Results 11 to 20 of 21
Thread: P0346 CAMSHAFT POSITION SENSOR IMPLAUSIBLE SIGNAL INTERMITTENT (G163)
    May 2016
    Quote Originally Posted by rafa3092 View Post
    Thank you Jack
    It will be dismantled the engine as the noise when starting is evident and check adjuster for damage or oil feed problem.
    I have already checked the ECU wiring and is fine, the water drain holes are clean and tested.
    Keep on touch.
    Rafa, my question about the oil was not when changed?, but alluding to is it circulating and activating everything. Good Luck.
  2. Likes rafa3092 liked this post
  3. #12
    May 2016
    Good morning here is the Auto-Scan:
    Let me know your comments please.
    Monday,09,April,2018,23:55:24:38924
    VCDS Version: 18.2.0.3  HEX-V2 CB: 0.4411.4
    VIN: WVGAN87P2CD057736   License Plate:
    Mileage: 77664km-48258mi   Repair Order: 4673
    Chassis Type: 7P-VW52 (7P6)
    Scan: 01 02 03 05 06 08 09 10 15 16 17 19 28 34 36 42 46 52 53 55
              56 5F 62 6C 6D 72
    VIN: WVGAN87P2CD057736   Mileage: 77664km-48258miles
    Address 01: Engine (------CGNA)       Labels:* None
       Part No SW: 7P0 907 560     HW: 7P0 907 560
       Component: 4.2l V8/4V    H05 0003
       Revision: N9H05---
       Coding: 04210003290F0558
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM42FSI0117P0907560 001005
       ROD: EV_ECM42FSI0117P0907560.rod
       VCID: 72BC2BE68426A15774C-8026
    8626 - Camshaft Position Sensor (G163)
              P0346 00 [096] - Implausible Signal
                        Mileage: 77590 km
                        Date: 2018.04.07
                        Time: 14:41:32
                        Engine speed: 1066.00 /min
                        Normed load value: 50.6 %
                        Coolant temperature: 87 °C
                        Intake air temperature: 68 °C
                        Ambient air pressure: 750 mbar
                        Voltage terminal 30: 11.756 V
                        AFS dm: 77.2 kg/h
                        Median injection timing: 1.620 ms
                        Engine operating condition-Channel 87: Idling
                        Relative load value: 32.25 %
                        Tumg: 27.8 °C
                        Psr w: 547.66 hPa
                        Engine torque: 126.6 Nm
       Part No SW: 0C8 927 750 B    HW: 0C8 927 750 B
       Component: AL1000 AISIN  001 2074
       Coding: 001168
       Shop #: WSC 00017 993 999999
       ROD: EV_TCMAL991031_002.rod
       VCID: 2B02F682638CB09FF7A-807E
    Address 03: ABS Brakes (J104)       Labels:| 7P0-907-379.clb
       Part No SW: 7P0 907 379 J    HW: 7P0 907 379 A
       Component: MK25A         H36 0433
       Revision: --------    Serial number: 409320010EC815
       Coding: 5B6B53C32329255ADAFBCA96C4D8A440F700
       ASAM Dataset: EV_MK25AXT 008001
       ROD: EV_ESPMK25A00800.rod
       VCID: 44D0BD3EEE125FE7160-8010
       Part No SW: 4H0 907 064 BK    HW: 4H0 907 064 BK
       Coding: 0D860000000000000000
       VCID: 73B22EE2FBBCA85F7FA-8026
       Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Serial number: 2312000035125015
       Revision: AA000000    Serial number: 00000026770795
       Coding: 0018330000004201000001010101202020202121202020
       VCID: 3430EDFEBE32EF67A60-8060
       Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
       Component: Klima 4 Zonen H20 1305
       Coding: 4886207EC0
       VCID: 7EA40FD6C07EF537004-802A
       Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
       Component: BCM1 2.0      H12 0111
       Revision: 15012002    Serial number: 00000001279295
       Coding: 26001011D1345D010021000380005D0C431C470882010261800000020000
       Component: WWS    120214  31  0020
       Serial number: 90243400120224215304
       Coding: 004DBD
       Component: RLFS  H09 0011
       Serial number: 10351513
       Coding: 025223
       Component: E1 - LDS  H04 0031
       Serial number: 00000000000204120047
       Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0020
       Serial number: 0000001805569R11GY07
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA103085000001114693
       Coding: 010300
    Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
       Part No SW: 7P6 919 475 B    HW: 7N0 919 475
       Component: PARKHILFE 8K  H05 0021
       Revision: --------    Serial number: 28261208903238
       Coding: 308501
       ASAM Dataset: EV_VW526ParkiAssis2 001011
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 42DCBB26F40651D724C-8016
       Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
       Component: VW10Airbag001 H05 0025
       Revision: --------    Serial number: 003L0002JSXK
       Coding: 000000000000000000000000000000003031
       VCID: 41DEB42AF1004ACF3D6-8014
       Serial number: 3575LRB405F18NQQBGA9
       Serial number: 3585LRB405R17UE0E8I-
       Serial number: 3515RRB405117ABU609Y
       Serial number: 3525RRB405517ABU90ND
       Serial number: 3555NRB406118E5G7P5%
       Serial number: 3565NRB406118E5G2GUB
       Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
       Revision: --------    Serial number: 90815LD60002N
       Coding: 000C35
       VCID: 3828D9CEA25A0B078A8-806C
       Serial number: 0164366
       Part No SW: 7P6 920 881 S    HW: 7P6 920 881 S
       Component: Kombi         H14 0253
       Revision: 12240067    Serial number: 658300312592063
       Coding: 133732003A000008000004
       ASAM Dataset: EV_KombiUDSRBVW526 001013
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 4CC0951EC64297A7DE0-8018
       Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
       Component: GW-CAN-L-MOST H08 5202
       Revision: --------    Serial number: 00000000467553
       Coding: 0021034800
       ASAM Dataset: EV_GatewVW526UDS 001006
       ROD: EV_GatewUDS_VW52.rod
       VCID: 3828D9CEA2DA0B078A8-806C
       Serial number: 00000000005650658939
    Address 28: HVAC, Rear (E265)       Labels:* None
       Part No SW: 7P6 907 049 P    HW: 7P6 907 049 P
       Component: Klima Fond    H14 1305
       Coding: 0000000000
       ASAM Dataset: EV_AirCondiHeck 001007
       ROD: EV_AirCondiHeck.rod
       VCID: 4ACC9306CC368997ECC-801E
    Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
       Part No SW: 7P0 907 553 K    HW: 7P0 907 553 K
       Component: PASM          H01 1110
       Revision: 00000000    Serial number: 00000120730186
       Coding: 14210000
       ASAM Dataset: EV_PASMConti 001004
       ROD: EV_PASMConti.rod
       VCID: 3FDAB2D287F43C3F4B2-806A
       Revision: AA000000    Serial number: 00000026768091
       Coding: 00183B0000004201000001010101202020202121202020
       Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
       Component: TSG FA        H07 0166
       Revision: --------    Serial number: 0000126124617
       Coding: 011D1720DE00451205080002
       VCID: 44D0BD3EEE925FE7160-8010
       Revision: 00002001    Serial number: 0174008358
       Coding: 011E163A28B9509583300620010000000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
       Component: GTO BT  H19 0059
       Serial number: 0821212358
       Subsystem 2 - Part No: 7P6 951 171
       Component: DWA-Sensor  002 0204
       Subsystem 4 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
       Component: J245 PS30.055  H01 0008
       Serial number:     WOO15653475
       Coding: 191100
       Subsystem 5 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
       Component: J394 PS30.055  H01 0008
       Serial number:     WOO1569877H
       Coding: 191100
       Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
       Component: TSG BF        H07 0166
       Revision: --------    Serial number: 0000126247944
       Coding: 011D1720DE00451205080000
       VCID: 3B22C6C2936C201F67A-806E
       Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C1232500220
       Coding: 01040100
       ROD: EV_ParkbA7.rod
       VCID: 3634D7F6A8CEFD77984-8062
       Slave 3:
       Part No SW: 7P6 907 357     HW: 7L6 907 357 C
       Component: AFS-ECU       H04 0110
       Coding: 012A00000F000200
       VCID: 7CA005DED662E7272E0-8028
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Coding: 130000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Coding: 130000
       Part No SW: 4G1 035 053 E    HW: 4G1 035 053
       Component: Radio U Basic H41 0093
       Revision: AB001007    Serial number: 227DZ0C7561625
       Coding: 050005020100000003
       VCID: 211E14AA11C06ACF5D6-8074
       Part No SW: 7P6 035 664 B    HW: 7P6 035 664
       Component: H-BN-NA       H44 0319
       Revision: --------    Serial number: 445CV0C7530661
       Coding: 010200050040C1EF41020B0E00000003F0000101
       VCID: 372ADAF2AF44047F832-8062
       Subsystem 1 - Part No: 8R0 060 884 AC
       Component: NAR 2011  0503
       Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: DU8 SV Touch  H26 0045
       Serial number: VWZ8Z9L79003SP
       Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: CD-Database  1886
       Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
       Component: TSG HL        H09 0167
       Revision: --------    Serial number: 0000126317014
       Coding: 011C17200000251005080000
       VCID: 3A2CC3C69C5619177CC-806E
       Part No SW: 7P6 907 441 F    HW: 4H0 907 441 B
       Component: SG Rueckfahrkamera  0120
       Revision: 00H05000    Serial number: 525 PA8J220811
       Coding: 0020001
       Shop #: WSC 98765 666 38384
       VCID: 3C20C5DE9A6227276E0-8068
       Part No SW: 7P6 959 107 A    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0620
       Revision: 22010001    Serial number: 083201008
       Coding: 0533314002
       ASAM Dataset: EV_HeckkTouar 202137
       ROD: EV_HeckkTouar.rod
       VCID: 3D26C8DA8DF82E2F59E-8068
       Component: TSG HR        H09 0167
       Revision: --------    Serial number: 0000126318054
    End----------(Elapsed Time: 02:17, VBatt start/end: 12.2V/12.2V)-----------
    Mileage: 77590 km
    Date: 2018.04.07
    Time: 14:41:32
    AFS dm: 77.2 kg/h
    Tumg: 27.8 °C
    Psr w: 547.66 hPa
    Rafa, going to open myself up to criticism which I am okay with. Not familiar with the subtle nuances of the Tourage but the voltage here is only 11.75 @ idle. I have no idea if the tensioner is all hydralic, or both that and electrical, but voltage here is insufficient IMO.
    Larimore.
  4. Likes rafa3092 liked this post
  5. #13
    Apr 2015
    South Africa
    This eng is chain driven. Correct oil is extremely important. Tensioners are hydraulic.
    No other fault codes logged, then maybe the Central electrics made the alternator charge less at that specific rpm/load from other consumers.
  6. Likes rafa3092 liked this post
  7. #14
    Quote Originally Posted by RyMar View Post
    11.75V with the engine running is never right, that's way too low a voltage.
  8. #15
    May 2016
    Thank you PDave, thought I was the odd man out.
  9. #16
    Apr 2018
    Mexico
    Hello Larimore;
    Sorry for my late response but you are right, I will first check why there is only 11.75V if it should be like 14V at idle.
    I keep updating the results obtained.
  11. #17
    Apr 2018
    Mexico
    Hello RyMar:
    The oil level is correct, not yet revised the chain and hydraulic tensioners.
    I will check with a multimeter the battery charge and if the alternator is charging correctly the battery and if there is a voltage drop using the vehicle.
    Let you know what happened with this test.
  12. #18
    Pictures please or it didn't happen as Uwe says.........
  13. Likes rafa3092 liked this post
  14. #19
    Apr 2018
    Mexico
    Hello RyMar
    You are right indeed, have already fixed the problem after long investigation.
  15. #20
    Apr 2018
    Mexico
    The resolution was when the engine oil change was required I added the correct Castrol 5W30 and after a while it was tested and used, finally the code never appeared again. The rattle sound was caused by the incorrect oil type.
    So my recommendation first before you attempt to dismantle the engine inspect the oil level & correct oil type.
  16. Likes Uwe liked this post
