Results 11 to 20 of 34
Thread: ABS/Parking Brake lights on
    I bought the car used at around 94k, went to the dealer where it was serviced it’s whole life previously and got the whole service history. Let me dig it out for you. I found that it went through oil consumption tests, they made fixes, but found metal in the oil pan at 90+k and replaced the engine just before I bought it.
    No accidents, no warranty voiding. Looks like the dealer/owner split the costs of the engine/labor.
    Very interesting......
  2. #12
    Sep 2016
    US
    Here is the service history.
  3. #13
    Thank you for that information.
    Wow that car has had a hard life & with all those water pumps and oil/air leaks + pistons under warranty and then basically a third of second rebuilt engine traded for a complete engine that was destroyed not under warranty?
    Very Interesting!
  4. #14
    Sep 2016
    US
    Very Interesting!
    I know! It was like a new car by the time I got it but I understand why the previous owner cut bait. The only issue I've had (and would love your insight here), is all the 12V sockets are inactive. Relays/fuses are good, haven't found any wiring issues. Haven't been able to get those powered.
  5. #15
    02615 - Fuel Tank Cap; Lock
    009 - Open or Short to Ground
    Fault Status: 01101001
    Fault Frequency: 64
    Reset counter: 193
    Mileage: 166208 km
    Date: 2017.05.29
    Time: 11:50:50
    02616 - Fuel Tank Cap; Unlock
    Fault Frequency: 92
    Reset counter: 194
    Mileage: 166208 km
    Date: 2017.05.29
    Time: 11:59:20
    16349 - Control Module - Error in Output Stage <<<<<<<<<<<<<<<<<< Hmmm!
    014 - Defective
    Fault Status: 01101110
    Mileage: 169392 km
    Date: 2017.08.07
    Time: 12:50:28
    These faults might have something to do with it..........stand by will have a look at WD since you were kind enough to share with me.
  6. #16
    Sep 2016
    US
    This one is new, the other two have always been there
  7. #17
    Building abstract PR....
    Vehicle Identification No. XXXXXXXXXXXXXXXXX
    Model audi a4 av. qu. 2,0 A4
    Date of production 17.11.2008
    Year 2009
    Sales type 8K556L
    Engine Code CAEB
    Transmission Code KXT
    Axle drive 6A
    Equipment GD
    Roof color X5
    Carpet color code
    Exterior color / Paint Code X5 / Z7H
    x
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PA Standard wheel bolts
    Vehicle class differentiation units/platform components 0HV Vehicle class differentiation -8K0-
    Emission standard 7GB Emission standard ULEV 2
    Trailer hitch 1D0 without trailer towing
    airbag 4UB Airbag for NAR
    Label for central electric 0W2 Label for central electric system English-speaking countries
    Tray areas package QE1 Storage compartment package 1
    Applications GS4 Applications
    Exterior mirror setting 6XD Exterior mirrors, power-adjustable/ heated
    Left exterior mirror 5SG Left exterior mirror, flat
    Right exterior mirror 5RW Right exterior mirror, convex (US) large viewing field
    Drive type 1X1 Four-wheel drive
    "Multimedia"video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
    Equipment levels A8U Executive US equipment
    Brake type in rear 1KW Disc brakes in rear
    batteries J1N Battery 420 A (75 Ah)
    Brake type, front 1LA Disc brakes in front
    Components with special surface 6FA Components without special surface
    Receiver (car phone) QF0 Without receiver (car phone)
    Battery/alternator capacity NY2 Increased battery capacity
    Component part sets with country-specific design requirements B0A build parts set without county specific documentatio
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AS Electronic stability control (ESC)
    Owner's manuals 0VM Information kit in American English
    Operating voltage 9Z0 Operating voltage 12 V
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A3 CD player
    "Charism" 2H0 Without "drive select"
    General operating permit, alterations C00 Operating permit, initial registration
    Cd enhancing underbody panel 2D0 Without cd enhancing underbody panel
    Shock absorption/suspension, chassis 1BA Federung/Daempfung, standard
    Roof rails/roof load rack 3S1 Bright roof rails
    Roof insert/convertible top 3FU Big roof system
    Load-through hatch/ski bag 3X0 without load through system
    Theft protection system 7AJ Electronic immobilizer, with anti-theft alarm system and backup horn
    Inserts 5TE Decorative aluminum inserts
    Scuff plates 7M1 Scuff plates in door apertures with metal inserts
    Park distance control 7X0 Without park distance control
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    Headlight activation 8K4 Separate daytime running lights NAR
    Parking brake UH1 Parking brake
    Vehicle tracing system 7G0 Without preparation for VTS (Vehicle Tracing System)
    Alternators 8GU Alternator 140 A
    Transmission types/gearshift mechanisms 0G7 tiptronic
    Weight category rear axle 0YL Weight range 11 installation control only, no requirement forecast
    Weight category front axle 0JH Weight category front axle weight range 8
    Base engine TG6 4-cyl. petrol engine 2.0 l assembly 06H.G
    Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
    cruise control system 8T1 Cruise control system (CCS)
    Garage door opener VC0 without Garage door opener
    Transmission specifications G0R 6-speed automatic transmission for four-wheel drive
    rear axle differential GH1 Basic rear axle differential
    Rear trim panel 6V2 Rear trim panel
    Manufacturer A51 Audi AG
    Rear spoiler 5J0 Without rear spoiler
    Molded headliner 6NJ Standard molded headlining
    Rear seats 3NZ Rear bench seat, not split, split backrest, folding
    Heating and air-conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Headlamps 8BJ Halogen headlamps for driving on the right, US design
    Customized installation FC0 Without individual installation
    Instrument clusters U1B Instrument cluster with mph speedometer, clock, tachometer and trip odometer
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    Body style K8D Wagon/Avant
    Luggage compartment floor covering 6SS Luggage compartment floor covering
    Climatic zones 0Y4 Cold and tropical climatic zones (US)
    Fuel quantity for initial filling 1Z6 Increase in initial standard fuel filling
    Fuel quality 0U0 Fuel quality 98 RON
    Fuel systems 1A2 Fuel system for SI engine with direct injection (FSI)
    Body measures 5C1 Body measures for increased safety requirements
    Child seat anchors in front 3G0 Without child seat anchora in front (ISOFIX)
    Front license plate bracket 6W3 License plate bracket front (small, NAR)
    Paint preservative/transit coating 5K4 Full body cover (shape-adapted system) with additional transport protection measures
    Rear cargo area 3GD Plane rear cargo area
    Light package (lighting) QQ1 With additional lights (interior lighting)
    Steering system arrangement L0L Left-hand drive
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Lumbar support 7P7 Power-adjustable lumbar support for left front seat
    steering wheels 2ZQ Leather-wrapped multi-function steering wheel for airbag system
    Driving on the left/on the right AV1 right-hand traffic
    Speaker installation 9VD active loudspeakers
    Leather scope 7HA Without leather trim
    Headlight range control 8Q0 without beam length regulator
    Center armrest 6E3 Front center armrest
    Versions FM0 Basic equipment variant
    Multi-function display/trip computer 9Q3 Multi-function display, without trip computer and check control
    Engine cooling 8Z6 Hot country
    Engine specifications D2D 4-cylinder petrol engine 2.0 L/155 KW (16 V) Turbo FSI, homogeneous Basic engine is: TM2/TV2/TG6/TJ6/TD6
    Navigation device 7Q0 without navigation system
    Front fog lamp/additional headlamp 8WB Front fog lamps
    Upgrading measures GP0 Vehicles w/o special upgrade measures
    Audi Sport/ Quattro GmbH FQ0 Series wheels
    Quality class AQ0 Standard-production quality
    Wheels C7R Alloy wheels 7.5J x 17
    Radios 8YN Radio "symphony" for USA
    Tire pressure monitoring system 7K8 Tire pressure monitoring system 315 MHz Basic
    tire HM2 All-season tires 225/50 R17 94H (NAR)
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G5 Space-saving spare wheel, same size (same rolling circumference) as original equipment tires
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 7F9 Gearshift knob/handle in plastic/leather
    Self-collection / special control A00 No self-collection
    Special labels/plates 0SS Labels in English and French
    Tail lamp assemblies 8SA Rear combination lamp, standard design
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Bumper systems 2K2 bumper reinforced
    Seat belt check 9P5 Visual and acoustic seat belt reminder, electric contact
    seat covers N1F Seat trim covers in leather, G-grain pattern/leatherette, B-grain pattern
    Seat adjustment 3L5 Both front seats power-adjustable
    seat heater 4A3 seat heating for front seats separat controlable
    Safety certificate 1QE Special labels safety certificate for Massachusetts
    Control number (no PR family) SA7 Bespoke model 2
    Audio-response system/voice control QH0 without voice control
    Lane change assist/lane keeping system 7Y0 no lane change assistant
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    power outlet 7B3 12-volt socket(s)
    Handling production and pre-production FA0 Control of standard production
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N1 Windshield wiper intermittent control
    Special approval measures 3M3 Passenger car design
    Door and lid locking system 4K2 Central locking system with radio remote control, two-stage unlocking
    Type approval countries/countries with special requirements B34 Legal requirements USA
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Transit coating NT1 Transit coating (type 2)
    TV reception/digital radio reception QV8 Satellite radio reception NAR
    Assembly parts for engine (drive bearing) 1VG Assembly part for 4-cyl. engine
    Identification plates 1EP Special identification label (USA)
    Type sign 2Z1 Type sign at rear and "Quattro" nameplates respectively
    First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
    Front seats Q1A Standard seats in front
    Telephone / telematics 9ZG preperation for mobile phone with hands free teleph.
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GQ Windshield in heat-insulating glass
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZE Black decorative trims
    Additional body panels, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchors 3B7 Child seat anchors as per Canadian requirements a. ISOFIX child seat system
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
    x
  8. #18
  9. #19
    Sep 2016
    US
    Much thanks, I'll see if I missed any. Fuse panel F is in the trunk, and ST4 is also in panel F?
  10. #20
    All fuses are in panel F.
    Please do yourself a favor and get the WD in Erwin by printing to PDF.
