Tuesday,17,April,2018,10:52:30:13440
VCDS Version: 18.2.0.3 (x64) HEX-NET CB: 0.4411.4
Dealer/Shop Name: ivagp
VIN: WVWJK73C19P021764 License Plate: JOE
Mileage: 139230km-86513mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 53 56 62 65
72 77
VIN: WVWJK73C19P021764 Mileage: 139230km-86513miles
37-Navigation -- Status: Malfunction 1010
77-Telephone -- Status: Not registered 0011
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 906 026 AG HW: 06J 906 026 AF
Component: MED17.5 TFSI 2,0 3319
Revision: AAH03--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 00028 028 00001
VCID: EFAEBA97FEA90C3C71-80BA
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Date: 2047.15.31
Time: 31:63:63
Temperature: 30.0°C
Temperature: 26.0°C
Absolute Pres.: 980.0 mbar
Voltage: 9.144 V
001378 - System Voltage
P0562 - 000 - Too Low - Intermittent
Temperature: 15.0°C
Temperature: 15.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 9.017 V
001393 - Brake Switch (F)
P0571 - 000 - Implausible Signal
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Mileage: 139233 km
Date: 2018.04.16
Time: 17:27:29
RPM: 760 /min
Load: 20.8 %
Temperature: 96.0°C
Temperature: 60.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.954 V
Part No SW: 09G 927 750 GP HW: 09G 927 750 GP
Component: AQ 250 6F 1391
Revision: 00H76000 Serial number:
Coding: 0000840
VCID: 8542F83FCC15266CAB-80D0
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
Component: J104 C4 440 V2 0011
Revision: --025--- Serial number: 00000785898014
Coding: 0000376
VCID: AB166E870A31301C1D-80FE
00532 - Supply Voltage B+
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.10
Time: 10:53:11
Speed: 3.0 km/h
Hex Value: 0x0004
Voltage: 8.50 V
Bin. Bits: 00011110
Count: 112
Hex Value: 0x0000
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: F8BC81CB8BE74B84A0-80AC
Revision: 00H54000 Serial number: 00000005874614
Coding: 15848F0340041A00470000000F00000000285D435C000100000000000000
VCID: B32676E7D20168DC55-80E6
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 210508 003 0205
Coding: 00046997
Shop #: WSC 00028
01259 - Fuel Pump Relay (J17)
Fault Status: 00101001
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.12
Time: 07:28:00
Voltage: 13.80 V
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.10
Time: 11:02:00
Voltage: 8.40 V
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__01F VW10 HI 1815
Revision: 19013000 Serial number: 0039BPCGDJXC
Coding: 0012614
VCID: FAB89BC3B5EB5994D6-80AE
Subsystem 1 - Part No: 3C0 959 339 D
Component: BF-Gewichtsens. 001 0002
Subsystem 2 - Serial number: 00000000001BQM
Subsystem 3 - Serial number: 0024.05.080000100000630046ÿ†63
Subsystem 4 - Serial number: 630046ÿ†6333FTS650091948 ÿ†63
Subsystem 5 - Serial number: 91948 ÿ†6343FTS648931928 ÿ†63
Subsystem 6 - Serial number: 31928 ÿ†6353ETS62T03UVNH ÿ†63
Subsystem 7 - Serial number: 3UVNH ÿ†6363ETS60103UVNH ÿ†63
Subsystem 8 - Serial number: 3UVNH ÿ†6374CTS6TCBMSVNH ÿ†63
Subsystem 9 - Serial number: MSVNH ÿ†6384CTS61BAMSVNP ÿ
Subsystem 10 - Serial number: MSVNP ÿ
Reset counter: 47
Mileage: 128283 km
Date: 2017.11.23
Time: 00:15:52
03551 - Functional Restriction of Seat Occupied Recognition
000 - - - Intermittent - MIL ON
Fault Status: 10100000
Fault Frequency: 32
Reset counter: 47
Mileage: 128283 km
Date: 2017.11.23
Time: 00:15:52
Part No SW: 3C0 953 549 AC HW: 3C0 953 549 AC
Component: J0527 0020
Revision: 00026000 Serial number: 3C5953507AR
Coding: 0001111
VCID: ED92A09FF4A5FE2C43-80B8
Component: E0221 002 0010
Part No SW: 3C0 920 972 A HW: 3C0 920 972 A
Component: KOMBIINSTRUMENT VD1 2416
Revision: V0002000 Serial number: 00000000000000
Coding: 0007205
VCID: A40485BB67EFFF64DC-80F0
Fault Frequency: 7
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.10
Time: 11:07:46
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.11
Time: 13:49:06
00771 - Fuel Level Sensor (G)
Fault Status: 00101010
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.12
Time: 07:47:25
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 H HW: 3C0 907 951
Component: J533__Gateway H13 0142
Revision: H13 Serial number: 2600P08714064F
Coding: FD807F074002121002
VCID: A6009FB311D30D74C2-80F2
Reset counter: 20
Mileage: 120144 km
Date: 2017.07.05
Time: 09:25:41
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.10
Time: 10:45:17
01304 - Radio
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.10
Time: 10:45:17
Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 22503 444 103841
VCID: F3A6B6E7928128DC95-80A6
Component: ELV 029 0380
3C0905861J ELV 029 0380
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Fault Frequency: 16
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.11
Time: 13:28:31
Part No SW: 5N0 035 342 A HW: 5N0 035 342 A
Component: SG EXT.PLAYER H13 0062
Revision: A1001003 Serial number: 7667022012
VCID: A50298BFACD5066CCB-80F0
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.10
Time: 10:52:42
01304 - Radio
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.11
Time: 13:44:25
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.11
Time: 13:47:19
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C0 035 684 HW: 3C0 035 684
Component: RNS-MID H17 0210
Revision: AB001001 Serial number: VWZ6Z7H8218084
Coding: 040004000400000200
VCID: E08CC9ABF377A344F8-80B4
02633 - Antenna for Satellite Tuner
Fault Status: 00101011
Reset counter: 47
Mileage: 139224 km
Date: 2018.04.16
Time: 12:38:05
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.10
Time: 10:53:58
Fault Frequency: 10
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.10
Time: 10:52:29
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1517
Revision: 72009005 Serial number: 00000023688714
Coding: 0001205
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.11
Time: 13:48:59
Fault Status: 01100101
Reset counter: 9
Mileage: 139231 km
Date: 2018.04.11
Time: 13:37:09
Part No SW: 5N1 909 144 G HW: 5N1 909 148 F
Component: J500__APA-BS KL.082 0401
Revision: 1AH02234 Serial number: 00081340050002
Coding: 0000258
VCID: B6204FF3C1737DF472-80E2
01288 - Terminal 30; Steering Assist
Fault Priority: 9
Reset counter: 48
(no units): 2.0
Voltage: 11.00 V
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.10
Time: 10:53:33
Voltage: 0.10 V
Voltage: 8.40 V
Voltage: 0.80 V
Not Occup.
Not Occup.
00566 - Steering Assistance Operation
Fault Status: 11101000
Reset counter: 8
Mileage: 139231 km
Date: 2018.04.16
Time: 15:57:29
Hex Value: 0x5301
Hex Value: 0x4301
Hex Value: 0x1B01
Hex Value: 0x5601
Hex Value: 0x4601
Component: KSG PQ46 RDK 051 0221
Coding: 13910F8001862E521004141FF08A0F0E085801
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.11
Time: 13:48:19
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1517
Revision: 72009005 Serial number: 00000038388717
Coding: 0001204
VCID: F0ACB9EBE39713C468-80A4
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.11
Time: 13:49:00
Fault Status: 00100101
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.11
Time: 13:37:09
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000077350
Coding: 0000057
VCID: A81C918B1BC71B04F0-80FC
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.10
Time: 10:53:47
Voltage: 8.00 V
Count: 50
Speed: 6.0 km/h
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0101
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Reset counter: 47
Mileage: 139224 km
Date: 2018.04.16
Time: 12:38:05
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.10
Time: 10:53:58
Fault Frequency: 10
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.10
Time: 10:52:29
Part No SW: 1K0 959 703 AD HW: 1K0 959 795 P
Component: J388 TUER-SG HL 0308
Revision: 42004101 Serial number: 00000000518302
Coding: 0001168
VCID: F2A8B3E3ED9B21D49E-80A6
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.11
Time: 13:49:04
Component: RDK 0450
Coding: 0100101
00667 - Ambient Temperature Signal
Reset counter: 47
00625 - Vehicle Speed Signal
Fault Frequency: 149
Reset counter: 47
Mileage: 139231 km
Part No SW: 1K0 959 704 AD HW: 1K0 959 794 P
Component: J389 TUER-SG HR 0308
Revision: 42004101 Serial number: 00000000478550
Coding: 0001168
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.11
Time: 13:49:14
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 051 730 D HW: 1K8 051 730 D
Component: Telefon H03 6900
Revision: 00003000 Serial number: 00000A09617478
Coding: 402120
Shop #: WSC 22503 444 103858
VCID: A81C918BDBC71B04F0-80FC
Fault Frequency: 10
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.10
Time: 10:38:59
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.10
Time: 10:54:08
01304 - Radio
Reset counter: 47
Mileage: 139231 km
Date: 2018.04.11
Time: 13:44:25
End----------(Elapsed Time: 02:20, VBatt start/end: 13.4V/13.4V)-----------
