Results 1 to 10 of 15
Thread: Changing climatronic on e-Golf to remember last setting
Hybrid View
    Apr 2018
    Canada
    There is an issue with the climatronic on the e-Golf. It will not remember the last setting so when you get back in the car it resets to a default of 72F / 22C. There is a tech tip for the 2015 and 2016 e-Golf and I'm trying to implement this on my new 2018 e-Golf. The tech tip is TT 87-15-02. There is a user on MyVWeGolf who said it got it to work on his 2017, but I cannot get it to work on mine. I cannot get the value to change from inactive to active, in my case the first time I try to change the value I get an error saying "value out of range", and the second time saying "the value was rejected by the controller and it will probably fail" (or something to that effect).
    Looking for any insight as how I might set this value on my e-Golf?
    Here is a log from a scan I did just after I got it home from the dealer. The only change I made prior to the scan is I changed the setting to remember both driver and passenger electric seat heater setting. I was able to change the setting, but it did not work. After I get back in the car where I previously had the seat heat on, it is set to off, so it's not remembering the last setting. I have since set it back to the way it was.
    Saturday,14,April,2018,09:09:34:19795
    VCDS Version: 18.2.0.3
    VIN: WVWPR7AU3JW909878   License Plate:
    Mileage: 108km-67mi   Repair Order:
    Chassis Type  AU-VW37 (3Q0)
    Scan: 01 03 05 08 09 10 13 15 16 17 19 23 2B 3C 42 44 4B 51 52 5F
              8C A5 BD C0 C5 C6
    VIN: WVWPR7AU3JW909878   Mileage: 108km-67miles
    4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
    BD-Hi Volt. Batt. Charg. -- Status: OK 0000
    C5-Therm. mgt. -- Status: Malfunction 0010
    Address 01: Engine (J623-EAZA)       Labels:. 0EA-907-309-V1.clb
       Part No SW: 0EA 906 016 F    HW: 0EA 907 309 A
       Component: E-Vehicle     H24 4238
       Revision: WMH24---
       Coding: 000D0016006400003000
       ASAM Dataset: EV_VCU00XXX0110EA906016F 004005
       ROD: EV_VCU00XXX0110EA906016F_004.rod
       VCID: 3245C4D9656232D4DE-8066
       Part No SW: 5Q0 614 517 DB    HW: 5Q0 614 517 AH
       Component: ESC           H62 0856
       Revision: 00000000    Serial number: 60078000000101
       Coding: 01FA40A12C202175857F0207A1CB2980023484A14085943238915058C2E203
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
       ROD: EV_Brake1UDSContiMK100OMG_003_VW37.rod
       VCID: 74C902C1DFF67CE40C-8020
       Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0803
       Revision: 00021000    Serial number: 0470501508
       Coding: 032C0C
       ASAM Dataset: EV_KessyHellaMQBAB 002020
       VCID: 3C59EAE1B726F4A404-8068
       Part No SW: 5GE 907 044 AN    HW: 5GE 907 044 AN
       Component: Climatronic   H04 1702
       Revision: 00001K01
       Coding: 0002220020011001050500020010102B
       VCID: 08314631B37E680450-805C
       Air quality sensor:
       Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H36 0253
       Serial number: 01001803900229
       ROD: EV_BCMCONTI.rod
       VCID: 062D4809B96A7E7422-8052
       Component: WWS    180113  043 0551
       Serial number:         180119102247
       Component: RLHS  047 0105
       Serial number: S4Y18M02D14H08M34S43
       Coding: 00A8DD
       Part No SW: 5QA 919 298 E    HW: 5QA 919 298 A
       Component: PLA 3.0 12KH07 0452
       Serial number: 000308417617296
       Coding: 2271167811
       ASAM Dataset: EV_EPHVA2CAU3700000 009038
       VCID: 5285A45905A212D4FE-8006
       Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
       Coding: 7D0000C159FFC728949C810580400600000000000000000000
    1236 - Databus
                        Reset counter: 43
                        Mileage: 96 km
                        Date: 2018.04.13
                        Time: 10:27:35
                        Control Module temperature: 28 °C
                        Voltage terminal 15: 14.7 V
                        Velocity_vehicle_reference: 7.11 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.30 m/s²
       Serial number: 003GCR09PSC3
       Coding: 8CCCFC00002000005000001AC20800000065
       VCID: 47B3850DFEE0A77C99-8012
       Occupant Detection:
       Serial number: IBH000000000008H3VK$
       Coding: 303139
       Subsystem 2 - Part No SW: -----------    HW: 480 001 002 18
       Serial number: 35700000000C3755CB2T
       Subsystem 3 - Part No SW: -----------    HW: 480 001 002 18
       Serial number: 35800000000B6555CB2U
       Subsystem 4 - Part No SW: -----------    HW: 480 400 902 18
       Serial number: 35100019D291EE450566
       Subsystem 5 - Part No SW: -----------    HW: 480 400 902 18
       Serial number: 3520001BF28DB2A2048B
       Subsystem 6 - Part No SW: -----------    HW: 480 400 802 18
       Serial number: 35500019D2909F02D2EG
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 802 18
       Component: FrontSensor_P  000 6149
       Serial number: 35600019D2909F035565
       Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 04021808490139
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 09374335A874110C4F-805C
       Part No SW: 5G1 920 795 A    HW: 5G1 920 795 A
       Component: KOMBI         408 3195
       Coding: 0BB4701A6F8888090288690B5701002080000000
       VCID: 2E7DD0A9715A1634BA-807A
       Part No SW: 3Q0 907 530 M    HW: 3Q0 907 530 D
       Component: GW MQB EV     618 6322
       Serial number: 04011810800014
       Coding: 0201001704F81000FB001212081D00000001070100070000000300000000
       ROD: EV_GatewNF_VW27.rod
       VCID: 3957F3F5B814C18C1F-806C
       Subsystem 1 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
       Serial number: 29170002564560127451
       Coding: 34FFFF
       Subsystem 2 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
       Serial number: 8162526704
    Address 23: Brake Booster (J539)       Labels:* None
       Part No SW: 5QE 909 059 G    HW: 5QE 909 059 B
       Component: EBKV          H14 0211
       Serial number:   085460013516
       Coding: 06720100321A00010002000500
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
       ROD: EV_BrakeBoostBoschMQBOMG_004.rod
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0155
       Serial number: 05802861230118154454
       Revision: 00000000    Serial number: 18000039633005
       Coding: 7900000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3449C2C19F763CE4CC-8060
       Component: HRE_Master    H12 0080
       Serial number: 0468916317
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D5FE7E5AC3CFDAC33-8068
       Component: HRE_Slave  H12 0080
       Serial number: 0469208477
       Coding: 020111
       Serial number: 201217ELK13082
       Coding: 003E13208000040000000000
       VCID: 43AB911DCAD88B5C45-8016
       Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000019154673
       Coding: 111000
       Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  130 1081
       Coding: D3020000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 73CB01DDDAF87BDC15-8026
    Address 4B: Multifunc. Module
    Interface not compatible.
       Part No SW: 5QE 907 080 K    HW: 5QE 907 080 K
       Component: LE Gen 3.3H16 2052
       Revision: 00H16000
       Coding: 40020000000000000000
       ASAM Dataset: EV_DMCM10030115QE907080K 001008
       ROD: EV_DMCM10030115QE907080K.rod
       VCID: 4EBDB029119A7634DA-801A
       Serial number: 120118EAC12342
       VCID: 42A59419D5C282544E-8016
       Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000019199712
       Coding: 091000
       Part No SW: 5NA 035 047 B    HW: 5NA 035 047
       Component: MU-H-NS-US    H54 1126
       Serial number: A852A0JB001486
       Coding: 02738002FF00000051220001001828009F0105F401200405DE
       Subsystem 1 - Part No SW: 5G6 919 606 B    HW: 5G6 919 606 B
       Component: ABT_High-2  H50 9130
       Serial number: VWZ6ZJV0106186
       Subsystem 2 - Part No SW: V03 959 803 SR    HW: -----------
       Component: NAR 2017/2018  --- 0060
       Component: Gracenote2  --- 3011
    Address 8C: Hybrid Battery
       Component: MQB_B_MFK     H07 0272
       Serial number: 20011812K21732
       Coding: 000307000000020100222354C150490084000E200120
       ROD: EV_MFKBoschMQBB_VW27.rod
    Address BD: Hi Volt. Batt. Charg. (J966)       Labels:* None
       Part No SW: 5QE 915 022 AP    HW: 12E 915 022 H
       Component: LMSG          H20 1096
       Serial number: 01148074970422
       Coding: 4A4914040400
       ASAM Dataset: EV_HVChargManagVWMQB 003004
       ROD: EV_HVChargManagVWMQB.rod
       VCID: 0F036D2DD6103F3C91-805A
    Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
       Part No SW: 5QE 035 335 M    HW: 5QE 035 335 B
       Component: E_SOUND_SG    H10 0223
       Serial number: EN180350400000
       Coding: 04
       ASAM Dataset: EV_ENoiseS1NNVW3707 007015
       ROD: EV_ENoiseS1NNVW3707_007.rod
       VCID: 4BBBB93DE288431CBD-801E
    Address C5: Therm. mgt. (J1024)       Labels:* None
       Part No SW: 5GE 907 458 C    HW: 5GE 907 458
       Component: TME-Min       H06 0203
       Serial number: 0064769
       Coding: 02
       ASAM Dataset: EV_ThermContrVISAU49X 001021
       ROD: EV_ThermContrVISAU49X_VW37.rod
       VCID: 45AF8F05C4ECB56C6B-8010
       Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
       Component: G395 pT-Sens1  H11 0010
       Subsystem 2 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
       Component: J848 HV-PTC  H09 0208
       Serial number: LR180243003810000133
       Subsystem 3 - Part No SW: 5QE 816 803 A    HW: 5QE 816 803 A
       Component: J842 eKK  H03 0009
       Refrigerant Pressure And Temperature Sender 2:
       Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
       Component: G826 pT-Sens2  H11 0010
       Refrigerant Pressure And Temperature Sender 3:
       Subsystem 5 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
       Component: G827 pT-Sens3  H11 0010
       Refrigerant Pressure And Temperature Sender 4:
       Subsystem 6 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
       Component: G828 pT-Sens4  H11 0010
       Refrigerant Pressure And Temperature Sender 5:
       Subsystem 7 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
       Component: G829 pT-Sens5  H11 0010
       Refrigerant Expansion Valve 1:
       Subsystem 8 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
       Component: N636 EV1_KaMi  H12 0102
       Serial number: 00000000000120293565
       Refrigerant Expansion Valve 2:
       Subsystem 9 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
       Component: N637 EV2_KaMi  H12 0102
       Serial number: 00000000000120293568
       Refrigerant Expansion Valve 3:
       Subsystem 10 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
       Component: N638 EV3_KaMi  H12 0102
       Serial number: 00000000000120293511
       Refrigerant Shut Off Valve 1:
       Subsystem 11 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
       Component: V424 AV1_KaMi  H12 0102
       Serial number: 00000000000140292785
       Refrigerant Shut Off Valve 4:
       Subsystem 12 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
       Component: N642 AV4_KaMi  H12 0102
       Serial number: 00000000000140292787
       Refrigerant Shut Off Valve 5:
       Subsystem 13 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
       Component: N643 AV5_KaMi  H12 0102
       Serial number: 00000000000140290909
    37024 - A/C Compressor
              U103B 00 [044] - No Communication
                        Mileage: 108 km
                        Date: 2018.04.13
                        Time: 22:33:11
    Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
       Part No SW: 5QE 915 681 B    HW: 5QE 915 681 B
       Component: OBC Delta-ES  H59 1560
       ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
       ROD: EV_OBCTwoPhaseDT2VW3707.rod
    End-------------------------(Elapsed Time: 05:41)--------------------------
    Apr 2018
    Having gotten a bit of time to assemble screen shots today, I’ll follow up with more detail.
    87-15-02TT is straight forward:
    1. 08- Air Conditioning
    2. Guided Functions
    3. Calibration
    4. Adaptation Channel-5 Switching-on behavior
    5. Select option “2 - activated” (Other options are “1 - not activated”, and “3 -corresponds coding”)
    While the TT only cites 2015-2016 models, 2017 owners have reported elsewhere that dealers have applied the fix to 2017 instances as well. Though it isn’t completely certain whether or not they are using 87-15-02TT as written on a 2017, I haven’t found anything newer on on the topic in erwin.
    The VCDS process described in http://www.myvwegolf.com/forum/viewt...hp?f=12&t=1128 suggests an error will pop up on the first attempt of changing to “activated”, but the controller will accept the request on the second.
    My experience on a 2017 starts here:
    On pressing “Do It!” I get:
    Press “Yes”, I get a “Request out of range”:
    Going through the process a second time is the same, except instead of “Request out of range” I get:
    Followed by a “Request Sequence Error”
    I'm fairly low on the VCDS learning curve, so have no real idea what is going on there.
    For reference, the “out-of-box” adaptation mapping for my 2017 SEL + DAP:
    ;SW:5GE-907-044-AN   HW:5GE-907-044-AN ---  Auto HVAC
    ;Component:Climatronic   H04 1702, Coding:0002220020011001050500021211102B
    ;EV_ACClimaBHBVW37X,006145,EV_ACClimaBHBVW37X_006_VW37.rod
    ;Friday,27,April,2018,19:29:14:41186
    ;VCDS Version: Release 18.2.0 (x64)  Data version: 20180212 DS287.0
    ;VCID: 885CEF8533935904D0-80DC
    IDE00001-Production mode,Deactivating ,3
    IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
    IDE01478-Ignore compressor switch-off by Engine Control Module,Do not ignore ,1
    IDE01479-Gear ratio of engine - A/C compressor,0.00 ,1
    IDE01483-Blower voltage for voice operation,not activated ,1
    IDE01488-Retrofitting of parking heater without CAN,not installed ,1
    IDE01493-Air quality sensor sensitivity,Maximum ,1
    IDE01503-Runtime for compressor run-in basic setting,120 s,1
    IDE01536-Post-heating of parking heater,10 min,1
    IDE02155-Reset all counters,not activated ,1
    IDE03176-Duration of compressor run in,0 s,1
    IDE03251-Stop release for start-stop function,According to function requirements ,1
    IDE04159-Deactivation of start-stop function,not active ,1
    IDE06097-Target temperature of A/C - heater function via remote control,22.0 ºC,1
    IDE06544-Speed switch-off threshold for compressor run-in (engine speed),1500 /min,1
    IDE06545-Blower voltage for production routines,6.0 V,1
    IDE06546-Interior target temperature for production routines,22 ºC,1
    IDE06547-Air distribution for production routines,No effect ,1
    IDE06593-Recirculation air for production routines,No effect ,1
    IDE07108-Climate modes,activated ,1
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
    IDE07301-Remote start function: activation of seat heating,Seat heater front ,1
    IDE07302-Remote start function: interior climate control status,Remote start function with fixed rated temperature active ,1
    IDE07303-Rem.start funct.:activ.temper. of windshield defrost.heat.,4 ºC,1
    IDE07304-Remote start function: activation of seat ventilation,activated ,1
    IDE07305-Rem. start funct.: activat.temper. of seat heating,15 ºC,1
    IDE07306-Rem. start funct.: activat.temper. of seat ventilation,20 ºC,1
    IDE07307-Remote start function: activation stage of seat heating,2 ,1
    IDE07308-Remote start function: activation stage of seat ventilation,2 ,1
    IDE07398-Blower logic for manual adjustment,Matching coding ,1
    IDE07585-Hand heater function during cold start,active ,1
    IDE07865-Automatic Activation of front windshield heater at MAX-Defrost,active ,1
    IDE07948-Retention of frt.pass. seat heater level,not active ,1
    IDE12229-Filtering of interior air: store,Service life-dependent store ,1
    IDE80006-Analysis 6,not activated ,1
    IDE80007-Analysis 7,00000000 00000000  ,2
    IDE80008-Analysis 8,not active ,1
    MAS05739-CO2 compressor on-time reduction,Matching coding ,1
    MAS06564-Window condensation exterior reduction at high humidity,Matching coding ,1
    MAS07251-Cut-in behavior,not activated ,1
    MAS14860-Remote start function: windshield defogger takeover,activated ,1
    MAS14861-Remote start function: windshield defogger,activated ,1
    ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
    ENG122844-ENG99557-dimming_characteristic_1-X2,6 ,12
    ENG122844-ENG102140-dimming_characteristic_1-X3,40 ,12
    ENG122844-ENG102936-dimming_characteristic_1-X4,60 ,12
    ENG122844-ENG103548-dimming_characteristic_1-X5,80 ,12
    ENG122844-ENG113992-dimming_characteristic_1-X6,100 ,12
    ENG122844-ENG99777-dimming_characteristic_1-Y1,0 %,12
    ENG122844-ENG100480-dimming_characteristic_1-Y2,6 %,12
    ENG122844-ENG100773-dimming_characteristic_1-Y3,40 %,12
    ENG122844-ENG100631-dimming_characteristic_1-Y4,60 %,12
    ENG122844-ENG102174-dimming_characteristic_1-Y5,80 %,12
    ENG122844-ENG113993-dimming_characteristic_1-Y6,100 %,12
    ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
    ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
    ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
    ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
    ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
    ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
    ENG122845-ENG99777-dimming_characteristic_2-Y1,2 %,12
    ENG122845-ENG100480-dimming_characteristic_2-Y2,2 %,12
    ENG122845-ENG100773-dimming_characteristic_2-Y3,10 %,12
    ENG122845-ENG100631-dimming_characteristic_2-Y4,21 %,12
    ENG122845-ENG102174-dimming_characteristic_2-Y5,85 %,12
    ENG122845-ENG113993-dimming_characteristic_2-Y6,100 %,12
    ENG122846-ENG101574-dimming_characteristic_3-X1,0 ,12
    ENG122846-ENG99557-dimming_characteristic_3-X2,10 ,12
    ENG122846-ENG102140-dimming_characteristic_3-X3,50 ,12
    ENG122846-ENG102936-dimming_characteristic_3-X4,100 ,12
    ENG122846-ENG103548-dimming_characteristic_3-X5,220 ,12
    ENG122846-ENG113992-dimming_characteristic_3-X6,253 ,12
    ENG122846-ENG99777-dimming_characteristic_3-Y1,3 %,12
    ENG122846-ENG100480-dimming_characteristic_3-Y2,3 %,12
    ENG122846-ENG100773-dimming_characteristic_3-Y3,6 %,12
    ENG122846-ENG100631-dimming_characteristic_3-Y4,12 %,12
    ENG122846-ENG102174-dimming_characteristic_3-Y5,100 %,12
    ENG122846-ENG113993-dimming_characteristic_3-Y6,100 %,12
    ENG122847-ENG101574-dimming_characteristic_4-X1,0 ,12
    ENG122847-ENG99557-dimming_characteristic_4-X2,10 ,12
    ENG122847-ENG102140-dimming_characteristic_4-X3,50 ,12
    ENG122847-ENG102936-dimming_characteristic_4-X4,100 ,12
    ENG122847-ENG103548-dimming_characteristic_4-X5,220 ,12
    ENG122847-ENG113992-dimming_characteristic_4-X6,253 ,12
    ENG122847-ENG99777-dimming_characteristic_4-Y1,2 %,12
    ENG122847-ENG100480-dimming_characteristic_4-Y2,2 %,12
    ENG122847-ENG100773-dimming_characteristic_4-Y3,5 %,12
    ENG122847-ENG100631-dimming_characteristic_4-Y4,10 %,12
    ENG122847-ENG102174-dimming_characteristic_4-Y5,85 %,12
    ENG122847-ENG113993-dimming_characteristic_4-Y6,100 %,12
    ENG122848-ENG101574-dimming_characteristic_5-X1,0 ,12
    ENG122848-ENG99557-dimming_characteristic_5-X2,10 ,12
    ENG122848-ENG102140-dimming_characteristic_5-X3,50 ,12
    ENG122848-ENG102936-dimming_characteristic_5-X4,100 ,12
    ENG122848-ENG103548-dimming_characteristic_5-X5,220 ,12
    ENG122848-ENG113992-dimming_characteristic_5-X6,253 ,12
    ENG122848-ENG99777-dimming_characteristic_5-Y1,2 %,12
    ENG122848-ENG100480-dimming_characteristic_5-Y2,2 %,12
    ENG122848-ENG100773-dimming_characteristic_5-Y3,5 %,12
    ENG122848-ENG100631-dimming_characteristic_5-Y4,10 %,12
    ENG122848-ENG102174-dimming_characteristic_5-Y5,85 %,12
    ENG122848-ENG113993-dimming_characteristic_5-Y6,100 %,12
    ENG130577-Knockout_timer_activation,not activated ,1
    Elapsed Time: 00:13
    Terminology footnote: On a German language forum, I found MAS07251 described as “Einschaltverhalten”, which Google Translate says is “Switch-on behavior”, which is also the terminology 87-15-02TT, uses. Curious about the origin of “cut-in behavior” in VCDS.
    Quote Originally Posted by seacycle View Post
    That's VAG's own translation. They will set people to do translation who are not native English speakers and who may be lacking appropriate context for the strings being translated as well. When we see stuff like that, the question is: Should we improve it, or should we leave it the same as it would be in the factory tool?
    Try setting up new WSC, Importer, and Equipment number values on the Options screen in VCDS:
    The importer number for Canada is 999. These don't have any functional effect on anything, but the module may not like the fact that we're trying to put back the same values it already has (which might be factory defaults). After you change the values on that screen, click [Save], then exit and restart VCDS before you try the Adaptation again.
    Apr 2018
    Has this worked on your car?
  6. #6
    Apr 2018
    FYI, I tried yesterday with exact above instructions and was unable to make it work. Can we try anything else? Many thanks!
  7. #7
    May 2018
    Norway
    I have the exact same problem on my MY2018 e-golf. As well as everyone else with VCDS and the facelift model, according to forums.
    I have tried with two different WSC, Importer, and Equipment number combinations that I know are both valid: one used for preparation of new cars before delivery (software update etc.), and one used by an authorized local dealer.
    Dealers are now able to change this with their own tools on the very same facelift cars, so clearly there must be a bug here, either in VCDS or in the module itself.
    Edit; Using latest VCDS software version 18.2.1 and HEX-NET interface with latest firmware installed.
  8. #8
    Quote Originally Posted by Erlingni View Post
    Another possibility is that nobody presently understands what the dealers' tool is actually doing when it changes this.
  9. #9
    Oct 2014
    London ON, Canada
    Same issue here... waiting patiently for Ross tech to respond
  10. #10
    If we knew what the "magic trick" was, we would happily tell you guys. Unfortunately, the e-Golf is not sold in Pennsylvania, nor is it likely to have a customer bring one to us to play with because they don't have sufficient range to make it here.
  11. Likes NZDubNurd liked this post
