Monday,09,April,2018,23:55:24:38924
VCDS Version: 18.2.0.3 HEX-V2 CB: 0.4411.4
VIN: WVGAN87P2CD057736 License Plate:
Mileage: 77664km-48258mi Repair Order: 4673
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 28 34 36 42 46 52 53 55
56 5F 62 6C 6D 72
VIN: WVGAN87P2CD057736 Mileage: 77664km-48258miles
Address 01: Engine (------CGNA) Labels:* None
Part No SW: 7P0 907 560 HW: 7P0 907 560
Component: 4.2l V8/4V H05 0003
Revision: N9H05---
Coding: 04210003290F0558
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM42FSI0117P0907560 001005
ROD: EV_ECM42FSI0117P0907560.rod
VCID: 72BC2BE68426A15774C-8026
8626 - Camshaft Position Sensor (G163)
P0346 00 [096] - Implausible Signal
Mileage: 77590 km
Date: 2018.04.07
Time: 14:41:32
Engine speed: 1066.00 /min
Normed load value: 50.6 %
Coolant temperature: 87 °C
Intake air temperature: 68 °C
Ambient air pressure: 750 mbar
Voltage terminal 30: 11.756 V
Unlearning counter according OBD: 35
AFS dm: 77.2 kg/h
Median injection timing: 1.620 ms
Engine operating condition-Channel 87: Idling
Relative load value: 32.25 %
Tumg: 27.8 °C
Psr w: 547.66 hPa
Engine torque: 126.6 Nm
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 B HW: 0C8 927 750 B
Component: AL1000 AISIN 001 2074
Coding: 001168
Shop #: WSC 00017 993 999999
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002.rod
VCID: 2B02F682638CB09FF7A-807E
Address 03: ABS Brakes (J104) Labels:| 7P0-907-379.clb
Part No SW: 7P0 907 379 J HW: 7P0 907 379 A
Component: MK25A H36 0433
Revision: -------- Serial number: 409320010EC815
Coding: 5B6B53C32329255ADAFBCA96C4D8A440F700
ROD: EV_ESPMK25A00800.rod
VCID: 44D0BD3EEE125FE7160-8010
Part No SW: 4H0 907 064 BK HW: 4H0 907 064 BK
Component: BCM2 2.0 H31 0333
Coding: 0D860000000000000000
VCID: 73B22EE2FBBCA85F7FA-8026
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 2312000035125015
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000026770795
Coding: 0018330000004201000001010101202020202121202020
VCID: 3430EDFEBE32EF67A60-8060
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BK HW: 7P6 907 040 BK
Component: Klima 4 Zonen H20 1305
Coding: 4886207EC0
VCID: 7EA40FD6C07EF537004-802A
Part No SW: 4H0 907 063 BL HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0111
Revision: 15012002 Serial number: 00000001279295
Coding: 26001011D1345D010021000380005D0C431C470882010261800000020000
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 120214 31 0020
Serial number: 90243400120224215304
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10351513
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000000204120047
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R11GY07
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103085000001114693
Coding: 010300
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H05 0021
Revision: -------- Serial number: 28261208903238
Coding: 308501
ASAM Dataset: EV_VW526ParkiAssis2 001011
ROD: EV_VW526ParkiAssis2.rod
VCID: 42DCBB26F40651D724C-8016
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 C HW: 7P0 959 655 C
Component: VW10Airbag001 H05 0025
Revision: -------- Serial number: 003L0002JSXK
Coding: 000000000000000000000000000000003031
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 41DEB42AF1004ACF3D6-8014
Serial number: 3575LRB405F18NQQBGA9
Serial number: 3585LRB405R17UE0E8I-
Serial number: 3515RRB405117ABU609Y
Serial number: 3525RRB405517ABU90ND
Serial number: 3555NRB406118E5G7P5%
Serial number: 3565NRB406118E5G2GUB
Part No SW: 4H0 953 568 H HW: 7P6 953 507 M
Revision: -------- Serial number: 90815LD60002N
Coding: 000C35
VCID: 3828D9CEA25A0B078A8-806C
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0164366
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 881 S HW: 7P6 920 881 S
Component: Kombi H14 0253
Revision: 12240067 Serial number: 658300312592063
Coding: 133732003A000008000004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: 4CC0951EC64297A7DE0-8018
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000467553
Coding: 0021034800
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 3828D9CEA2DA0B078A8-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650658939
Address 28: HVAC, Rear (E265) Labels:* None
Part No SW: 7P6 907 049 P HW: 7P6 907 049 P
Component: Klima Fond H14 1305
Coding: 0000000000
ASAM Dataset: EV_AirCondiHeck 001007
ROD: EV_AirCondiHeck.rod
VCID: 4ACC9306CC368997ECC-801E
Address 34: Level Control (J197) Labels:. 7P0-907-553.clb
Part No SW: 7P0 907 553 K HW: 7P0 907 553 K
Component: PASM H01 1110
Revision: 00000000 Serial number: 00000120730186
Coding: 14210000
ASAM Dataset: EV_PASMConti 001004
ROD: EV_PASMConti.rod
VCID: 3FDAB2D287F43C3F4B2-806A
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000026768091
Coding: 00183B0000004201000001010101202020202121202020
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000126124617
Coding: 011D1720DE00451205080002
VCID: 44D0BD3EEE925FE7160-8010
Revision: 00002001 Serial number: 0174008358
Coding: 011E163A28B9509583300620010000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 0821212358
Subsystem 2 - Part No: 7P6 951 171
Component: DWA-Sensor 002 0204
Subsystem 4 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Serial number: WOO15653475
Coding: 191100
Subsystem 5 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Serial number: WOO1569877H
Coding: 191100
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000126247944
Coding: 011D1720DE00451205080000
VCID: 3B22C6C2936C201F67A-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1232500220
Coding: 01040100
ROD: EV_ParkbA7.rod
VCID: 3634D7F6A8CEFD77984-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 012A00000F000200
VCID: 7CA005DED662E7272E0-8028
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 130000
Part No SW: 4G1 035 053 E HW: 4G1 035 053
Component: Radio U Basic H41 0093
Revision: AB001007 Serial number: 227DZ0C7561625
Coding: 050005020100000003
VCID: 211E14AA11C06ACF5D6-8074
Part No SW: 7P6 035 664 B HW: 7P6 035 664
Component: H-BN-NA H44 0319
Revision: -------- Serial number: 445CV0C7530661
Coding: 010200050040C1EF41020B0E00000003F0000101
VCID: 372ADAF2AF44047F832-8062
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9L79003SP
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: CD-Database 1886
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0167
Revision: -------- Serial number: 0000126317014
Coding: 011C17200000251005080000
VCID: 3A2CC3C69C5619177CC-806E
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 F HW: 4H0 907 441 B
Component: SG Rueckfahrkamera 0120
Revision: 00H05000 Serial number: 525 PA8J220811
Coding: 0020001
Shop #: WSC 98765 666 38384
VCID: 3C20C5DE9A6227276E0-8068
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 A HW: 7P6 959 107
Component: HDSG-Modul H10 0620
Revision: 22010001 Serial number: 083201008
Coding: 0533314002
ASAM Dataset: EV_HeckkTouar 202137
ROD: EV_HeckkTouar.rod
VCID: 3D26C8DA8DF82E2F59E-8068
Component: TSG HR H09 0167
Revision: -------- Serial number: 0000126318054
End----------(Elapsed Time: 02:17, VBatt start/end: 12.2V/12.2V)-----------
