Results 1 to 6 of 6
Thread: Retro Fitting Keyless Start and Entry - Help
    Apr 2018
    Replaced my CCM module to get the 32 pin Blu connector, coded the new module based on my long coding from the old CCM module (old module had the settings just not the pins to plug into).
    Now my car will not start and on the dash it notes Please Remove Key when put into the slot. Navigation, Radio and Telephone functions all work fine. NO other warning lights appear on the dash. I think the keys need to be programed to the new CCM but not sure of the settings required or which module to go into to update, as used the long coding already.
    Vehicle is an Audi S5 2011.
    Tartu, Estonia
    Immobiliser needs to be matched at dealer.
    The world is my oyster...
    Apr 2018
    is there anyway to reset the immobilizer to work with the new CCM with the VAGCOM tool?
    I was just at the dealer not long ago to fix component protection after I did the 3g MMI to 3g+ mmi with google maps.
    Verified VCDS User DJAlix's Avatar
    Apr 2015
    London, United Kingdom
    Quote Originally Posted by djdracine View Post
    No, and on top of your IMMO you would have triggered CP again with CCM swap
    VAG Car Coding
    Adaptation | Coding | Diagnostic | Retrofit - London, United Kingdom
    Authorised VW Group Services Provider and Independent Repairer
    @vagcarcoding
    Apr 2018
    Quote Originally Posted by DJAlix View Post
    I would have thought that as well about the CP, but the radio, navigation, phone all work fine no issues, windows up down etc. I don't think CP was activated as the new CCM was a direct replacement/current version. But sounds like ether way I can stuck with another visit to the dealer if I want to finish this retrofit or I strap it and figure out how to just make the button work even if the key is in the slot as the new MMI panel has the button.
    Apr 2015
    Interesting, but if all is working bar the IMMO then cool. You have an S5 and you have come this far... why mess about? Just get it done properly via your dealer or an authorised 3rd party.
    VAG Car Coding
    @vagcarcoding
  7. Likes Uwe liked this post
