ABS/Parking brake malfunction :: throwing codes 01321/00473
My 2009 Audi B8 A4 Avant threw Parking Brake and ABS warning lights on the dash. In looking under the seat for a connection/wiring issue, I did find that the driver's seat belt wire was snapped off. Could that be the issue? Based on the scan I'm looking at 01321 and 00473. I've seen several folks with the same, which ended up being the ABS control module, but I was hoping to get a little further before buying/replacing parts to see what fixes it. Car runs as normal so I don't believe it's an MAF issue (another often seen symptom). I've looked at the below links, but could anyone take a look at the faults to advise me if there is any other info there to go on? Thx!
http://wiki.ross-tech.com/wiki/index.php/01321
http://wiki.ross-tech.com/wiki/index.php/00473
Tuesday,10,April,2018,20:55:27:02305
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
VIN: License Plate:
Mileage: 176870km-109901mi Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 65 72 77
VIN: Mileage: 176870km-109901miles
Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Revision: E1H14---
Coding: 010C010A190F0160
Shop #: WSC 40832 444 999999
VCID: 79AF101F6959C2DF356-802C
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 C HW: 0B6 927 156
Component: 0B6 20TFSIUSA H04 0050
Revision: --H04---
Coding: 001002
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: 3635DB2318C7EDA7984-8062
Part No SW: 8K0 907 379 AB HW: 8K0 907 379 AB
Component: ESP8 quattro H04 0060
Coding: 150500
VCID: 79AF101F69D9C2DF356-802C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 196
Mileage: 176864 km
Date: 2018.04.08
Time: 22:38:05
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0013
Hex Value: 0x028F
Hex Value: 0x00FF
Part No SW: 8K0 907 064 AG HW: 8K0 907 064 AG
Component: BCM2 1.1 H80 0143
Coding: 090200
VCID: 75B71C2F45C1A6BF51E-8020
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000057866019
Component: ELVAUDIB8 H36 0041
Serial number: 0208000071974008
Reset counter: 146
Mileage: 169392 km
Date: 2017.08.07
Time: 12:50:28
Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
Component: KLIMA 1 ZONE H06 0140
Revision: A1000000 Serial number: 0106.10.080892
Coding: 64002000
VCID: 70B92D3B3AA38397828-8024
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000242883
Coding: 690000B1063C00010000080300007F5F0F14460800000001000000
VCID: 3039ED3BFA23C397C28-8064
Component: WWS 011008 H06 0070
Serial number: SWF08100016732
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 F HW: 8K0 941 531 F
Component: E1 - LDS H07 0070
Serial number: 00000000002909081354
Part No SW: 8K0 959 655 F HW: 8K0 959 655 F
Serial number: 0039KD149H9%
VCID: 40D9BDFB4A035317328-8014
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0800001AX2
Serial number: 6334MSME40350507/
Serial number: 6344MSME432108743
Serial number: 6352QSME7B0E523AT
Serial number: 6362QSME4D10401AB
Serial number: 63732SME5B10483C0
Serial number: 63832SME4B115320R
9444373 - Safety belt switch - driver side
B101C 15 [137] - Open or Short to Plus
Mileage: 176864 km
Date: 2018.04.08
Time: 22:36:16
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90319HJ3000CU
Coding: 000017
Shop #: WSC 06335 123 12345
VCID: 3D27C40F3D713EFF59E-8068
Part No SW: 8K0 920 950 A HW: 8K0 920 950 A
Component: KOMBIINSTR. H17 0224
Revision: 00000000 Serial number: 9DR3526A8
Coding: 8B1E11000300D705020000
VCID: 2D07F44FED11AE7FE9E-8078
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0094
Revision: 4GB20042 Serial number: 4200G089258155
Coding: 000303
VCID: 46D5ABE368A77D27084-8012
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 18048AFC200908
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007770700
Coding: 011C03204000410001
VCID: 3FDBBE07377D2CEF4B2-806A
Revision: 00002001 Serial number: 0114949719
Coding: 0126023A207A001400B002
Subsystem 2 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS127 H06 0037
Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J394 PS222 H06 0037
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 64
Reset counter: 193
Mileage: 166208 km
Date: 2017.05.29
Time: 11:50:50
02616 - Fuel Tank Cap; Unlock
Fault Frequency: 92
Reset counter: 194
Mileage: 166208 km
Date: 2017.05.29
Time: 11:59:20
16349 - Control Module - Error in Output Stage
014 - Defective
Fault Status: 01101110
Mileage: 169392 km
Date: 2017.08.07
Time: 12:50:28
Address 47: Sound System
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007879759
Coding: 011C03204C00410001
VCID: 3E25C303307725E7404-806A
Fault Frequency: 11
Reset counter: 213
Mileage: 175341 km
Date: 2018.02.08
Time: 14:00:24
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000238339
VCID: 313FE83FF129CA9FCD6-8064
Fault Status: 11101101
Fault Frequency: 9
Reset counter: 193
Mileage: 175842 km
Date: 2018.03.02
Time: 14:58:41
Voltage: 13.10 V
Count: 80
Hex Value: 0x02E0
Hex Value: 0x0001
Hex Value: 0x0101
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 L HW: 8T1 035 195 L
Component: Symph3 Sirius H02 0211
Revision: 00000004 Serial number: AUZ5Z4H1051362
Coding: 05020002010285004159070000
VCID: 40D9BDFB4A835317328-8014
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
Component: TSG HL H06 0170
Revision: Serial number: 0000007815169
Coding: 010C03204000210001
Address 65: Tire Pressure (J502) Labels:. 8K0-907-273.clb
Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
Component: J502-RDK H03 0250
Revision: 00001001 Serial number: 13140781839473
Coding: 0CD154
Shop #: WSC 06334 000 00000
Part No SW: 8K0 959 794 A HW: 8K0 959 795 A
Component: TSG HR H06 0170
Revision: Serial number: 0000007912630
Fault Status: 01101000
Reset counter: 172
Mileage: 176603 km
Date: 2018.03.25
Time: 14:39:17
Part No SW: 8T0 862 336 C HW: 8T0 862 336 C
Component: FSE_256x BT H33 0550
Revision: 00000000 Serial number: 00000005021039
Coding: 0010370
VCID: 3B23CA172F6530CF67A-806E
End----(Elapsed Time: 01:54, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
