Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: ABS/Parking Brake lights on
    Sep 2016
    US
    ABS/Parking brake malfunction :: throwing codes 01321/00473
    My 2009 Audi B8 A4 Avant threw Parking Brake and ABS warning lights on the dash. In looking under the seat for a connection/wiring issue, I did find that the driver's seat belt wire was snapped off. Could that be the issue? Based on the scan I'm looking at 01321 and 00473. I've seen several folks with the same, which ended up being the ABS control module, but I was hoping to get a little further before buying/replacing parts to see what fixes it. Car runs as normal so I don't believe it's an MAF issue (another often seen symptom). I've looked at the below links, but could anyone take a look at the faults to advise me if there is any other info there to go on? Thx!
    http://wiki.ross-tech.com/wiki/index.php/01321
    http://wiki.ross-tech.com/wiki/index.php/00473
    Tuesday,10,April,2018,20:55:27:02305
    VIN:  License Plate:
    Mileage: 176870km-109901mi   Repair Order:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 65 72 77
    VIN: Mileage: 176870km-109901miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H14 0001
       Revision: E1H14---
       Coding: 010C010A190F0160
       Shop #: WSC 40832 444 999999
       ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
       ROD: EV_ECM20TFS0118K2907115AL.rod
       VCID: 79AF101F6959C2DF356-802C
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 C    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H04 0050
       Revision: --H04---
       Coding: 001002
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMAL651 A01004
       ROD: EV_TCMAL651.rod
       VCID: 3635DB2318C7EDA7984-8062
       Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
       Component: ESP8 quattro  H04 0060
       Coding: 150500
       VCID: 79AF101F69D9C2DF356-802C
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 196
                        Mileage: 176864 km
                        Date: 2018.04.08
                        Time: 22:38:05
                        Hex Value: 0x0000
                        Hex Value: 0x0782
                        Hex Value: 0x0013
                        Hex Value: 0x028F
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
       Component: BCM2 1.1      H80 0143
       Coding: 090200
       VCID: 75B71C2F45C1A6BF51E-8020
       Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
       Serial number: 0508000057866019
       Component: ELVAUDIB8  H36 0041
       Serial number: 0208000071974008
                        Reset counter: 146
                        Mileage: 169392 km
                        Date: 2017.08.07
                        Time: 12:50:28
       Part No SW: 8T1 820 043 AA    HW: 8T1 820 043 AA
       Component: KLIMA 1 ZONE  H06 0140
       Revision: A1000000    Serial number: 0106.10.080892
       Coding: 64002000
       VCID: 70B92D3B3AA38397828-8024
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H22 0253
       Revision: 05022001    Serial number: 00000000242883
       Coding: 690000B1063C00010000080300007F5F0F14460800000001000000
       VCID: 3039ED3BFA23C397C28-8064
       Component: WWS 011008  H06 0070
       Serial number: SWF08100016732
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 941 531 F    HW: 8K0 941 531 F
       Component: E1 - LDS  H07 0070
       Serial number: 00000000002909081354
       Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
       Component: AirbagVW-AU10 H27 0410
       Serial number: 0039KD149H9%
       Coding: 303836354230303030304A55304C384B3053
       VCID: 40D9BDFB4A035317328-8014
       Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
       Component: BF-Gewichtss.  H01 0030
       Serial number: 5810000R0800001AX2
       Serial number: 6334MSME40350507/
       Serial number: 6344MSME432108743
       Serial number: 6352QSME7B0E523AT
       Serial number: 6362QSME4D10401AB
       Serial number: 63732SME5B10483C0
       Serial number: 63832SME4B115320R
    9444373 - Safety belt switch - driver side
              B101C 15 [137] - Open or Short to Plus
                        Mileage: 176864 km
                        Date: 2018.04.08
                        Time: 22:36:16
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90319HJ3000CU
       Coding: 000017
       Shop #: WSC 06335 123 12345
       VCID: 3D27C40F3D713EFF59E-8068
       Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
       Component: KOMBIINSTR.   H17 0224
       Revision: 00000000    Serial number: 9DR3526A8
       Coding: 8B1E11000300D705020000
       VCID: 2D07F44FED11AE7FE9E-8078
       Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0094
       Revision: 4GB20042    Serial number: 4200G089258155
       Coding: 000303
       VCID: 46D5ABE368A77D27084-8012
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H04 0150
       Serial number: 18048AFC200908
       Part No SW: 8K0 959 793 B    HW: 8K0 959 793
       Component: TSG FA        H10 0170
       Revision:             Serial number: 0000007770700
       Coding: 011C03204000410001
       VCID: 3FDBBE07377D2CEF4B2-806A
       Revision: 00002001    Serial number: 0114949719
       Coding: 0126023A207A001400B002
       Subsystem 2 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS127  H06 0037
       Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J394 PS222  H06 0037
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Fault Frequency: 64
                        Reset counter: 193
                        Mileage: 166208 km
                        Date: 2017.05.29
                        Time: 11:50:50
    02616 - Fuel Tank Cap; Unlock
                        Fault Frequency: 92
                        Reset counter: 194
                        Mileage: 166208 km
                        Date: 2017.05.29
                        Time: 11:59:20
    16349 - Control Module - Error in Output Stage
                014 - Defective
                        Fault Status: 01101110
                        Mileage: 169392 km
                        Date: 2017.08.07
                        Time: 12:50:28
    Address 47: Sound System
       Part No SW: 8K0 959 792 B    HW: 8K0 959 792
       Component: TSG BF        H10 0170
       Revision:             Serial number: 0000007879759
       Coding: 011C03204C00410001
       VCID: 3E25C303307725E7404-806A
                        Fault Frequency: 11
                        Reset counter: 213
                        Mileage: 175341 km
                        Date: 2018.02.08
                        Time: 14:00:24
       Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
       Component: EPB Audi B8   H05 0060
       Revision: 00000003    Serial number: 00000000238339
       VCID: 313FE83FF129CA9FCD6-8064
                        Fault Status: 11101101
                        Fault Frequency: 9
                        Reset counter: 193
                        Mileage: 175842 km
                        Date: 2018.03.02
                        Time: 14:58:41
                        Voltage: 13.10 V
                        Count: 80
                        Hex Value: 0x02E0
                        Hex Value: 0x0001
                        Hex Value: 0x0101
       Part No SW: 8T1 035 195 L    HW: 8T1 035 195 L
       Component: Symph3 Sirius H02 0211
       Revision: 00000004    Serial number: AUZ5Z4H1051362
       Coding: 05020002010285004159070000
       VCID: 40D9BDFB4A835317328-8014
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
       Part No SW: 8K0 959 795 A    HW: 8K0 959 795 A
       Component: TSG HL        H06 0170
       Revision:             Serial number: 0000007815169
       Coding: 010C03204000210001
    Address 65: Tire Pressure (J502)       Labels:. 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0250
       Revision: 00001001    Serial number: 13140781839473
       Coding: 0CD154
       Shop #: WSC 06334 000 00000
       Part No SW: 8K0 959 794 A    HW: 8K0 959 795 A
       Component: TSG HR        H06 0170
       Revision:             Serial number: 0000007912630
                        Reset counter: 172
                        Mileage: 176603 km
                        Date: 2018.03.25
                        Time: 14:39:17
       Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
       Component: FSE_256x BT     H33 0550
       Revision: 00000000    Serial number: 00000005021039
       Coding: 0010370
       VCID: 3B23CA172F6530CF67A-806E
    End----(Elapsed Time: 01:54, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
    Sep 2016
    US
    Can anyone give some help? I'm wondering if there is some detail in these error codes that point to anything in particular. Thanks in advance!
                        Reset counter: 196
                        Mileage: 176864 km
                        Date: 2018.04.08
                        Time: 22:38:05
                        Hex Value: 0x0000
                        Hex Value: 0x0782
                        Hex Value: 0x0013
                        Hex Value: 0x028F
                        Hex Value: 0x00FF
                        Fault Frequency: 9
                        Reset counter: 193
                        Mileage: 175842 km
                        Date: 2018.03.02
                        Time: 14:58:41
                        Voltage: 13.10 V
                        Count: 80
                        Hex Value: 0x02E0
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    Weird....
    The ABS fault is telling you it's aware of a fault in the EPB.
    The EPB is telling you it's aware of a fault in the Airbags.
    The Airbag module has an actual fault.
    I've never seen two levels of indirection like that, but one is common. In any case, the seat belt switch fault in the airbag module should be reasonably straightforward to correct, so I'd certainly do that before throwing any other parts (such as an ABS module) at the car.
    PS: For those with a good memory, the OP now has a legit VCDS system (HEX-V2).
    Sep 2016
    US
    The driver's seat belt latch has a wire to it which is broken. To fix I have to pull the seat to replace the entire latch. Are you saying it's possible that this could be throwing the ABS and EPB codes?
    Thanks for taking a look.
    Well, the EPB is aware of the fault in the Airbag Module. The EPB wants to know that the seatbelt switches are functioning properly because its behavior is different if the occupants are belted in than if they aren't. With occupants belted in, it's willing to release the parking brake automatically under some circumstances..
    The ABS is aware of the fault in the EPB. TBH, I'm not sure why the ABS cares, and like I said, I haven't previously seen (or noticed) two levels of indirection like this, but hey... Fixing a broken wire should be a whole lot cheaper/easier than replacing an ABS or EPB control module, so that's what I'd do first.
  6. Likes Jack@European_Parts, Zenerdiode liked this post
    Sep 2016
    US
    Thanks Uwe - I'll replace that seatbelt receiver. But, that wire looks to be just a simple two wire; do you think I can just bridge the contacts to close the circuit to quickly test to see if that is the issue?
    Revision: E1H14---
    So 109K with original firmware level and no DTC's ........interesting!
    Is this car FOD tuned altered modified?
    Have you recently changed the engine?
    Ohm out passenger side belt switch to compare and simulate a good reading before a wire bridge & just in case or use RTFB or swap the plugs to isolate & see if fault moves.
  9. #8
    Sep 2016
    US
    Hi Jack - The car is stock and not tuned/altered/modified. The engine was replaced at 95k
  10. #9
    ooooh a clue!
    Thank you for the feedback on this!
    Ok so why did the engine fail and did they change the engine under warranty extension or was this done at outside repair station with cost out of pocket?
    Any major accidents causing FOD or warranty being voided?
    Any pictures?
    I would love to see the service history to this EA888 CAEB car.
    VIN: XXXXXXXXXXXXXXXXX Mileage: 176870km-109901miles
    I ask because it may help me help you even more now & you really have my interest on this.
  11. #10
    Sep 2016
    US
    I bought the car used at around 94k, went to the dealer where it was serviced it’s whole life previously and got the whole service history. Let me dig it out for you. I found that it went through oil consumption tests, they made fixes, but found metal in the oil pan at 90+k and replaced the engine just before I bought it.
    No accidents, no warranty voiding. Looks like the dealer/owner split the costs of the engine/labor.
