Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: P0346 CAMSHAFT POSITION SENSOR IMPLAUSIBLE SIGNAL INTERMITTENT (G163)
    Apr 2018
    Mexico
    Hello
    I own a Touareg 2012 V8 4.2L Fuel engine and I am having trouble with the camshaft position sensor.
    It has been replaced the two sensors (g163) and (g40) and the fault is still present.
    Also it has been inspected the sensor 3 plug cables and they are working as it should with the 6 volts.
    The fault code appears only when you start the engine, sometimes you can hear a knock sound 2 seconds when starting, the fault frequency can appear many times before you clear again the code.
    I am thinking that the knock sound is because of a loose cam adjuster or time change misaligned?
    Let me know your comments.
    Thank you.
  3. Likes Jack@European_Parts, rafa3092 liked this post
    Apr 2015
    South Africa
    Is the cambelt timing set correct with the special tool?
    Cambelt tensioner and hydraulic tensioner in good oreder?
  5. Likes Jack@European_Parts, rafa3092 liked this post
  6. #4
    May 2016
    Along with auto scan, what is the condition of the oil?
    Larimore
  7. Likes rafa3092 liked this post
  8. #5
    Apr 2018
    Mexico
    Good morning here is the Auto-Scan:
    Let me know your comments please.
    Monday,09,April,2018,23:55:24:38924
    VCDS Version: 18.2.0.3  HEX-V2 CB: 0.4411.4
    VIN: WVGAN87P2CD057736   License Plate:
    Mileage: 77664km-48258mi   Repair Order: 4673
    Chassis Type: 7P-VW52 (7P6)
    Scan: 01 02 03 05 06 08 09 10 15 16 17 19 28 34 36 42 46 52 53 55
              56 5F 62 6C 6D 72
    VIN: WVGAN87P2CD057736   Mileage: 77664km-48258miles
    Address 01: Engine (------CGNA)       Labels:* None
       Part No SW: 7P0 907 560     HW: 7P0 907 560
       Component: 4.2l V8/4V    H05 0003
       Revision: N9H05---
       Coding: 04210003290F0558
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM42FSI0117P0907560 001005
       ROD: EV_ECM42FSI0117P0907560.rod
       VCID: 72BC2BE68426A15774C-8026
    8626 - Camshaft Position Sensor (G163)
              P0346 00 [096] - Implausible Signal
                        Mileage: 77590 km
                        Date: 2018.04.07
                        Time: 14:41:32
                        Engine speed: 1066.00 /min
                        Normed load value: 50.6 %
                        Coolant temperature: 87 °C
                        Intake air temperature: 68 °C
                        Ambient air pressure: 750 mbar
                        Voltage terminal 30: 11.756 V
                        AFS dm: 77.2 kg/h
                        Median injection timing: 1.620 ms
                        Engine operating condition-Channel 87: Idling
                        Relative load value: 32.25 %
                        Tumg: 27.8 °C
                        Psr w: 547.66 hPa
                        Engine torque: 126.6 Nm
       Part No SW: 0C8 927 750 B    HW: 0C8 927 750 B
       Component: AL1000 AISIN  001 2074
       Coding: 001168
       Shop #: WSC 00017 993 999999
       ROD: EV_TCMAL991031_002.rod
       VCID: 2B02F682638CB09FF7A-807E
    Address 03: ABS Brakes (J104)       Labels:| 7P0-907-379.clb
       Part No SW: 7P0 907 379 J    HW: 7P0 907 379 A
       Component: MK25A         H36 0433
       Revision: --------    Serial number: 409320010EC815
       Coding: 5B6B53C32329255ADAFBCA96C4D8A440F700
       ASAM Dataset: EV_MK25AXT 008001
       ROD: EV_ESPMK25A00800.rod
       VCID: 44D0BD3EEE125FE7160-8010
       Part No SW: 4H0 907 064 BK    HW: 4H0 907 064 BK
       Coding: 0D860000000000000000
       VCID: 73B22EE2FBBCA85F7FA-8026
       Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Serial number: 2312000035125015
       Revision: AA000000    Serial number: 00000026770795
       Coding: 0018330000004201000001010101202020202121202020
       VCID: 3430EDFEBE32EF67A60-8060
       Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
       Component: Klima 4 Zonen H20 1305
       Coding: 4886207EC0
       VCID: 7EA40FD6C07EF537004-802A
       Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
       Component: BCM1 2.0      H12 0111
       Revision: 15012002    Serial number: 00000001279295
       Coding: 26001011D1345D010021000380005D0C431C470882010261800000020000
       Component: WWS    120214  31  0020
       Serial number: 90243400120224215304
       Coding: 004DBD
       Component: RLFS  H09 0011
       Serial number: 10351513
       Coding: 025223
       Component: E1 - LDS  H04 0031
       Serial number: 00000000000204120047
       Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0020
       Serial number: 0000001805569R11GY07
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA103085000001114693
       Coding: 010300
    Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
       Part No SW: 7P6 919 475 B    HW: 7N0 919 475
       Component: PARKHILFE 8K  H05 0021
       Revision: --------    Serial number: 28261208903238
       Coding: 308501
       ASAM Dataset: EV_VW526ParkiAssis2 001011
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 42DCBB26F40651D724C-8016
       Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
       Component: VW10Airbag001 H05 0025
       Revision: --------    Serial number: 003L0002JSXK
       Coding: 000000000000000000000000000000003031
       VCID: 41DEB42AF1004ACF3D6-8014
       Serial number: 3575LRB405F18NQQBGA9
       Serial number: 3585LRB405R17UE0E8I-
       Serial number: 3515RRB405117ABU609Y
       Serial number: 3525RRB405517ABU90ND
       Serial number: 3555NRB406118E5G7P5%
       Serial number: 3565NRB406118E5G2GUB
       Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
       Revision: --------    Serial number: 90815LD60002N
       Coding: 000C35
       VCID: 3828D9CEA25A0B078A8-806C
       Serial number: 0164366
       Part No SW: 7P6 920 881 S    HW: 7P6 920 881 S
       Component: Kombi         H14 0253
       Revision: 12240067    Serial number: 658300312592063
       Coding: 133732003A000008000004
       ASAM Dataset: EV_KombiUDSRBVW526 001013
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 4CC0951EC64297A7DE0-8018
       Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
       Component: GW-CAN-L-MOST H08 5202
       Revision: --------    Serial number: 00000000467553
       Coding: 0021034800
       ASAM Dataset: EV_GatewVW526UDS 001006
       ROD: EV_GatewUDS_VW52.rod
       VCID: 3828D9CEA2DA0B078A8-806C
       Serial number: 00000000005650658939
    Address 28: HVAC, Rear (E265)       Labels:* None
       Part No SW: 7P6 907 049 P    HW: 7P6 907 049 P
       Component: Klima Fond    H14 1305
       Coding: 0000000000
       ASAM Dataset: EV_AirCondiHeck 001007
       ROD: EV_AirCondiHeck.rod
       VCID: 4ACC9306CC368997ECC-801E
    Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
       Part No SW: 7P0 907 553 K    HW: 7P0 907 553 K
       Component: PASM          H01 1110
       Revision: 00000000    Serial number: 00000120730186
       Coding: 14210000
       ASAM Dataset: EV_PASMConti 001004
       ROD: EV_PASMConti.rod
       VCID: 3FDAB2D287F43C3F4B2-806A
       Revision: AA000000    Serial number: 00000026768091
       Coding: 00183B0000004201000001010101202020202121202020
       Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
       Component: TSG FA        H07 0166
       Revision: --------    Serial number: 0000126124617
       Coding: 011D1720DE00451205080002
       VCID: 44D0BD3EEE925FE7160-8010
       Revision: 00002001    Serial number: 0174008358
       Coding: 011E163A28B9509583300620010000000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
       Component: GTO BT  H19 0059
       Serial number: 0821212358
       Subsystem 2 - Part No: 7P6 951 171
       Component: DWA-Sensor  002 0204
       Subsystem 4 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
       Component: J245 PS30.055  H01 0008
       Serial number:     WOO15653475
       Coding: 191100
       Subsystem 5 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
       Component: J394 PS30.055  H01 0008
       Serial number:     WOO1569877H
       Coding: 191100
       Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
       Component: TSG BF        H07 0166
       Revision: --------    Serial number: 0000126247944
       Coding: 011D1720DE00451205080000
       VCID: 3B22C6C2936C201F67A-806E
       Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C1232500220
       Coding: 01040100
       ROD: EV_ParkbA7.rod
       VCID: 3634D7F6A8CEFD77984-8062
       Slave 3:
       Part No SW: 7P6 907 357     HW: 7L6 907 357 C
       Component: AFS-ECU       H04 0110
       Coding: 012A00000F000200
       VCID: 7CA005DED662E7272E0-8028
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Coding: 130000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Coding: 130000
       Part No SW: 4G1 035 053 E    HW: 4G1 035 053
       Component: Radio U Basic H41 0093
       Revision: AB001007    Serial number: 227DZ0C7561625
       Coding: 050005020100000003
       VCID: 211E14AA11C06ACF5D6-8074
       Part No SW: 7P6 035 664 B    HW: 7P6 035 664
       Component: H-BN-NA       H44 0319
       Revision: --------    Serial number: 445CV0C7530661
       Coding: 010200050040C1EF41020B0E00000003F0000101
       VCID: 372ADAF2AF44047F832-8062
       Subsystem 1 - Part No: 8R0 060 884 AC
       Component: NAR 2011  0503
       Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: DU8 SV Touch  H26 0045
       Serial number: VWZ8Z9L79003SP
       Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: CD-Database  1886
       Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
       Component: TSG HL        H09 0167
       Revision: --------    Serial number: 0000126317014
       Coding: 011C17200000251005080000
       VCID: 3A2CC3C69C5619177CC-806E
       Part No SW: 7P6 907 441 F    HW: 4H0 907 441 B
       Component: SG Rueckfahrkamera  0120
       Revision: 00H05000    Serial number: 525 PA8J220811
       Coding: 0020001
       Shop #: WSC 98765 666 38384
       VCID: 3C20C5DE9A6227276E0-8068
       Part No SW: 7P6 959 107 A    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0620
       Revision: 22010001    Serial number: 083201008
       Coding: 0533314002
       ASAM Dataset: EV_HeckkTouar 202137
       ROD: EV_HeckkTouar.rod
       VCID: 3D26C8DA8DF82E2F59E-8068
       Component: TSG HR        H09 0167
       Revision: --------    Serial number: 0000126318054
    End----------(Elapsed Time: 02:17, VBatt start/end: 12.2V/12.2V)-----------
  9. #6
    Apr 2018
    Mexico
    Thank you for your quick response and details.
    I have not yet adjusted the timing.
    If you mention that, it will be the next step to focus.
    The strange sound only appears once in a while you start the engine and not always.
  10. #7
    Apr 2018
    Mexico
    Thank you Larry
    The condition of the oil is good.
    It was changed 1,500 miles ago.
  11. #8
    Apr 2018
    Mexico
    The correct engine sound term is (rattling when starting).
  12. #9
    Prepare for mechanical tear down and check adjuster for oil feed & or damage if noise evident!
    Also check that wiring and ECU is in proper order with no water ingress.
  13. Likes rafa3092 liked this post
  14. #10
    Apr 2018
    Mexico
    Thank you Jack
    It will be dismantled the engine as the noise when starting is evident and check adjuster for damage or oil feed problem.
    I have already checked the ECU wiring and is fine, the water drain holes are clean and tested.
    Keep on touch.
