P0346 CAMSHAFT POSITION SENSOR IMPLAUSIBLE SIGNAL INTERMITTENT (G163)
rafa3092
Mexico
C?ID=302336
Hello
I own a Touareg 2012 V8 4.2L Fuel engine and I am having trouble with the camshaft position sensor.
It has been replaced the two sensors (g163) and (g40) and the fault is still present.
Also it has been inspected the sensor 3 plug cables and they are working as it should with the 6 volts.
The fault code appears only when you start the engine, sometimes you can hear a knock sound 2 seconds when starting, the fault frequency can appear many times before you clear again the code.
I am thinking that the knock sound is because of a loose cam adjuster or time change misaligned?
Let me know your comments.
Thank you.
rafa3092
Mexico
C?ID=302336
Good morning here is the Auto-Scan:
Let me know your comments please.
Monday,09,April,2018,23:55:24:38924
VCDS Version: 18.2.0.3  HEX-V2 CB: 0.4411.4
VIN: WVGAN87P2CD057736   License Plate:
Mileage: 77664km-48258mi   Repair Order: 4673
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 28 34 36 42 46 52 53 55
          56 5F 62 6C 6D 72
VIN: WVGAN87P2CD057736   Mileage: 77664km-48258miles
Address 01: Engine (------CGNA)       Labels:* None
   Part No SW: 7P0 907 560     HW: 7P0 907 560
   Component: 4.2l V8/4V    H05 0003
   Revision: N9H05---
   Coding: 04210003290F0558
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM42FSI0117P0907560 001005
   ROD: EV_ECM42FSI0117P0907560.rod
   VCID: 72BC2BE68426A15774C-8026
8626 - Camshaft Position Sensor (G163)
          P0346 00 [096] - Implausible Signal
                    Mileage: 77590 km
                    Date: 2018.04.07
                    Time: 14:41:32
                    Engine speed: 1066.00 /min
                    Normed load value: 50.6 %
                    Coolant temperature: 87 °C
                    Intake air temperature: 68 °C
                    Ambient air pressure: 750 mbar
                    Voltage terminal 30: 11.756 V
                    AFS dm: 77.2 kg/h
                    Median injection timing: 1.620 ms
                    Engine operating condition-Channel 87: Idling
                    Relative load value: 32.25 %
                    Tumg: 27.8 °C
                    Psr w: 547.66 hPa
                    Engine torque: 126.6 Nm
   Part No SW: 0C8 927 750 B    HW: 0C8 927 750 B
   Component: AL1000 AISIN  001 2074
   Coding: 001168
   Shop #: WSC 00017 993 999999
   ROD: EV_TCMAL991031_002.rod
   VCID: 2B02F682638CB09FF7A-807E
Address 03: ABS Brakes (J104)       Labels:| 7P0-907-379.clb
   Part No SW: 7P0 907 379 J    HW: 7P0 907 379 A
   Component: MK25A         H36 0433
   Revision: --------    Serial number: 409320010EC815
   Coding: 5B6B53C32329255ADAFBCA96C4D8A440F700
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 44D0BD3EEE125FE7160-8010
   Part No SW: 4H0 907 064 BK    HW: 4H0 907 064 BK
   Coding: 0D860000000000000000
   VCID: 73B22EE2FBBCA85F7FA-8026
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 2312000035125015
   Revision: AA000000    Serial number: 00000026770795
   Coding: 0018330000004201000001010101202020202121202020
   VCID: 3430EDFEBE32EF67A60-8060
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 4 Zonen H20 1305
   Coding: 4886207EC0
   VCID: 7EA40FD6C07EF537004-802A
   Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0111
   Revision: 15012002    Serial number: 00000001279295
   Coding: 26001011D1345D010021000380005D0C431C470882010261800000020000
   Component: WWS    120214  31  0020
   Serial number: 90243400120224215304
   Coding: 004DBD
   Component: RLFS  H09 0011
   Serial number: 10351513
   Coding: 025223
   Component: E1 - LDS  H04 0031
   Serial number: 00000000000204120047
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R11GY07
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA103085000001114693
   Coding: 010300
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28261208903238
   Coding: 308501
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 42DCBB26F40651D724C-8016
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag001 H05 0025
   Revision: --------    Serial number: 003L0002JSXK
   Coding: 000000000000000000000000000000003031
   VCID: 41DEB42AF1004ACF3D6-8014
   Serial number: 3575LRB405F18NQQBGA9
   Serial number: 3585LRB405R17UE0E8I-
   Serial number: 3515RRB405117ABU609Y
   Serial number: 3525RRB405517ABU90ND
   Serial number: 3555NRB406118E5G7P5%
   Serial number: 3565NRB406118E5G2GUB
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Revision: --------    Serial number: 90815LD60002N
   Coding: 000C35
   VCID: 3828D9CEA25A0B078A8-806C
   Serial number: 0164366
   Part No SW: 7P6 920 881 S    HW: 7P6 920 881 S
   Component: Kombi         H14 0253
   Revision: 12240067    Serial number: 658300312592063
   Coding: 133732003A000008000004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 4CC0951EC64297A7DE0-8018
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000467553
   Coding: 0021034800
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3828D9CEA2DA0B078A8-806C
   Serial number: 00000000005650658939
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 7P6 907 049 P    HW: 7P6 907 049 P
   Component: Klima Fond    H14 1305
   Coding: 0000000000
   ASAM Dataset: EV_AirCondiHeck 001007
   ROD: EV_AirCondiHeck.rod
   VCID: 4ACC9306CC368997ECC-801E
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 K    HW: 7P0 907 553 K
   Component: PASM          H01 1110
   Revision: 00000000    Serial number: 00000120730186
   Coding: 14210000
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
   VCID: 3FDAB2D287F43C3F4B2-806A
   Revision: AA000000    Serial number: 00000026768091
   Coding: 00183B0000004201000001010101202020202121202020
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000126124617
   Coding: 011D1720DE00451205080002
   VCID: 44D0BD3EEE925FE7160-8010
   Revision: 00002001    Serial number: 0174008358
   Coding: 011E163A28B9509583300620010000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 0821212358
   Subsystem 2 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Subsystem 4 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO15653475
   Coding: 191100
   Subsystem 5 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO1569877H
   Coding: 191100
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000126247944
   Coding: 011D1720DE00451205080000
   VCID: 3B22C6C2936C201F67A-806E
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1232500220
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 3634D7F6A8CEFD77984-8062
   Slave 3:
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 012A00000F000200
   VCID: 7CA005DED662E7272E0-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Part No SW: 4G1 035 053 E    HW: 4G1 035 053
   Component: Radio U Basic H41 0093
   Revision: AB001007    Serial number: 227DZ0C7561625
   Coding: 050005020100000003
   VCID: 211E14AA11C06ACF5D6-8074
   Part No SW: 7P6 035 664 B    HW: 7P6 035 664
   Component: H-BN-NA       H44 0319
   Revision: --------    Serial number: 445CV0C7530661
   Coding: 010200050040C1EF41020B0E00000003F0000101
   VCID: 372ADAF2AF44047F832-8062
   Subsystem 1 - Part No: 8R0 060 884 AC
   Component: NAR 2011  0503
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9L79003SP
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  1886
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000126317014
   Coding: 011C17200000251005080000
   VCID: 3A2CC3C69C5619177CC-806E
   Part No SW: 7P6 907 441 F    HW: 4H0 907 441 B
   Component: SG Rueckfahrkamera  0120
   Revision: 00H05000    Serial number: 525 PA8J220811
   Coding: 0020001
   Shop #: WSC 98765 666 38384
   VCID: 3C20C5DE9A6227276E0-8068
   Part No SW: 7P6 959 107 A    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0620
   Revision: 22010001    Serial number: 083201008
   Coding: 0533314002
   ASAM Dataset: EV_HeckkTouar 202137
   ROD: EV_HeckkTouar.rod
   VCID: 3D26C8DA8DF82E2F59E-8068
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000126318054
End----------(Elapsed Time: 02:17, VBatt start/end: 12.2V/12.2V)-----------
rafa3092
Mexico
C?ID=302336
Thank you for your quick response and details.
I have not yet adjusted the timing.
If you mention that, it will be the next step to focus.
The strange sound only appears once in a while you start the engine and not always.
rafa3092
Mexico
C?ID=302336
Thank you Larry
The condition of the oil is good.
It was changed 1,500 miles ago.
rafa3092
Mexico
C?ID=302336
The correct engine sound term is (rattling when starting).
Prepare for mechanical tear down and check adjuster for oil feed & or damage if noise evident!
Also check that wiring and ECU is in proper order with no water ingress.
rafa3092
Mexico
C?ID=302336
Thank you Jack
It will be dismantled the engine as the noise when starting is evident and check adjuster for damage or oil feed problem.
I have already checked the ECU wiring and is fine, the water drain holes are clean and tested.
Keep on touch.
Larry Manton
C?ID=112505
Thank you Jack
Keep on touch.
Rafa, my question about the oil was not when changed?, but alluding to is it circulating and activating everything. Good Luck.
Larry Manton
C?ID=112505
          56 5F 62 6C 6D 72
   Revision: N9H05---
                    Mileage: 77590 km
                    Date: 2018.04.07
                    Time: 14:41:32
                    AFS dm: 77.2 kg/h
                    Tumg: 27.8 °C
                    Psr w: 547.66 hPa
   Coding: 001168
   Coding: 4886207EC0
   Coding: 004DBD
   Coding: 025223
   Coding: 010300
   Coding: 308501
   Coding: 000C35
   Coding: 0021034800
   Coding: 0000000000
   Coding: 14210000
   Coding: 191100
   Coding: 191100
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   Slave 3:
   Coding: 130000
   Coding: 130000
   Coding: 0020001
   Coding: 0533314002
Mileage: 77590 km
Date: 2018.04.07
Time: 14:41:32
AFS dm: 77.2 kg/h
Tumg: 27.8 °C
Psr w: 547.66 hPa
Rafa, going to open myself up to criticism which I am okay with. Not familiar with the subtle nuances of the Tourage but the voltage here is only 11.75 @ idle. I have no idea if the tensioner is all hydralic, or both that and electrical, but voltage here is insufficient IMO.
Larimore.
RyMar
South Africa
C?ID=133909
This eng is chain driven. Correct oil is extremely important. Tensioners are hydraulic.
No other fault codes logged, then maybe the Central electrics made the alternator charge less at that specific rpm/load from other consumers.
rafa3092
Mexico
C?ID=302336
Hello Larimore;
Sorry for my late response but you are right, I will first check why there is only 11.75V if it should be like 14V at idle.
I keep updating the results obtained.
rafa3092
Mexico
C?ID=302336
Hello RyMar:
The oil level is correct, not yet revised the chain and hydraulic tensioners.
I will check with a multimeter the battery charge and if the alternator is charging correctly the battery and if there is a voltage drop using the vehicle.
Let you know what happened with this test.
rafa3092
Mexico
C?ID=302336
Hello RyMar
You are right indeed, have already fixed the problem after long investigation.
rafa3092
Mexico
C?ID=302336
The resolution was when the engine oil change was required I added the correct Castrol 5W30 and after a while it was tested and used, finally the code never appeared again. The rattle sound was caused by the incorrect oil type.
So my recommendation first before you attempt to dismantle the engine inspect the oil level & correct oil type.
