2015 Golf MK7 - eGolf LED headlight conversion - leveling problem
alpinehans
C?ID=144881
I am converting a 2015 Golf SE Sportwagen TDI from halogen to the OEM eGolf LED headlights. The lights are in, wiring is complete, coding is complete, and the LEDs are amazing. What I am struggling with is getting the auto leveling to work.
My car came with a mid CAN Gateway J533 which does not support leveling. So I upgraded to a HIGH. The dealership removed CP but didn't perform all the required steps in ODIS so a few of my modules on the CAN bus are throwing faults. The most annoying one is 17149 - Check Coding of ECUs on Powertrain Data Bus because it causes the coil in the instrument cluster to flash. I have found a procedure and I am scheduled to go back to the dealership in a few days to get this straightened out.
In addition, when I plugged in the leveling module J431 it says it is missing End of Line Programming. I haven't been able to find out if the dealership sold me an incomplete module or if uploading the End of Line Parameters is a normal procedure. Unfortunately VCDS does not have that capability (yet?!). Is this done using ODIS? Unfortunately my dealership is very inexperienced and not too motivated to research it on their own.
Attached is my scan.
Sunday,15,April,2018,18:10:17:40467
VIN: 3VWFA7AU8FM519186   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 69 75
VIN: 3VWFA7AU8FM519186   Mileage: 14152km-8793miles
47-Sound System -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 C    HW: 04L 907 309
   Component: R4 2.0l TDI   H23 9282
   Revision: 85H23---
   Coding: 01190012032410081000
   Shop #: WSC 30840 002 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021C 004014
   ROD: EV_ECM20TDI01104L906021C_004.rod
   VCID: 25170C6B2568E71F21E-8070
          P1647 00 [175] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Fault Frequency: 65
                    Mileage: 13738 km
                    Date: 2018.03.27
                    Time: 16:57:16
                    Coolant temperature: 22 °C
                    Intake air temperature: 22 °C
                    Ambient air pressure: 830 mbar
                    Voltage terminal 30: 11.660 V
                    ACC variants-Bits 0-7: 0
                    CCS Switch-Bits 0-7: 1
                    Cruise control switch actuation-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 32
                    ACC variants (coding)-Bits 0-7: 1
                    Acceleration: 0.000 m/s²
17921 - Databus
          U1122 00 [038] - Implausible Message
                    Mileage: 14152 km
                    Date: 2018.04.15
                    Time: 17:27:39
                    Coolant temperature: 12 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 12.040 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 1
                    Drivetrain coordinator: brake function status-Bits 0-7: 0
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revision: 00000000    Serial number: 51385000000080
   Coding: 04FA6AA1242109750078020881C92520562490004081A4B200630050C002
   VCID: 47CBA6E3FF24150FF32-8012
   Revision: 00021000    Serial number: 0365852065
   Coding: 030C1C
   Shop #: WSC 01383 790 50316
   VCID: 3A2DCF17BCD678E77CC-806E
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 02020104202100000000000000000000
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 46D5ABE7F82E0C07084-8012
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Component: BCM PQ37BOSCH 028 0145
   Revision: --------    Serial number: 86582404150684
   Coding: 005308464041026969E44000001407001800000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4ACD9FD7EC36E867ECC-801E
   Component: WWS    150411  043 0581
   Serial number:         150609124147
   Coding: 0F4DFD
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y15M04D16H23M14S06
   Coding: 14A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST0004CZM100000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST0004CZKZ00000
   Coding: 191800
   Serial number: 003GCR01VAAO
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J150002P5XA0H
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 002 005 15
   Serial number: 3570000000090685941E
   Subsystem 3 - Part No SW: -----------    HW: 480 002 005 15
   Serial number: 3580000000035585941D
   Subsystem 4 - Part No SW: -----------    HW: 480 401 404 15
   Serial number: 3510002A91A87854010V
   Subsystem 5 - Part No SW: -----------    HW: 480 402 104 15
   Serial number: 3520002B519EFF53C3EX
   Subsystem 6 - Part No SW: -----------    HW: 480 401 404 15
   Serial number: 3550002BF19EFF50E13W
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 804 15
   Serial number: 3560002BF1A878553216
   Revision: FF032032    Serial number: 20150422500922
   Coding: 0400
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 045171EF8E92FE17560-8050
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 08A5121228004F0502004A000000000000000000
   VCID: 65974C6B65E8271FE1E-8030
          U1014 00 [009] - -
                    Reset counter: 53
                    Mileage: 14152 km
                    Date: 2018.04.15
                    Time: 17:43:43
   Revision: --------    Serial number: 19101610522089
   Coding: 000000F0000F58000E000002000B00000000000100000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 7CA1090FF66286D72E0-8028
131695 - Digital sound System control module
          U106A 00 [009] - No Communication
          [Timeout Knoten 0x6F / 47 - Steuergerät für digitales Soundpaket]
                    Reset counter: 53
                    Mileage: 14152 km
                    Date: 2018.04.15
                    Time: 17:54:07
                    Supply voltage: Terminal 30: 11.8 V
                    Terminal 15: On
67072 - Local Databus
          U1125 00 [009] - Additional Installations Detected
          [Subsystem Mehrverbau erkannt]
                    Reset counter: 53
                    Mileage: 14152 km
                    Date: 2018.04.15
                    Time: 17:54:07
                    Terminal 15: On
   Revision: 00000000    Serial number: 15000105448003
   Coding: 5500000000000000
   Shop #: WSC 00066 790 07030
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431E12F9EB28E97A60-8060
12666368 - Databus
          [Timeout Message Gateway_71]
                    Reset counter: 63
                    Mileage: 13738 km
                    Date: 2018.03.27
                    Time: 14:52:39
                    ELV State: 04
                    Information Clamps: 00 00
                    CoCo State: E0 01
                    WFS State: 07 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 68
                    AD-Value H-bridge: 34
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
12666372 - Databus
          [Timeout Message Gateway_73]
                    Reset counter: 63
                    Mileage: 13738 km
                    Date: 2018.03.27
                    Time: 14:52:39
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 07 06
                    Voltage: 68
                    CAN signals: 00
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 21051506050FWV
   Coding: 003013200000040000000000
   VCID: 3E25C307A0FE54C7404-806A
   Serial number: 00000000000001282438
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43D3B2F3CB1C392F2FA-8016
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0070
   Serial number: VWZ8Z1FC402PGHI
   Coding: 22000000AAAAAA0000
   ASAM Dataset: EV_AMPMst12C1ALPI 001007
   ROD: EV_AMPMst12C1ALPI.rod
   VCID: 639352736BDC592F0FA-8036
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 280515060506FW
   Coding: 003013200C00040000000000
   VCID: 3D27C40BADF84FDF59E-8068
   Serial number: 00000000000001235066
   Coding: 091000
   Coding: 0000000000000000
   VCID: 75B71C2BD548D79F51E-8020
10490624 - No End-of-Line Programming
          B2013 00 [137] -  -
                    Reset counter: 34
                    Mileage: 13897 km
                    Date: 2018.04.03
                    Time: 17:40:21
13636352 - Control module not coded
          U1013 00 [137] - -
          [Steuergeraet nicht codiert]
                    Reset counter: 34
                    Mileage: 13897 km
                    Date: 2018.04.03
                    Time: 17:40:21
5275220 - Headlight
                    Reset counter: 34
                    Mileage: 13897 km
                    Date: 2018.04.03
                    Time: 17:40:21
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0655
   Serial number: V7B00405150080
   Coding: 027302000000000021220002001800001F0102340100010000
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 6491516F6ED25E17F60-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9RS501W29
          B11CF 53 [009] - Deactivated
                    Reset counter: 52
                    Mileage: 14146 km
                    Date: 2018.04.14
                    Time: 14:13:45
                    Voltage terminal 30: 11.8 V
6963 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Emergency call module (0x33) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 53
                    Mileage: 14152 km
                    Date: 2018.04.15
                    Time: 17:47:58
7219 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 53
                    Mileage: 14152 km
                    Date: 2018.04.15
                    Time: 17:48:01
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0204
   Revision: 8C001003    Serial number: 0410657900
   Coding: 0100000000000000
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C0023A01000000000000
   Shop #: WSC 00066 790 00322
   ROD: EV_OCULowMQB.rod
End----(Elapsed Time: 01:19, VBatt start/end: 11.7V/11.5V. VIgn 11.6V)-----
myounus
Northwest UK
C?ID=321059
Hi
New modules require paramaterisation which unfortunately VCDS cannot do. The dealer should be able to do this using ODIS, otherwise there are other tools on the market such as VCP that can also do the same. The best advice I can give you is to go back to the dealer.
alpinehans
C?ID=144881
Parameterization of the leveling module J431 using ODIS failed today:
The following malfunction has occurred: ERP0617E - Software configuration (coding, adaptation/calibration, parameterization) could not be computed. Please check whether a compatible control module or replacement part is installed in the vehicle. If the malfunction continues, consult Customer Support.
The same fault is reported when we try to run the "replace control module" and "function release" procedures in ODIS for the CAN Gateway J533, which still is showing some data bus faults.
Out of curiosity I checked with the dealership parts guy again today and he says the part number of the high CAN Gateway for my VIN ends in "AC". The one he sold me a few months ago ends in "AM". Aren't these letters the software revision? This might be the problem right there ...
No, they are software part numbers.
The software revision for that part number is here:
alpinehans
C?ID=144881
OK, so the difference between a 5Q0-907-530 AC and AM is software or hardware? When I search the online parts catalog for a J533 for my VIN it gives me both plus a half dozen others.
What's the chance that this is the source of my programming trouble?
Cheers
Hans
Again, those are software part numbers, so the difference between them is software.
You currently have:
So you have 5Q0-907-530-AM software installed on 5Q0-907-530-M hardware.
myounus
Northwest UK
C?ID=321059
Alpinehans
A gateway which is AC is normally high as I've got one myself. Uwe has quite rightly pointed out how you can tell the difference with a simple VCDS scan. However I don't think the Gateway is your issue. If you cannot paramaterise the module it's likely to be the wrong one.
I've fitted auto-levelling myself in a Golf7 and used module 7P6 907 357D, although I've not studied the schematics for an e-golf. You can check the part numbers on ETKA but beware they're not always 100% accurate. On a recent installation the part numbers were incorrect for the level sensor, fortunately I'd done it before so sussed it out!
Regards
Mohammed
alpinehans
C?ID=144881
Got the exact same results when trying to program the 5Q0-907-530 AC Z00 version of the J533 Gateway using ODIS at the dealership:
The dealership is getting the VW technical rep involved now.
myounus
Northwest UK
C?ID=321059
Get a used one off eBay or from a damaged car. Fit it in, get component protection removed and it'll work.
DJAlix
London, United Kingdom
C?ID=238277
The dealership version of ODIS, ODIS service, is never going to be able to do this as the module in question is not meant to be in the car. The only way to parameterise the module will be via hosting it in a car / chassis number which has the module already or "offline" via 3rd party software.
alpinehans
C?ID=144881
The 5Q0 907 530 AC is the official replacement module for my VIN.
alpinehans
C?ID=144881
@DJAlix, I understand you're across the pond from me, but would you be able to perform any of these things for me without having access to the car?
darkchina811
ITALY
C?ID=333184
hi I am wondering if you ever sorted this out. I am looking into the same eGolf LED retrofits for my halogens so I could use a little help.
darkchina811
ITALY
C?ID=333184
forget it, I just remembered why I had put this retrofit on the side. DRL modules are external to the headlight and to fit the e-Golf's, the bumper needs to be replaced. how did you handle that?
vastechnics
C?ID=143747
Just do FES. That will release all function incl CCS Drive mode etc. The fault code you get is only involved with online coding and svm. If FES also no work need to get AC
Morski
Cheshire UK
C?ID=90186
Can you elaborate on FES please?
alpinehans
C?ID=144881
I have kept the stock bumper and have programmed the low beams as DRL. The low beams are LED with a long life expectancy and use low wattage, plus they are bright compared to the DRL in the bumper that are stylish but in MHO do not enhance safety which is the primary purpose of the DRL.
alpinehans
C?ID=144881
I agree that it appears that the fault is produced by the VW server - whether it's a bug or intentional - you make it sound there's a way to do FES offline?
My car came with CCS from the factory, and I am only interested in restoring what I originally had.
darkchina811
ITALY
C?ID=333184
that sounds promising, I did not think about it. so the low beams are also DRLs with a lower brightness or did you keep the same?
alpinehans
C?ID=144881
Regular brightness. Light configuration-Dimmwert 127 for both low beam and DRL.
I didn't try to reduce the brightness. Not sure if it is possible because these are powered by the LED light module.
