Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
Thread: ABS/Parking Brake lights on
  1. #31
    Sep 2016
    US
    It might.......... never hurts to try a fiberglass sanding pen and an anti oxidizer after a spritz with oven cleaner containing sodium hydroxide.
    Wear gloves and eye protection!
    Hair dryer!
    Did your service history come in an electronic form the VAG dealer emailed or did you use an external source to pull that record?
    The format is so nice!
    The service history is what the dealer sent me. If I replace J393 can it be programmed via VCDS or does that require a dealer. Just in case the cleaning doesn't go well...
  2. #32
    Quote Originally Posted by 4lane View Post
    The Kessy module would need a dealer (or independent with Geko server access).
  3. #33
    Sep 2016
    US
    Update here. I had J393 replaced and recoded which resolved the 12v socket issue.
  4. Likes Uwe liked this post
  5. #34
    Sep 2016
    US
    My 2009 Audi B8 A4 Avant threw Parking Brake and ABS warning lights on the dash. In looking under the seat for a connection/wiring issue, I did find that the driver's seat belt wire was snapped off. Could that be the issue? Based on the scan I'm looking at 01321 and 00473. I've seen several folks with the same, which ended up being the ABS control module, but I was hoping to get a little further before buying/replacing parts to see what fixes it. Car runs as normal so I don't believe it's an MAF issue (another often seen symptom). I've looked at the below links, but could anyone take a look at the faults to advise me if there is any other info there to go on? Thx!
    Update: I replaced the seat belt latch/wire which removed all Parking Brake and ABS warning lighs.
  6. Likes Uwe, Fredrick Awuor liked this post
