Audi A5 F5 (B9) Steering Wheel Stalk replacement coding
o33err
C?ID=317589
I am planning to change the Steering Wheel Stalks assembly in an Audi A5 2018 Sportback (B9). Does any one know what coding might be needed when a new Steering Wheel Stalk assembly is installed. The new cars don't come with separate Slip ring and stalks. Everything is a single unit. Is the G85 Steering Wheel sensor calibration routine the same in the B9 cars?
Moved to Retrofits.
DJAlix
London, United Kingdom
C?ID=238277
Can I ask why the change is needed / what you are trying to retrofit?
o33err
C?ID=317589
I am trying to retrofit a Heated Steering Wheel. It's no longer an available option in the UK on the 2018 A5 Sportbacks. It was available until last year and is still available in many countries.
I have the required new Steering Wheel. But need to buy a new Steering Wheel stalk assembly.
And since I need to install a new Steering Wheel stalk assembly for the Heated function, I thought I might as well get one that comes with the ALA button.
So when I install the new Steering wheel stalk assembly that will need to be coded to the car. So as a basic step I guess the Steering wheel sensor will need calibration. Is the procedure on the B9 cars the same?
WAUZZZ
EU
C?ID=333045
I Can help You code via online Acces to Fazit/S42
DJAlix
C?ID=238277
Good stuff, got to love a heated wheel! :)
Well I am not sure on the answers to your questions but if you are in or around London I can assist with any of the needed works if VCDS will not complete the job. I have online access should SVM or CP be needed.
o33err
C?ID=317589
Is someone prepared to tell me what I need to do if only VCDS is required? Also is the VIN number stored in the Steering Wheel Stalk assembly controller? I.e. Do I need to buy a new one or will a used one also work?
o33err
C?ID=317589
Having just seen the A Map and B Map of the Steering Wheel Stalk, I can see that the car's VIN number is indeed stored in it. However the part itself has no coding possible. So how does one go about coding a new Steering Wheel Stalk to the car when the part doesn't accept coding? Is there even a concept of a module in the car that stores the car's Vehicle Order? Or is the Vehicle Order only stored online at VW HQ? This confirms that I can't use a Used part unless there is a way to change the VIN on that part?
PetrolDave
Westbury, UK
C?ID=1423
Does the part have Adaptation channels? VW are moving over to using only adaptation and no coding, so worth checking I think.
o33err
C?ID=317589
The A Map shows some Adaptation channels. But the only one of note is the Steering Wheel Heater Temperature setting which is known. However the Block map shows a lot of values that the control has either learnt by itself, were pushed to it or were coded in. But if the part itself can't be coded how did those values get into the control module. That's my question.
o33err
C?ID=317589
Module 16 Auto Scan output
   Part No SW: 4M0 907 129 LQ    HW: 4M0 907 129 LQ
   Component: Lenks.Modul   H11 0009
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 0A4D5F7F1CBA61972CC-805F
It's A Map
;SW:4M0-907-129-LQ   HW:4M0-907-129-LQ ---  Steering wheel
;Component:Lenks.Modul   H11 0009, Coding:
;EV_SMLSKLOAU736,006008,EV_SMLSKLOAU736_006.rod
;Wednesday,11,April,2018,18:51:50:21132
;VCDS Version: Release 18.2.0 (x64)  Data version: 20180212 DS287.0
;VCID: 0A4D5F7F1CBA61972CC-805F
IDE00820-IDE80001-Activating and deactivating all development messages-Analysis 1,OFF ,1
IDE00820-IDE80002-Activating and deactivating all development messages-Analysis 2,OFF ,1
IDE00820-IDE80003-Activating and deactivating all development messages-Analysis 3,OFF ,1
IDE00820-IDE80004-Activating and deactivating all development messages-Analysis 4,OFF ,1
IDE00820-IDE80005-Activating and deactivating all development messages-Analysis 5,OFF ,1
IDE02744-Steering wheel heater,34 °C,1
Elapsed Time: 00:01
And B Map
;Wednesday,11,April,2018,18:51:45:21132
Group,Description,Actual
IDE00030,Status of actuator test,not active,
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00333,Driver assistance systems button,not activated,
IDE00333-MAS00243,Driver assistance systems button-Buttons for driver assistance systems: status,No malfunction detected,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No malfunction detected,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not activated,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,Engaged ON,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,not activated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Accelerate tap,not activated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,not activated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,not activated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,not activated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,Cruise control switch with ACC,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Delay tip level 2,not activated,
IDE00356-MAS04523,Cruise Control System (CCS): switch position-Accelerate tip level 2,not activated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,Initializing,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS10720,Cruise Control System (CCS): switch position-Speed limiter,not installed,
IDE02068-MAS00106,Time stamp-Year,2000, yr
IDE02068-MAS00107,Time stamp-Month,1, m
IDE02068-MAS00108,Time stamp-Day,22, d
IDE02068-MAS00109,Time stamp-Hours,14, H
IDE02068-MAS00110,Time stamp-Minutes,2, min
IDE02068-MAS00111,Time stamp-Seconds,16, s
IDE02068-MAS00711,Time stamp-Odometer reading,0, km
IDE02068-MAS02543,Time stamp-VIN determined during calibration,57 41 55 43 34 43 46 35 32 4A 41 30 36 33 37 36 32,
IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,not activated,
IDE02693-IDE08189,Turn signals and parking lights-Malfunction status flasher,No malfunction detected,
IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,Intermittent operation,
IDE02695-IDE11269,Front wiping: front washing-Front windshield wiper error status,No malfunction detected,
IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 3,
IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,not activated,
IDE02743-IDE05742,High Beam-Light switch position,not activated,
IDE02744-MAS02201,Steering wheel heater-Temperature,26, °C
IDE02744-MAS02324,Steering wheel heater-Voltage at sensor,0.00, V
IDE02744-MAS03746,Steering wheel heater-Current: actual value,0.00, A
IDE02744-MAS04457,Steering wheel heater-PWM pulse duty factor,0, %
IDE03504-MAS03692,Personalized settings-Key 1,not recognized,
IDE03504-MAS03693,Personalized settings-Key 2,detected,
IDE03504-MAS03694,Personalized settings-Key 3,not recognized,
IDE03504-MAS03695,Personalized settings-Key 4,not recognized,
IDE03504-MAS11282,Personalized settings-Status steering wheel heater key 1,OFF,
IDE03504-MAS11283,Personalized settings-Status steering wheel heater key 2,OFF,
IDE03504-MAS11284,Personalized settings-Status steering wheel heater key 3,OFF,
IDE03504-MAS11285,Personalized settings-Status steering wheel heater key 4,OFF,
IDE03680-IDE00019,Supply voltages-Voltage terminal 30,11842.97, mV
IDE03680-IDE00618,Supply voltages-Voltage supply 5V,4978.13, mV
IDE03680-MAS00125,Supply voltages-Cruise control system,0.00, mV
IDE05725-IDE01763,Terminal 58xs dimmer-Dimming,99, %
IDE05725-MAS03873,Terminal 58xs dimmer-Duty cycle,86, %
IDE08696-IDE02219,Steerg. wheel angle sens.-Steering wheel angle: sign,Positive,
IDE08696-MAS00037,Steerg. wheel angle sens.-Calibration status,calibrated,
IDE08696-MAS00370,Steerg. wheel angle sens.-Vehicle speed,in permissible range,
IDE08696-MAS02125,Steerg. wheel angle sens.-Steering wheel angle speed,0, °/s
IDE08696-MAS02126,Steerg. wheel angle sens.-Steering angle sensor: status,initialized,
IDE08696-MAS02128,Steerg. wheel angle sens.-Q bit: steering wheel angle,valid,
IDE08696-MAS02357,Steerg. wheel angle sens.-Vehicle identification,detected,
IDE08696-MAS02358,Steerg. wheel angle sens.-Calibration angle,outside permissible range,
IDE08696-MAS02406,Steerg. wheel angle sens.-Steering wheel angle: internal value,13.2, °
IDE08696-MAS02453,Steerg. wheel angle sens.-Steering wheel angle offset,0.0, °
IDE08696-MAS02832,Steerg. wheel angle sens.-Malfunction status,no error,
IDE08696-MAS02983,Steerg. wheel angle sens.-Steering wheel angle,13.2, °
IDE08696-MAS04474,Steerg. wheel angle sens.-Left front wheel speed,0.00, km/h
IDE08696-MAS04475,Steerg. wheel angle sens.-Right front wheel speed,0.00, km/h
IDE08696-MAS04476,Steerg. wheel angle sens.-Left rear wheel speed,0.00, km/h
IDE08696-MAS04477,Steerg. wheel angle sens.-Right rear wheel speed,0.00, km/h
IDE08696-MAS07727,Steerg. wheel angle sens.-Steering wheel angle: prefix internal value,Positive,
IDE08696-MAS07728,Steerg. wheel angle sens.-Steering wheel angle offset: prefix,Positive,
IDE08696-MAS07729,Steerg. wheel angle sens.-Steering wheel speed: prefix,Positive,
IDE09381-IDE02219,Steering angle sensor calibration status-Steering wheel angle: sign,Positive,
IDE09381-MAS00037,Steering angle sensor calibration status-Calibration status,calibrated,
IDE09381-MAS00370,Steering angle sensor calibration status-Vehicle speed,in permissible range,
IDE09381-MAS02126,Steering angle sensor calibration status-Steering angle sensor: status,initialized,
IDE09381-MAS02357,Steering angle sensor calibration status-Vehicle identification,detected,
IDE09381-MAS02358,Steering angle sensor calibration status-Calibration angle,outside permissible range,
IDE09381-MAS02406,Steering angle sensor calibration status-Steering wheel angle: internal value,13.2, °
IDE09381-MAS02832,Steering angle sensor calibration status-Malfunction status,no error,
IDE09381-MAS02983,Steering angle sensor calibration status-Steering wheel angle,13.2, °
IDE09381-MAS04121,Steering angle sensor calibration status-Voltage,in permissible range,
IDE09381-MAS07727,Steering angle sensor calibration status-Steering wheel angle: prefix internal value,Positive,
IDE09381-MAS08808,Steering angle sensor calibration status-Maximal allowed offset angle,0.0, °
IDE09381-MAS08809,Steering angle sensor calibration status-Maximal allowed offset angle: sign,Positive,
IDE09381-MAS08810,Steering angle sensor calibration status-Minimum allowed offset angle,0.0, °
IDE09381-MAS08811,Steering angle sensor calibration status-Minimum allowed offset angle: sign,Positive,
Elapsed Time: 00:05
I'm keen to understand how the car now "knows" it has a Heated Steering Wheel when previously it didn't have one. In older cars, this module 16 was codeable and that made sense. Now this module isn't codeable so clearly other modules will need to be coded to make the Heated Steering Wheel function work? So does the simple fact of installing and powering the new control module allow for the Heating function to work because the new module is pre-coded to listen to the BUS message that the new Heated Steering Wheel will put out? I know there is an additional power line to the Steering Wheel control depending on whether the car has a Heated Wheel or not.
o33err
C?ID=317589
What is also strange is I have seen references to Steering Wheel Heater in Modules 09 and 19 in a maps and b maps from cars without the Heated Steering Wheel. Yet the car with the Heated Wheel from the factory has absolutely none of those references!
partsaut
Poland
C?ID=513023
hi did you solved it
