Results 21 to 30 of 34
Thread: ABS/Parking Brake lights on
  1. #21
    Jun 2014
    Newcastle, England
    Quote Originally Posted by 4lane View Post
    They've really mastered the 'upselling' to some poor unsuspecting owner; when the 'RAD FLUSH' costs more than the G12...
  2. Likes PetrolDave, Jack@European_Parts liked this post
  3. #22
    Sep 2016
    US
    All fuses are in panel F.
    Please do yourself a favor and get the WD in Erwin by printing to PDF.
    Yeah, I checked all the fuses and I didn’t find any blown.
  4. #23
    Sep 2016
    US
    Well, the EPB is aware of the fault in the Airbag Module. The EPB wants to know that the seatbelt switches are functioning properly because its behavior is different if the occupants are belted in than if they aren't. With occupants belted in, it's willing to release the parking brake automatically under some circumstances..
    The ABS is aware of the fault in the EPB. TBH, I'm not sure why the ABS cares, and like I said, I haven't previously seen (or noticed) two levels of indirection like this, but hey... Fixing a broken wire should be a whole lot cheaper/easier than replacing an ABS or EPB control module, so that's what I'd do first.
    UPDATE: I tied the broken seat belt wire together with no change. Seemed like that wire does nothing other than trigger a belt not buckled warning.
    Then I started going through ABS (3)/Airbag (15)/Parking Brake(53) controllers. Clearing the codes in (3) & (53) results in the fault codes returning either immediately or after closing/reopening the controller with no change to the ABS/Parking Brake dash lights. However, with Airbag (15), I would clear fault 9444373 which would remove both the ABS and Parking Brake dash lights. The fault would come back, but perhaps that belt buckle wire is doing more than I think?
  5. #24
    Did you have measured power at each identified fuse and did you tone out to verify in correct panel?
  6. #25
    Verified VCDS User phelmerj's Avatar
    Mar 2018
    Edmonton, Alberta, Canada.
    Had this code on my 2003 Jetta Wagon.
    Pulled ABS plug and checked voltages and one terminal at 12.7vdc and other 11.7vdc. Checked the fuses as per Jef the GURU and the one had 2 small (less than 1mm) carbon arc marks on it. Replaced the fuse and cleaned up the holder and problem fixed.
    Check the voltages the with a good meter, all computers are very voltage sensitive. Check the fuses. I really had to look to see those carbon marks and 1 volt difference was enough to cause a pile of head scratching. The WD from Erwin is worth its weight in gold.
  7. Likes Uwe, Jack@European_Parts liked this post
  8. #26
    Quote Originally Posted by phelmerj View Post
    What they said ...
  9. Likes Uwe, Jack@European_Parts liked this post
  10. #27
    Sep 2016
    US
    I didn’t have the time to fully vet this. I did check to see if there was power at any of the fuses and did not find any.
  11. #28
    Back feed the 12 volt sockets tracks with tone generator to seek the Terminal 87 location relay, since they all share this terminal.
    DIN spec's Terminals in JPPSG
    http://www.bosch-classic.com/media/e...eichnungen.pdf
    Overview be valid also for Avant (5-door models)!
    1 - Relay /Fuse Panel F -SF-
    q Components: -J9- , -J84- , -J807-
    1 - Battery Separation Relay -J7-
    q Component Location: in spare tire well, beside auxiliary battery
    2 - Relay / fuse panel with Vehicle Electrical System Control Module -J519-
    q Components:-J160- , -J329- , -J413- , -J601- , -J608- , -J910-
    q Relay / fuse panel with Vehicle Electrical System Control Module -J519- → Chapter
  12. #29
    Sep 2016
    US
    I did take a peek at J393 to see if I found anything obvious (even though those faults are no longer showing - trying to fix the fuel door faults as well). I see four areas of oxidation of some sort. You can see two of them in this image, one circled. I'm assuming this can potentially interfere with the circuit and J393's functions. If so, is it worth it to try in and clean it?
  13. Likes Jack@European_Parts, Uwe liked this post
  14. #30
    It might.......... never hurts to try a fiberglass sanding pen and an anti oxidizer after a spritz with oven cleaner containing sodium hydroxide.
    Wear gloves and eye protection!
    Hair dryer!
    Did your service history come in an electronic form the VAG dealer emailed or did you use an external source to pull that record?
    The format is so nice!
