Page 7 of 7 FirstFirst ... 567
Results 61 to 69 of 69
Thread: Golf 7 Multifunction retrofit
  1. #61
    Jan 2017
    Canada
    Hmmm....so it *should* work.
    Thanks for the reply, DV52!
    My problem, I guess, then, is that I can't get 16-Steering Wheel-CODING to accept my coding change. I'm sure I tried every option in the drop-down (in your example, changing 0100 to 6100; mine stock is 0410 - I tried changing it to 6410 numerous times
    but every time I got "Coding not accepted" or "rejected" or wording to that effect.
    Is there a "Security Access" that I need to access / re-code that module?
  2. #62
    Jun 2014
    Poland
    post autoscan at first
  3. Likes Uwe, DV52 liked this post
  4. #63
    Jan 2017
    Canada
    Auto-scan:
    2016.12.28. AUTO-SCAN
    VIN: 3VWCA7AUXFMxxxxxx
    Scan: 01 02 03 05 08 09 13 15 16 17 19 20 2B 42 44 47 52 55 5F
    Address 01: Engine  (CRUA J623)	Labels: 04-01.lbl
    	Part No SW: 04L 906 021 D	HW: 04L 907 309
    	Component: R4 2,0L EDC   H23 8278
    	Revision: 85H23---
    	Coding: 011D0012832410081000
    	Shop #: WSC 00066 790 00221
    	ASAM Dataset: EV_ECM20TDI01104L906021D 001013
    	ROD: N/A
    	VCID: 260F659BCD38852CB87FA4DB12-8073
    	No ASAM data for: "EV_ECM20TDI01104L906021D"
    No fault codes found.
    Address 02: Auto Trans  (J743)	Labels: 0D-02.lbl
    	Part No SW: 0D9 300 041 N	HW: 02E 927 770 AQ
    	Component: DQ250-6F MQB  H53 4506
    	Revision: 03253104
    	ROD: N/A
    	VCID: 23097C8FBE0A7004DF6185B729-8076
    	No ASAM data for: "EV_TCMDQ250021"
    Address 03: ABS Brakes  (J104)	Labels: None
    	Part No SW: 3Q0 907 379 P	HW: 3Q0 907 379 C
    	Component: ESC           H32 0385
    	Revision: 00000000
    	Coding: 04FA6AA12420096C0079020981CC2520562490004081A4B210630050C002
    	Shop #: WSC 01383 790 50316
    	ROD: N/A
    	VCID: 47D1C81F6A727C2463C911477D-8012
    	No ASAM data for: "EV_Brake1UDSContiMK100ESP"
    016401 - ROD - Unknown faultcode
    Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
    	Part No SW: 5Q0 959 435 A	HW: 5Q0 959 435
    	Revision: 00021000
    	Coding: 030C0C
    	ROD: N/A
    	VCID: 3A37A1EB298011CCEC4780AB16-806F
    	No ASAM data for: "EV_KessyHellaMQBAB"
    Address 08: Auto HVAC  (J255)	Labels: 5G0-907-044.clb
    	Part No SW: 5GM 907 044 A	HW: 5GM 907 044 A
    	Revision: 00001K01
    	Coding: 02020124200100010005000000101400
    	ROD: N/A
    	VCID: 42C7D90B4150590CB497D80BBE-8017
    	No ASAM data for: "EV_ACClimaBHBVW37X"
    	Subsystem 1 -
    	Subsystem 2 -
    	Subsystem 3 -
    Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.lbl
    	Part No SW: 5Q0 937 087 R	HW: 5Q0 937 087 R
    	Component: BCM PQ37BOSCH 028 0145
    	Revision: --------
    	Coding: 00511B464041A2E949E44000091407001800000000000000000000000000
    	Shop #: WSC 00066 790 07031
    	ROD: N/A
    	VCID: 4AD7F12B7960814C7CE7306B26-801F
    	No ASAM data for: "EV_BodyContrModul1UDSBosc"
    	Subsystem 1 - 	Part No SW: 5GM-955-119	Labels: 5Qx-955-119-V1.clb
    	Component: MŻ
    	Subsystem 2 -
    	Subsystem 3 - 	Component:
    	Subsystem 4 - 	Component:
    	Subsystem 5 -
    534549 - ROD - Unknown faultcode
    329480 - ROD - Unknown faultcode
    Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
    	Part No SW: 5Q0 907 572 D	HW: 5Q0 907 572 D
    	Component: ACC Bosch MQB H05 0304
    	Coding: 01001000280438
    	Shop #: WSC 00066 790 00194
    	ROD: N/A
    	VCID: 3833BBE3178C03DC1A336AB338-806D
    	No ASAM data for: "EV_ACCMRRBoschVW372"
    Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
    	Part No SW: 5Q0 959 655 T	HW: 5Q0 959 655 T
    	ROD: N/A
    	VCID: 51E5E6479436B2943D2D7FDFC3-8004
    	No ASAM data for: "EV_AirbaVW20SMEVW37X"
    	Subsystem 1 - 	Part No SW: 4M0-959-339-B
    	Component: 016
    	Subsystem 2 - 	Component: ---
    	Subsystem 3 - 	Component: ---
    	Subsystem 4 - 	Component: ---
    	Subsystem 5 - 	Component: ---
    	Subsystem 6 - 	Component: ---
    Address 16: Steering wheel  (J524)	Labels: 5Q-16.lbl
    	Part No SW: 5Q0 953 521 AT	HW: 5Q0 953 569 A
    	Revision: FF032032
    	Coding: 0410
    	ROD: N/A
    	VCID: 844B9F139BC4173C462BAE2354-80D1
    	No ASAM data for: "EV_SMLSVALEOMQB"
    Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
    	Part No SW: 5G1 920 741	HW: 5G1 920 741
    	Component: KOMBI         243 4270
    	Coding: 0BA4121929808809028868011000000000000000
    	ROD: N/A
    	VCID: E48BBF937B84B73CE6EBCEA374-80B1
    	No ASAM data for: "EV_DashBoardVDDMQBAB"
    Address 19: CAN Gateway  (J533)	Labels: 5Q0-907-530-V1.clb
    	Part No SW: 5Q0 907 530 AC	HW: 5Q0 907 530 M
    	Revision: --------
    	Coding: 0901000800087300EF00020A1C0F00000001050000000000000000000000
    	Shop #: WSC 00066 790 07026
    	ROD: N/A
    	VCID: 72A749CB3170A98CE477E84B2E-8027
    	No ASAM data for: "EV_GatewConti"
    	Subsystem 1 -
    	Subsystem 2 - 	Component: (˙˙
    	Subsystem 3 -
    131632 - ROD - Unknown faultcode
    Address 20: High Beam Assist.  (J844)	Labels: 8X0-857-511.clb
    	Part No SW: 5G0 857 511 D	HW: 5G0 857 511
    	Component: FLA           H04 0002
    	Revision: AA001001
    	Coding: 02018864727264565625393E01
    	ROD: N/A
    	VCID: 2B1994AFD6DAB84467B1DD17D1-807E
    	No ASAM data for: "EV_HighBeamAssisAU37X"
    Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
    	Part No SW: 5Q0 905 861 A	HW: 5Q0 905 861 A
    	Revision: 00000000
    	Coding: 5D00000000000000
    	ROD: N/A
    	VCID: 342B8FD30BE4E7BC360B3E6344-8061
    	No ASAM data for: "EV_ELVMarquMQB"
    Address 42: Door Elect, Driver  (J386)	Labels: 5QX-959-X93-42.clb
    	Part No SW: 5Q0 959 593 B	HW: 5Q0 959 593 B
    	Coding: 003A13200000040000000000
    	ROD: N/A
    	VCID: 40C3D3034F5C4B1CA283C213A0-8015
    	No ASAM data for: "EV_DCUDriveSideEWMAXKLO"
    Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
    	Part No SW: 5Q0 909 144 R	HW: 5Q0 909 144 R
    	Component: EPS_MQB_ZFLS  126 1061
    	Coding: 0102
    	ROD: N/A
    	VCID: 43C9DC0F5E4A5004BFA1E53789-8016
    	No ASAM data for: "EV_SteerAssisMQB"
    Address 47: Sound System  (J525)	Labels: None
    	Part No SW: 5G0 035 456	HW: 5G0 035 456
    	Component: MIB_lite_amp  H40 0060
    	Coding: 22000000AAAAAA0000
    	ASAM Dataset: EV_AMPMst11CALPI 001006
    	ROD: N/A
    	VCID: E389BC8F7E8AB0041FE1C5B769-80B6
    	No ASAM data for: "EV_AMPMst11CALPI"
    Address 52: Door Elect, Pass.  (J387)	Labels: 5QX-959-X92-52.clb
    	Part No SW: 5Q0 959 592 B	HW: 5Q0 959 592 B
    	ROD: N/A
    	VCID: 3FC1D0FF32A234E4DB79B9E7D5-806A
    	No ASAM data for: "EV_DCUPasseSideEWMAXKLO"
    Address 55: Xenon Range  (J745)	Labels: 7P6-907-357.clb
    	Part No SW: 7P6 907 357 D	HW: 7P6 907 357 A
    	Revision: --------
    	Coding: 060A00010B000400
    	ROD: N/A
    	No ASAM data for: "EV_HeadlRegulVWAFSMQB"
    	Subsystem 1 - 	Part No SW: 5N0-941-329	Labels: 3D0-941-329.clb
    	Component: .
    Address 5F: Information Electr.  (J794)	Labels: 5G-5f.lbl
    	Part No SW: 5G0 035 876	HW: 5G0 035 876
    	Component: MU-S-NS-US    014 0645
    	Coding: 027302020000000021220002001800001F02023401000101C6
    	ROD: N/A
    	VCID: E995AEA79CA6EA54D51D07FF3B-80BC
    	No ASAM data for: "EV_MUStd4CPASE"
    	Subsystem 1 - 	Part No SW: 5G0-919-605-K
    	Component: ABT_Std_Nav
    	Subsystem 2 -
    000020 - ROD - Unknown faultcode
    End-------------------------(Elapsed Time: 03:07)--------------------------
  5. #64
    Quote Originally Posted by Nuje View Post
    hmmm.......... No, I didn't need a SA to make the changes on my module. I don't have access to ETKA, so I don't know if your "AT" version firmware supports ACC (my firmware is E version). If you can change another Bit in Byte 0 in your module (try Bit 2 - rear wiper installed) and you can't change Bit 4-6, perhaps this might be an explanation - just guessing?
  6. #65
    Jun 2014
    Poland
    Seems is supporting ELECTRONIC CCS via MFSW only
    But better is to use google to find this same SWCM and compare coding
    ETKA not always right
  7. Likes DV52 liked this post
  8. #66
    Quote Originally Posted by Spacewalker View Post
    Spacewaker: Thanks - that's odd then! Found lots of 5Q0 953 521 AT examples on the net, but they ALL had code-strings of 0410, or 0400
  9. #67
    Jan 2017
    Canada
    The "AT" firmware (I can see the reference to it in the auto-scan): Is that the button hardware itself? Or is that a module located somewhere in the bowels under the dash (or elsewhere)?
    (Just wondering what my "upgrade" options might be should it come to that...)
  10. #68
    Nuje: It's the thing that I have labelled "Steering Wheel module" in the picture of my test bench below (which also contains the coil)
    In its "basic form", it breaks down to just the thing in the picture below
  11. Likes Uwe liked this post
  12. #69
    Jan 2017
    Canada
    That, my friend, is an impressive setup!
    (Thanks for clarifying.)
    I'd hesitate to spend on a different module without knowing if the ECU/BCM will accept it...and then get caught in a parts chase.
