Enricoroberto
New Member
Hello all,
I have a 2017 VW Bettle and would like to disable the turn signal sound because I do drive in the city a lot. VW's do not have relays, the sound is generated from a speaker along with other sounds. The only area I found that is close when I did some VCDS research is in the central electronics section but did not find anything regarding muting the sound. First question, is it possible, second which model Ross-Tech can deactivate the sound if this can be done? Thanks for your input, Enrico
