 00:34:27
                        Temperature: 62.0C
                        Temperature: 33.0C
                        Voltage: 11.176 V
    000604 - Fuel Pump Control Module
                   P025C - 000 - Short to Ground - Intermittent
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 12.319 V
    005703 - Check Coding of ECUs on Powertrain Data Bus
                   P1647 - 000 -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 74701 km
                        Date: 2012.08.20
                        Time: 00:00:27
                        RPM: 1258 /min
                        Load: 25.1 %
                        Temperature: 25.0C
                        Temperature: 30.0C
                        Voltage: 14.351 V
    Readiness: 1010 0001
       Part No SW: 0AM 300 051 R    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 2711
       Revision: 00043014    Serial number: CU501107265644
       Shop #: WSC 00028 028 00001
       VCID: 392FD0561550820F756-806C
    006079 - Hydraulic Pump
                   P17BF - 000 - Play Protection
                        Reset counter: 10
                        Mileage: 74701 km
                        Date: 2012.08.20
                        Time: 00:07:25
    006279 - Wheel-Speed Signal from ABS Control Module
                   P1887 - 000 - Implausible Signal
                        Reset counter: 10
                        Mileage: 74701 km
                        Date: 2012.08.20
                        Time: 00:07:27
    006300 - Function Restriction due to Insufficient Pressure Build-Up
                   P189C - 000 -
                        Reset counter: 10
                        Mileage: 74701 km
                        Date: 2012.08.20
                        Time: 00:07:45
       Part No SW: 3AA 614 109 AB    HW: 3AA 614 109 AB
       Component: J104   C2 450M V4B6 0022
       Revision: --H07---    Serial number: 00000004573842
       Coding: 0131450
       VCID: 6D8734061198EEAFA9E-8038
                        Reset counter: 182
                        Mileage: 74701 km
                        Date: 2012.08.20
                        Time: 00:07:26
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 14.00 V
                        Bin. Bits: 00011111
                        Count: 215
                        Hex Value: 0x0000
                        Reset counter: 182
                        Mileage: 74701 km
                        Date: 2012.08.20
                        Time: 00:07:26
       Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
       Component: AC Manuell    H19 0304
       Revision: 00001015
       Coding: 0000001002
       Shop #: WSC 00028 028 00022
       VCID: 7F5BFE4E47746C3F0B2-802A
    Address 09: Cent. Elect.
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__101 VW10 HI   1918
       Revision: 22014000    Serial number: 003K0PE55JHM
       Coding: 0012337
       VCID: 4CC199824AC207A7DE0-8018
       Subsystem 1 - Serial number: 6332MTS650652071
       Subsystem 2 - Serial number: 6342MTS690322081
       Subsystem 3 - Serial number: 6351HTS6HPK7AAKR
       Subsystem 4 - Serial number: 6361HTS6HJPR8AKJ
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Revision: --X01---    Serial number: 20170602200939
       Coding: 7982A00000
       Shop #: WSC 01286 386 08256
       VCID: 025D77BA348601D764C-8056
       Serial number: 70000000000000316582
       Coding: E20000
    226839 - Turn Signal Switch
              B1144 11 [009] - Short to Ground
                        Reset counter: 182
                        Mileage: 74701 km
                        Date: 2018.03.30
                        Time: 00:07:26
              B1149 13 [009] - Open Circuit
                        Reset counter: 182
                        Mileage: 74701 km
                        Date: 2018.03.30
                        Time: 00:07:26
    1140738 - Steering angle sensor
                        Reset counter: 182
                        Mileage: 74701 km
                        Date: 2018.03.30
                        Time: 00:07:26
                        UBat: 14.40 V
                        MC1 interner Fehlercode: 0
                        MC2 interner Fehlercode: 0
       Part No SW: 3AA 920 870 C    HW: 3AA 920 870 C
       Coding: 160F00
       VCID: 323DE77AC4A67157B4C-8066
       Part No SW: 7N0 907 530 K    HW: 1K0 907 951
       Component: J533  Gateway H40 1620
       Revision:   H40       Serial number: 180711F2001885
       Coding: 469007
       VCID: 3829D552225A9B078A8-806C
                        Mileage: 74701 km
                        Date: 2012.08.20
                        Time: 00:07:26
       Part No SW: 3AA 959 433     HW: 3AA 959 433
       Component:    IMMO         043 0400
       VCID: 76B51B6A64CE2D77584-8022
       Component: TUER-SG FT    002 0533
       Revision: 12110009    Serial number: 0003312361
       Coding: 0010B7
       VCID: 3537DC6635C8666F91E-8060
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0408
       Serial number: 00000002351948
       Coding: 000090
       Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.310 1002
       Revision: 1AH03733    Serial number: 00112160156401
       Coding: 0000258
       VCID: 3C21C9421A62B7276E0-8068
    00566 - Steering Assistance Operation
                        Fault Status: 11101000
                        Reset counter: 182
                        Mileage: 74701 km
                        Date: 2012.08.20
                        Time: 00:07:25
                        Hex Value: 0x7301
                        Hex Value: 0x7601
                        Hex Value: 0x7301
                        Hex Value: 0x7601
                        Hex Value: 0x0000
    02546 - Steering Limit Stop
                        Fault Status: 11100101
                        Reset counter: 182
                        Mileage: 74701 km
                        Date: 2012.08.20
                        Time: 00:07:25
                        RPM: 759 /min
                        (no units): 7.0
                        Voltage: 14.30 V
                        Reset counter: 182
                        Mileage: 74701 km
                        Date: 2012.08.20
                        Time: 00:07:25
                        (no units): 7.0
                        Steering Angle: 0.00
                            Not OK
                        (no units): 8
                        Fault Status: 11101101
                        Reset counter: 182
                        Mileage: 74701 km
                        Date: 2012.08.20
                        Time: 00:07:27
                        RPM: 769 /min
                        (no units): 7.0
                        Voltage: 14.20 V
    03375 - Steering Motor
                003 - Mechanical Failure - MIL ON
                        Fault Status: 11100011
                        Reset counter: 84
                        Mileage: 73598 km
                        Date: 2012.01.08
                        Time: 19:43:19
                        (no units): 7.0
                            OK
                        (no units): 9
       Component:    KSG PQ47 ELV 043 0634
       Coding: 00910A0002860E763004941570084F0B607801
       Component: EZE_2         H40 1620
       Coding: 00000008
       VCID: 6FBB2E0E17941CBF9B2-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0003
       Component: TUER-SG BT    002 0533
       Revision: 14110009    Serial number: 0003321874
       Coding: 0010B6
       VCID: 3635DB6A28CE6D77984-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0408
       Serial number: 00000002355979
       Coding: 000090
              B11EC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 182
                        Mileage: 74701 km
                        Date: 2018.03.30
                        Time: 00:07:26
       Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
       Component: J540 EPB4  VW-64783 0009
       Revision:   H19       Serial number: 00000000122502
       Coding: 0022157
       VCID: 3537DC663948666F91E-8060
                        Fault Status: 01101101
                        Reset counter: 182
                        Mileage: 74701 km
                        Date: 2012.08.20
                        Time: 00:07:27
                        Voltage: 14.40 V
                        Count: 104
                        Hex Value: 0x1260
                        Hex Value: 0x0001
                        Hex Value: 0x0101
       Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
       Component: Radio RCD310  032 0079
       Revision: 01000001    Serial number: VWZ1Z2L3142520
       Coding: 05000400040010
       VCID: 72BD277A04A6315774C-8026
       Component: Batt.regelung H40 1620
       Coding: 03220858
       VCID: 71BF287601A00A4F8D6-8024
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900216624
    End----(Elapsed Time: 01:23, VBatt start/end: 14.0V/14.1V. VIgn 0.0V)------
    Mar 2018
    Nigeria
    HOW DO I ADD PICTURES
    Quote Originally Posted by imoebu View Post
    See here:
    http://forums.ross-tech.com/showthread.php?95
    New User
    Jun 2018
    Hi, IS there any way you could tell me what the measuring blocks were for this as I have just fitted a new accumulator on my dsg megatronics and yet I am still not getting enough pressure for the pump to stop, my pressure before was 30-40 and now I am getting up to 45-55 but it just won't get up to 60 or 70 where I believe it needs to be so the pump is running constantly and the fault is still there,
    I am wondering if it is possible that I have air lock in the system? I first refilled the hydraulic fluid through the breather cap, then I read that causes air locks , so I drained it, removed the starter motor and refilled from correct point, now I am scratching my head wondering why it not getting enough pressure still
    My car mk6 1.6 TDI 2011 DSG , 139,000 miles,
    any advice many thanks
    Quote Originally Posted by alesypalsy View Post
    Please post an Auto-Scan so people can see exactly which DSG and Mechatronics (TCU) your car has.
    Jun 2016
    Guyana
    This is the DSG 7 0AM dry clutch, many mech unit issues relating pressure, this unit needs to maintain between 40 - 60 bars to fully functional and working, air lock can be a problem , also the accumulator plate is a main reason for a low pressure issue would replace this, i would recommend you uninstall the mech unit change the plate , bench refill it with exactly one litre hydraulic fluid, and installed correctly and this will fix your problem.
  7. Likes Uwe liked this post
    New User
    Jun 2018
    Thank you for helpful reply!,, I today stripped the megatronic unit down and found the o-ring had been squashed when I installed the new part!,, I am 99.9% sure this is my problem, I shall try to find some where I can buy a o-ring to fit this tomorrow, otherwise I will have to await one in post,
    I got the Kinergo housing and accumulator repair and when I installed the housing I had squashed the o-ring ! silly move by myself but at least I now have the cause.
    thanks again
  9. #8
    Jun 2016
    Guyana
    hope that is the issue, please keep us posted with the results, thanks!!
  10. #9
    New User
    Jun 2018
    Just to update here, I today refitted the unit with new O ring seal and it has fixed the problem,, so I am now very happy!
    the update is good news,
    thanks!
  11. #10
    This is why you should always use seal lube when installing any oring
  12. Likes Golftwincharged liked this post
