- Joined
- Oct 2, 2014
- Messages
- 30
- Reaction score
- 11
- Location
- Serbia, Novi Sad
- VCDS Serial number
- C?ID=206733
Hello Everyone,
I planned to retrofit steering wheel on my Golf MK7, which is maybe impossible. I bought MFSW, as well as different airbag harness with MF support, but it doesn't work.
No buttons light, nothing...
At the first, I thought I must code something in VCDS, but in Steering Wheel - 16 I can't find anything? (see attached). Basically there is nothing in VCDS about MFSW. I found just a few things under Infotainment, which didn't help.
Also, I read over internet about can gateway and the possibility of replacing my current low gateway with the high one which should support MF (not sure is that true). But it's a bit weird, since my current gateway supporting TV, NAV, etc...
At the end, I read somewhere I can't do that because I don't have "Maxi dot", just basic bord computer. So a lot of informations over internet, but nobody tried.
The only thing I can do, is to replace CAN gateway, except I am not sure is that going to help or not.
If anyone has similar experience, or maybe VCDS tips&tricks for my specific case, please let me know.
Thanks, Milos
VCDS Version: Beta 14.8.1 (x64)
Data version: 20140905
Thursday,02,October,2014,21:29:06:17869
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZDW139432 Mileage: 30184km-18755miles
Address 01: Engine (J623-CJZB) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 E HW: 04E 907 309 A
Component: 1.2l R4 TSI H08 5542
Revision: WAH08---
Coding: 01110012232415082000
Shop #: WSC 05026 000 1048576
ASAM Dataset: EV_ECM12TFS01104E906016E 001009
ROD: EV_ECM12TFS01104E906016H.rod
VCID: 2447E9B62F9E321A9D-8071
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 01FA6AA120232A75037B060301C52580560454C06080A4F300280028C0
ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
VCID: 7DF1FCD2ECB4A3D2B2-8028
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 Q HW: 5G0 907 044 Q
Component: Climatronic H02 0503
Revision: 00001K06
Coding: 00020004200100011005004000101000
ROD: EV_ACClimaBHBVW37X_VW37.rod
VCID: 356124F29404BB923A-8060
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 N HW: 5Q0 937 084 N
Component: BCM MQBAB M H14 0106
Serial number: 00011309401406
Coding: 00000842C24100DB4FE44000000403081000000000000000000000000000
ROD: EV_BCMBOSCH_SE37.rod
VCID: 43854A2ACAD0152284-8016
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A
Component: WWS 130329 042 0551
Serial number: 130402145957
Coding: 0E4DD5
Subsystem 2 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20332439
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Component: AirbagVW20 011 0361
Serial number: 003F5R040XNO
VCID: 408F4526DBC60E3A99-8015
Subsystem 1 - Part No SW: ----------- HW: 480 002 803 13
Serial number: 35767000000096B0AC0X
Subsystem 2 - Part No SW: ----------- HW: 480 002 803 13
Serial number: 358670000009651D1D0Y
Subsystem 3 - Part No SW: ----------- HW: 480 402 703 13
Serial number: 35165029F0FBDE4052BZ
Subsystem 4 - Part No SW: ----------- HW: 480 402 703 13
Serial number: 3526502AF0FBDE32E13
Subsystem 5 - Part No SW: ----------- HW: 480 402 603 13
Serial number: 3556502A50FBDE46417U
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AB HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 29031308491698
Coding: 9604
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 76E3E3FEC982F08AF3-8023
Part No SW: 5G0 920 850 HW: 5G0 920 850
Component: KOMBI 136 0580
Coding: 07A502002380000800080800040000
VCID: 64C7A9B66F1E721A5D-8031
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5Q0 907 530 D HW: 5Q0 907 530 D
Component: GW MQB Low 123 1109
Revision: -------- Serial number: 0000463362
Coding: 030000042B086400EF000248080E00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear.rod
VCID: 326B1FEE656AACAA1F-8067
Subsystem 2 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 6972830203
Part No SW: 5Q0 959 393 A HW: 5Q0 959 393
Component: TSG FS 012 0006
Serial number: 16031302090982
Coding: 003003208000040000001000
VCID: 3D713CD2AC3463D2F2-8068
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A
Serial number: 00000000000001069817
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 01
ROD: EV_SteerAssisMQB_SE37.rod
Part No SW: 5Q0 959 392 A HW: 5Q0 959 392
Component: TSG BFS 012 0006
Serial number: 13031304080124
Coding: 003001208000040000801000
VCID: 3C7731D6B72E6ADAC5-8069
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A
Serial number: 00000000000001076345
Coding: 090000
Part No SW: 5G0 035 867 HW: 5G0 035 867
Component: MU-E--ER 615 5561
Serial number: 30011300010328
Coding: 02730000FF0000004011000100000000000000040000010000
ASAM Dataset: EV_MUEnt4CLGE 001025
ROD: EV_MUEnt4CLGE_SK37.rod
VCID: 69D9B882883C2F726E-803C
End-------------------------(Elapsed Time: 02:50)--------------------------
Thanks, Milos
